hMailServer 5.7
glenluo
Re: hMailServer 5.7
Post by glenluo » 2019-09-06 13:38
I think i got the answer here.
https://www.spamhaus.org/faq/section/Spamhaus%20DBL#330
If hMailserver can check return result matching: 127.0.1.X ,then such issue never happen.
Re: hMailServer 5.7
Post by mattg » 2019-09-07 09:11
SURBL works fine for me for
multi.surbl.org
uribl.spameatingmonkey.net
It is just not working for dbl.spamhaus.org
Re: hMailServer 5.7
Post by palinka » 2019-09-15 14:52
2019-08-26 23:39
Please wait until it is a BETA at least - it is currently very much still ALPHA
But yes just that.
HOWEVER I had to track down the 64 bit libMySQL.dll manually, (this was flagged as to-fix in the hMailserver 5.7 builds - don't know if that is done yet), which also required me to update my MySQL to the latest of the installed version
Where did you find this? And will it work with Maria DB? Dravion's answer was surely intentionally vague. But I'm willing to test it to find out.
Re: hMailServer 5.7
Post by mattg » 2019-09-15 23:38
I downloaded a MYSQL.zip (for my version) and extracted just this single file
Re: hMailServer 5.7
Post by palinka » 2019-09-16 16:14
Aha.. I was looking at the wrong downloads. Got it.
Since you pointed me in the right direction, I instead went to look for a zip install for my version of MariaDB, which I found here: https://downloads.mariadb.com/MariaDB/
I'm running xampp. There is a text file at the root of the install that contains a listing of components with their versions.
Then extracted libmysql.dll, then upgraded to 5.7, then replaced the existing libmysql.dll with the new MariaDB one and voila. No errors yet (less than 1 hour running), one test email was successful, my scripts using OnHELO and OnClientLogon are working without any modification. Life is good. Will update later if any issues.
Now, maybe a stupid question, but I have not done anything at all with ODBC connector and yet my database related scripts seem to be running OK. I remember a hassle of making sure the connector was a 32 bit version. Is that anything to worry about?
Re: hMailServer 5.7
Post by mattg » 2019-09-17 00:17
You haven't changed the database, so the scripts should still work fine.
Whatever script engine you use must be only 32 bit for you to need the 32 bit ODBC connector to use your scripts. From memory VBS is 32 bit, but VB.NET is 64 bit
Re: hMailServer 5.7
Post by palinka » 2019-09-17 00:29
That makes sense. Thanks. Since everything is working, I guess I don't need to change anything.
Re: hMailServer 5.7
Post by mattg » 2019-09-17 01:16
Welcome to the bleeding edge
Re: hMailServer 5.7
Post by mattg » 2019-09-17 04:37
Is IMAP SASL new?
Re: hMailServer 5.7
Post by jimimaseye » 2019-09-17 08:55
2019-09-17 04:37
Is IMAP SASL new?
I believe Martin has included it in 5.7.
Re: hMailServer 5.7
Post by mattg » 2019-09-17 09:08
Do you know anything about the settings, or use cases?
Re: hMailServer 5.7
Post by jimimaseye » 2019-09-17 09:24
Not any more. I had to Google when i first saw it a couple of years ago.
hmbaer
Re: hMailServer 5.7
Post by hmbaer » 2019-09-26 06:47
When will hMailServer 5.7 be public?
If i will create a new hMailServer-installation today with Version 5.6.7 (Build 2425): which database should i use to be best prepared to upgrade to future versions? Thank you.
Re: hMailServer 5.7
Post by mattg » 2019-09-26 07:39
Any database you like, but NOT The built in one if this is going to be anything but a project
MS SQL Express is free to download
MS SQL other editions cost $ but work well
MariaDB
MySQL
PostgreSQL
are all free and open source
Most of us use either MySQL or MariaDB (MariaDB was a fork from MySQL)
And 5.7 is public, just still officially APLHA
I've been using live for over a month as have a few others
You should wait until it is BETA, but don't know when that will be
Alpha is here >> https://build.hmailserver.com/repositor ... 86-x64.exe
Re: hMailServer 5.7
Post by mattg » 2019-10-11 11:03
Just did this suite of tests
https://www.immuniweb.com/ssl/
I scored an A+ which is awesome
I did pass PCI DSS
I didn't get HIPAA or NIST passes though because I don't have OCSP stapling
Also didn't get perfect in the 'best practices' section due to 'server does not have a cipher preference'
I run only TLSv1.2 and TLSv1.3 with my cipher suite being 'HIGH:!TLSv1:!SSLv3;', and I have a let's encypt cert
How can I improve? Is that an OpenSSL thing or a hMailserver thing
I see that I can ask letsencrypt for a --must-staple tag on the certificate, but it only works (in apache/ngnix etc if stapling is enabled)
Perhaps this could also be because I don't force startTLS on port 25, but I don't imagine that I could do that
tolberjj
Re: hMailServer 5.7
Post by tolberjj » 2019-10-16 02:12
I'd like to propose a small change. I just installed 5.7 and it installs and launches with this tweak so far. 5.6.7 didn't work with the same change.
The issue is that MySQL 8 with the innodb cluster requires a primary key on every table, and hm_dbversion doesn't have one currently in the scripts.
I modified C:\Program Files\hMailServer\DBScripts\CreateTablesMYSQL.sql to the following:
Line 193 (added definition for dbversionid):
create table hm_dbversion
dbversionid int auto_increment not null, primary key(`dbversionid`), unique(`dbversionid`),
value int not null
) DEFAULT CHARSET=utf8;
Line 772 (specified field):
insert into hm_dbversion (value) values (5700);
Thanks for all of your work. We have sent a lot of email (ethically) for many years with previous versions and I am excited to move forward with a 64 bit version in our testing.
nitro
Re: hMailServer 5.7
Post by nitro » 2019-10-16 10:20
Good morning, I have updated my staging version with the latest compiled version 5.7 B-2490. I could update just by clicking on the installer, completely transparent for me. My database runs on MSSQL Express 2014. Everything seems to be working without any problem. I only report it as feedback from the alpha version.
Thanks to Martin for his work.
Mar_ty
Re: hMailServer 5.7
Post by Mar_ty » 2019-10-17 16:08
Just upgraded to hmailserver 5.7-B2490 from 5.7.0 64 Bit (LTS). Installed with no problems. Passed PCI DSS, HIPAA, NIST and Best Practices and Analysis tests.
Thank you Martin for your excellent work.
"Too much of anything is Bad, But TOO MUCH GOOD WHISKEY IS BARELY ENOUGH"
- Mark Twain
hMailServer 5.7 -B2490 64-Bit
Re: hMailServer 5.7
Post by mattg » 2019-10-17 16:48
How did you pass HIPAA and NIST
What do you do differently than me?
What is your cipher suite?
Mar_ty
Re: hMailServer 5.7
Post by Mar_ty » 2019-10-18 05:45
2019-10-17 16:48
I followed the suggestions from the first test report I received from ImmuniWeb.
Tested again and you can see the results in my last post.
- Mark Twain
Re: hMailServer 5.7
Post by mattg » 2019-10-18 06:11
can you please share your current cipher suite
mine is
HIGH:!TLSv1:!SSLv3;
and I only allow TLSv1.2 and TLSv1.3
Also how did you achieve 'OCSP stapling'
X509 CERTIFICATES ARE IN VERSION 3
All the X509 certificates provided by the server are in version 3.Good configuration
SERVER DOES NOT SUPPORT OCSP STAPLING
The server does not support OCSP stapling for its RSA certificate. Its support allows better verification of the certificate validation status.Non-compliant with HIPAA guidance
SUPPORTED PROTOCOLS
List of all SSL/TLS protocols supported by the server:
TLSv1.2Good configuration
TLSv1.3Information
SUPPORTED CIPHERS
List of all cipher suites supported by the server:
TLSv1.3
TLS_CHACHA20_POLY1305_SHA256Information
TLS_AES_256_GCM_SHA384Information
TLS_AES_128_GCM_SHA256Information
TLSv1.2
TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256Non-compliant with HIPAA guidance
TLS_DHE_RSA_WITH_CHACHA20_POLY1305_SHA256Non-compliant with HIPAA guidance
TLS_RSA_WITH_AES_128_CBC_SHA256Good configuration
TLS_RSA_WITH_AES_256_CBC_SHA256Good configuration
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256Good configuration
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256Good configuration
TLS_RSA_WITH_AES_128_GCM_SHA256Good configuration
TLS_RSA_WITH_AES_256_GCM_SHA384Good configuration
TLS_DHE_RSA_WITH_AES_128_GCM_SHA256Good configuration
TLS_DHE_RSA_WITH_AES_256_GCM_SHA384Good configuration
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256Good configuration
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384Good configuration
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256Good configuration
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384Good configuration
TLS_DHE_RSA_WITH_AES_256_CCM_8Non-compliant with HIPAA guidance
TLS_DHE_RSA_WITH_AES_256_CCMNon-compliant with HIPAA guidance
TLS_DHE_RSA_WITH_AES_128_CCM_8Non-compliant with HIPAA guidance
TLS_DHE_RSA_WITH_AES_128_CCMNon-compliant with HIPAA guidance
TLS_RSA_WITH_AES_256_CCM_8Non-compliant with HIPAA guidance
TLS_RSA_WITH_AES_256_CCMNon-compliant with HIPAA guidance
TLS_RSA_WITH_AES_128_CCM_8Non-compliant with HIPAA guidance
TLS_RSA_WITH_AES_128_CCMNon-compliant with HIPAA guidance
DIFFIE-HELLMAN PARAMETER SIZE
Diffie-Hellman parameter size: 2048 bitsGood configuration
SUPPORTED ELLIPTIC CURVES
List of all elliptic curves supported by the server:
P-256 (prime256v1) (256 bits)Good configuration
EC_POINT_FORMAT EXTENSION
The server supports the EC_POINT_FORMAT TLS extension.Good configuration
Re: hMailServer 5.7
Post by Dravion » 2019-10-18 07:09
It's hard to see for me on which website you running your Test, can you just copy and paste it into your next reply?
For Webservers i use Qualys SSL testing, but i wasnt aware there is sometibg availabe for Mailservers to :)
Re: hMailServer 5.7
Post by mattg » 2019-10-18 07:55
2019-10-11 11:03
Put a ':25' at the end and it will check mail server on port 25
Re: hMailServer 5.7
Post by palinka » 2019-10-18 12:13
I scored an F, due to not being able to connect. My firewall ban blocked their IPs long before trying the test due to being listed by spamhaus. I could unblock them easy enough, but what's up with the spamhaus listing?
Re: hMailServer 5.7
Post by palinka » 2019-10-18 13:31
RESULTS OF LOOKUP
192.175.111.241 is listed
This IP address was detected and listed 17 times in the past 28 days, and 3 times in the past 24 hours. The most recent detection was at Fri Oct 18 03:25:00 2019 UTC +/- 5 minutes
Your IP address (192.175.111.241) is sending email in such a way as to strongly indicate that the IP itself is operating somes sort of spam package.
This IP is impersonating (via SMTP HELO command) being a domain we know it _cannot_ be. No properly configured mail server does this under any circumstances.
If the IP is a NAT firewall, we strongly recommend configuring the firewall to prevent machines on your network connecting to the Internet on port 25, except for machines that are supposed to be mail servers.
SOFTWARE NOTES:
NEW: If you are using a TLS scanner or some other mechanism to check TLS settings of mail servers based on openssl, change the HELO value to something reasonable (the reverse-DNS of your IP address is usually a good idea) instead of the default in the openssl command line.
Ok that makes sense. Still, it's an easy fix. Why don't they just fix it?
Re: hMailServer 5.7
Post by SorenR » 2019-10-18 13:52
2019-10-18 13:31
RESULTS OF LOOKUP
SOFTWARE NOTES:
RFC tells you to use your FQDN in your greeting. That is actually what they are telling you.
Anyways, it's an easy fix, change the MX for your domain to the FQDN your ISP set on your connection and use the same FQDN in your greeting.
As long as FQDN = PTR = HELO/EHLO then all is fine. It does not have to be your domain. (It's like a c/o postal address ;-) )
Anyways, my server never finished the test - all test sites ended up in my AutoBan :oops:
" I will initiate self-destruct. " — IG-11.
Mar_ty
Re: hMailServer 5.7
Post by Mar_ty » 2019-10-18 14:21
This is the cipher suite I use. It passes without OCSP stapling. I have SPF and DMARC records for server security hardening.
SUPPORTED CIPHERS
TLSv1.3
Information
Information
Information
TLSv1.2
SUPPORTED PROTOCOLS
TLSv1.2
Good configuration
TLSv1.3
Information
- Mark Twain
Re: hMailServer 5.7
Post by palinka » 2019-10-18 17:46
2019-10-18 13:52
2019-10-18 13:31
RESULTS OF LOOKUP
SOFTWARE NOTES:
The HELOs immuniweb use are mail.example.com and openssl.client.net - every one of them got hit by Spamhaus. Client.net exists but its not part of immuniweb and example.com has no A record at all. Probably reserved or something. If not, I'll grab it today. :mrgreen:
Edit -
Example domains
As described in RFC 2606 and RFC 6761, a number of domains such as example.com and example.org are maintained for documentation purposes. These domains may be used as illustrative examples in documents without prior coordination with us. They are not available for registration or transfer.
Re: hMailServer 5.7
Post by SorenR » 2019-10-18 22:00
2019-10-18 17:46
Edit -
Example domains
Huh ???
1692		"2019-10-18 13:26:50.878"	"--- Connect ---	70.38.27.252    	25 	                	f10.immuniweb.com"
3160		"2019-10-18 13:26:50.878"	"--- Connect ---	64.15.129.117   	25 	                	f18.immuniweb.com"
1692		"2019-10-18 13:26:50.878"	"IDS Add        	70.38.27.252"
3160		"2019-10-18 13:26:50.878"	"IDS Add        	64.15.129.117"
148		"2019-10-18 13:27:00.253"	"--- Connect ---	64.15.129.117   	25 	                	f18.immuniweb.com"
148		"2019-10-18 13:27:00.253"	"IDS Add        	64.15.129.117"
1720		"2019-10-18 13:27:10.437"	"--- Connect ---	64.15.129.102   	25 	                	f03.immuniweb.com"
1720		"2019-10-18 13:27:10.453"	"IDS Add        	64.15.129.102"
3448		"2019-10-18 13:27:20.609"	"--- Connect ---	72.55.136.156   	25 	                	f06.immuniweb.com"
3448		"2019-10-18 13:27:20.609"	"IDS Add        	72.55.136.156"
148		"2019-10-18 13:27:31.328"	"--- Connect ---	64.15.129.117   	25 	                	f18.immuniweb.com"
148		"2019-10-18 13:27:31.328"	"IDS Add        	64.15.129.117"
3448		"2019-10-18 13:27:40.484"	"--- Connect ---	192.175.111.228 	25 	                	f01.immuniweb.com"
3448		"2019-10-18 13:27:40.500"	"IDS Add        	192.175.111.228"
1720		"2019-10-18 13:27:50.671"	"--- Connect ---	192.175.111.233 	25 	                	f12.immuniweb.com"
1720		"2019-10-18 13:27:50.671"	"IDS Add        	192.175.111.233"
1692		"2019-10-18 13:28:00.671"	"--- Connect ---	64.15.129.119   	25 	                	f20.immuniweb.com"
1692		"2019-10-18 13:28:00.687"	"IDS Add        	64.15.129.119"
3160		"2019-10-18 13:28:10.671"	"--- Connect ---	192.175.111.240 	25 	                	f13.immuniweb.com"
3160		"2019-10-18 13:28:10.671"	"IDS Add        	192.175.111.240"
148		"2019-10-18 13:28:21.390"	"--- Connect ---	64.15.129.119   	25 	                	f20.immuniweb.com"
148		"2019-10-18 13:28:21.390"	"IDS Add        	64.15.129.119"
3160		"2019-10-18 13:28:30.437"	"--- Connect ---	192.175.111.233 	25 	                	f12.immuniweb.com"
3160		"2019-10-18 13:28:30.453"	"IDS Add        	192.175.111.233"
3448		"2019-10-18 13:28:40.859"	"--- Connect ---	70.38.27.248    	25 	                	f05.immuniweb.com"
3448		"2019-10-18 13:28:40.875"	"IDS Add        	70.38.27.248"
1692		"2019-10-18 13:28:50.500"	"--- Connect ---	64.15.129.119   	25 	                	f20.immuniweb.com"
1692		"2019-10-18 13:28:50.500"	"IDS Add        	64.15.129.119"
1720		"2019-10-18 13:28:53.156"	"--- Connect ---	47.254.178.255  	25"
1720		"2019-10-18 13:28:53.156"	"IDS Add        	47.254.178.255"
1720		"2019-10-18 13:28:53.218"	"SnowShoe       	47.254.178.255"
1720		"2019-10-18 13:28:54.703"	"DISCONNECT     	47.254.178.255"
1720		"2019-10-18 13:29:00.703"	"--- Connect ---	64.15.129.116   	25 	                	f17.immuniweb.com"
1720		"2019-10-18 13:29:00.703"	"IDS Add        	64.15.129.116"
3160		"2019-10-18 13:29:10.484"	"--- Connect ---	72.55.136.156   	25 	                	f06.immuniweb.com"
3160		"2019-10-18 13:29:10.484"	"IDS Add        	72.55.136.156"
148		"2019-10-18 13:29:20.984"	"--- Connect ---	192.175.111.231 	25 	                	f11.immuniweb.com"
148		"2019-10-18 13:29:20.984"	"IDS Add        	192.175.111.231"
3160		"2019-10-18 13:29:30.562"	"--- Connect ---	64.15.129.117   	25 	                	f18.immuniweb.com"
3160		"2019-10-18 13:29:30.562"	"IDS Add        	64.15.129.117"
1692		"2019-10-18 13:29:40.546"	"--- Connect ---	192.175.111.240 	25 	                	f13.immuniweb.com"
1692		"2019-10-18 13:29:40.546"	"IDS Add        	192.175.111.240"
3448		"2019-10-18 13:29:50.562"	"--- Connect ---	64.15.129.117   	25 	                	f18.immuniweb.com"
3448		"2019-10-18 13:29:50.562"	"IDS Add        	64.15.129.117"
2900		"2019-10-18 13:30:00.496"	"IDS BAN        	64.15.129.117"
1720		"2019-10-18 13:30:00.812"	"--- Connect ---	64.15.129.106   	25 	                	f04.immuniweb.com"
1720		"2019-10-18 13:30:00.812"	"IDS Add        	64.15.129.106"
1720		"2019-10-18 13:30:11.777"	"--- Connect ---	192.175.111.252 	25 	                	f08.immuniweb.com"
1720		"2019-10-18 13:30:11.777"	"IDS Add        	192.175.111.252"
148		"2019-10-18 13:30:20.843"	"--- Connect ---	64.15.129.118   	25 	                	f19.immuniweb.com"
148		"2019-10-18 13:30:20.843"	"IDS Add        	64.15.129.118"
3160		"2019-10-18 13:30:30.636"	"--- Connect ---	72.55.136.156   	25 	                	f06.immuniweb.com"
3160		"2019-10-18 13:30:30.636"	"IDS Add        	72.55.136.156"
3448		"2019-10-18 13:30:40.605"	"--- Connect ---	70.38.27.248    	25 	                	f05.immuniweb.com"
3448		"2019-10-18 13:30:40.621"	"IDS Add        	70.38.27.248"
1692		"2019-10-18 13:30:50.699"	"--- Connect ---	72.55.136.156   	25 	                	f06.immuniweb.com"
1692		"2019-10-18 13:30:50.699"	"IDS Add        	72.55.136.156"
3584		"2019-10-18 13:31:00.371"	"IDS BAN        	72.55.136.156"
148		"2019-10-18 13:31:01.199"	"--- Connect ---	192.175.111.240 	25 	                	f13.immuniweb.com"
148		"2019-10-18 13:31:01.199"	"IDS Add        	192.175.111.240"
3448		"2019-10-18 13:31:10.886"	"--- Connect ---	72.55.136.199   	25 	                	f07.immuniweb.com"
3448		"2019-10-18 13:31:10.902"	"IDS Add        	72.55.136.199"
1720		"2019-10-18 13:31:20.667"	"--- Connect ---	64.15.129.102   	25 	                	f03.immuniweb.com"
1720		"2019-10-18 13:31:20.667"	"IDS Add        	64.15.129.102"
1720		"2019-10-18 13:37:35.066"	"--- Connect ---	70.38.27.252    	465	                	f10.immuniweb.com"
3448		"2019-10-18 13:37:35.082"	"--- Connect ---	72.55.136.199   	465	                	f07.immuniweb.com"
1692		"2019-10-18 13:37:35.097"	"--- Connect ---	72.55.136.156   	465	                	f06.immuniweb.com"
3160		"2019-10-18 13:37:35.097"	"--- Connect ---	192.175.111.228 	465	                	f01.immuniweb.com"
1720		"2019-10-18 13:37:35.191"	"GEOBlock       	70.38.27.252    	   	                	SMTPS"
3448		"2019-10-18 13:37:35.191"	"GEOBlock       	72.55.136.199   	   	                	SMTPS"
1692		"2019-10-18 13:37:35.207"	"GEOBlock       	72.55.136.156   	   	                	SMTPS"
148		"2019-10-18 13:37:35.332"	"--- Connect ---	192.175.111.229 	465	                	f02.immuniweb.com"
148		"2019-10-18 13:37:35.394"	"GEOBlock       	192.175.111.229 	   	                	SMTPS"
148		"2019-10-18 13:37:37.300"	"DISCONNECT     	192.175.111.229"
1692		"2019-10-18 13:37:37.300"	"DISCONNECT     	72.55.136.156"
1720		"2019-10-18 13:37:37.300"	"DISCONNECT     	70.38.27.252"
3448		"2019-10-18 13:37:37.300"	"DISCONNECT     	72.55.136.199"
3160		"2019-10-18 13:37:37.316"	"GEOBlock       	192.175.111.228 	   	                	SMTPS"
148		"2019-10-18 13:37:37.332"	"--- Connect ---	192.175.111.231 	465	                	f11.immuniweb.com"
148		"2019-10-18 13:37:37.363"	"GEOBlock       	192.175.111.231 	   	                	SMTPS"
1692		"2019-10-18 13:37:37.582"	"--- Connect ---	192.175.111.242 	25 	                	f15.immuniweb.com"
1692		"2019-10-18 13:37:37.582"	"IDS Add        	192.175.111.242"
3448		"2019-10-18 13:37:37.613"	"--- Connect ---	192.175.111.241 	25 	                	f14.immuniweb.com"
3448		"2019-10-18 13:37:37.613"	"IDS Add        	192.175.111.241"
1720		"2019-10-18 13:37:38.925"	"--- Connect ---	192.175.111.243 	25 	                	f16.immuniweb.com"
1720		"2019-10-18 13:37:38.925"	"IDS Add        	192.175.111.243"
3160		"2019-10-18 13:37:49.660"	"DISCONNECT     	192.175.111.228"
3448		"2019-10-18 13:37:49.660"	"--- Connect ---	192.175.111.252 	25 	                	f08.immuniweb.com"
148		"2019-10-18 13:37:49.675"	"DISCONNECT     	192.175.111.231"
1720		"2019-10-18 13:37:49.675"	"--- Connect ---	64.15.129.106   	25 	                	f04.immuniweb.com"
1692		"2019-10-18 13:37:49.675"	"--- Connect ---	64.15.129.102   	25 	                	f03.immuniweb.com"
3448		"2019-10-18 13:37:49.675"	"IDS Add        	192.175.111.252"
1720		"2019-10-18 13:37:49.675"	"IDS Add        	64.15.129.106"
1692		"2019-10-18 13:37:49.675"	"IDS Add        	64.15.129.102"
148		"2019-10-18 13:37:49.785"	"WList HELO     	192.175.111.242 	   	                	f11.immuniweb.com"
148		"2019-10-18 13:37:49.800"	"WList HELO     	192.175.111.243 	   	                	f11.immuniweb.com"
3160		"2019-10-18 13:38:00.691"	"WList HELO     	192.175.111.241 	   	                	f11.immuniweb.com"
148		"2019-10-18 13:38:00.832"	"WList HELO     	64.15.129.102   	   	                	f11.immuniweb.com"
3448		"2019-10-18 13:38:00.832"	"WList HELO     	192.175.111.252 	   	                	f11.immuniweb.com"
1720		"2019-10-18 13:38:02.316"	"WList HELO     	64.15.129.106   	   	                	f11.immuniweb.com"
Re: hMailServer 5.7
Post by palinka » 2019-10-18 23:25
2019-10-18 22:00
2019-10-18 17:46
Edit -
Example domains
Huh ???
HELO = oClient.HELO grabbed from OnHELO. Is there another?
That also explains the note from Spamhaus:
SOFTWARE NOTES:
Re: hMailServer 5.7
Post by palinka » 2019-10-18 23:35
2019-10-18 22:00
Huh ???
Never mind. I see what you're doing. Very sneaky. :) You're using PTR lookup, not HELO. I tested one of their IPs and it returned what you'd shown.
C:\Users\palinka>nslookup 70.38.27.252
Server:  resolver1.opendns.com
Address:  208.67.222.222
Address:  70.38.27.252
But that's not what they present for HELO on these tests, or scanning or whatever they were doing that got them PERMANENTLY FIREWALL BANNED!!!!!! :mrgreen:
Re: hMailServer 5.7
Post by SorenR » 2019-10-19 00:32
2019-10-18 23:35
2019-10-18 22:00
Huh ???
Last 6 lines in that log are HELO's. I had to whitelist HELO = (.*\.immuniweb\.com) to allow it to test but it eventually failed on the GEOIP for IMAPS and SMTPS. I have not edited the log, it is one section cut'n paste.
I have no trace of the HELO's you saw in any of my logs.
Re: hMailServer 5.7
Post by palinka » 2019-10-19 01:29
2019-10-19 00:32
Weird. That's what i got for oClient.HELO. The HELOs didn't trip spamhaus - the IPs did.
Re: hMailServer 5.7
Post by SorenR » 2019-10-19 01:41
2019-10-19 01:29
2019-10-19 00:32
They didnt get that far on my server since I don't do StartTLS. Anyways, I have "DNSBLChecksAfterMailFrom=0" in my .ini so RBL's are not checked until after "RECEIVED: RCPT TO:".
Re: hMailServer 5.7
Post by mattg » 2019-10-19 02:59
Dravion wrote:
2019-10-18 07:09
I do these fairly routinely
Mailserver
https://dkimvalidator.com/
https://ssl-tools.net/mailservers
https://mecsa.jrc.ec.europa.eu/en/
https://luxsci.com/smtp-tls-checker
Website
https://observatory.mozilla.org/
https://www.ssllabs.com/ssltest/
I find the Mozilla one very harsh, but the others I mostly do well with
Re: hMailServer 5.7
Post by mattg » 2019-10-19 03:03
Changed my cipher suite in hMailserver to this and got an A+, with green for PCI, HIPAA and NIST
TLS13-AES-256-GCM-SHA384:TLS13-AES-128-GCM-SHA256:TLS13-AES-128-CCM-8-SHA256:TLS13-AES-128-CCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA38:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA384:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256
:mrgreen: :mrgreen:
Re: hMailServer 5.7
Post by mattg » 2019-10-19 06:04
Also found this statement today
https://blog.pcisecuritystandards.org/a ... -early-tls
If you have an EFTPOS machine on your network, or accept payments on your website, you need to have met this (in most countries)
30 June 2018 is the deadline for disabling SSL/early TLS and implementing a more secure encryption protocol – TLS 1.1 or higher (TLS v1.2 is strongly encouraged) in order to meet the PCI Data Security Standard (PCI DSS) for safeguarding payment data.
shar0119
Re: hMailServer 5.7
Post by shar0119 » 2019-10-20 21:06
Do I have to uninstall the x86 version to install the 64 bit version or will the install of 64 bit just take over the existing hMailServer windows service after install? I am hoping to install it on the same machine and if possible so its easier for the 64 bit version to have access to the data folder.
Re: hMailServer 5.7
Post by mattg » 2019-10-21 00:39
THIS IS AN ALPHA version
This is NOT recommended on production machines
You should backup your entire system prior to upgrade, you should test this multiple times and provide feedback about your experiences.
You just install over the top of an existing hMailserver, like any other upgrade
(When I moved very early on I had to find the correct database connector for my choice of database - but I think that is included in the current builds)
tolberjj
Re: hMailServer 5.7
Post by tolberjj » 2019-10-21 20:39
One more table that could use a pk for mysql 8 innodb clusters. This prevents autoban from working.
create table hm_logon_failures
logonfailid int auto_increment not null, primary key(`logonfailid`), unique(`logonfailid`),
ipaddress1 bigint not null,
ipaddress2 bigint null,
failuretime datetime not null
DJP
Re: hMailServer 5.7
Post by DJP » 2019-10-23 17:25
First of all, many thanks for the job done by Martin. I’m an old old (old) users.
Just to say that the 5.7 64bits version works really well (using mysql) and is stable since few month/year now for me.
The libmysql 64bit stuff is annoying but I’ve seen that it should be bundle anytime soon at the installation.
Regards,
Ps: i’d love to contribute on few development thing but I got a headache to create a “good” dev. environment. Someone have a virtualbox image or something of a fresh dev env so we can contribute easily ?
Re: hMailServer 5.7
Post by mattg » 2019-11-04 16:23
I noticed the new builds, so I moved up to 5.7.0b2497 yesterday
Just checking my logs (to answer a post here) and I noticed something not correct.
DNS Score + HELOHost Score were lost after a positive SURBL score
This didn't happen long before, but I haven't checked logs on any 5.7
Please note that I accept all mail then delete the high score spam
"TCPIP"	5552	"2019-11-04 23:51:52.872"	"TCP - 196.15.183.2 connected to 10.10.10.150:25."
"DEBUG"	5552	"2019-11-04 23:51:52.872"	"Executing event OnClientConnect"
"DEBUG"	5552	"2019-11-04 23:51:56.404"	"Event completed"
"DEBUG"	5552	"2019-11-04 23:51:56.404"	"TCP connection started for session 4690"
"SMTPD"	5552	4690	"2019-11-04 23:51:56.404"	"196.15.183.2"	"SENT: 220 example.com ESMTP"
"SMTPD"	20572	4690	"2019-11-04 23:51:57.185"	"196.15.183.2"	"RECEIVED: EHLO lundstedt.it"
"DEBUG"	20572	"2019-11-04 23:51:57.185"	"Executing event OnHELO"
"DEBUG"	20572	"2019-11-04 23:52:00.607"	"Event completed"
"SMTPD"	20572	4690	"2019-11-04 23:52:00.607"	"196.15.183.2"	"SENT: 250-example.com[nl]250-SIZE[nl]250-STARTTLS[nl]250 HELP"
"SMTPD"	20572	4690	"2019-11-04 23:52:01.810"	"196.15.183.2"	"RECEIVED: MAIL FROM: <BenjaminYoungbazrg@lundstedt.it>"
"SMTPD"	20572	4690	"2019-11-04 23:52:01.826"	"196.15.183.2"	"SENT: 250 OK"
"SMTPD"	19732	4690	"2019-11-04 23:52:02.591"	"196.15.183.2"	"RECEIVED: RCPT TO: <sales@example.com>"
"TCPIP"	19732	"2019-11-04 23:52:02.810"	"DNS lookup: 2.183.15.196.bl.spamcop.net, 1 addresses found: 127.0.0.2, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:02.826"	"DNS lookup: 2.183.15.196.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	19732	"2019-11-04 23:52:03.279"	"DNS lookup: 2.183.15.196.b.barracudacentral.org, 1 addresses found: 127.0.0.2, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:03.326"	"DNS lookup: 2.183.15.196.cbl.abuseat.org, 1 addresses found: 127.0.0.2, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:03.857"	"DNS lookup: 2.183.15.196.aspews.ext.sorbs.net, 0 addresses found: (none), Match: False"
"TCPIP"	19732	"2019-11-04 23:52:03.919"	"DNS lookup: 2.183.15.196.dnsbl.sorbs.net, 2 addresses found: 127.0.0.7, 127.0.0.6, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:04.544"	"DNS lookup: 2.183.15.196.ubl.unsubscore.com, 1 addresses found: 127.0.0.2, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:04.576"	"DNS lookup: 2.183.15.196.sbl.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	19732	"2019-11-04 23:52:05.218"	"DNS lookup: 2.183.15.196.zz.countries.nerd.dk, 1 addresses found: 127.0.2.198, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:05.466"	"DNS lookup: 2.183.15.196.hostkarma.junkemailfilter.com, 1 addresses found: 127.0.0.2, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:05.685"	"DNS lookup: 2.183.15.196.all.bl.blocklist.de, 0 addresses found: (none), Match: False"
"TCPIP"	19732	"2019-11-04 23:52:06.107"	"DNS lookup: 2.183.15.196.all.spamrats.com, 3 addresses found: 127.0.0.37, 127.0.0.38, 127.0.0.43, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:06.716"	"DNS lookup: 2.183.15.196.ix.dnsbl.manitu.net, 1 addresses found: 127.0.0.2, Match: False"
"TCPIP"	19732	"2019-11-04 23:52:07.216"	"DNS lookup: 2.183.15.196.dnsbl-1.uceprotect.net, 1 addresses found: 127.0.0.2, Match: True"
"TCPIP"	19732	"2019-11-04 23:52:07.513"	"DNS lookup: 2.183.15.196.torexit.dan.me.uk, 0 addresses found: (none), Match: False"
"DEBUG"	19732	"2019-11-04 23:52:07.513"	"Spam test: SpamTestDNSBlackLists, Score: 21"
"DEBUG"	19732	"2019-11-04 23:52:08.091"	"Spam test: SpamTestHeloHost, Score: 1"
"DEBUG"	19732	"2019-11-04 23:52:08.685"	"Spam test: SpamTestMXRecords, Score: 0"
"DEBUG"	19732	"2019-11-04 23:52:08.685"	"Total spam score: 22"
"SMTPD"	19732	4690	"2019-11-04 23:52:08.685"	"196.15.183.2"	"SENT: 250 OK"
"SMTPD"	19732	4690	"2019-11-04 23:52:09.435"	"196.15.183.2"	"RECEIVED: DATA"
"DEBUG"	19732	"2019-11-04 23:52:09.435"	"Executing event OnSMTPData"
"DEBUG"	19732	"2019-11-04 23:52:09.544"	"Event completed"
"SMTPD"	19732	4690	"2019-11-04 23:52:09.544"	"196.15.183.2"	"SENT: 354 OK, send."
"DEBUG"	20572	"2019-11-04 23:52:11.951"	"Could not retrieve PTR record for IP (false)! 196.15.183.2"
"DEBUG"	20572	"2019-11-04 23:52:11.951"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	14904	"2019-11-04 23:52:11.951"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	14904	"2019-11-04 23:52:11.951"	"SURBL: Execute"
"DEBUG"	14904	"2019-11-04 23:52:11.951"	"SURBL: Found URL: toppharmacy02.su"
"DEBUG"	14904	"2019-11-04 23:52:11.966"	"SURBL: Found URL: tildacdn.com"
"DEBUG"	14904	"2019-11-04 23:52:11.966"	"SURBL: Found URL: directupload.net"
"DEBUG"	14904	"2019-11-04 23:52:11.966"	"SURBL: Found URL: 666kb.com"
"DEBUG"	14904	"2019-11-04 23:52:11.966"	"SURBL: 4 unique addresses found."
"DEBUG"	14904	"2019-11-04 23:52:11.966"	"SURBL: Lookup: 666kb.com.multi.surbl.org"
"DEBUG"	14904	"2019-11-04 23:52:12.283"	"SURBL: Lookup: directupload.net.multi.surbl.org"
"DEBUG"	14904	"2019-11-04 23:52:12.497"	"SURBL: Lookup: tildacdn.com.multi.surbl.org"
"DEBUG"	14904	"2019-11-04 23:52:12.529"	"SURBL: Lookup: toppharmacy02.su.multi.surbl.org"
"DEBUG"	14904	"2019-11-04 23:52:12.763"	"SURBL: Match found"
"DEBUG"	14904	"2019-11-04 23:52:12.763"	"SURBL: Execute"
"DEBUG"	14904	"2019-11-04 23:52:12.763"	"SURBL: Found URL: toppharmacy02.su"
"DEBUG"	14904	"2019-11-04 23:52:12.763"	"SURBL: Found URL: tildacdn.com"
"DEBUG"	14904	"2019-11-04 23:52:12.779"	"SURBL: Found URL: directupload.net"
"DEBUG"	14904	"2019-11-04 23:52:12.779"	"SURBL: Found URL: 666kb.com"
"DEBUG"	14904	"2019-11-04 23:52:12.779"	"SURBL: 4 unique addresses found."
"DEBUG"	14904	"2019-11-04 23:52:12.779"	"SURBL: Lookup: 666kb.com.dbl.spamhaus.org"
"DEBUG"	14904	"2019-11-04 23:52:12.810"	"SURBL: Lookup: directupload.net.dbl.spamhaus.org"
"DEBUG"	14904	"2019-11-04 23:52:12.826"	"SURBL: Lookup: tildacdn.com.dbl.spamhaus.org"
"DEBUG"	14904	"2019-11-04 23:52:12.857"	"SURBL: Lookup: toppharmacy02.su.dbl.spamhaus.org"
"DEBUG"	14904	"2019-11-04 23:52:12.872"	"SURBL: Match not found"
"DEBUG"	14904	"2019-11-04 23:52:12.872"	"SURBL: Execute"
"DEBUG"	14904	"2019-11-04 23:52:12.872"	"SURBL: Found URL: toppharmacy02.su"
"DEBUG"	14904	"2019-11-04 23:52:12.872"	"SURBL: Found URL: tildacdn.com"
"DEBUG"	14904	"2019-11-04 23:52:12.888"	"SURBL: Found URL: directupload.net"
"DEBUG"	14904	"2019-11-04 23:52:12.888"	"SURBL: Found URL: 666kb.com"
"DEBUG"	14904	"2019-11-04 23:52:12.888"	"SURBL: 4 unique addresses found."
"DEBUG"	14904	"2019-11-04 23:52:12.888"	"SURBL: Lookup: 666kb.com.uribl.spameatingmonkey.net"
"DEBUG"	14904	"2019-11-04 23:52:13.279"	"SURBL: Match found"
"DEBUG"	14904	"2019-11-04 23:52:13.279"	"Spam test: SpamTestSURBL, Score: 6"
"DEBUG"	14904	"2019-11-04 23:52:13.279"	"Spam test: SpamTestDKIM, Score: 0"
"DEBUG"	14904	"2019-11-04 23:52:13.329"	"Pre-creating session 4697"
"TCPIP"	14904	"2019-11-04 23:52:13.329"	"Connecting to 10.10.10.15:783..."
"DEBUG"	20572	"2019-11-04 23:52:13.329"	"TCP connection started for session 4697"
"DEBUG"	20572	"2019-11-04 23:52:13.329"	"Sending message to SpamAssassin. Session 4697, File: c:\hMailServer\Data\{79B4BDB4-0E48-4C48-8BF4-D050F4FA1760}.eml"
"DEBUG"	18888	"2019-11-04 23:52:13.657"	"No messages to index."
"DEBUG"	11672	"2019-11-04 23:52:15.872"	"Parsing response from SpamAssassin. Session 4697"
"DEBUG"	19732	"2019-11-04 23:52:15.888"	"SA - Copy+Delete used"
"DEBUG"	19732	"2019-11-04 23:52:15.888"	"Ending session 4697"
"DEBUG"	14904	"2019-11-04 23:52:15.888"	"Spam test: SpamTestSpamAssassin, Score: 124"
"DEBUG"	14904	"2019-11-04 23:52:15.888"	"Total spam score: 130"
"DEBUG"	14904	"2019-11-04 23:52:15.904"	"Executing event OnAcceptMessage"
"DEBUG"	14904	"2019-11-04 23:52:39.576"	"Event completed"
"DEBUG"	14904	"2019-11-04 23:52:39.576"	"Saving message: {79B4BDB4-0E48-4C48-8BF4-D050F4FA1760}.eml"
"DEBUG"	14904	"2019-11-04 23:52:39.591"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	14904	4690	"2019-11-04 23:52:39.591"	"196.15.183.2"	"SENT: 250 Queued (6.336 seconds)"
"DEBUG"	19732	"2019-11-04 23:52:39.591"	"The write operation failed. Bytes transferred: 0 Remote IP: 196.15.183.2, Session: 4690, Code: 10053, Message: An established connection was aborted by the software in your host machine"
"DEBUG"	11672	"2019-11-04 23:52:39.591"	"Ending session 4690"
"DEBUG"	21428	"2019-11-04 23:52:39.591"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	21216	"2019-11-04 23:52:39.591"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	21216	"2019-11-04 23:52:39.591"	"Delivering message..."
"APPLICATION"	21216	"2019-11-04 23:52:39.591"	"SMTPDeliverer - Message 1243175: Delivering message from BenjaminYoungbazrg@lundstedt.it to spam@example.com. File: c:\hMailServer\Data\{79B4BDB4-0E48-4C48-8BF4-D050F4FA1760}.eml"
"DEBUG"	21216	"2019-11-04 23:52:39.591"	"Executing event OnDeliveryStart"
"DEBUG"	21216	"2019-11-04 23:52:39.608"	"Event completed"
"DEBUG"	21216	"2019-11-04 23:52:39.608"	"Running custom virus scanner..."
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Scanner: "C:\Program Files\Windows Defender\mpcmdrun.exe" -scan -scantype 3 -file "c:\hMailServer\Data\{79B4BDB4-0E48-4C48-8BF4-D050F4FA1760}.eml" -disableremediation. Return code: 0"
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Applying rules"
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Applying rule SPAM"
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Applying rule Spam Senders"
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Applying rule Delayed one hour"
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Applying rule Delayed one day"
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Applying rule Avast Virus"
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Applying rule Dominos_vouchers"
"DEBUG"	21216	"2019-11-04 23:52:39.904"	"Applying rule Vista Print"
"DEBUG"	21216	"2019-11-04 23:52:39.924"	"Applying rule Clam Virus"
"DEBUG"	21216	"2019-11-04 23:52:39.924"	"Applying rule Windows Insider"
"DEBUG"	21216	"2019-11-04 23:52:39.924"	"Applying rule Backups"
"DEBUG"	21216	"2019-11-04 23:52:39.924"	"Applying rule logs"
"DEBUG"	21216	"2019-11-04 23:52:39.924"	"Applying rule System Parameters"
"DEBUG"	21216	"2019-11-04 23:52:39.924"	"Applying rule Shadow Protect Fail"
"DEBUG"	21216	"2019-11-04 23:52:39.924"	"Applying rule Test for ZuckMail"
"DEBUG"	21216	"2019-11-04 23:52:39.935"	"Applying rule Mailer Daemon"
"DEBUG"	21216	"2019-11-04 23:52:39.935"	"Applying rule Mailer Daemon2"
"DEBUG"	21216	"2019-11-04 23:52:39.935"	"Applying rule Test header log"
"DEBUG"	21216	"2019-11-04 23:52:39.935"	"Performing rule action"
"DEBUG"	21216	"2019-11-04 23:52:39.935"	"Executing event Unknown"
"DEBUG"	21216	"2019-11-04 23:52:41.203"	"Event completed"
"DEBUG"	21216	"2019-11-04 23:52:41.203"	"Applying rule Logitech"
"DEBUG"	21216	"2019-11-04 23:52:41.203"	"Applying rule testlist@example.com"
"DEBUG"	21216	"2019-11-04 23:52:41.203"	"Applying rule test ??"
"DEBUG"	21216	"2019-11-04 23:52:41.203"	"Executing event OnDeliverMessage"
"DEBUG"	21216	"2019-11-04 23:52:41.232"	"Event completed"
"DEBUG"	21216	"2019-11-04 23:52:41.232"	"Performing local delivery"
"DEBUG"	21216	"2019-11-04 23:52:41.232"	"Applying rules"
"DEBUG"	21216	"2019-11-04 23:52:41.232"	"Applying rule Delete large score"
"DEBUG"	21216	"2019-11-04 23:52:41.232"	"Performing rule action"
"APPLICATION"	21216	"2019-11-04 23:52:41.232"	"SMTPDeliverer - Message 1243175: The message was not delivered to spam@example.com. Delivery to this account was canceled by an account rule Rule name: Delete large score, ID: 176."
"DEBUG"	21216	"2019-11-04 23:52:41.252"	"Local delivery completed"
"DEBUG"	21216	"2019-11-04 23:52:41.252"	"Deleting message"
"DEBUG"	21216	"2019-11-04 23:52:41.252"	"Deleting message file."
"APPLICATION"	21216	"2019-11-04 23:52:41.252"	"SMTPDeliverer - Message 1243175: Message delivery thread completed."
ALSO
In my hmailserver.ini I have the following lines
; DNSBLChecksAfterMailFrom now works. It was removed during the re-design of the spam protection but have been added again.
; By default, hMailServer runs DNS blacklists checks after SMTP/MAIL FROM.
; Some users prefer to have it running after the SMTP/RCPT TO command.
; In this case, set the value of this setting to 0.
mats
Re: hMailServer 5.7
Post by mats » 2019-11-23 21:27
upgraded one testserver and got one interesting effect.
After the upgrade it required smtp authentication on external to internal mail delivery. That's despite the config said it should be allowed.
After some troubleshooting i found that i had to disable and re-enable my maildomains to get the server to understand that it should handle them
hmbaer
Re: hMailServer 5.7
Post by hmbaer » 2019-12-10 11:28
When will the new hMailServer version be released? Thank you very much :-)
Re: hMailServer 5.7
Post by Dravion » 2019-12-10 17:55
hmbaer wrote:
2019-12-10 11:28
It's not official now, but i have a 64-Bit Testing Release you can play with (Supports TLSv1.3)
https://github.com/Dravion/hmailserver/releases
Re: hMailServer 5.7
Post by mattg » 2019-12-10 23:19
hmbaer wrote:
2019-12-10 11:28
The official hmailserver 5.7 release is in ALPHA and isn't recommended for production use.
It can be found here under 'artifcats' >>https://build.hmailserver.com/
Use your forum username + password for logon access
hmbaer
Re: hMailServer 5.7
Post by hmbaer » 2019-12-14 21:08
Thank you very much! When will there be a release version from mattg or dravion?
Re: hMailServer 5.7
Post by Dravion » 2019-12-14 21:25
hmbaer
Re: hMailServer 5.7
Post by hmbaer » 2020-01-02 10:20
2019-12-10 23:19
hmbaer wrote:
2019-12-10 11:28
Thank you. I would like to create a new installation with hMailServer. Should i wait till the next version for productive use will be pusblished? Or use the current version and upgrade then?
Re: hMailServer 5.7
Post by palinka » 2020-01-19 19:09
Is Sub OnError removed from 5.7? I wanted a notification for certain things and it didn't work. Then I put a simple eventlog.write just to see if it was working at all and no, it does not do anything.
Re: hMailServer 5.7
Post by mattg » 2020-01-19 23:07
Works for me
Among other things I have this in OnError
Call CustomMonthlyLog("OnError :- " & iSeverity & " " & iCode & " " & sSource & " " & sDescription, "Events2")
And I get these type of entries in that log
2020-01-16 13:21:32.390 OnError :- 3 5406 ClamAVVirusScanner::Scan Unable to connect to ClamAV server at 10.10.10.100:3310.
2020-01-16 16:12:19.234 OnError :- 3 5157 SpamAssassinClient::OnReadError There was a communication error with SpamAssassin. hMailServer tried to retrieve data from SpamAssassin but the connection to SpamAssassin was lost. The WinSock error code is 2. Enable debug logging to retrieve more information regarding this problem. The problem could be that SpamAssassin is malfunctioning.
Re: hMailServer 5.7
Post by palinka » 2020-01-20 03:01
2020-01-19 23:07
Works for me
That's exactly the error I had in mind when I was thinking about doing the notification. But it doesn't work. If I force an error, I don't get any notification, nor is anything sent to the event log.
Sub OnError(iSeverity, iCode, sSource, sDescription)
	EventLog.Write( "hMailServer Error " & iCode & " | Severity: " & iSeverity & " | Source: " & sSource & " | Description: " & sDescription )
	Dim SMSNumber, sMSG
	sMSG = "hMailServer Error " & iCode & " | Severity: " & iSeverity & " | Source: " & sSource & " | Description: " & sDescription
	Call SendSMS(SMSNumber, sMSG)
The SendSMS function works fine outside of OnError. But even if it didn't the event log should still work. Errors appear in the error log normally. I'm stumped.
Re: hMailServer 5.7
Post by palinka » 2020-01-22 16:59
I got one instance of OnError working. Both eventlog and sms function worked as expected.
8256	"2020-01-20 23:51:15.222"	"hMailServer Error 5508 | Severity: 2 | Source: SpamAssassinTestConnect::TestConnect | Description: The SpamAssassin tests did not complete. Please confirm that the configuration (host name and port) is valid and that SpamAssassin is running."
However, no other errors were recorded into the event log. The error logs have lots of script errors thanks to me playing around with stuff.
Under what circumstances is OnError triggered?
hmbaer
Re: hMailServer 5.7
Post by hmbaer » 2020-02-02 13:24
Mattg, could you please tell us (of course non-committal) when the finished release will be there (general timeframe)?
So great work!
Re: hMailServer 5.7
Post by mattg » 2020-02-02 14:33
no idea, depends on Martin
hmbaer
Re: hMailServer 5.7
Post by hmbaer » 2020-02-02 15:01
2020-02-02 14:33
Please do not let this project die.
Lee Thompson
Re: hMailServer 5.7
Post by Lee Thompson » 2020-02-17 10:05
hmbaer wrote:
2020-02-02 15:01
2020-02-02 14:33
I doubt it's dying, server software development takes time and, most importantly, a lot of testing.
Re: hMailServer 5.7
Post by Dravion » 2020-02-17 10:12
Lee Thompson wrote:
2020-02-17 10:05
hmbaer wrote:
2020-02-02 15:01
2020-02-02 14:33
And testing Network code is a special kind of beast^^
Bodos
Re: hMailServer 5.7
Post by Bodos » 2020-03-10 16:09
I see hMailServer-5.7.0-B2500-x64 (07 Mar 20 15:02)
New build I guess. Is there any change log?
Re: hMailServer 5.7
Post by mattg » 2020-03-10 16:24
The drop down box next to the version number in the build environment shows a change log
https://build.hmailserver.com/viewType. ... eChangeLog
