Development environment
DJP
Post by DJP » 2019-11-07 14:12
Do anyone have a VirtualBox image (or something) with VS Express configured, GitHub for windows, etc. ready to build HMS 5.7 x64 ?
I'd like to contribute, but I have issue setting up a working dev. environment, even using README stuff... :( I guess it is not up-to-date and it didn't worked for me...
Thanks,
DJP
Re: Development environment
Post by mattg » 2019-11-07 23:53
Make sure that use exact versions detailed in the readme
Post by SorenR » 2019-11-08 00:31
2019-11-07 23:53
Readme says to use VS 2013 (PRO or Express) Update 3 ... I use VS 2013 Community Update 5 and install the MS API add-ons like with the Express edition.
Using the FREE "Community" edition (covers full version) enables you to use Extensions. I have installed the "Format All Files" extension to reformat all files in a project to a defined layout (tabs vs. spaces, 4 space indentations etc etc.).
https://my.visualstudio.com/Downloads?q ... -downloads
Post by RvdH » 2019-11-09 04:31
DJP
Post by DJP » 2019-11-12 15:27
Thanks everyone, I'll try with your direct link + clarifications and check if I've more luck ;-)
DJP
