Hmailserver Forum incorrct operation
Post by jimimaseye » 2017-10-21 16:50
Since some months ago the SELECT ALL feature of
 tag displays no longer works under Firefox and some other browsers.  Instead of selecting the code ready for copy/pasting (as it was designed to and used to) it now simply jumps to the top of the webpage.
Research shows that a fix for this was created under PhpBB v 3.1.7 https://tracker.phpbb.com/browse/PHPBB3-14163
Martin, any chance of updating the forum software to incorporate this fix - it would make life easier for all the contributors.
