Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: hMailServer does not show script error
PostPosted: 2012-04-05 14:34
I am using hMailServer 5.3.3-B1879. I am using scripts for handling incoming messages. When the script has no errors, everything is OK. However when the script has some runtime errors, the messages are not handled, but the error log does not contain the location of the error within the script.
Here is the contents of the error log file:
"ERROR" 2816 "2012-04-05 16:30:14.585" "Script Error: Source: "ERROR" 2900 "2012-04-05 16:30:14.610" "Script Error: Source:
As I searched in web, the source of error (VBScript error: ..... line .., col ..) should be shown.
The logging is enabled. What I am doing wrong?
Thanks,
Vsevolod
Top
 Profile
 Post subject: Re: hMailServer does not show script error
PostPosted: 2012-04-07 08:21
did you check syntax when you reloaded the script?
_________________
Documentation
Top
 Profile
PostPosted: 2012-04-07 09:03
Thank you for the reply. I checked the syntax after reloading scripts. The syntax is correct. I am talking about runtime errors like "Access denied while trying to write into a file". Currently, when a runtime error occurs, I can not locate and fix it.
I used Windows 7 and Windows 2008 Server.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 5 guests
Search for:
