Unencrypted IMAP Server Password Error
CDX
Post by CDX » 2020-04-16 20:20
Hey everyone.
I am currently using hMailServer to run as the mail server for a cyber defence exercise in a course I'm taking.
One of the requirements for the course is to support unencrypted IMAP connections.
I'm attempting to connect to the unencrypted IMAP server through my configured account on Thunderbird, but I continue getting a wrong password error.
I was previously using a STARTTLS (Optional) encrypted connection with an SSL certificate for both my SMTP and IMAP servers and everything worked correctly (i.e. I could send/receive secure email between machines using my domain).
Would anyone be able to explain why I continue to receive this password error message?
I know for a fact the password is correct considering I used the exact same password with the encrypted IMAP connection and was able to establish secure email communications.
I've included attachments to display my current mail configuration.
Thunderbird Security Settings:
Connection Security: None
Authentication Method: Password, transmitted insecurely
hMailServer TCP/IP Port IMAP Configuration:
Protocol: IMAP
TCP/IP Address: (My machine's IP)
TCP/IP Port: 143
Looking into the log files, unfortunately, did not show anything useful regarding this error.
Thanks for the help.
Thunderbird Email Account IMAP Settings
hMailServer IMAP configuration
hMailServer Settings
Re: Unencrypted IMAP Server Password Error
Post by Dravion » 2020-04-16 21:02
Username is: your_hmailserver_emailaddress@yourdomain.com
TB shows up Password dialog until any params are correctly setup.
Try telnetting your hMailServer ports and take a look in hMailServer log files.
CDX
Post by CDX » 2020-04-16 21:35
Thanks for the prompt reply, Dravion.
Could you clarify what you meant for the username? I attempted to set my username to "your_hmailserver_mail@rmc.bluenet", as well as "hmailserver_mail@rmc.bluenet" and just "mail@rmc.bluenet" but I still received the same Wrong Password error message. I was a little confused as to whether you were referencing the actual name of my hMailServer account, or of something else.
I had also used telnet to view the hMailServer ports, and received the results shown in the attachments, so I believe there's nothing wrong there.
I also know for sure that the hMailServer was properly configured as I am able to successfully log in to my IMAP server whenever I set the connection security back to STARTTLS (optional).
Overlooking the resulting IMAP, TCP/IP, Application, and Debug log files did not show anything pertaining to me attempting to log in.
Would you consider that there might be a problem with the database? Perhaps because it was initially configured to run with IMAP encryption?
Telnet IMAP (telnet 192.168.0.46 143)
Telnet SMTP (telnet 192.168.0.46 25)
Post by Dravion » 2020-04-16 22:11
You need to enable the Debug settings in hMailAdmin to get detailed logs.
If you don't use a DNS-Server, you need to append your ip address instead of your DNS-Domain name after the user account @.
Like this: joe@192.168.1.1
CDX
Post by CDX » 2020-04-16 22:58
Thanks again for your reply, Dravion.
I managed to resolve what the issue was:
  1. Under the IP Ranges, I had selected that the traffic on my selected IP range required SSL/TLS for authentication
  2. After unselecting this feature, I was able to successfully login through to my IMAP server and send/receive emails as I had before (although now with an unencrypted IMAP connection)
  3. Changing the username of my accounts did not affect anything. I was able to leave them as they had been automatically filled out (e.g. joe@domain.net would have a username of joe)
Thanks again for the help!
It's much appreciated.
Post by mattg » 2020-04-17 03:06
CDX wrote:
2020-04-16 22:58
#1 then you changed the defaults
#3 Then you have set a default domain, this is not recommended
#2 what do you hope is achieved by securing connections?
Have you installed a certificate?
Is your certificate an issued certificate from a reputable supplier, or is this a self signed certificate?
Run this and post the results please
viewtopic.php?f=20&t=30914
CDX
Post by CDX » 2020-04-17 04:06
In regards to your concerns, mattg:
For the course which I am taking, we are required to create our own domain and establish secure protocols for the various services to operate in a cyber operations environment.
My tasking for this exercise is to create the mail server, while connecting to our team's DNS services which resolve my ip for smtp and imap protocols.
#1 Yes I changed the defaults to not allow SSL/TLS authentication as my orders demand that I go about using unencrypted IMAP connections.
#2 To be clear I do not hope to secure IMAP connections, I'm already using end-to-end encryption with a certificate from my teammate who's tasked as the ICA.
#3 As per our directives, using the one domain for our exercise suits my needs and I'm sticking to them since they work.
I ran the settings diagnostic report you provided, results are below:
2020-04-16   Hmailserver: 5.6.8-B2494
DOMAINS
   "Domain1.com" - rmx.blxxxxx                    Enabled: True
                   Max message size:     5000                      Plus addressing: False
                   Max size of accounts: 1000
        Greylisting:     False
GLOBAL RULES
IP RANGES
     POP3:  False                              Antivirus:  False
     External To Local    -  True              External To Local    -  True
     External To External - False
IP: 10.0.0.0 - 192.168.255.255     Priority: 10     Name: Traffic
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain1.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: False
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  4 Mins:  1   Plain Text:         True  Bind: 192.168.0.46
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
 !! Service Not Enabled !!
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Add X-HmailServer-Spam:    False    Check HELO host:   False
  Add X-HmailServer-Reason:  False    Check MX records:  False
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   imap.Domain1.com
       Certificate: C:\Users\Administrator\Documents\SSL\imap.Domain1.com.cert.pem
       Private key: C:\Users\Administrator\Documents\SSL\private\imap.Domain1.com.key.pem
   smtp.Domain1.com
       Certificate: C:\Users\Administrator\Documents\SSL\smtp.Domain1.com.cert.pem
       Private key: C:\Users\Administrator\Documents\SSL\private\smtp.Domain1.com.key.pem
SSL/TLS
             TLS 1.0 :   True
             TLS 1.1 :   True
             TLS 1.2 :   True
             TLS 1.3 :   True                Verify Remote SSL/TLS Certs:   True
SslCipherList  :
               192.168.0.46    / 25    / SMTP   -   StartTLS Optional   Cert: smtp.Domain1.com
               192.168.0.46    / 143   / IMAP   -   None
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-04-16.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-04-16.log - !! ERRORS PRESENT !!
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MySQL
Backup directory C:\Users\Administrator\Documents\MailServer Backup is writable.
HMAILSERVER.INI
Database folder:
Type=              MYSQL
Username=          MailDB
Port=              3306
Server=            localhost
Internal=          0
Generated by HMSSettingsDiagnostics v1.99, Hmailserver Forum.
Thanks again.
Post by mattg » 2020-04-17 05:25
#1
You missed my point
If you had to turn SSL/TLS off in IP ranges, then you had ALREADY changed form the default which doesn't have that selected. There is no point in setting that until you have a SSL certificate installed in Hmailsevrer
Why have you changed the internet IP range
(that IP grouping doesn't make sense)
On IP ranges page there is a 'default' button. please press it
#2
TCPIP PORTS
You have a certificate installed, but it isn't set to the IMAP port. This should be set to StartTLS Required
#3 a default domain being set is likely to you more incoming spam
If this is a live server connected to the internet, you should consider removing that
Your diagnostics show errors
Can you please show the contents of your
CDX
Post by CDX » 2020-04-17 22:10
1. I think you overlooked the fact that I already had an SSL certificate installed on hMailServer. The reason I unselected it was due to my original problem in this forum thread, regarding the continuous incorrect IMAP password errors I was receiving.
I set the IP ranges back to default, the reason as to why I had originally selected that IP range is because I only wanted to accept connections from the IP ranges set within our simulation environment.
2. After realizing that I no longer needed a certificate for my IMAP connections, I went on to delete the IMAP SSL certificate which was originally imported onto hMailServer.... so no I will not select STARTTLS (Required) because, as I mentioned before, I am required to support unencrypted IMAP connections for my simulation environment.
3. Another requirement for my email server, as laid out in my computer engineering course's simulation environment administration instructions, is that I am not allowed to use spam filtering of any kind. Also considering this is simply a simulation environment that is not connected to the outside world, I'm honestly not too worried about receiving spam.
Below are the contents of the error log:
"ERROR"	2688	"2020-04-16 12:06:17.564"	"Severity: 3 (Medium), Code: HM4403, Source: Message::GetHeader, Description: Could not read the message header, since the file was not available. File: C:\Program Files (x86)\hMailServer\Data\rmc.bluenet\rubberneck\2F\{2F87CC3A-FCFF-48C8-9E00-5F1CC3AF3B7E}.eml"
"ERROR"	2884	"2020-04-16 13:37:07.843"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-BackupTask', Error code: 2, Message: boost::filesystem::copy_file: The system cannot find the file specified: "C:\Program Files (x86)\hMailServer\Data\{0088DEDB-60B3-4341-93F7-76A8DB6A1420}.eml", "C:\Users\Administrator\Documents\MailServer Backup\DataBackup\{0088DEDB-60B3-4341-93F7-76A8DB6A1420}.eml""
"ERROR"	2884	"2020-04-16 13:37:08.421"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-04-16 133707_{4B4BF1C7-3553-456B-AB3F-A644609118DB}.dmp"
Would you be able to explain what exactly the "mini dumps" are? I have a few of these now but they just seem to be binary text files.
