RTL In the management software for administrators
shmuel
Post by shmuel » 2020-02-02 19:29
I translated the interface into Hebrew
In the web interface I did RTL by
<HTML DIR="RTL">
I wanted to ask could you also make the computer software fit RTL?
Thanks!
Attached is a sample image of the WEB interface
Re: RTL In the management software for administrators
Post by palinka » 2020-02-02 20:10
Have a look here: https://www.hmailserver.com/documentati ... t_language
Maybe you can finish off the few empty strings for Hebrew.
shmuel
Post by shmuel » 2020-02-02 22:25
2020-02-02 20:10
I agree to give the Hebrew file I translated.
But I asked do I do RTL in the software itself?
Post by palinka » 2020-02-02 22:38
From the link:
How do I install a new translation?
In the future this functionality is likely to be built-in into hMailServer Administrator, but at the moment it's a manual process.
Go to the hMailServer Translation Status page and select the translation you want to use.
When you see the list of all translated strings, select all of them and copy them to the clip board.
Start Notepad, and paste all the strings into that program.
Save the file in the hMailServer Languages directory, typically C:\Program Files\hMailServer\Languages. Name the file <language>.ini, for example italian.ini or german.ini. The file should be saved in Unicode format.
Open hMailServer.ini, typically located under C:\Program Files\hMailServer\Bin.
Locate the line which contains ValidLanguages=english,swedish and add italian to this line. Notice that every language is separated by comma. For example:
ValidLanguages=english,swedish,italian
Restart the hMailServer service.
Now the hMailServer service is aware of the, in this example, italian translation.
Post by mattg » 2020-02-02 23:16
RTL (Right to Left) isn't a change I'd expect anytime soon
Feel free to fork the source on Github, and either do it yourself or pay someone to do it for you
You can also add a 'feature request', but honestly unless there is a lot of support, and someone with the required skill set does the work, it's unlikely to happen
shmuel
Post by shmuel » 2020-02-02 23:27
2020-02-02 23:16
Post by palinka » 2020-02-03 00:08
2020-02-02 23:16
RTL (Right to Left)
:oops:
Thought it was only related to language choice.
Post by jimimaseye » 2020-02-03 00:24
Perhaps a mirror might help?
:wink:
Post by mattg » 2020-02-03 01:04
shmuel wrote:
2020-02-02 19:29
...In the web interface...
Didn't realise that you were talking about the PHPWebAdmin interface.
That should handle RTL if you know PHP
Thought that you were talking about the main admin GUI
shmuel
Post by shmuel » 2020-02-03 01:08
2020-02-03 01:04
shmuel wrote:
2020-02-02 19:29
In PHPWebAdmin I did RTL.
What I want is to do it on the software itself on the computer itself
Post by mattg » 2020-02-03 03:18
shmuel wrote:
2020-02-03 01:08
2020-02-02 23:16
