LetsEncrypt + Wilcard + cloudflare
bagu
Post by bagu » 2019-09-27 14:21
Here is a small tutorial to get Letsencrypt wildcard easily with Posh-Acme and Cloudflare (thanks to palinka)
It auto-create Cloudflare DNS TXT.
  1. Launch powershell as an admin
  2. Remove restrictions with :
    set-executionpolicy unrestricted
  3. Install Posh-ACME with this command :
    Install-Module -Name Posh-ACME
  4. Set the server as a production server (to use a staging server, replace LE_PROD by LE_STAGE) :
    Set-PAServer LE_PROD
  5. Set cloudflare param with :
    $pArgs = @{ CFAuthEmail=cloudflareemail@email.com'; CFAuthKey='cloudflarepassword' }
  6. Ask a new certificate with :
    New-PACertificate '*.domain1oncloudflare.com','*.domain2oncloudflare.org' -AcceptTOS -Contact my@email.com -DnsPlugin Cloudflare -PluginArgs $pArgs -Verbose
  7. Follow screen instructions on powershell
  8. Then, search your certificate with :
    Get-PACertificate | fl
  9. Get cert.key as key and fullchain.cer as public certificate and insert them in Hmailserver
Then, you can make a planned task to renew the certificate every 85days with a script witch contain :
Submit-Renewal -PluginArgs @{CFAuthEmail='cloudflareemail@email.com'; CFAuthKey='cloudflarepassword'}
Don't forget to get the renewed certificate and copy them to the folder where hmailserver is set to get them.
And, don't forget to restart hmailserver
I will put here an example of script wich renew, copy and restart hmailserver later.
If you have any tips to improve or modify this tutorial, do not hesitate to propose your modifications.
Re: LetsEncrypt + Wilcard + cloudflare
Post by palinka » 2019-09-27 15:07
đź‘Ť
bagu
Post by bagu » 2020-05-20 00:39
Update !
The old method seem to don't work anymore.
Here is the new way to do this working :
First, follow this on cloudflare:
  • In the API Tokens section, click Create Token
  • Give it a name such as 'DNS edit all zones'
  • Add the following permissions:
    • Zone - DNS - Edit
    • Zone - Zone - Read
  • Set the following Zone Resources:
    • Include - All Zones
  • Click Continue to summary
  • Click Create Token
  • This is your token. Copy it for later because it can't be retrieved after leaving this page. You must generate a new value if you forget the old one.
From : https://github.com/rmbolger/Posh-ACME/b ... -Readme.md
Then, next steps are quite the same :
    If you wish to update Posh-Acme, type :
    Update-Module -Name Posh-ACME
    $pArgs = @{ CFTokenInsecure = 'Poshedit-token' }
    $pArgs.CFTokenReadAllInsecure = 'Poshread-token'
    Replace Poshedit-token and Poshread-token by your tokens
    New-PACertificate 'site1.fr','site2.fr','*.site1.fr','*.site2.fr' -AcceptTOS -Contact yourcloudflare@email.fr -DnsPlugin Cloudflare -PluginArgs $pArgs -Verbose
To refresh your certificate, you can use this batch (and laucnch it by scheduled task):
%localappdata%\Posh-ACME\acme-v02.api.letsencrypt.org\IdOfYourPosh-ACMEDirectory\!NameOfCertPath = get from Get-PACertificate | fl command
Replace PathToYourCertificates by the certificate location folder where HmailServer pick your certificate
<# : Begin batch (batch script is in commentary of powershell v2.0+)
@echo off
: Use local variables
setlocal
: Change current directory to script location - usefull for including .ps1 files
cd %~dp0
: Invoke this file as powershell expression
powershell -executionpolicy remotesigned -Command "Invoke-Expression $([System.IO.File]::ReadAllText('%~f0'))"
: Restore environment variables present before setlocal and restore current directory
endlocal
: End batch - go to end of file
set orgpath=%localappdata%\Posh-ACME\acme-v02.api.letsencrypt.org\IdOfYourPosh-ACMEDirectory\!NameOfCertPath
set destpath=C:\PathToYourCertificates\
net stop hmailserver
robocopy %orgpath% %destpath% *.pfx *.cer *.key /is
certutil -addstore -f "My" "%destpath%\chain.cer"
net start hmailserver
timeout 60
goto:eof
# here start your powershell script
Set-PSRepository -Name "PSGallery" -installationpolicy Trusted
# Update Posh-ACME
# Update certificates
Submit-Renewal -PluginArgs $pArgs -Verbose
Hope it can help.
If you have some idea, you're welcome.
The batch can be use to update certificate form apache.
I also use mailsend command to send a notification when the certificate is renewed.
You must set site1.fr AND *.site1.fr to avoid some weird problems on apache for example. ("server certificate does NOT include an ID which matches the server name")
b8engl
Post by b8engl » 2020-06-01 15:36
Thanks for pointing me to the right direction, but I think you can improve the tutorial!
Install-Module -Name Posh-ACME -Scope CurrentUser
iex (irm https://raw.githubusercontent.com/rmbolger/Posh-ACME/master/instdev.ps1)
New-PACertificate '*.one.pt','one.pt','*.two.pt','two.pt' -AcceptTOS -Contact yourPersonalEmail -DnsPlugin Cloudflare -PluginArgs @{CFAuthEmail='yourClouflareEmail'; CFAuthKey='yourGlobalAPIKey'} -Verbose
bagu
Post by bagu » 2020-06-01 15:47
First, thanks for your contribution.
Then,
Can you explain why you add
-Scope CurrentUser
? For which benefit ?
Also, why using
while
seem easier ?
-> Yes ! Mistake in my post, but i can't edit anymore :cry:
As i say just before, the method with CFAuthEmail/CFAuthKey seem to don't work everytime.
I used it before it stop to work.
b8engl
Post by b8engl » 2020-06-01 16:11
I don't think that you will pull an update if you download the latest version, so that's why I included the correct method to use the development instead the latest stable release.
Plus, explaining to use production server as Set-PAServer LE_STAGE is wronge! The correct method is Set-PAServer LE_PROD
Additional, the Set-PAServer LE_PROD has a limit for 50 certificates for week (letsencrypt limit rate), so that's why is recomende to use Set-PAServer LE_STAGE for testing purpose.
Your wellcome!
Post by jimimaseye » 2020-06-01 21:15
bagu wrote: ↑
2020-06-01 15:47
I have amended the first post to reflect this.
Mod.
