Wanting to try the newest 5.7 build?
binarydad
Post by binarydad » 2020-04-17 03:50
I'm trying to catch up on the various builds and would like to try whatever is the latest and/or most stable. I'm looking to see if it may address issues with a certain email client (specifically emClient) regarding IMAP sync.
Is there an official 5.7 build?
Is HCD still a thing? Is it in development?
What are these Dravion builds?
Thanks!
Re: Wanting to try the newest 5.7 build?
Post by mattg » 2020-04-17 05:13
https://build.hmailserver.com/
look under artifacts
Use your forum logon details from here
It is still VERY Alpha
HCD >> you'll need to check with @Dravion
Dravion is the developer of some custom builds - There are some others
Post by Dravion » 2020-04-17 06:51
No, HCD isn't any longer in development, because it would result in a complete different development direction which wasn't my plan.
