Unix style "tail -f" written in VBS.
Post by SorenR » 2019-06-25 13:32
In case someone need this functionality I found this ...
https://stujordan.wordpress.com/2012/09 ... -vbscript/
The download link triggered all the bells and whistles, so I took one for the community and here is the script. :mrgreen:
Remember to include drive and path of the file or it will simply just sit the and do nothing. CPU load wise it appears like it is not there :wink:
'# Name: Tail.vbs
'# Description: Tail a file with follow
'# Version History:
'# 1.0	Stuart Jordan	Script creation
'Grab the path of the file to be tailed from the command line
Set args = WScript.Arguments
If WScript.Arguments.Count <> 1 Then
    WScript.echo vbCrLf
    WScript.echo "------------------------------------------------------------"
    WScript.echo "                   Tail.vbs syntax help                     "
    WScript.echo "You haven't correctly specified the filename to be tailed."
    WScript.echo vbCrLf
    WScript.echo "Syntax:"
    WScript.echo vbCrLf
    WScript.echo vbTab & "cscript /nologo tail.vbs c:\myfolder\myfilename.txt"
    WScript.echo vbCrLf
    WScript.echo "If there are spaces in your folder or filename please"
    WScript.echo "enclose the filename in double quotes"
    WScript.quit
strLongFileName = args.Item(0)
arrArgsLine=Split(strLongFileName,"\")
strDrive=arrArgsLine(0)
If UBound(arrArgsLine)>1 Then
    For i=1 To UBound(arrArgsLine)-1
        strFolder=strFolder & "\\" & arrArgsLine(i)
strFileName=arrArgsLine(UBound(arrArgsLine))
If strDrive = "" Or strFilename = "" Then
    WScript.echo "WARNING: Either the drive or filename was not specified. Please try again."
    WScript.quit
WScript.echo vbCrLf
WScript.echo "----------------------------------------------------------------"
WScript.echo "This is the information that was detected:"
WScript.echo "Full path = " & strLongFileName
WScript.echo "Drive letter = " & strDrive
WScript.echo "File name = " & strFileName
WScript.echo "Folder path = " & strFolder
WScript.echo vbCrLf
WScript.echo vbCrLf
'This is the interval with which the WMI events are checked
intInterval = "2"
strComputer = "."
intLastRunLineinFile=get_NumLinesInFile(strLongFileName)
Set objWMIService = GetObject( "winmgmts:" & _
"{impersonationLevel=impersonate}!\\" & _
strComputer & "\root\cimv2" )
If Len(strFolder) Then
    strQuery =  _
    "Select * From __InstanceOperationEvent" _
    & " Within " & intInterval _
    & " Where Targetinstance Isa 'CIM_DataFile'" _
    & " And TargetInstance.Drive='" & strDrive & "'" _
    & " And TargetInstance.Path='" & strFolder & "'"
    strQuery =  _
    & " And TargetInstance.Drive='" & strDrive & "\\'"
Set colEvents = objWMIService. ExecNotificationQuery (strQuery)
WScript.Echo "Monitoring events...[Ctl-C] to end"
Do
    Set objEvent = colEvents.NextEvent()
    Set objTargetInst = objEvent.TargetInstance
    Select Case objEvent.Path_.Class
        Case "__InstanceDeletionEvent"
        If 0=StrComp(objTargetInst.Name,strLongFileName,1) Then
            WScript.echo objTargetInst.Name & " has been deleted. Exiting."
            WScript.quit
        Case "__InstanceModificationEvent"
            tailFile(objTargetInst.Name)
    End Select
Loop
Function tailFile(strFileName)
    Const FOR_READING = 1
    Dim intCurrLine,intNewNumLines
    Set objFSO   = WScript.CreateObject("Scripting.FileSystemObject")
    Set objFile = objFSO.OpenTextFile(strFileName, FOR_READING)
    intNewNumLines=0
    intCurrLine=0
    Do Until objFile.AtEndOfStream
        intCurrLine=intCurrLine+1
        If intCurrLine <= intLastRunLineinFile Then
            objFile.skipline
            WScript.echo objFile.ReadLine
            intNewNumLines=intNewNumLines+1
    Loop
    If intCurrLine < intLastRunLineinFile Then
        'The number of lines on this scan was less than the last run so resetting the num lines in file
        intLastRunLineinFile = intCurrLine
        intLastRunLineinFile=intLastRunLineinFile+intNewNumLines
    'wscript.echo "(" & intLastRunLineinFile & ")"
    objFile.close
Function get_NumLinesInFile(strFileName)
    intTotalNumLines=0
        objFile.skipline
        intTotalNumLines=intTotalNumLines+1
    Loop
    objFile.close
    get_NumLinesInFile=intTotalNumLines
Re: Unix style "tail -f" written in VBS.
Post by SorenR » 2019-06-25 17:19
How to always use the current logfile on startup.
Delete this ...
    WScript.echo vbCrLf
    WScript.echo vbCrLf
    WScript.echo vbCrLf
    WScript.echo vbCrLf
    WScript.quit
And replace with this ...
Dim oLog : Set oLog = CreateObject("hMailServer.Logging")
strLongFileName = oLog.CurrentDefaultLog
Set oLog = Nothing
Post by jimimaseye » 2019-06-25 21:24
In addition: for those looking for a non vbs tailing program, i and some others also use this: https://www.baremetalsoft.com/baretail/ (free version is adequate).
Now you have choices.
Post by SorenR » 2019-06-25 22:26
2019-06-25 21:24
I think you missed the obvious. It's not for eyeballing the log as it happens - I can use hMailAdmin for that ...
It's VBScript, it can monitor hMailServer log files in real-time and you can interact with hMailServer based on what is logged. Banning on failed logons or send a mail to admin if some debug event occurs.
The bonus is that you are not slowing the server down.
Post by jimimaseye » 2019-06-25 23:27
2019-06-25 22:26
Indeed. Plenty of options and good stuff. (I simply posted the other for users who were looking for read only (tail type) thingy.)
Post by palinka » 2019-06-26 00:09
Could this be used to check if multiple rejections from the same IP within n seconds?
For example, if the same IP gets rejected by spamhaus 5 times within 30 seconds: I want to autoban.
Post by mattg » 2019-06-26 00:59
I think that is where it is headed...
I can't wait to get some time to play, could possibly read the log in real time from eventhandlers.vbs, and then create some AutoBans. Currently I parse the log every five minutes with a scheduled task...
Post by SorenR » 2019-06-26 07:59
2019-06-26 00:09
That is what my IDS code does, sort of...
But yes, that was the idea.
Post by SorenR » 2019-06-26 08:22
2019-06-26 00:59
Not "could"... "is" reading the log in real-time. It sets a 2 second event timer in WMI so in any case log data is max 2 seconds "old".
I'm working on the basic set-up with switching logfile after midnight and making it more "modulized" for ease of programming.
I want it to be able to monitor the server 24/7 or easily used as a one-off to monitor for any event/logon and send a mail to admin.
Post by palinka » 2019-06-26 11:42
2019-06-26 07:59
2019-06-26 00:09
Right, but not in real time, correct? The scheduled task does the banning, i thought. I'll have to look at it again.
Post by SorenR » 2019-06-26 13:11
Proof-of-Concept code.
1: Hardcoded to look for hmailserver_<date>.log via COM API.
2: Added "__InstanceCreationEvent" Case from WMI ExecNotificationQuery to capture new logfile at midnight.
3: Will send email to postmaster@acme.inc (feel free to change) if mail arrive to unknown user.
Run with cscript /nologo log_tail.vbs
Option Explicit
'********** Configuration        **********
'   COM authentication
Private Const PASSWORD = "VerySecretPassword"
'   Misc. settings
Private Const intInterval = "2" '   Event trigger interval in seconds.
Private Const strComputer = "." '   Nodename/Computer name
Private Const FOR_READING = 1
    Dim intCurrLine, intNewNumLines, strReadLine, arrReadLine
    Dim oFSO, oFile
    Set oFSO = WScript.CreateObject("Scripting.FileSystemObject")
    Set oFile = oFSO.OpenTextFile(strFileName, FOR_READING)
    intNewNumLines = 0
    intCurrLine = 0
    Do Until oFile.AtEndOfStream
        intCurrLine = intCurrLine + 1
            oFile.skipline
            '    THIS IS WHERE THE FUN BEGINS ==>
            strReadLine = oFile.ReadLine
            WScript.echo strReadLine
            If (InStr(1, strReadLine, "SENT: 550 Unknown user", 1) > 0) Then
                    .AddRecipient "Postmaster", "postmaster@acme.inc"
                    .FromAddress = "postmaster@acme.inc"
                    .HeaderValue("To") = Chr(34) & "Postmaster" & Chr(34) & " <postmaster@acme.inc>"
                    .HeaderValue("From") = Chr(34) & "Postmaster" & Chr(34) & " <postmaster@acme.inc>"
                    .Subject = "Mail to unknown user"
                    .Body = strReadLine
                    .Save
            '    ==> THIS IS WHERE THE FUN ENDS
            intNewNumLines = intNewNumLines + 1
    Loop
        '   The number of lines on this scan was less than the last run so resetting the num lines in file
        intLastRunLineinFile = intLastRunLineinFile + intNewNumLines
    oFile.close
    Set oFile = Nothing
    Set oFSO = Nothing
    Dim intTotalNumLines
    Dim oFSO, oFile
    intTotalNumLines = 0
        oFile.skipline
        intTotalNumLines = intTotalNumLines + 1
    Loop
    oFile.close
    Set oFile = Nothing
    Set oFSO = Nothing
    get_NumLinesInFile = intTotalNumLines
Function get_DefaultLogFileName(stdDrive, strFolder, strFileName)
    Dim oLog, i, arrArgsLine
    get_DefaultLogFileName = oLog.CurrentDefaultLog
    Set oLog = Nothing
    arrArgsLine = Split(get_DefaultLogFileName, "\")
    strDrive = arrArgsLine(0)
    If UBound(arrArgsLine) > 1 Then
        For i = 1 To UBound(arrArgsLine)-1
            strFolder = strFolder & "\\" & arrArgsLine(i)
    strFileName = arrArgsLine(UBound(arrArgsLine))
'********** Main Code        **********
Dim strLongFileName, strDrive, strFolder, strFileName, strQuery, intLastRunLineinFile, colEvents
Dim oWMIService, oEvent, oTargetInst
Do
    '   Read logfile
    strLongFileName = get_DefaultLogFileName(strDrive, strFolder, strFileName)
    intLastRunLineinFile = get_NumLinesInFile(strLongFileName)
    '   Build interface to WMI
    strQuery = "Select * From __InstanceOperationEvent Within " & intInterval & _
               " Where Targetinstance Isa 'CIM_DataFile' And TargetInstance.Drive='" & strDrive & _
               "' And TargetInstance.Path='" & strFolder & "'"
    Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
    Set colEvents = oWMIService.ExecNotificationQuery(strQuery)
    '   Event management
    Do
        Set oEvent = colEvents.NextEvent()
        Set oTargetInst = oEvent.TargetInstance
        Select Case oEvent.Path_.Class
            If 0 = StrComp(oTargetInst.Name, strLongFileName, 1) Then
                WScript.echo oTargetInst.Name & " has been deleted. Exiting."
                WScript.quit
                tailFile(oTargetInst.Name)
            Case "__InstanceCreationEvent"
            If 0 = StrComp(Left(oTargetInst.Name, 12), Left(strLongFileName, 12), 1 ) Then
                WScript.echo oTargetInst.Name & " has been created. Loading new logfile."
            	 Exit Do
        End Select
    Loop
Loop
WScript.quit
Any further postings should be done in the Scripting forum. Yes?
https://www.hmailserver.com/forum/viewt ... 68#p212968
