Block IPs
eliassal
Re: Block IPs
Post by eliassal » 2020-03-04 21:12
max IPs added in a single day = 8 x 1.2 = 9.6 rounded to nearest 10 = 10
max IPs blocked in a single day = 11 x 1.2 = 13.2 rounded to nearest 10 = 10
max total blocks in a single day = ~ 5900 x 1.2 = 7080 rounded to nearest 1000 = 7000
another question, what is the reason you chose to divide by 1.2 ? any scientific or programming constraints
eliassal
Re: Block IPs
Post by eliassal » 2020-03-04 21:44
Because there are two for each dial: today's data and max data
the other 2 diq...don't the issue of group by
Re: Block IPs
Post by palinka » 2020-03-04 22:13
eliassal wrote:
2020-03-04 21:12
Nothing scientific. I wanted the red/yellow line to be 100%. I could have assigned the query to be 100% and then multiplied that by 1.2 to get to 120% (red line max). Its just the way I chose to do it. I wanted red to be record breaking, so its obvious.
eliassal
Re: Block IPs
Post by eliassal » 2020-03-05 19:45
I have port 25 and 465 open and DisableAUTHList=25. My users use 465 (SSL) to send and I receive (external-to-local) on port 25.
I am trying to follow your recommendation and try to make all internal users use port 465 or 587 with a Certificate.
The account I use to configure outlook works fine and can send emails through port 587 and receive at port 995 m I remember at first connection i was asked if i accept the certificate and i did.
The other users, one of them is a user I configured for sqlserver to send and receive. With port 25 and 110, it works fine but when I configure sending to port 465 or 487, TLS/SSL shakehands always fails. I eveny took the .crt file certificate and installed it on the sql but no way. Hre is the error I am getting
"TCPIP" 5640 "2020-03-05 18:18:30.650" "TCP - mysqlip connected to my hMailServerIP:587."
"DEBUG" 5640 "2020-03-05 18:18:30.665" "Executing event OnClientConnect"
"DEBUG" 5640 "2020-03-05 18:18:30.681" "Event completed"
"DEBUG" 5640 "2020-03-05 18:18:30.681" "TCP connection started for session 250"
"DEBUG" 5640 "2020-03-05 18:18:30.681" "Performing SSL/TLS handshake for session 250. Verify certificate: False"
"TCPIP" 2664 "2020-03-05 18:18:30.681" "TCPConnection - TLS/SSL handshake failed. Session Id: 250, Remote IP: mysqlip, Error code: 335544539, Message: short read"
"DEBUG" 2664 "2020-03-05 18:18:30.681" "Ending session 250"
or
"TCPIP" 5640 "2020-03-05 18:24:41.893" "TCP - mysqlip connected to hMailServerIP:465."
"DEBUG" 5640 "2020-03-05 18:24:41.898" "Executing event OnClientConnect"
"DEBUG" 5640 "2020-03-05 18:24:41.898" "Event completed"
"DEBUG" 5640 "2020-03-05 18:24:41.898" "TCP connection started for session 270"
"DEBUG" 5640 "2020-03-05 18:24:41.914" "Performing SSL/TLS handshake for session 270. Verify certificate: False"
"TCPIP" 5640 "2020-03-05 18:25:01.732" "TCPConnection - TLS/SSL handshake failed. Session Id: 268, Remote IP: mysqlip, Error code: 335544539, Message: short read"
"DEBUG" 5640 "2020-03-05 18:25:01.732" "Ending session 268"
"TCPIP" 2664 "2020-03-05 18:25:25.081" "TCPConnection - TLS/SSL handshake failed. Session Id: 270, Remote IP: mysqlip.69, Error code: 335544539, Message: short read"
"DEBUG" 2664 "2020-03-05 18:25:25.081" "Ending session 270"
Re: Block IPs
Post by palinka » 2020-03-05 20:34
Use port 587 with starttls set to OPTIONAL.
Is the sql server in your LAN or outside? If inside, encryption is not really necessary unless you put your unsecured open wifi on the same subnet, which you surely didn't, did you? :mrgreen:
eliassal
Re: Block IPs
Post by eliassal » 2020-03-05 21:13
I really have no idea what starttls is :lol: , are there steps to follow as TLS and creating certificates
My wifi is secure and have a guest wifi also secured with key and isolated from my internal network, but the other wifi is on the same subnet as sql
Sometimes when I am in another country, I need to use the email to send and receive, that I why I need to use certificates
Re: Block IPs
Post by palinka » 2020-03-05 22:56
eliassal wrote:
2020-03-05 21:13
Look in the tutorials section.
Also, run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914
I think the problem is on your client's end. Best way to deal with that is to not attempt to connect with tls.
eliassal
Re: Block IPs
Post by eliassal » 2020-03-05 23:29
Here you go the config settings
2020-03-05   Hmailserver: 5.6.6-B2383
DOMAINS
   "Domain1.com" - prxxxxxxxxxxx.saxxx.net        Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - saxxx.hd.frxx.fr               Enabled: True
                                                Private key: c:\program files (x86)\hmailserver\data\Domain2.com\dkim.Domain2.com.pem
                                                Selector:    dkim
GLOBAL RULES
  1, mboconnect2019@hotmail.com   Criteria:  Use AND
             From                      Equals          mboconnect2019@hotmail.com
                                  -----Actions-----
             Delete
  2, evil9dead@hotmail.com        Criteria:  Use AND
             From                      Equals          evil9dead@hotmail.com
                                  -----Actions-----
             Delete
  3, spameri@tiscali.it           Criteria:  Use AND
             From                      Equals          spameri@tiscali.it
                                  -----Actions-----
             Delete
IP RANGES
IP: 127.0.0.1 - 127.0.0.1     Priority: 15     Name: myserver.mynetwork.net
     External To External - False
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      6
                              Minutes Before Reset:            5  (0.08 hours, 0.00 days)
                              Minutes to Autoban:              5  (0.08 hours, 0.00 days)
INCOMING RELAYS
                    xxx.xxx.x.14     -   xxx.xxx.x.14
MIRRORING         Disabled
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Add X-HmailServer-Spam:     True    Check HELO host:   False        Hostname:       127.0.0.1
  Add X-HmailServer-Subject:  True    Verify DKIM:        True - 5    Use SA score: False -   5
              Subject Text: "[SPAM]"
DNSBL ENTRIES:
                    bl.spamcop.net      Score: 3     Result: 127.0.0.4
            b.barracudacentral.org      Score: 0     Result: 127.0.0.2
SURBL ENTRIES:
   No 'enabled' entries
GREYLISTING:
  Greylisting:   True       Defer mins: 30       Days Unused: 1      Days Used: 36
                            Bypass SPF: True     Bypass A/MX: False
Greylist WHITELIST ENTRIES:
   No entries
Greylist DOMAINS enabled:
  !! No active domains enabled - GREYLISTING INEFFECTIVE !!
WHITELISTING
   No entries
ANTIVIRUS
GENERAL:
  When found - Delete email. Notify Sender: False,  Notify Receiver: True
  Max Message Size: 0
     CLAMWIN:   False
     CUSTOMAV:  False
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
SSL CERTIFICATES
   FromFedoraFeb142020
       Certificate: C:\Program Files (x86)\hMailServer\Certificates\Domain2.com.crt
       Private key: C:\Program Files (x86)\hMailServer\Certificates\Domain2.com.key
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               xxx.xxx.x.34    / 25    / SMTP   -   None
               xxx.xxx.x.34    / 110   / POP3   -   None
               xxx.xxx.x.34    / 143   / IMAP   -   None
               xxx.xxx.x.34    / 465   / SMTP   -   SSL/TLS             Cert: FromFedoraFeb142020
               xxx.xxx.x.34    / 587   / SMTP   -   SSL/TLS             Cert: FromFedoraFeb142020
               xxx.xxx.x.34    / 995   / POP3   -   SSL/TLS             Cert: FromFedoraFeb142020
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-03-05.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-03-05.log - !! ERRORS PRESENT !!
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL
Backup directory E:\hMailServerBackup is writable.
HMAILSERVER.INI
Database folder:
Type=              MSSQL
Username=
Port=              0
Server=            SQL2K12\SC2K12
Internal=          0
eliassal
Re: Block IPs
Post by eliassal » 2020-03-05 23:46
I did but outlook client was not able to connect, switched back to ssl/tls
Re: Block IPs
Post by jimimaseye » 2020-03-06 00:24
What's in this:
Re: Block IPs
Post by mattg » 2020-03-06 01:27
eliassal wrote:
2020-03-05 23:46
I'd use StartTLS is REQUIRED for port 587
Outlook may call starttls something different - depending on version they may call it TLS, with SSL being a separate option.
Re: Block IPs
Post by palinka » 2020-03-06 01:34
2020-03-06 01:27
eliassal wrote:
2020-03-05 23:46
I have mine set to optional with "require ssl/tls for authentication" on the internet IP range. Its a happy medium.
Re: Block IPs
Post by mattg » 2020-03-06 01:42
The ONLY StartTLS optional that I have is port 25
All of my other StartTLS ports are StartTLS required, and all but a specific LAN IP address are set to 'Require SSL/TLS for AUTH'.
I also only allow TLSv1.2 and TLSv1.3 connections from a strict cipher list
I still get more than a dozen IPs a day that try and logon from international IP addresses on non-SMTP ports, ie trying to guess usernames and passwords via IMAP or POP ports
Re: Block IPs
Post by palinka » 2020-03-06 01:58
2020-03-06 01:42
Then you force clients on localhost to encrypt?
My understanding is that 'Require SSL/TLS for AUTH' forces connection upgrade on AUTH, so it offers the same "protection" as TLS/SSL required. Is that not correct? I prefer to leave localhost without encryption because it unnecessarily complicates things.
Re: Block IPs
Post by mattg » 2020-03-06 04:19
2020-03-06 01:58
Yes I would if I had mail clients on the machine with hMailserver, but I don't now that I moved my webmail to my Ubuntu server
hMailserver is not installed on my daily use machine
Re: Block IPs
Post by palinka » 2020-03-06 04:22
2020-03-06 04:19
2020-03-06 01:58
Ah.. I was thinking more along the lines of scripting.
Re: Block IPs
Post by mattg » 2020-03-06 06:17
My scripts don't use SMTP to AUTH
My hMailserver scripts directly run from either eventhandlers.vbs or as standalone vbs files called via scheduled tasks
Even when I send (from other servers) automated scripted messages via CDO or Mail.NET I send via SSL(or StartTLS) connections, whether I authenticate or not
What scripts do you do that you need to AUTH via SMTP (or IMAP or POP3)??
eliassal
Re: Block IPs
Post by eliassal » 2020-03-06 12:47
I think I have discovered a bug. This morning, after all scripts run, all gauges displayed nothing as follows (which caught my attention).
I chekced the script in chrome, I see
['Bans', 0]]);var options = { width: 100, height: 100, min: 0, max: 10.0, redFrom: 8.3333333333333, redTo: 10.0, yellowFrom: 6.25, yellowTo: 8.3333333333333, 		minorTicks: 10
I banned explicitly an IP, refreshed index page, hop Gauge displayed as before with 1 IP banned. So it seems that if 0 banned IP gauge does not display anything, in chrome I had
['Bans', 1]]);var options = { width: 100, height: 100, min: 0, max: 10.0, redFrom: 8.3333333333333, redTo: 10.0, yellowFrom: 6.25, yellowTo: 8.3333333333333, 		minorTicks: 10
The only difference is ['Bans', 0]]) and ['Bans', 1]])
Please note theat the other 2 gauges are behaving in the same way, I will check later
Re: Block IPs
Post by palinka » 2020-03-06 13:17
2020-03-06 06:17
I have a couple of powershell scripts that use the built in smtp client. But I've been playing with com objects in powershell lately and I could get around auth, I suppose.
Also webmail is on localhost.
I use SMS for most automated notifications.
Still, security-wise, is there a difference between the two scenarios? TLS mandatory vs optional with require TLS for auth?
Re: Block IPs
Post by palinka » 2020-03-06 13:23
eliassal wrote:
2020-03-06 12:47
I never had 0 values (while I was awake to look). It turns over at midnight and there's always been a positive value when i look at it in the morning. I'll test it later with 0 hard-coded in and see what happens.
But I think if it's a bug, it's on Google's end - the code is producing the correct data.
Re: Block IPs
Post by palinka » 2020-03-06 14:21
Hard coding 0 results in successful rendering.
Edit - also editing the query to search for nonexistent data produces a "0" because the query is to COUNT, which always results in an integer. So this also renders the dial appropriately with a 0.
eliassal
Re: Block IPs
Post by eliassal » 2020-03-06 14:56
For the time being, it is Database Mail service in sql server, he only sends so no POP no IMAP. It is on a 2nd Vlan not the vlan where SQL server is
I have also powershell scripts, other services email like jenkins server....once I succed I need to modify all
eliassal
Re: Block IPs
Post by eliassal » 2020-03-06 14:59
Well I don't know, mu indicator is that once there was 1 IP banned, gauge showed somehting
I can't say why neither
Re: Block IPs
Post by palinka » 2020-03-06 15:54
eliassal wrote:
2020-03-06 12:47
Looks good. Here's what I get in view-source. Looks the same.
['Bans', 0]]);var options = { width: 100, height: 100, min: 0, max: 330, redFrom: 275, redTo: 330, yellowFrom: 206.25, yellowTo: 275, minorTicks: 10 };
eliassal
Re: Block IPs
Post by eliassal » 2020-03-06 18:02
OK, tell me how did you hard code so I will test again and see if this will happen again? in php pages?
Re: Block IPs
Post by palinka » 2020-03-06 18:49
eliassal wrote:
2020-03-06 18:02
Yes. In dialtodayshits.php:
	echo "['Bans', ".$hits."]";
to:
	echo "['Bans', 0]";
Or you could change the query for today to produce a nonexistent result:
	//Get current (today's) bans
	$sql = $pdo->prepare("
		SELECT
			COUNT(DISTINCT(ipaddress)) AS hits
		FROM hm_fwban
		WHERE ".DBCastDateTimeFieldAsDate('timestamp')." LIKE ".DBCastDateTimeFieldAsDate(DBGetCurrentDateTime())." AND country = 'foofoo'
