Post new topic Reply to topic  [ 16 posts ]
Author Message
 Post subject: hMailServer 3.0.0 - Alpha
PostPosted: 2004-03-21 19:31
An alpha of hMailServer 3.0.0 is now availible for download. It includes support for IMAP, specifying SMTP relayer, changing welcome messages, enhanced logging, Ilohamail and more.
Known problems in the alpha:
- Not possible to use international characters in IMAP folder names
- IMAP search function does not work properly.
Top
 Profile
 Post subject:
PostPosted: 2004-03-29 00:53
Alpha 3 is now availible.
Includes a number of fixes:
- A number of IMAP fixes.
- Improved tcp/ip-performance on sending large emails.
- IP range bugs fixed.
Still some known problems:
- IMAP still not RFC compliant. Works OK when using OE, Outlook 2003, IlohaMail.
- In Thunderbird it's not always possible to download attachments when using IMAP. Tested with another mail server and got the exact same error. (so it might be a bug in thunderbird)
- Crashes once in a while.
Top
 Profile
 Post subject:
PostPosted: 2004-03-30 00:41
Would you mind posting the latest binaries in a zip file?
Top
 Profile
 Post subject:
PostPosted: 2004-03-31 21:34
I'm really interested in hmailserver. I think you guys are doing a great service to those of us looking for a free e-mail server solution. Anyways, I'd like to set up squirrel mail but every time I try to log in with Squirrel mail it loads pretty slowly, eventually opens up but in the left hand panel It tells me it loses connection. I think go check the hmail server and I see it stopped.
I see you've done IMAP testing with OE, Outlook, etc. Can we get some more work done to get it to work with Squirrel Mail? =) Thanks again.
oh, and I am using alpha 3 of v3.0 hmailserver.
Top
 Profile
 Post subject:
PostPosted: 2004-04-05 07:11
he says he will work on Squirrel mail and I cant wait I am so Excited!
Top
 Profile
 Post subject:
PostPosted: 2004-04-06 01:24
I'm getting closer to having a version working with Squirrelmail. The squirrelmail part works perfect, but I'm having some general problem with memory beeing overwritten which results in a crash. Will look at it tomorrow..
Latest version of squirrelmail will work really nice with next hmailserver alpha. (Folders will be automatically created). Squirrelmail is actually much nicer than iLohamail.. but it's also much bigger :-(
Top
 Profile
 Post subject:
PostPosted: 2004-04-06 01:37
I cant wait! Hurry up!!! oh lol and I have so much space I am not worried. I have noticed that the hmailserver crashes when I run Squirrel mail!
Top
 Profile
 Post subject:
PostPosted: 2004-04-08 20:01
Yup - known problem. Fixed this a couple of days ago and will put up a new version soon..
Top
 Profile
 Post subject:
PostPosted: 2004-04-10 00:08
Alpha 4 is now availible for download.
- Quite a lot of fixes to improve stability
- "Support" for Squirrelmail
Top
 Profile
 Post subject:
PostPosted: 2004-04-12 17:44
Well does it come with squirrell mail or do we have to configure it?
There should be a tutorial! lol
Top
 Profile
 Post subject:
PostPosted: 2004-04-12 19:47
No, it does not come with squirrelmail.
Don't think you have to configure squirrelmail at all. Just to put it in your 'web-directory' and use it.
Top
 Profile
 Post subject:
PostPosted: 2004-04-12 19:58
You do have to run conf.pl.
Top
 Profile
 Post subject:
PostPosted: 2004-04-13 18:45
Update:
Just to put it in your 'web-directory', run conf.pl and then use it ;)
Top
 Profile
 Post subject:
PostPosted: 2004-04-13 23:27
well OOOOOH!
Top
 Profile
 Post subject:
PostPosted: 2004-04-15 22:29
well if you actually read the instructions on how to install squil, you can do it without perl. most people know jack about perl but yes, there's a few things to do before you can set up..
here's the instructions for all the newbs like me.
http://www.squirrelmail.org/wiki/en_US/ ... uirrelMail
"Windows administrators: You are encouraged to use SquirrelMail, but many of the PHP files were unintentionally written for UNIX or Linux distributions. For example, you must have Perl installed if you want to use the installation script (conf.pl). But even if you don't install Perl, you can manually edit your configuration file located in C:\YourWebDir\config\config.php. And for many administrators, this will work fine! Also, if you install Plugins, you might need certain UNIX or GNU utilities."
I would also suggest reading the requirements section for windows users.
http://www.squirrelmail.org/wiki/en_US/ ... quirements
Top
 Profile
 Post subject:
PostPosted: 2004-04-15 23:16
I knew that. In fact that is what I do...
Top
 Profile
Who is online
Search for:
