Let's Encrypt on hmailserver
broxturf
Post by broxturf » 2020-11-18 18:18
I've been trying to get an encryption on my mail server.
I've got the certificate from Let's Encrypt's Certbot and are stored at C:\Certbot\...
- cert.pem
- chain.pem
- fullchain.pem
- privkey.pem
So I've linked it
but when I reconfigure a client to the new ports with the respective encryption (I'm using Port 995 and Port 587 with SSL/TLS for both) and I get a message that says
The server you are connected to is using a security certificate that cannot be verified
and when I click "see certificate" I see this
And everytime I open Outlook i get the error message again.
BTW I can't open the .pem files for some reason, apparently I don't have permissions to open the file, the same occurred when I tried to link hmail to my certificate files, I had to write the file path myself.
jim.bus
Re: Let's Encrypt on hmailserver
Post by jim.bus » 2020-11-19 02:56
I have trouble with using my Let's Encrypt Chain certificate because it shows an already expired certificate which is a different error than you have though.
I manage to get my Let's Encrypt Certificates to work by using the cert.pem for the Certificate File and Privkey.pem for the Private key file.
You can try this to see if this helps your problem.
Also be sure there are no Passwords on the Let's Encrypt .pem files.
Post by mattg » 2020-11-19 03:02
using fullchain.pem is correct
What is the domain name(s) on the cert
Is the mail client looking for a server with EXACTLY the same FQDN
Post by palinka » 2020-11-19 12:52
What is "fullchain"? Is that a certbot thing? I only get cert, chain and key from win-acme, so I use "chain". Try that one.
broxturf wrote:
2020-11-18 18:18
This is probably your issue, though. Make sure hMailServer has privileges to read the certificate. hMailServer runs under local system account by default.
broxturf
Post by broxturf » 2020-11-19 13:13
2020-11-19 12:52
I don't know what fullchain is, probably just a combination of domain names, from what I read on some forums, but don't take my word for it, I'm new to this xD
2020-11-19 12:52
How can I check if hMailServer has those privileges?
broxturf
Post by broxturf » 2020-11-19 13:16
2020-11-19 03:02
Well matt, I have two different domains in hMail and I created one certificate with the exact same FQDN for each.
I've even tried switching the certificates around but no luck as I anticipated.
Post by palinka » 2020-11-19 13:18
broxturf wrote:
2020-11-19 13:13
2020-11-19 12:52
Look at the folder properties the certificates are stored in and make sure local system account has access.
Also open services and check the properties for hMailServer to make sure its actually running under local system account.
broxturf
Post by broxturf » 2020-11-19 13:21
jim.bus wrote:
2020-11-19 02:56
Just tried it but no luck, I still get the error where the certificate can't be verified
broxturf
Post by broxturf » 2020-11-19 13:26
2020-11-19 13:18
All are setup correctly.
jim.bus
Post by jim.bus » 2020-11-19 13:33
broxturf wrote:
2020-11-19 13:16
2020-11-19 03:02
Unless I'm mistaken about what you are doing, the Domain name for the Certificate should be for your hMailServer hostname. Not the Domain names you are hosting on hMailServer. Example if your hMailServer hostname is mail.example.com then this hostname is the name which should be used on the Certificate.
broxturf
Post by broxturf » 2020-11-19 13:44
jim.bus wrote:
2020-11-19 13:33
Then should I create a certificate for mail.example.com or for example.com?
johang
Post by johang » 2020-11-19 14:24
broxturf wrote:
2020-11-19 13:44
jim.bus wrote:
2020-11-19 13:33
FQDN = fully qualified domain name
example: A device with the hostname myhost in the parent domain example.com has the fully qualified domain name myhost.example.com.. The FQDN uniquely distinguishes the device from any other hosts called myhost in other domains.
so to answer your question: mail.example.com
Post by SorenR » 2020-11-19 14:29
broxturf wrote:
2020-11-19 13:44
jim.bus wrote:
2020-11-19 13:33
The certificate apply to the server, not the hosted domains.
The validity of your mailserver serving your hosted domains is done by your SPF & DKIM settings and ultimately the DMARC policy.
jim.bus
Post by jim.bus » 2020-11-19 20:24
broxturf wrote:
2020-11-19 13:44
jim.bus wrote:
2020-11-19 13:33
Ditto to what johang and sorenr has said about the FQDN and hostname. In my example of hostname for hMailServer, mail.example.com, the name which should should appear on the Certificate is mail.example.com.
Post by mattg » 2020-11-20 00:37
broxturf wrote:
2020-11-19 13:16
2020-11-19 03:02
You need a certificate that matches your 'local host name', and your MX record, not necessarily the same as any domains on your hMailserver
For instance,
My local host name and RDNS is set to example.com, as does my certificate
All DNS MX records for all domains point to mail.example.com
Any server looking for any domain hosted on my server will get the same EHLO, to match my RDNS, and to match the certificate
MATCH
And yes fullchain is a cert bot thing. It is the certificate PLUS all CAs needed to substantiate it
Virinum
Post by Virinum » 2020-11-20 09:20
For testing mailserver certificates I like using this tool: https://ssl-tools.net/mailservers
broxturf
Post by broxturf » 2020-11-20 11:36
2020-11-20 00:37
For instance,
MATCH
I didn't have anything setup on my local host name, I'm using routes and rules for each of my domains.
Should I set the local hostname as one of my domains and use the routing and rules for the other one (and using the certificate pointing to the domain I use on my local host name) ?
Post by mattg » 2020-11-21 03:17
broxturf wrote:
2020-11-20 11:36
The certificate in hMailserevr is ONLY Used for incoming connections to your hMailserver.
These could be POP3 or IMAP connections checking for mail (Not affected by routes or SMTP Relayer), OR
These could be SMTP connections either from clients wanting to send outbound mail, or by other mailserver forwarding mail to your users
(Again not affected by routes or SMTP relayer)
The local host name is what your server details as it's name when asked
Mail Clinet or other server connecting to your server -> EHLO there
Your server in response -> Hi my name is xxxxxxx and I offer these services. What would you like?
That is ALSO the only time that your certificate is used
When you send mail to another server, and secure connections are made using the OTHER SERVER's certificate
