Add a Certificate / Reduce Blocing
G4ELI
Post by G4ELI » 2020-11-30 07:21
Hi All,
I am running hMailServer with phpBB and it's superb. One small issue - I use a static IP which is registered as residential, some hosts such as Hotmail return errors, example below.
I assume that I cannot overcome this by adding a certificate somewhere? I'm sure the answer is no - but let's see what you say. ATT is (was) a PITA with residential addresses.
Error Type: SMTP
   Remote server (104.47.17.161) issued an error.
   hMailServer sent: MAIL FROM:<forums@dit-dit-dit.com>
   Remote server replied: 550 5.7.1 Unfortunately, messages from [81.174.138.141] weren't sent. Please contact your Internet service provider since part of their network is on our block list (S3150). You can also refer your provider to http://mail.live.com/mail/troubleshooting.aspx#errors. [VI1EUR05FT037.eop-eur05.prod.protection.outlook.com]
G4ELI
Re: Add a Certificate / Reduce Blocing
Post by G4ELI » 2020-11-30 07:38
I think I can answer this myself, the answer being no :(
https://stackoverflow.com/questions/911 ... -classifie
Post by mattg » 2020-11-30 10:25
RDNS may help, certificates help, SPF helps, DMARC helps, static IPs certainly help
Most services classed as residential are dynamic IP
Check this guide for more hints
https://www.hmailserver.com/forum/viewt ... 21&t=32458
Post by palinka » 2020-11-30 14:22
G4ELI wrote:
2020-11-30 07:21
Hi All,
Error Type: SMTP
You're on a PBL (Policy Block List) maintained by your ISP and reported to various blacklists. They do this to reduce spam with the idea that only a business account should have a mail server, therefore residential IPs should automatically be regarded as spammers. The ONLY way off the list is to upgrade your account and ask your ISP to remove you from the PBL (if its not automatically removed when you upgrade your account).
Alternatively, you can send through a third party relay. There are a few free ones with limitations. The most generous one I've found is smtp2go.com. I pay for their service. The free one has a pretty generous monthly limit but there is an hourly limit as well. Anyway, have a look to see if it works for your volume. Also, there are plenty of free alternatives as well. I haven't looked in a long time. Good luck.
G4ELI
Post by G4ELI » 2020-12-01 20:09
2020-11-30 14:22
G4ELI wrote:
2020-11-30 07:21
Hi All,
Error Type: SMTP
Thanks - sadly you're right :( .
Virinum
Post by Virinum » 2020-12-02 08:30
No. It’s Microsoft. They have their own blocklist. Problem with Microsoft is that if someone from your subnet sends spam, Microsoft blocks the whole subnet.
You can ask for delisting here: https://support.microsoft.com/en-us/get ... =edfsmsbl3
But you have to be persistent. I have done that a multiple times, because my VPS provider (netcup, Germany) has this problem with their IP addresses, too.
Just google for the phrase "Unfortunately, messages from weren't sent. Please contact your Internet service provider since part of their network is on our block list" and you’ll find a lot of results from people with this problem.
Post by RvdH » 2020-12-02 17:06
Virinum wrote:
2020-12-02 08:30
Not entirely true, his IP is also on http://www.spamrats.com/bl?81.174.138.141
Virinum
Post by Virinum » 2020-12-02 18:06
2020-12-02 17:06
Yes, you’re right.
I don’t know which blacklists Microsoft uses. But when I got exactly this error from Microsoft I wasn’t on any public blocklist. Just on Microsoft’s internal list.
For me the IP 81.174.138.141 seems to be a business IP because it has a proper reverse entry.
G4ELI
Post by G4ELI » 2020-12-02 22:13
All,
Your replies are superb, just like hMailServer.
