Post new topic Reply to topic  [ 11 posts ]
Author Message
 Post subject: database server address
PostPosted: 2012-08-03 02:10
Trying to set up the datbase, im not familiar with these type of things,what is my data server address,
Top
 Profile
 Post subject: Re: database server address
PostPosted: 2012-08-03 02:31
Please see technical knowledge section here >> http://www.hmailserver.com/documentatio ... quirements
If you don't have the required technical knowledge, you should find someone local to you who does.
Which type of database are you using?
_________________
Documentation
Top
 Profile
PostPosted: 2012-08-03 02:46
MySQL
Top
 Profile
PostPosted: 2012-08-03 04:08
and is that installed on the same machine, or is it installed elsewhere on your network?
_________________
Documentation
Top
 Profile
PostPosted: 2012-08-03 04:25
so I need a hosting plan that includes a MySQL database?
Top
 Profile
PostPosted: 2012-08-03 06:37
if you want to use a MySQL database on a hosted server (where I'm assuming the hMailserver will also be installed) then yes, your hosting plan should include MySQL.
Does your hosting plan include any databases?
Does it even run windows operating system? (Most don't)
_________________
Documentation
Top
 Profile
PostPosted: 2012-08-03 12:37
I dont even have a hosting plan right now, I thought hmailserver was independent. and there was no need for one. I can get sign up for a hosting plan, what is the best hosting plan for hmailserver?
Top
 Profile
PostPosted: 2012-08-04 03:30
No you don't need a hosting plan for hmailserver.
You mentioned the hosting plan, not me.
Where are YOU intending to install hmailserver?
Why did YOU say that you were going to use MySQL as the database?
_________________
Documentation
Top
 Profile
PostPosted: 2012-08-04 13:21
I want to install the server on our pc
when I try to setup the database it gives me the MySQL option
Top
 Profile
PostPosted: 2012-08-05 01:21
by the way, my isp only allows dynamic ip. and blocks port 25.
Anyway around this
Top
 Profile
PostPosted: 2012-08-05 12:52
Not for free no.
You will need to purchase a server hosting plan that allows bulk email to be sent.
_________________
Top
 Profile
Who is online
Search for:
