5.7 X-hMailServer-Reason-Score
Post by RvdH » 2020-04-25 19:30
On the latest 5.7 build, but might also be the case earlier on all outgoing mail (authenticated) the X-hMailServer-Reason-Score: 0 header is added, i was under the impression outgoing & authenticated send messages were not checked for spam, right? Or does 5.7 do outgoing spam checking?
Anyone can confirm?
Re: 5.7 X-hMailServer-Reason-Score
Post by RvdH » 2020-04-25 20:40
Seems intentional, and it's not a big deal...i just didn't notice until today
5.6.x
https://github.com/hmailserver/hmailser ... .cpp#L1124
5.7.x
https://github.com/hmailserver/hmailser ... .cpp#L1141
Post by mattg » 2020-04-26 00:10
yes the header is added
no the spam tests are not run, no spamassassin either
AV is checked, and rules are run
