Block IPs
eliassal
Re: Block IPs
Post by eliassal » 2020-02-16 15:36
My first tries were with PHP 7.0
eliassal
Re: Block IPs
Post by eliassal » 2020-02-16 15:38
I clicked on the link, I got
Access forbidden!
You don't have permission to access the requested directory. There is either no index document or the directory is read-protected.
If you think this is a server error, please contact the webmaster.
Error 403
hmsfirewallbandemo.ddns.net
Apache/2.4.26 (Win32) OpenSSL/1.0.2l PHP/5.6.31
eliassal
Re: Block IPs
Post by eliassal » 2020-02-16 15:40
getting "host cannot be resolved" in the browser.
Is this hosted on a synology NAS?
eliassal
Re: Block IPs
Post by eliassal » 2020-02-16 15:42
Also can you please provide a link or info on learning google charts that you are using?
Re: Block IPs
Post by palinka » 2020-02-16 15:43
Oops. I accidentally copied .htaccess there. I just deleted it but give it a minute - I just restarted for windows update.
Re: Block IPs
Post by palinka » 2020-02-16 15:46
eliassal wrote:
2020-02-16 15:42
Just go to the Google charts pages. They have examples. That's how I worked it out.
Honestly, I think it would be a lot easier to just fix php/SQL.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-16 16:00
I tried both versions 5.3 and 7, it is not going through
eliassal
Re: Block IPs
Post by eliassal » 2020-02-16 20:57
Yes the demo is working fine I should say that it is very nice and useful, we see good ideas behind the desihgner
:wink:
I activated debug on the php.ini, now I can this error
Parse error: syntax error, unexpected '$pdo' (T_VARIABLE), expecting ',' or ';' in C:\inetpub\wwwroot\PHPBanAdmin\functions.php on line 7
which is
$pdo = new PDO("sqlsrv:Server=".$Database['host'].",".$Database['port'].";Database=".$Database['dbname'], $Database['username'], $Database['password']);
As I told you yesterday, the app is not reaching sql when I triggered monitoring of sql server profiler
Re: Block IPs
Post by palinka » 2020-02-16 21:20
eliassal wrote:
2020-02-16 20:57
:wink:
which is
Google around for a new connection string and hard code it into functions.php. For example: https://stackoverflow.com/questions/311 ... 7#31132520
$pdo = new PDO("sqlsrv:Server=SQL\SC2K12;Database=hmailserver;", myuserrun, mypassword);
-or-
$pdo = new PDO("sqlsrv:Server=".$Database['host'].";".$Database['dbname'].";", $Database['username'], $Database['password']);
If you look around there are other variations. This keeps pointing back to connection, so I would definitely have a closer look at the connection string. There are plenty of variations you could use.
And also use PHP 7 with the correct SQL driver.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 00:32
Wooooooow, I discovered the issue, my bad
On MS site, I did not notice that there is versions when having php7.dll or php7ts.dll (I really don't know what or from where this php7ts.dll come fom)
64-bit php_sqlsrv_72_nts.dll
64-bit php_pdo_sqlsrv_72_nts.dll 7.2 no Use with 64-bit php7.dll
64-bit php_sqlsrv_72_ts.dll
64-bit php_pdo_sqlsrv_72_ts.dll 7.2 yes 64-bit php7ts.dll
I changed the php.ini file to use
extension="C:\Program Files\PHP\v7.2\ext\php_sqlsrv_72_nts_x64.dll"
extension="C:\Program Files\PHP\v7.2\ext\php_pdo_sqlsrv_72_nts_x64.dll"
and the site displayed like a charm, thanks for your help. I will walk through all functionalities and give you back my feedback
Re: Block IPs
Post by palinka » 2020-02-17 00:54
OK cool.
Today I uploaded a "major" change to github. I suggest starting from scratch since there is a new database table plus one altered table. There's no point in trying to use the upgrade scripts when you have very little data and you never really got started with it anyway.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 01:51
Palinka,
Clicking on "IDS" link. I find 2 records 1 with 8 hits.
How can I ban the one with 8 hits from web site? Or it should be through Powershell script?, can you give me an idea on the workflow for each function (link)
Should the site runs on the server where hMailServer is running in order the site works correctly or can we run it from anywhere.
The version working in my environment is on one of my desktops not on the hMailServer
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 01:56
search was returning nothing, I fixed it.
in sql server "Like operator" does not work with columns of type Datetime, it should be converted to a string, I replaced the line
WHERE timestamp LIKE '%{$search}%'
by
WHERE (convert(nvarchar(50), timestamp, 126) LIKE '%{$search}%'
or
CONVERT(VARCHAR, DateTimeColumn , 120)
the page started to return results
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 02:05
Also as a general note, Stored procedures are more efficient and easy to maintain than T-sql statements distributed in all pages, much more pefrormant andm make code more easy to read
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 02:06
I will stop now, go to bed, time to sleep, my wife shouting :D
I will continue tomorrow. Tell me where are based, in Europe or US?
Re: Block IPs
Post by palinka » 2020-02-17 02:08
eliassal wrote:
2020-02-17 01:56
by
or
It works in mysql. Funny that lcamilo, the guy that added the mssql queries did not bring this up. Could this be an issue specific to a particular version of SQL server?
What you should do is create a function for it and pass it on to me so I can incorporate it into the project properly.
Re: Block IPs
eliassal wrote:
2020-02-17 02:06
US and A....
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 02:17
ok, i will write the function tomorow
I have tested like operator with versions 2005, 2008, 2008R2, 2012, 2014 and 2016. I will check if it is the same thing for version 2017 and 2019
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 02:18
Do you mean a php function or T-SQL function?
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 02:20
You did not answer this question
Should the site runs on the server where hMailServer is running in order the site works correctly or can we run it from anywhere?
Re: Block IPs
Post by palinka » 2020-02-17 02:43
eliassal wrote:
2020-02-17 01:51
Palinka,
Did you set up a scheduled task to run hmsFirewallBan.ps1 every 5 minutes? If you did not, you need to. If you did, then the last 6 hits came within the last 5 minute interval.
You can't. It's done via the powershell script on a 5 minute interval.
Before today, it could be anywhere. However, today I added a script that creates several data cache files for use by charts and other things (to speed things up). The www folder needs to be writable and accessible to the powershell script, so it needs to be on the same machine as the powershell components.
Everything should be on the same machine as hmailserver. After all, the firewall doing the work is there. :D
I think netsh works on remote hosts, so theoretically you could put everything on a different machine or multiple machines. But writing the data cache files would require smb or ftp or some other method to get the file moved. Also you'd have to modify the script, of course.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 13:46
Palinka, I visited the github, in hmsFirewallBan.ps1, no table added or modified?
hmsFirewallBanDBSetup.ps1 Fixed all other queries 6 days ago
which is the I used to create the DB objects.
I have alreay ptr field in hm_fwban table I don't need the
I checked the downloaded zip file I downloade last week , I have already the 2 files
hmsRetroAddPTR.ps1 & hmsRetroAddRuleName.ps1
but did not apply them yet
I compared my EventHandlers.vbs in my download which I used in hmailserver and the one on github, they have exactly the same number of code lines.
So should't I only apply
BUT commenting the line?
$Query = "ALTER TABLE hm_fwban ADD ptr VARCHAR(192) NULL;"
Re: Block IPs
Post by palinka » 2020-02-17 14:06
Just start from scratch. Trust me.
Db creation is in hmsFirewallBanDBSetup.ps1.
I'll try to update the installation instruction today.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 14:24
Palinka, it is the same exact code that I have for creating the tables, only 3 tables and 1 function, here is the copy from Githyub, no new table and ptr field is already there, github says the file was updated 6 days ago
If ($DatabaseType -eq "MSSQL") {
	#	Create hm_fwban table if it doesn't exist
	$Query = "
		IF NOT EXISTS (SELECT 1 FROM SYSOBJECTS WHERE NAME = 'hm_fwban')
		BEGIN
			CREATE TABLE hm_fwban (
				ID int IDENTITY(1,1) NOT NULL PRIMARY KEY,
				ipaddress varchar NOT NULL,
				timestamp datetime NOT NULL,
				ban_reason varchar(192) DEFAULT NULL,
				country varchar(192) DEFAULT NULL,
				flag int DEFAULT NULL,
				helo varchar(192) DEFAULT NULL,
				ptr varchar(192) DEFAULT NULL,
				rulename varchar(192) DEFAULT NULL
		END;
	RunSQLQuery $Query
	#	Create hm_fwban_rh table if it doesn't exist
	$Query = "
		IF NOT EXISTS (SELECT 1 FROM SYSOBJECTS WHERE NAME = 'hm_fwban_rh')
		BEGIN
			CREATE TABLE hm_fwban_rh (
				id int IDENTITY(1,1) NOT NULL PRIMARY KEY,
				timestamp datetime NOT NULL DEFAULT '0000-00-00 00:00:00',
				ipaddress varchar(15) NOT NULL
		END;
	RunSQLQuery $Query
	#	Create hm_ids table if it doesn't exist
	$Query = "
		IF NOT EXISTS (SELECT 1 FROM SYSOBJECTS WHERE NAME = 'hm_ids')
		BEGIN
			CREATE TABLE hm_ids (
				ipaddress varchar(15) NOT NULL PRIMARY KEY,
				hits int NOT NULL,
				country varchar(64) DEFAULT NULL,
				helo varchar(128) DEFAULT NULL
		END;
	RunSQLQuery $Query
	#Create MSSQL Function equivalent to INET_ATON() from MySQL
	#first drop if exists
	$Query = "
	IF EXISTS (SELECT 1 FROM SYSOBJECTS WHERE NAME = 'ipStringToInt')
		DROP FUNCTION dbo.ipStringToInt
	RunSQLQuery $Query
	#then create
	$Query = "
		CREATE FUNCTION dbo.ipStringToInt
			@ip CHAR(15)
		RETURNS INT
		AS
		BEGIN
			DECLARE @rv INT,
				@o1 INT,
				@o2 INT,
				@o3 INT,
				@o4 INT,
				@base INT
			SELECT
				@o1 = CONVERT(INT, PARSENAME(@ip, 4)),
				@o2 = CONVERT(INT, PARSENAME(@ip, 3)),
				@o3 = CONVERT(INT, PARSENAME(@ip, 2)),
				@o4 = CONVERT(INT, PARSENAME(@ip, 1))
			IF (@o1 BETWEEN 0 AND 255)
				AND (@o2 BETWEEN 0 AND 255)
				AND (@o3 BETWEEN 0 AND 255)
				AND (@o4 BETWEEN 0 AND 255)
			BEGIN
				SELECT @base = CASE
					WHEN @o1 < 128 THEN
						(@o1 * 16777216)
					ELSE
						-(256 - @o1) * 16777216
					END
				SET @rv = @base +
					(@o2 * 65536) +
					(@o3 * 256) +
					(@o4)
			END
			ELSE
				SET @rv = -1
			RETURN @rv
		END
	RunSQLQuery $Query
Re: Block IPs
Post by palinka » 2020-02-17 16:05
eliassal wrote:
2020-02-17 14:24
	$Query = "
		BEGIN
		END;
	RunSQLQuery $Query
	$Query = "
		BEGIN
		END;
	RunSQLQuery $Query
	$Query = "
		BEGIN
				hits int NOT NULL,
		END;
	RunSQLQuery $Query
	$Query = "
	RunSQLQuery $Query
	#then create
	$Query = "
			@ip CHAR(15)
		RETURNS INT
		AS
		BEGIN
			DECLARE @rv INT,
				@o1 INT,
				@o2 INT,
				@o3 INT,
				@o4 INT,
				@base INT
			SELECT
			BEGIN
				SELECT @base = CASE
					WHEN @o1 < 128 THEN
						(@o1 * 16777216)
					ELSE
					END
				SET @rv = @base +
					(@o2 * 65536) +
					(@o3 * 256) +
					(@o4)
			END
			ELSE
				SET @rv = -1
			RETURN @rv
		END
	RunSQLQuery $Query
I think you need to refresh your browser or something.
https://github.com/palinkas-jo-reggelt/ ... BSetup.ps1
_  _ _  _  _  _ _    ____ ____ ____ _  _ ____ ____
|__| |\/| /_\ | |    [__  |___ |__/ |  | |___ |__/
|  | |  |/   \| |___ ___] |___ |  \  \/  |___ |  \
____ _ ____ ____ _ _ _  _  _    _       ___   _  _  _
|___ | |__/ |___ | | | /_\ |    |       |__] /_\ |\ |
|    | |  \ |___ |_|_|/   \|___ |___    |__]/   \| \|
.SYNOPSIS
	Database Setup
.DESCRIPTION
.FUNCTIONALITY
.NOTES
.EXAMPLE
# Include required files
Try {
	.("$PSScriptRoot\Config.ps1")
	.("$PSScriptRoot\CommonCode.ps1")
Catch {
	Write-Output "Error while loading supporting PowerShell Scripts" | Out-File -Path "$PSScriptRoot\PSError.log"
	$Query = "
		BEGIN
		END;
	RunSQLQuery $Query
	$Query = "
		BEGIN
				ipid INT(22) NULL,
				timestamp timestamp NOT NULL,
		END;
	RunSQLQuery $Query
	#	Create hm_fwban_blocks_ip table if it doesn't exist
	$Query = "
		IF NOT EXISTS (SELECT 1 FROM SYSOBJECTS WHERE NAME = 'hm_fwban_blocks_ip')
		BEGIN
			CREATE TABLE IF NOT EXISTS hm_fwban_blocks_ip (
			  id INT(22) NOT NULL AUTO_INCREMENT,
			  ipaddress varchar(15) NOT NULL UNIQUE,
			  hits INT(8),
			  lasttimestamp timestamp NOT NULL,
			  PRIMARY KEY (id)
		END;
	RunSQLQuery $Query
	$Query = "
	BEGIN
			hits int NOT NULL,
	END;
	RunSQLQuery $Query
If ($DatabaseType -eq "MYSQL") {
	$Query = "
		CREATE TABLE IF NOT EXISTS hm_fwban (
		ID int(11) NOT NULL AUTO_INCREMENT,
		ipaddress varchar(192) NOT NULL,
		flag int(1) DEFAULT NULL,
		rulename varchar(192) DEFAULT NULL,
		PRIMARY KEY (ID),
		UNIQUE KEY ID (ID)
		) ENGINE=InnoDB DEFAULT CHARSET=utf8;
		COMMIT;
	RunSQLQuery $Query
	$Query = "
		CREATE TABLE IF NOT EXISTS hm_fwban_rh (
		  ipid INT(22) NULL,
		  ipaddress varchar(15) NOT NULL,
		COMMIT;
	RunSQLQuery $Query
	$Query = "
		  hits INT(8),
		  PRIMARY KEY (id)
		COMMIT;
	RunSQLQuery $Query
	$Query = "
		CREATE TABLE IF NOT EXISTS hm_ids (
		  hits int(1) NOT NULL,
		  helo varchar(128) DEFAULT NULL,
		  PRIMARY KEY (ipaddress),
		  UNIQUE KEY ipaddress (ipaddress)
		COMMIT;
	RunSQLQuery $Query
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 16:28
Oh my god, I was at
https://github.com/lcamilo/hMailServer-Firewall-Ban
all files I used where downloaded from there
Re: Block IPs
Post by palinka » 2020-02-17 16:58
There's a new user variable in Config.ps1. You should start from scratch. I'm warning you now. I won't be able to help much if you're mixing and matching files and database tables without understanding the reason why they're there in the first place.
Also, every upgrade should be a complete upgrade. In other words - replace ALL files because they are interconnected.
lcamilo
Re: Block IPs
Post by lcamilo » 2020-02-17 17:26
2020-02-17 02:08
eliassal wrote:
2020-02-17 01:56
by
or
Excuse me! It was my fault! : oops:
I don't think I tested it correctly or didn't understand how this search should work, perhaps because my data mass was too small and I didn't pay the necessary attention.
I will correct this and send a pull request as soon as possible.
Re: Block IPs
Post by palinka » 2020-02-17 17:30
lcamilo wrote:
2020-02-17 17:26
I will correct this and send a receipt request as soon as possible.
Should be:
WHERE timestamp LIKE '{$search}%'
No % on the left side forces it to look at DATE.
lcamilo
Re: Block IPs
Post by lcamilo » 2020-02-17 17:32
lcamilo wrote:
2020-02-17 17:26
2020-02-17 02:08
eliassal wrote:
2020-02-17 01:56
by
or
Wait, I tested and it is working. See:
lcamilo
Re: Block IPs
Post by lcamilo » 2020-02-17 17:36
lcamilo wrote:
2020-02-17 17:32
lcamilo wrote:
2020-02-17 17:26
2020-02-17 02:08
Wait, I tested and is working. See:
The final query is:
SELECT Count(*) AS count
FROM   hm_fwban
WHERE  ( Cast(timestamp AS DATE) LIKE '%2020-02-10%'
          OR ipaddress LIKE '%2020-02-10%'
          OR ban_reason LIKE '%2020-02-10%'
          OR country LIKE '%2020-02-10%'
          OR helo LIKE '%2020-02-10%'
          OR ptr LIKE '%2020-02-10%' )
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 17:38
Ok, don't worry, I downlaoded your version, deleted old tables, I noticed the existance of the new variable which I repalced with my iis path as follows
$wwwFolder = "P:\inetpub\wwwroot\PHPBanAdmin"
I have just tried to run the
script but getting a strange behavior, it is able to include config.ps1 but not commoncode.ps1
in terminal and ise editor
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 17:46
I solved the strange issue, the file was blocked, I unblocked it
Any reason this specific security on this file?
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 17:56
Palinka, there is a typo in the script commoncode.ps1
Function RunSQLQuery($Query){
        MySQLQuery($Query)
    } ElseIf ($DatabaseType -eq "MSSQL"){
        [b]MySQLQuery[/b]($Query)
    } Else {
        Out-Null
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 18:43
Lot of issues in the new hmsFirewallBanDBSetup.ps1 and CommonCode.ps1
Bugs
1 -No need for the word "port=" in the connection string
;port=" + $SQLPort, only ,number
,427
2 - what is this for in mssql runquery which I commented
[void][System.Reflection.Assembly]::LoadWithPartialName("MySql.Data")
3 - Also, you can Cannot specify a column width on data type int as in lines
ipid INT(22) NULL,
hits INT(8), (table hm_fwban_blocks_ip)
4 - Several errors in creating hm_fwban_rh and 'hm_fwban_blocks_ip, I have the impression you have copied/pasted from mysql without updating
I replaced it from
BEGIN
hits INT(8),
PRIMARY KEY (id)
END;
To
BEGIN
hits int NOT NULL,
END;
5 You cannot do this in sql
Do you want me to share the updated 2 files which are working fine now with you?
Re: Block IPs
Post by palinka » 2020-02-17 19:18
eliassal wrote:
2020-02-17 18:43
Post it here in forum code block.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 19:25
so Palinke, I did everyhting from scratch, tables are created , events are working fine in hMaiserver,
I dumped the data in the tables before starting from scratch, I am thinking of populating the ids table manullay then fire hmsFirewallBan.ps1, of course I will take care of having those tables clean from new structure perspectives
but tell me, the other scripts in the directory, should I run them as well and when?
BlockCount.ps1
hmsConsolidateRules.ps1
hmsDuplicateRuleFinder.ps1
hmsRetroAddBlocksIPTable.ps1
hmsRetroAddPTR.ps1
hmsRetroConsolidateRules.ps1
hmsUpdateChartTables.ps1
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 19:28
Here is the code for hmsFirewallBanDBSetup.ps1
.SYNOPSIS
	Database Setup
.DESCRIPTION
.FUNCTIONALITY
.NOTES
.EXAMPLE
Try {
Catch {
	$Query = "
		BEGIN
		END;
	RunSQLQuery $Query
	Write-Host 'Created hm_fwban'
	$Query = "
		BEGIN
				ipid INT NULL,
		END;
	RunSQLQuery $Query
	Write-Host 'Created hm_fwban_rh'
	$Query = "
		BEGIN
			CREATE TABLE hm_fwban_blocks_ip (
			  id INT IDENTITY(1,1) PRIMARY KEY,
			  hits INT,
		END;
	RunSQLQuery $Query
	Write-Host 'hm_fwban_blocks_ip'
	$Query = "
	BEGIN
			hits int NOT NULL,
	END;
	RunSQLQuery $Query
	Write-Host 'Created hm_ids'
	$Query = "
		PRIMARY KEY (ID),
		UNIQUE KEY ID (ID)
		COMMIT;
	RunSQLQuery $Query
	$Query = "
		  ipid INT(22) NULL,
		COMMIT;
	RunSQLQuery $Query
	$Query = "
		  hits INT(8),
		  PRIMARY KEY (id)
		COMMIT;
	RunSQLQuery $Query
	$Query = "
		COMMIT;
	RunSQLQuery $Query
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 19:29
and here is the code for the commoncode.ps1
.SYNOPSIS
	Powershell component to hMailServer Firewall Ban (CommonCode.ps1)
.DESCRIPTION
	Backend firewall rule administration for hMailServer Firewall Ban Project
.FUNCTIONALITY
	* Provide Common Code to run Firewall Ban modules
.NOTES
.EXAMPLE
Try {
Catch {
#             EMAIL CODE              #
Function EmailResults {
	$Subject = "hMS Firewall Ban Notification"
	$Body = (Get-Content -Path $EmailBody | Out-String )
	$SMTPClient = New-Object Net.Mail.SmtpClient($SMTPServer, $SMTPPort)
	$SMTPClient.EnableSsl = [System.Convert]::ToBoolean($SSL)
	$SMTPClient.Send($FromAddress, $Recipient, $Subject, $Body)
#           DATABASE CODE             #
        MySQLQuery($Query)
        MSSQLQuery($Query)
    } Else {
        Out-Null
Function MySQLQuery($Query) {
	$Today = (Get-Date).ToString("yyyyMMdd")
	$DBErrorLog = "$PSScriptRoot\$Today-DBError.log"
	$ConnectionString = "server=" + $SQLHost + ";port=" + $SQLPort + ";uid=" + $SQLAdminUserName + ";pwd=" + $SQLAdminPassword + ";database=" + $SQLDatabase
	Try {
		$Connection = New-Object MySql.Data.MySqlClient.MySqlConnection
		$Connection.ConnectionString = $ConnectionString
		$Connection.Open()
		$Command = New-Object MySql.Data.MySqlClient.MySqlCommand($Query, $Connection)
		$DataAdapter = New-Object MySql.Data.MySqlClient.MySqlDataAdapter($Command)
		$DataSet = New-Object System.Data.DataSet
		$RecordCount = $dataAdapter.Fill($dataSet, "data")
		$DataSet.Tables[0]
	Catch {
		Write-Output "$((get-date).ToString(`"yy/MM/dd HH:mm:ss.ff`")) : ERROR : Unable to run query : $query `n$Error[0]" | out-file $DBErrorLog -append
	Finally {
		$Connection.Close()
Function MSSQLQuery($Query) {
    $ConnectionString = "Data Source=" + $SQLHost + ", " + $SQLPort + ";uid=" + $SQLAdminUserName + ";password=" + $SQLAdminPassword + ";Initial Catalog=" + $SQLDatabase + ";"
	Try {
		#[void][System.Reflection.Assembly]::LoadWithPartialName("MySql.Data")
		$Connection = New-Object System.Data.SqlClient.SQLConnection($connectionString)
		$Connection.Open()
		$Command = New-Object System.Data.SqlClient.SqlCommand($Query, $Connection)
		$DataAdapter = New-Object System.Data.SqlClient.SqlDataAdapter($Command)
		$DataSet.Tables[0]
	Catch {
	Finally {
		$Connection.Close()
Function DBCastDateTimeFieldAsDate($fieldName){
    $Return = ""
        $Return = "DATE($fieldName)"
        $Return = "CAST($fieldName AS DATE)"
    return $Return
Function DBCastDateTimeFieldAsHour($fieldName){
	$Return = ""
		$Return = "HOUR($fieldName)"
		$Return = DBFormatDate $fieldName, '%H'
	return $Return;
Function DBSubtractIntervalFromDate(){
    param
        $dateString,
        $intervalName,
        $intervalValue
    $Return = ""
        $Return = "'$dateString' - interval $intervalValue $intervalName"
        $Return = "DATEADD($intervalName,-$intervalValue, '$dateString')"
    return $Return
Function DBSubtractIntervalFromField(){
    param
        $fieldName,
        $intervalName,
        $intervalValue
    $Return = ""
        $Return = "$fieldName - interval $intervalValue $intervalName"
        $Return = "DATEADD($intervalName,-$intervalValue, $fieldName)"
    return $Return
Function DBGetCurrentDateTime(){
    $Return = ""
        $Return = "NOW()"
        $Return = "GETDATE()"
    return $Return
Function DBLimitRowsWithOffset(){
    param(
        $offset,
        $numRows
	$QueryLimit = ""
		$QueryLimit = "LIMIT $offset, $numRows"
		$QueryLimit = "OFFSET $offset ROWS
		   	           FETCH NEXT $numRows ROWS ONLY"
	return $QueryLimit
Function DBFormatDate($fieldName, $formatSpecifier){
	$Return = ""
	$dateFormatSpecifiers = @{
		'%Y'                   = 'yyyy'
		'%c'                   = 'MM'
		'%e'                   = 'dd'
		'Y-m-d'                = 'yyyy-MM-dd'
		'%y/%m/%d'             = 'yy/MM/dd'
		'Y-m'                  = 'yyyy-MM'
		'%Y-%m'                = 'yyyy-MM'
		'%y/%m/%d %T'          = 'yy-MM-dd HH:mm:ss'
		'%Y/%m/%d %HH:%mm:%ss' = 'yyyy-MM-dd HH:mm:ss'
		'%Y/%m/01'             = 'yyyy-MM-01'
		'%y/%c/%e'             = 'yy/MM/dd'
		'%H'                   = 'HH'
		$Return = "DATE_FORMAT($fieldName, '$formatSpecifier')"
		$Return = "FORMAT($fieldName, '$dateFormatSpecifiers[$formatSpecifier]', 'en-US')"
	return $Return
#           FIREWALL CODE             #
<#  https://gist.github.com/Stephanevg/a951872bd13d91c0eefad7ad52994f47  #>
Function Get-NetshFireWallrule {
	Param(
		[String]$RuleName
	$Rules = & netsh advfirewall firewall show rule name="$ruleName"
	$return = @()
		$HAsh = [Ordered]@{}
		foreach ($Rule in $Rules){
			switch -Regex ($Rule){
				'^Rule Name:\s+(?<RuleName>.*$)'{$Hash.RuleName = $MAtches.RuleName}
				'^RemoteIP:\s+(?<RemoteIP>.*$)'{$Hash.RemoteIP = $Matches.RemoteIP;$obj = New-Object psobject -Property $Hash;$return += $obj}
	return $return
Function RemRuleIP($IP) {
	$Query = "SELECT rulename FROM hm_fwban WHERE ipaddress = '$IP'"
	RunSQLQuery $Query | ForEach {
		$RuleName = $_.rulename
	If (-not($RuleName)) {
		& netsh advfirewall firewall delete rule name=`"$IP`"
	Else {
		$RuleList = "$PSScriptRoot\fwrulelist.txt"
		$NewLine = [System.Environment]::NewLine
		Get-NetshFireWallrule ("$RuleName") | ForEach {
			$RemoteIP = $_.RemoteIP
			$ReplaceCIDR = ($RemoteIP).Replace("/32", "")
			$ReplaceNL = ($ReplaceCIDR).Replace(",", $NewLine)
			Write-Output $ReplaceNL
		} | out-file $RuleList
		Get-Content $RuleList | where { $_ -ne $IP } | Out-File "$RuleList.delIP.txt"
		$NL = [System.Environment]::NewLine
		$Content = [String] $Template = [System.IO.File]::ReadAllText("$RuleList.delIP.txt")
		$Content.Replace($NL, ",") | Out-File "$RuleList.rule.txt"
		(Get-Content -Path "$RuleList.rule.txt") -Replace ',$', '' | Set-Content -Path "$RuleList.rule.txt"
		& netsh advfirewall firewall delete rule name=`"$RuleName`"
		& netsh advfirewall firewall add rule name=`"$RuleName`" description="FWB Rules for $DateIP" dir=in interface=any action=block remoteip=$(Get-Content "$RuleList.rule.txt")
Re: Block IPs
Post by palinka » 2020-02-17 19:54
eliassal wrote:
2020-02-17 19:25
Altered columns in hm_fwban_rh mean your data won't line up correctly. Before: id=autoincrement. Now:id matches id on hm_fwban_blocks_ip where ipaddress is the same. In other words, the altered table accepts duplicates while the old table had unique key.
I don't understand what you're attempting to do here. IDS is triggered by activity in hmailserver. Why would you manually add entries? The web admin has a place to manually ban and release IPs.
RUN NIGHTLY AT 12:01 AM IN THIS ORDER
RUN WHENEVER YOU'RE CURIOUS - Same as BANALYZER in the web admin except without max execution time errors.
BlockCount.ps1
ONLY FOR UPGRADING
hmsRetroAddPTR.ps1
Re: Block IPs
Post by palinka » 2020-02-17 20:01
eliassal wrote:
2020-02-17 17:46
I think GitHub just transfers text without any file attributes. Must be something on your end. Nothing is blocked on my system.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 20:09
OK thanks for both answers, I will continue discovering the tool
Re: Block IPs
Post by palinka » 2020-02-17 20:31
eliassal wrote:
2020-02-17 20:09
If you reload your old hm_fwban_rh table with the old structure and data ==> then run hmsRetroAddBlocksIPTable.ps1, it will do the table upgrade for you. You will need to modify the CREATE statements because they are written for MySQL only at the moment.
* It creates hm_fwban_blocks_ip
* Alters hm_fwban_rh
* Populates hm_fwban_blocks_ip with data from hm_fwban_rh
* Populates "ipid" in hm_fwban_rh from autoincrement value in newly created hm_fwban_blocks_ip
I haven't figured out yet how I'm going to use the altered hm_fwban_rh. When I get a chance I'm going to play with queries to see if I can get faster execution. Eventually, I want to delete the ipaddress column altogether, but its still there because its still being used by the blocks and repeat pages, as well as the charts.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 20:52
tell me why in table hm_fwban_rh, the field is of type timestamp like the other fields in the other timesatamp fields in other tables whgic are of datetime type
Thios can generate issues
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 21:32
Panilka, in hmsFirewallBan.ps1
section
# FIREWALL LOG PARSING #
there is a sql query as follows
$Query = "INSERT INTO hm_fwban_blocks_ip (ipaddress, hits, lasttimestamp) VALUES ('$IP',1,'$DateTime') ON DUPLICATE KEY UPDATE hits=(hits+1),lasttimestamp='$DateTime';"
This doesn't work in sql as you use a specific extnesion to mysql which allows the use of
ON DUPLICATE KEY UPDATE.....
This should be really dealt with differently. Did your freind helping you talked about it?
Re: Block IPs
Post by palinka » 2020-02-17 22:21
eliassal wrote:
2020-02-17 21:32
section
No, he may not have seen it. I uploaded it last night. Do you have a workaround? Actually, the same ON DUPLICATE KEY UPDATE should be found in eventhandlers for IDS, which he did update.
strSQL = "IF NOT EXISTS (SELECT 1 FROM " & idsTable & " WHERE ipaddress = '" & sIPAddress & "') INSERT INTO " & idsTable & " (timestamp,ipaddress,hits,country) VALUES (" & DBGetCurrentDateTime() & ",'" & sIPAddress & "',1,'" & oGeoip("country") & "') ELSE UPDATE " & idsTable & " SET hits=(hits+1), timestamp=" & DBGetCurrentDateTime() & " WHERE ipaddress= '" & sIPAddress & "';"
Re: Block IPs
Post by palinka » 2020-02-17 22:39
Speak of the devil... He just put in a pull request for a bunch of things including this query:
$Query = "IF NOT EXISTS (SELECT 1 FROM hm_fwban_blocks_ip WHERE ipaddress='$ipaddress') INSERT INTO hm_fwban_blocks_ip (ipaddress, hits, lasttimestamp) VALUES ('$ipaddress',1,'$timestamp') ELSE UPDATE hm_fwban_blocks_ip SET hits=(hits+1),lasttimestamp='$timestamp'  WHERE ipaddress='$ipaddress';"
I'm going to merge it in a few minutes as soon as I get done checking it.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 23:00
This is very old way of processing such topic, There is a much better and neat way using "MERGE" Keyworg which does UpSert . either insert if record does not exist or update any other field if reord exists, somthing similar to this (this very quick and dirty example to show you)
MERGE hm_fwban_blocks_ip AS TARGET
USING (Select ipaddress =126.23.55.123 )   AS SOURCE
ON (TARGET.ipaddress = SOURCE.ipaddress)
--When records are matched, update the records if there is any change
WHEN MATCHED AND TARGET.ipaddress <> SOURCE.ipaddress OR ......OR ...and
THEN UPDATE SET TARGET.hits = TARGET.hits + 1, TARGET.otherfield = SOURCE.otherfield
--When no records are matched, insert the incoming records from source table to target table
WHEN NOT MATCHED BY TARGET
THEN INSERT (TARGET.ipaddress, TARGET.ipaddress, lasttimestamp) VALUES (value, value, value)
Aldo we can delete if want like that
WHEN NOT MATCHED BY SOURCE
THEN DELETE
eliassal
Re: Block IPs
Post by eliassal » 2020-02-17 23:07
OK please let me know once it is done as nothing is getting to my tables not from the PS ban script nor the hMailserver VBS
Re: Block IPs
Post by palinka » 2020-02-17 23:08
eliassal wrote:
2020-02-17 21:32
$FirewallLogObjects | foreach-object {
	If (($_.Action -match 'DROP') -and ($_.DestinationPort -match $MailPorts) -and ($_.SourceIP -notmatch $LSRegex)) {
		$IP = $_.SourceIP
		$DateTime = $_.Date + " " + $_.Time
		If ($DatabaseType -eq "MYSQL"){
		} ElseIf ($DatabaseType -eq "MSSQL") {
			$Query = "IF NOT EXISTS (SELECT 1 FROM hm_fwban_blocks_ip WHERE ipaddress='$IP') INSERT INTO hm_fwban_blocks_ip (ipaddress, hits, lasttimestamp) VALUES ('$IP',1,'$DateTime') ELSE UPDATE hm_fwban_blocks_ip SET hits=(hits+1),lasttimestamp='$DateTime'  WHERE ipaddress='$IP';"
		RunSQLQuery $Query
		$Query = "SELECT id FROM hm_fwban_blocks_ip WHERE ipaddress = '$IP'"
			$IPID = $_.id
			$Query = "INSERT INTO hm_fwban_rh (timestamp, ipaddress, ipid) VALUES ('$DateTime', '$IP', '$IPID')"
			RunSQLQuery $Query
Re: Block IPs
Post by palinka » 2020-02-17 23:21
eliassal wrote:
2020-02-17 23:07
How is that any different than before you learned of this project? :wink:
I just pushed another commit on top of the other changes lcamilo did.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-18 00:34
Here you records in hm_fwban_blocks_ip and hm_fwban_rh tqbles but nothing in hm_ids.
In section
# IDS #
# (Intrusion Detection System) #
you query hm_ids as follows
$Query = "SELECT ipaddress, country FROM hm_ids WHERE hits > 2"
no records no rules created and scripts finishes without creating the rules
eliassal
Re: Block IPs
Post by eliassal » 2020-02-18 00:36
I forgot to mention that the field timestamp in hm_fwban_blocks_ip should be changed to datetime otherwise insert will error
eliassal
Re: Block IPs
Post by eliassal » 2020-02-18 01:29
In scriptm hits per daym it generates a sql query
SELECT
a.daily,
a.year,
a.month,
a.day,
a.ipperday,
b.blockperday
FROM
SELECT
CAST(timestamp AS DATE) AS daily,
FORMAT(CAST(timestamp AS DATE), 'System.Collections.Hashtable[%Y]', 'en-US') AS year,
(FORMAT(CAST(timestamp AS DATE), 'System.Collections.Hashtable[%c]', 'en-US') ) AS month,
FORMAT(CAST(timestamp AS DATE), 'System.Collections.Hashtable[%e]', 'en-US') AS day,
COUNT(id) AS ipperday
FROM hm_fwban
WHERE CAST(timestamp AS DATE) < CAST(GETDATE() AS DATE)
GROUP BY CAST(timestamp AS DATE)
) AS a
LEFT JOIN
SELECT
COUNT(DISTINCT(ipaddress)) AS blockperday
FROM hm_fwban_rh
) AS b
ON a.daily = b.daily
ORDER BY a.daily
SAL server does not understand this neither me :shock:
eliassal
Re: Block IPs
Post by eliassal » 2020-02-18 01:31
I will stop for tonight as I worked a lotm the eqrlier version did not have so many sql statements issues :(
Re: Block IPs
Post by palinka » 2020-02-18 01:35
eliassal wrote:
2020-02-18 00:34
In section
#                IDS                  #
Its not working for you? Do you have entries in IDS? Are any rules being created? Are you sure your changes to CommonCode.ps1 didn't break something?
#	Pickup entries from IDS
RunSQLQuery $Query | foreach {
	$TS = $_.timestamp
	$IP = $_.ipaddress
	$Country = $_.country
	#	Grab PTR record
	try {
		$PTR = [System.Net.Dns]::GetHostEntry($IP).HostName
	catch {
		$PTR = "No.PTR.Record"
	#	Create firewall rule
	& netsh advfirewall firewall add rule name="$IP" description="Rule added $((get-date).ToString('MM/dd/yy')) - IDS" dir=in interface=any action=block remoteip=$IP
	#	Insert IP record into firewall ban table
	$Query = "INSERT INTO hm_fwban (timestamp,ipaddress,ban_reason,country,flag,ptr,rulename) VALUES ($(DBGetCurrentDateTime),'$IP','IDS','$Country',NULL,'$PTR','$IP');"
	RunSQLQuery $Query
Re: Block IPs
Post by palinka » 2020-02-18 01:56
eliassal wrote:
2020-02-18 01:29
SELECT
		a.daily,
		a.year,
		a.month,
		a.day,
		a.ipperday,
		b.blockperday
	FROM
		SELECT
			FORMAT(CAST(timestamp AS DATE), [b]'System.Collections.Hashtable[%Y]'[/b], 'en-US') AS year,
			(FORMAT(CAST(timestamp AS DATE), [b]'System.Collections.Hashtable[%c]'[/b], 'en-US') ) AS month,
			FORMAT(CAST(timestamp AS DATE), [b]'System.Collections.Hashtable[%e]'[/b], 'en-US') AS day,
		FROM hm_fwban
	) AS a
	LEFT JOIN
		SELECT
		FROM hm_fwban_rh
	) AS b
	ORDER BY a.daily
Where is this coming from? System.Collections.Hashtable[%Y]
			$( DBFormatDate (DBCastDateTimeFieldAsDate 'timestamp') '%Y') AS year,
			($( DBFormatDate (DBCastDateTimeFieldAsDate 'timestamp') '%c') $(If ($DatabaseType -eq 'MYSQL'){Write "- 1"})) AS month,
			$( DBFormatDate (DBCastDateTimeFieldAsDate 'timestamp') '%e') AS day,
Runs through 2 functions in CommonCode.ps1:
    $Return = ""
    return $Return
	--and--
Function DBFormatDate(){
	param(
		$fieldName,
		$formatSpecifier
	$Return = ""
		'%Y'                   = 'yyyy'
		'%c'                   = 'MM'
		'%e'                   = 'dd'
		'Y-m'                  = 'yyyy-MM'
		'%Y-%m'                = 'yyyy-MM'
		'%H'                   = 'HH'
		$Return = "FORMAT($fieldName, '$($dateFormatSpecifiers[$formatSpecifier])', 'en-US')"
	return $Return
Sooo.... MySQL:
DATE_FORMAT(DATE(timestamp), %Y) AS year
... gets transformed into ...
FORMAT(CAST(timestamp AS DATE), 'yyyy', 'en-US') AS year
I'm not sure why its not working for you. It looks as though the array %Y is not giving you back yyyy as it should be doing.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-18 02:00
in hmsFirewallBan.ps1 there is no code to populate ids table
		$IP = $_.SourceIP
		RunSQLQuery $Query
		$Query = "SELECT id FROM [b]hm_fwban_blocks_ip[/b] WHERE ipaddress = '$IP'"
			$IPID = $_.id
			$Query = "INSERT INTO [b]hm_fwban_r[/b]h (timestamp, ipaddress, ipid) VALUES ('$DateTime', '$IP', '$IPID')"
			RunSQLQuery $Query
Re: Block IPs
Post by palinka » 2020-02-18 02:10
eliassal wrote:
2020-02-18 02:00
Yes. The table gets populated by hmailserver eventhandlers.vbs.
Powershell only deletes entries due to either expiration or because an IP got up to 3 tries within the interval, triggering a ban.
eliassal
Re: Block IPs
Post by eliassal » 2020-02-18 02:13
in the hmsUpdateChartTables.ps1
