This script is very buggy. I added what Matt suggested and also corrected/added some code to fix error of mail not being sent to an admin account. So now user gets warnings and admin gets warnings unless you switch them off in setup CONST values (assuming that works).
I have also switched the code from writing its own event log to using the hmailserver_events.log file. This file will need to be rotated using script at bottom of this post.
Use at your own risk. There may well be more bugs in the code for all I know.
'Force error on undeclared variables
'Option Explicit
' Global variables and settings
'General
Public obApp
Public domain_buffer
Public Const ipslocalhost = "0.0.0.0" 'separated by #
Public Const user = "Administrator"
Public Const pw = "password" ' ## enter admin password here
Public Const write_log_active = True
'User and Domain outgoing limitation
Public Const outgoingstore = "c:\program files(x86)\hMailServer\Events\outboundstore.txt"
Public Const outgoingexceptions = "c:\program files(x86)\hMailServer\Events\outboundexceptions.txt"
Public Const outgoingstoreavg = "c:\program files(x86)\hMailServer\Events\outboundstoreavg.txt"
Public Const max_emails_per_user = 1000
Public Const max_emails_per_domain = 10000
Public Const warning_factor = 0.8
Public Const server_average_days = 20 ' 0 will deactivate
Public Const server_average_threshold_factor = 10
Public Const warning_factor_avg = 0.6
Public Const msg_admin_warning = True
Public Const msg_admin_passed = True
Public Const msg_user_warning = True
Public Const msg_user_passed = True
Public Const msg_from = "Email Admin <user@domain.com>"
Public Const msg_fromaddress = "user@domain.com"
Public Const msg_ToAdminName = "Admin User"
Public Const msg_ToAdminEmail = "user@admindomain.com"
Public Const DefaultDomain = "defaultdomain.com"
Result.Value = 0
Call obApp.Authenticate(user, pw)
If has_client_authenticated(oClient) Then
write_log (" User has authenticated. User " & oCLient.username & ", Client " & oClient.IPAddress)
if not check_outgoing_limitations(oClient, oMessage) Then
Result.Message = "Your account/Mailserver has passed SMTP outgoing limits."
Result.Value = 2
End if
End if
' SMTP limit outgoing emails of domain and user
function check_outgoing_limitations(oClient, oMessage)
check_outgoing_limitations = true
Const ForReading = 1, ForWriting = 2, ForAppending = 8
Dim fs , f
Set fs = CreateObject("scripting.filesystemobject")
Dim idt
Dim content
Dim ln
Dim arr
Dim usern
Dim usernadd
Dim usernnr
Dim usernnrmax
Dim domn
Dim domnadd
Dim domnnr
Dim domnnrmax
Dim reason
Dim rcptscnt
Dim dayamounts(200)
Dim i, k
For i = 0 To 200
dayamounts(i) = 0
Dim pos
Dim avg
Dim minday
minday = 999999
Dim toindex
Dim excptn
write_log(" SMTP outgoing limitations")
If oclient.username <> "" Then
If instr(1,oclient.username,"@") = 0 Then
usern = oclient.username & "@" & obApp.Settings.DefaultDomain
domn = "@" & obApp.Settings.DefaultDomain
domn = Mid(oclient.username,InStr(1,oclient.username,"@"))
ElseIf is_local_domain(omessage.fromaddress) then
usern = omessage.fromaddress
domn = Mid(omessage.fromaddress,InStr(1,omessage.fromaddress,"@"))
usern = "local"
domn = "@local"
content = "# SMTP outgoing storage" & nl & nl
usernadd = true
domnadd = true
usernnr = 1
domnnr = 1
usernnrmax = max_emails_per_user
domnnrmax = max_emails_per_domain
idt = CLng(Date())
rcptscnt = omessage.Recipients.count
write_log(" Number of recipients " & rcptscnt)
write_log(" Reading exceptions file " & outgoingexceptions)
If fs.FileExists(outgoingexceptions) Then
Set f = fs.OpenTextFile(outgoingexceptions, ForReading)
Do While Not f.AtEndOfStream
ln = f.ReadLine
If ln <> "" And Mid(ln,1,1) <> "#" And Len(ln) > 3 Then
arr = Split(ln,Chr(9))
If UBound(arr) = 1 Then
If arr(0) = usern Then
usernnrmax = CLng(arr(1))
write_log (" new user limit " & ln)
End if
If arr(0) = domn Then
domnnrmax = CLng(arr(1))
write_log (" new domain limit " & ln)
End if
write_log (" cannot process line " & Mid(ln,1,25))
ElseIf Len(ln) > 5 And f.Line > 4 + 1 then
write_log (" skipping line " & Mid(ln,1,25))
Loop
Set f = fs.OpenTextFile(outgoingexceptions, ForWriting, true)
f.Write("# Outgoing limitation exceptions tab / chr(9) separated" & nl)
f.Write("# Examples (without # at the beginning)" & nl)
f.Write("# @yourdomain.com 10000" & nl)
f.Write("# address@yourdomain.com 5000" & nl & nl)
f.Close
write_log(" Reading storage file " & outgoingstore)
If fs.FileExists(outgoingstore) Then
Set f = fs.OpenTextFile(outgoingstore, ForReading)
ln = f.ReadLine
If ln <> "" And Mid(ln,1,1) <> "#" And Len(ln) > 5 Then
arr = Split(ln," ")
If UBound(arr) > 1 Then
If minday > CLng(arr(0)) Then
minday = CLng(arr(0))
If UBound(arr) = 2 Or UBound(arr) = 3 Then
If CLng(arr(0)) = idt And arr(2) = usern Then
usernnr = CLng(arr(1)) + rcptscnt
usernadd = False
write_log (" adding to line " & ln)
If usernnr > usernnrmax Then
If UBound(arr) = 3 Then
If arr(3) = "X" then
write_log (" deny already sent")
write_log (" sending deny")
outgoing_limitations_send_message oClient, oMessage, false, usernnr, usernnrmax, false
End if
content = content & arr(0) & " " & usernnr & " " & arr(2) & " X" & nl
ElseIf usernnr > usernnrmax * warning_factor then
If arr(3) = "W" then
write_log (" warning already sent")
write_log (" sending warning")
outgoing_limitations_send_message oClient, oMessage, true, usernnr, usernnrmax, false
End if
content = content & arr(0) & " " & usernnr & " " & arr(2) & " W" & nl
content = content & arr(0) & " " & usernnr & " " & arr(2) & nl
End if
elseIf CLng(arr(0)) = idt And arr(2) = domn Then
domnnr = CLng(arr(1)) + rcptscnt
domnadd = false
If domnnr > domnnrmax Then
outgoing_limitations_send_message oClient, oMessage, false, domnnr, domnnrmax, true
End if
content = content & arr(0) & " " & domnnr & " " & arr(2) & " X" & nl
ElseIf domnnr > domnnrmax * warning_factor then
outgoing_limitations_send_message oClient, oMessage, true, domnnr, domnnrmax, true
End if
content = content & arr(0) & " " & domnnr & " " & arr(2) & " W" & nl
content = content & arr(0) & " " & domnnr & " " & arr(2) & nl
End if
ElseIf CLng(arr(0)) < idt - server_average_days Then
write_log (" deleting line " & ln)
content = content & arr(0) & " " & arr(1) & " " & arr(2) & nl
'write_log (" copying line " & ln)
If Mid(arr(2),1,1) <> "@" Then
pos = idt - CLng(arr(0))
dayamounts(pos) = dayamounts(pos) + CLng(arr(1))
ElseIf Len(ln) > 5 And f.Line > 1 + 1 then
Loop
f.Close
If usernadd Then
content = content & idt & " " & usernnr & " " & usern & nl
If domnadd Then
content = content & idt & " " & domnnr & " " & domn & nl
Set f = fs.OpenTextFile(outgoingstore, ForWriting, true)
f.Write(content)
f.Close
f.Write(content)
f.Close
toindex = idt - minday
avg = CDbl(0)
If toindex >=5 then
For i = 1 To toindex
avg = avg + CDbl(dayamounts(i))
avg = CDbl(avg) / CDbl(toindex)
write_log(" Statistic calculation over " & server_average_days & " days")
write_log(" todays amount " & dayamounts(0) & " average " & avg & " maximum " & avg * server_average_threshold_factor)
write_log(" Checking statistics")
If toindex < 5 then
write_log(" Statistic calculation is only done over at least 5 days. Available days: " & toindex)
ElseIf avg < 5 Then
write_log(" average below 5 mails per day, ignoring average statistic")
ElseIf dayamounts(0) > avg * server_average_threshold_factor Then
write_log(" todays amount has passed limit of " & avg * server_average_threshold_factor)
outgoing_limitations_avg_send_admin dayamounts(0),avg * server_average_threshold_factor,false
check_outgoing_limitations = False
ElseIf dayamounts(0) > avg * server_average_threshold_factor * warning_factor_avg Then
write_log(" todays amount has passed warning level of " & avg * server_average_threshold_factor * warning_factor_avg)
outgoing_limitations_avg_send_admin dayamounts(0),avg * server_average_threshold_factor,true
write_log(" within limits")
write_log(" Checking limits")
If usernnrmax < usernnr Then
check_outgoing_limitations = false
write_log(" max of user passed!")
ElseIf domnnrmax < domnnr Then
write_log(" max of domain passed!")
excptn = false
If oMessage.FromAddress = msg_ToAdminEmail Then
excptn = true
For k = 0 To oMessage.recipients.count - 1
If oMessage.recipients(k).OriginalAddress = msg_ToAdminEmail Then
excptn = True
If excptn = True Then
write_log(" Mail from/to admin -> passes lock")
End if
End function
Sub outgoing_limitations_avg_send_admin(nr, max, iswarning)
Dim fs , f
Dim txt
Dim tmp
Dim str
Dim out
Dim snd
If iswarning Then
tmp = "Warning: Todays outgoing emails will reach lock soon"
txt = "Hello " & msg_ToAdminEmail & nl & nl
txt = txt & "todays outgoing email will reach avg limit soon." & nl & nl
txt = txt & "Current amount is " & nr & nl
txt = txt & "Limit is " & max & nl & nl
txt = txt & "Regards" & nl
txt = txt & msg_ToAdminEmail
str = "W" & CLng(Date())
tmp = "Locked: Todays outgoing emails have passed avg limit"
txt = txt & "todays outgoing email have passed avg limit." & nl & nl
str = "X" & CLng(Date())
snd = true
If fs.FileExists(outgoingstoreavg) Then
Set f = fs.OpenTextFile(outgoingstoreavg,ForReading)
out = f.ReadAll
f.Close
If out = str Then
snd = false
If snd then
Set nMessage = CreateObject("hMailServer.Message")
nMessage.From = msg_from
nMessage.FromAddress = msg_fromaddress
nMessage.AddRecipient msg_ToAdminName, msg_ToAdminEmail
nMessage.Subject = tmp
nMessage.Body = txt
nMessage.Save
Set f = fs.OpenTextFile(outgoingstoreavg,ForWriting,True)
f.Write(str)
f.Close
Sub outgoing_limitations_send_message(oClient, oMessage, iswarning, nr, max, isdomain)
Dim txt
Dim tmp
Dim nMessage
If oclient.username <> "" then
tmp = oclient.username
tmp = oMessage.FromAddress
If instr(2, tmp, DefaultDomain) = 0 then
tmp=tmp & "@" & DefaultDomain
If iswarning Then
txt = "Hello " & tmp & nl & nl
txt = txt & "you will soon reach your account limits." & nl & nl
If isdomain Then
txt = txt & "This is a limit of the your domain." & nl & nl
txt = txt & "This is a limit of the your account." & nl & nl
If msg_admin_warning then
If msg_user_warning then
nMessage.AddRecipient tmp, tmp
nMessage.Subject = "Warning: Account limits will be reached soon"
nMessage.Body = txt
nMessage.Save
End if
txt = txt & "you have passed your account limits." & nl & nl
If isdomain Then
If msg_admin_passed then
nMessage.Subject = "Locked: Account limits passed"
nMessage.Body = txt
nMessage.Save
If msg_user_passed then
nMessage.Body = txt
nMessage.Save
End if
' General functions of all scripts
Sub write_log(txt)
If write_log_active then
EventLog.Write("Limit SMTP Script:"+txt)
End if
Function get_date
Dim tmp
Dim erg
tmp = Year(Date)
erg = CStr(tmp)
If Month(Date) < 10 Then
tmp = "0" & Month(Date)
tmp = Month(Date)
erg = erg & "-" & tmp
If day(Date) < 10 Then
tmp = "0" & day(Date)
tmp = day(Date)
get_date = erg
Function nl
nl = Chr(13) & Chr(10)
End function
Function is_local_domain(domain_or_email)
is_local_domain = False
Dim domain
Dim doms
Dim alss
Dim i
Dim j
If InStr(1," " & domain_or_email,"@") > 0 Then
domain = Mid(domain_or_email, InStr(1,domain_or_email,"@") + 1)
domain = domain_or_email
If domain_buffer = "" then
i = 0
Set doms = obapp.Domains
Do While i <= doms.Count - 1
Set dom = doms.Item(i)
domain_buffer = domain_buffer & "#" & dom.Name
j = 0
Set alss = dom.DomainAliases
Do While j <= alss.Count - 1
Set als = alss.item(j)
domain_buffer = domain_buffer & "#" & als.AliasName
j = j + 1
Loop
i = i + 1
Loop
If InStr(1, " " & domain_buffer, domain) > 0 Then
is_local_domain = True
Function has_client_authenticated(oclient)
has_client_authenticated = false
If oCLient.username <> "" Or InStr(1," " & ipslocalhost, oClient.IPAddress) > 0 Then
has_client_authenticated = true
End if
to cycle hmailserver_events.log file run following script from windows task scheduler daily
