Parsing Public Suffix List in VBS
Post by palinka » 2020-05-09 20:02
I'm trying to parse the public suffix list here: https://publicsuffix.org/list/public_suffix_list.dat
First I created a powershell script to download the list and output it into a regex string like this:
PubSufRegEx = "^ac$|^com\.ac$|^edu\.ac$|^gov\.ac$|^net\.ac$|^mil\.ac$|^org\.ac$|...REST OF LIST ABRIDGED...|^ad$"
This part works. The string is outputted to public_suffix_list.vbs and then in my VBS test function, I include the file.
The problem I'm having is getting the correct result. I'm split the domain into pieces then test each part against the regex string. This is the part that doesn't work. It seems to match anything. However, if I remove the "function" business and just run the code, then it does work. I'm obviously missing something stupid that I just can't put my finger on.
Here's my vbs test script:
Option Explicit
Function Include(sInstFile)
   Dim f, s, oFSO
   On Error Resume Next
   If oFSO.FileExists(sInstFile) Then
      Set f = oFSO.OpenTextFile(sInstFile)
      s = f.ReadAll
      f.Close
      ExecuteGlobal s
   On Error Goto 0
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
Function CheckDomain(strDomain)
	Dim strRegEx, PubSufRegEx, Match, Matches
	Dim TLDTopLevel, TLDSecondLevel, TLDThirdLevel, TLDFourthLevel, TLDFifthLevel, Domain
	Include("C:\scripts\hmailserver\FWBan\PublicSuffix\public_suffix_list.vbs")
	strRegEx = "[A-Za-z]+$"
	Set Matches = oLookup(strRegEx, strDomain, False)
	For Each Match In Matches
	   TLDTopLevel = LCase(Match.Value)
	strRegEx = "[A-Za-z0-9-]+\.[a-z]+$"
	   TLDSecondLevel = LCase((Split(Match.Value, "."))(0))
	strRegEx = "[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[a-z]+$"
	   TLDThirdLevel = LCase((Split(Match.Value, "."))(0))
	strRegEx = "[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[a-z]+$"
	   TLDFourthLevel = LCase((Split(Match.Value, "."))(0))
	strRegEx = "[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[A-Za-z0-9-]+\.[a-z]+$"
	   TLDFifthLevel = LCase((Split(Match.Value, "."))(0))
	If Lookup(PubSufRegEx, TLDTopLevel) Then
		Domain = TLDSecondLevel & "." & TLDTopLevel
	If Lookup(PubSufRegEx, (TLDSecondLevel & "." & TLDTopLevel)) Then
		Domain = TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	If Lookup(PubSufRegEx, (TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel)) Then
		Domain = TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	If Lookup(PubSufRegEx, (TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel)) Then
		Domain = TLDFifthLevel & "." & TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	CheckDomain = Domain
	Dim strDomain, DomainName
	' strDomain = "pool-72-76-221-125.nwrknj.fios.verizon.net"
	' strDomain = "msnbot-207-46-13-192.search.msn.com"
	' strDomain = "SKNcd-03p13-20.ppp11.odn.ad.jp"
	' strDomain = "v150-95-128-207.a079.g.TyO1.STATIC.cnode.io"
	' strDomain = "230.19.7.186.f.dyn.claro.net.do"
	' strDomain = "hotelbrisamaral.static.gvt.net.br"
	strDomain = "6thLevel.5thLevel.hotelbrisamaral.rs.gov.br"
WScript.Echo CheckDomain(strDomain)
And here is my powershell (working):
.SYNOPSIS
.DESCRIPTION
.FUNCTIONALITY
.NOTES
.EXAMPLE
<#  Set script variables  #>
$URL = "https://publicsuffix.org/list/public_suffix_list.dat"
$PubSufFile = "$PSScriptRoot\public_suffix_list.dat"
$CondensedDatList = "$PSScriptRoot\public_suffix_list.vbs"
<#  Download latest Public Suffix data  #>
$LastDownloadTime = (Get-Item $PubSufFile).LastWriteTime
$HoursSinceLastDownload = [int](New-Timespan $LastDownloadTime).TotalHours
If ($HoursSinceLastDownload -gt 23){
	Try {
		Start-BitsTransfer -Source $URL -Destination $PubSufFile -ErrorAction Stop
	Catch {
		Write-Host "Error downloading Public Suffix List: `n$Error[0]"
		Exit
<#  Read data file and output list  #>
 Get-Content $PubSufFile | Where {((-not([string]::IsNullOrEmpty($_))) -and ($_ -notmatch "^//|^\*|^\!"))} | ForEach {
	Write-Output "^$_$"
} | Out-File $CondensedDatList
<#  Convert list to RegEx pattern  #>
(Get-Content -Path $CondensedDatList) -Replace '$','|' | Set-Content -NoNewline -Path $CondensedDatList
(Get-Content -Path $CondensedDatList) -Replace '\.','\.' | Set-Content -NoNewline -Path $CondensedDatList
(Get-Content -Path $CondensedDatList) -Replace '^','PubSufRegEx = "' | Set-Content -NoNewline -Path $CondensedDatList
(Get-Content -Path $CondensedDatList) -Replace '\|$','' | Set-Content -NoNewline -Path $CondensedDatList
(Get-Content -Path $CondensedDatList) -Replace '$','"' | Set-Content -NoNewline -Path $CondensedDatList
Re: Parsing Public Suffix List in VBS
Post by palinka » 2020-05-09 20:09
This works - it returns the correct result. But no function. What I want is to turn this working thing into a function. Its the same as above except not in "function form".
' Function CheckDomain(strDomain)
	Dim strDomain
	WScript.Echo Domain
	' CheckDomain = Domain
' End Function
Post by palinka » 2020-05-13 03:44
Got it working. I knew it was something really stupid. I DIM'd PubSufRegEx, so it was always blank, therefore EVERYTHING MATCHES! YAY!
Anyway, this could be useful for a few things. I have a use for it.
Option Explicit
   Dim f, s, oFSO
      s = f.ReadAll
      f.Close
      ExecuteGlobal s
   On Error Goto 0
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
	Dim strRegEx, Match, Matches
	Dim SpamDomain
	Set Matches = oLookup(PubSufRegEx, TLDTopLevel, False)
		If Match.Value = TLDTopLevel Then
			SpamDomain = TLDSecondLevel & "." & TLDTopLevel
	Set Matches = oLookup(PubSufRegEx, (TLDSecondLevel & "." & TLDTopLevel), False)
		If Match.Value = TLDSecondLevel & "." & TLDTopLevel Then
			SpamDomain = TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	Set Matches = oLookup(PubSufRegEx, (TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel), False)
		If Match.Value = TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel Then
			SpamDomain = TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	Set Matches = oLookup(PubSufRegEx, (TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel), False)
		If Match.Value = TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel Then
			SpamDomain = TLDFifthLevel & "." & TLDFourthLevel & "." & TLDThirdLevel & "." & TLDSecondLevel & "." & TLDTopLevel
	CheckDomain = SpamDomain
' Test a few EHLOs
Dim strDomain
' strDomain = "pool-72-76-221-125.nwrknj.fios.verizon.net"    ' public suffix domain verizon.net
' strDomain = "msnbot-207-46-13-192.search.msn.com"           ' public suffix domain msn.com
' strDomain = "SKNcd-03p13-20.ppp11.odn.ad.jp"                ' public suffix domain odn.ad.jp
' strDomain = "v150-95-128-207.a079.g.TyO1.STATIC.cnode.io"   ' public suffix domain cnode.io
' strDomain = "230.19.7.186.f.dyn.claro.net.do"               ' public suffix domain claro.net.do
' strDomain = "hotelbrisamaral.static.gvt.net.br"             ' public suffix domain gvt.net.br
strDomain = "6thLevel.5thLevel.hotelbrisamaral.rs.gov.br"     ' public suffix domain hotelbrisamaral.rs.gov.br
' strDomain = "expressomx.pr.gov.br"                          ' public suffix domain expressomx.pr.gov.br
' strDomain = "mail.saude.ma.gov.br"                          ' public suffix domain saude.ma.gov.br
Dim RecordSpamDomain : RecordSpamDomain = CheckDomain(strDomain)
If RecordSpamDomain <> "" Then
	WScript.Echo "Record SpamEHLO: " & strDomain & " as Main Domain: " & Chr(34) & RecordSpamDomain & Chr(34)
	WScript.Echo "Shit's broke, yo!"
Post by palinka » 2020-11-30 06:03
Playing around with this tonight. I changed the vbs to a recursive function so it a) cuts down on the number of lines and b) can test any length of domain.
Option Explicit
   Dim f, s, oFSO
      s = f.ReadAll
      f.Close
      ExecuteGlobal s
   On Error Goto 0
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
Function GetMainDomain(strDomain)
	Dim SpamDomain, TestDomain, DomainParts, a, i, PubSuff
	DomainParts = Split(strDomain,".")
	a = UBound(DomainParts)
	If a > 1 Then
		TestDomain = DomainParts(1)
		For i = 2 to a
			TestDomain = TestDomain & "." & DomainParts(i)
	ElseIf a = 1 Then
		Exit Function
	Set Matches = oLookup(PubSufRegEx, TestDomain, False)
		PubSuff = 1
	If PubSuff <> 1 Then
		GetMainDomain = GetMainDomain(TestDomain)
		GetMainDomain = DomainParts(0) & "." & TestDomain
Dim strDomain
' strDomain = "6thLevel.5thLevel.hotelbrisamaral.rs.gov.br"   ' public suffix domain hotelbrisamaral.rs.gov.br
' strDomain = "foofoo.foofoobarbar"                           ' no public suffix exists
' WScript.Echo GetMainDomain(strDomain)
Dim RecordSpamDomain : RecordSpamDomain = GetMainDomain(strDomain)
' WScript.Echo "RecordSpamDomain: " & RecordSpamDomain
gotspatel
Post by gotspatel » 2020-12-30 09:07
2020-11-30 06:03
Option Explicit
   Dim f, s, oFSO
      s = f.ReadAll
      f.Close
      ExecuteGlobal s
   On Error Goto 0
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
	If a > 1 Then
		For i = 2 to a
	ElseIf a = 1 Then
		Exit Function
		PubSuff = 1
Dim strDomain
Hello Sir,
Trying to implement it,
First got error WScript not defined so DIM WScript, but after that
Getting error
Object required at this line.
Any help please.
By the way this is not included in your hMailServer-Firewall-Ban. Also Implemented it and working fine. Thanks for that wonderful Share. Though not implemented Apache/IIS as no experience in it but atleast got the server secured.
Post by palinka » 2020-12-30 16:14
How are you running it? Are you running it from cscript?
Post by SorenR » 2020-12-30 17:10
gotspatel wrote:
2020-12-30 09:07
Any help please.
You can't do that... EventHandlers.vbs is run in an embedded CScript interpreter. You can only use VBScript commands that do not require a command shell.
gotspatel
Post by gotspatel » 2020-12-30 17:18
2020-12-30 16:14
Yes I tried running it with Eventhandlers.vbs
gotspatel
Post by gotspatel » 2020-12-30 17:19
2020-12-30 17:10
Thank you for the pointer. I learnt it now.
Post by palinka » 2020-12-30 20:37
gotspatel wrote:
2020-12-30 17:18
2020-12-30 16:14
The one posted is just the test script. When i get back to my computer, I'll copy what i use in my eventhandlers.vbs.
Post by palinka » 2020-12-30 22:10
Here's what I have in my eventhandlers.vbs.
Function here:
	Dim TestDomain, DomainParts, a, i, PubSuffMatch
	If a > 1 Then
		For i = 2 to a
	ElseIf a = 1 Then
		Exit Function
		PubSuffMatch = True
	If PubSuffMatch Then
Then you can use it for whatever you want. I use it in my "catchspam" routine.
In Sub OnHelo:
	REM	- Reject on CatchSpam
	Dim spamDomain : spamDomain = GetMainDomain(oClient.HELO)  ' Also can use PTR, which is probably a better method.
	If IsCatchSpam(spamDomain) Then
		Result.Value = 2
		Result.Message = ". 19 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
		' Do whatever else you want to do to SMASH SPAMMERS
"GetMainDomain" is just a means of obtaining the highest level FQDN (without subdomains)
gotspatel
Post by gotspatel » 2020-12-31 07:13
2020-12-30 22:10
Function here:
Many Thanks and Happy new year there
