Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: how to log message headers in log file / raw text file?
PostPosted: 2010-01-15 06:53
Hi
I want to write one VC++ application OR VB Script which can find unread mails [mails which are not downloaded by client] for particular account and write that data in one log file.
How can I extract message header for each message for particular account?
Any help is appreciated.
Regards,
Yogesh
Top
 Profile
 Post subject: Re: how to log message headers in log file / raw text file?
PostPosted: 2010-01-18 21:20
You could write a custom scripts in the OnAcceptMessage event (using VBScript) to extract the headers and log them to a file.
It's tricky to log to a text file though, since you have to take into multi-threading into account. (What happens if two messages are received at the same time and hMailServer tries to log both of them to file at the same time).
Top
 Profile
PostPosted: 2010-01-19 08:56
Hi Martin,
Thank you for your response. I am beginner for vbscripts with hmailserver. can you please provide any sample script for the same?
OnAcceptMessage() is based on any events? is there any documentation available for this api?
Top
 Profile
PostPosted: 2010-01-19 14:50
http://www.hmailserver.com/documentatio ... ce_scripts
_________________
Documentation
Top
 Profile
Who is online
Search for:
