Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: hMailServer service terminated unexpectedly...
PostPosted: 2004-07-20 17:07
Hi, Does anyone ran into this error. I got this error from Windows Event Viewer "The hMailServer service terminated unexpectedly. It has done this 4 time(s). The following corrective action will be taken in 0 milliseconds: No action. " Mail service has been stopped for few times. Please help..i'm running Windows 2000 Server with Service Pack 4, hMailServer 3.2.1 build 29.
Top
 Profile
 Post subject:
PostPosted: 2004-07-20 17:50
Take a look at the change log...
http://www.hmailserver.com/?page=show_m ... nloadid=35
Top
 Profile
 Post subject:
PostPosted: 2004-07-20 22:41
This is the error that I received using Mozilla Mail. It would crash hmail when logging into the IMAP server. I had to abandon hmail until there is a fix for the way Mozilla talks IMAP.
Top
 Profile
 Post subject:
PostPosted: 2004-07-21 09:39
The problem that hMailServer crashed was fixed in 3.2.2? Perhaps you should read the change log aswell larrymail.. :)
Top
 Profile
 Post subject:
PostPosted: 2004-07-21 16:16
I'm still having same problem with version 3.2.2...When 2 or 3 users login simutaneously hMailserver crashes same with Outlook. Everytime I use outlook, it crashes...it connects about 5 mins sometime less hMailServer crash. Is there a way you can make hMailServer start itself when unexpected event causes it to stop?
Top
 Profile
 Post subject:
PostPosted: 2004-07-21 16:36
So when you use Outlook, hMailServer _always_ crashes regardless if there are other users trying to connect at the same time? If you turn on logging and send the logs to me after crash (buginfo at hmailserver.com), I'll fix it.
Does it work if you use another clients than Outlook? I use Outlook all the time without problems.
(You can configure the service to restart in the service applet in windows. It's under the Recovery tab.)
Top
 Profile
 Post subject:
PostPosted: 2004-07-21 19:23
Looks like 3.2.2 solved my problems with Mozilla Mail in the lab. Now, I'll need to test it further on the production server.
Top
 Profile
Who is online
Search for:
