New release hMailServer 5.6.8 - Build 2501
VadaDosaIdly
Post by VadaDosaIdly » 2020-06-10 23:42
I am using hMailServer 5.6.8-B2431 BETA and new version 5.6.8 - Build 2501 BETA is released.
If I have to use the new version, do I just install over existing application on the same server? Will it work with no problem.
Just-in-case, will I be able to rollback to previous version?
Sorry! I am asking these question because I could not find version release notes related to above questions.
Thank you in anticipation of help.
Re: New release hMailServer 5.6.8 - Build 2501
Post by jimimaseye » 2020-06-10 23:50
Simply run the install over the top of existing installation. It performs as 'upgrade' and shouldn't affect anything. (It literally just replaced the hmailserver.Exe with a new one. )
