Batch Add Users and/or Aliases from CSV file
Post by percepts » 2013-05-23 21:49
EDIT: VERSION 7 of this script containing mods and fixes is posted at the foot of this thread here viewtopic.php?p=197910#p197910.
This script adds Users and/or Aliases from a CSV file to your hMailServer installation.
This seems to be a frequent requirement so I have copied and updated an old hms 4 script from original
topic http://www.hmailserver.com/forum/viewto ... 13#p149913
The modifications include authorisation for hMailServer 5.x.x and also error trapping so that script will continue processing input file when duplicates are found. A popup summary of duplicates (already in HMS) and counts is produced. Otherwise it's same as original.
** N.B. 1 ** You need to set your password into the Authentication step on line 20 of following code
** N.B. 2 ** You need to set your CSV filename on line 22 of following code with correct path of where it is.
Option Explicit
On Error resume next
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Dim scrreport
Dim failed
Dim added
failed = 0
added = 0
Const ForReading = 1
Call obBaseApp.Authenticate("Administrator","password_here") '*** N.B. 1. set your administrator password in this line
Set objTextFile = objFSO.OpenTextFile("AddAccounts.txt", ForReading) 'N.B. 2. Set your CSV path/filename in this line
Do While objTextFile.AtEndOfStream <> True
    strNewAlias = split(objTextFile.Readline, ",")
    Select Case strNewAlias(0)
       Case "User"
          AddUser strNewAlias(1), strNewAlias(2), strNewAlias(3)
       Case "Alias"
          AddAlias strNewAlias(1), strNewAlias(2), strNewAlias(3)
    End Select
    If err.Number <> 0 Then    'error handling:
     scrreport = scrreport & "Failed add (probably duplicate) : " & strNewAlias(0) & "," & strNewAlias(1) & "," & strNewAlias(2) & "," & strNewAlias(3) & VBNewLine
     failed = failed + 1
     err.Clear
     added = added + 1
    i = i + 1
Loop
scrreport = scrreport & " " & VBNewLine
scrreport = scrreport & "Added = " & added & VBNewLine
scrreport = scrreport & "Failed or Duplicates = " & failed & VBNewLine
wscript.echo scrreport
Sub AddAlias(strAlias,strEmailAddress,strDomain)
   Dim obDomain
   Dim obAliases
   Dim obNewAlias
   Set obDomain = obBaseApp.Domains.ItemByName(strDomain)
   Set obAliases = obDomain.Aliases
   Set obNewAlias = obAliases.Add()
   obNewAlias.Name = strAlias & "@" & strDomain 'username
   obNewAlias.Value = strEmailAddress 'password
   obNewAlias.Active = 1 'activates user
   obNewAlias.Save() 'saves account
   Set obNewAlias = Nothing
   Set obAliases = Nothing
   Set obDomain = Nothing
Sub AddUser(strUsername, strPassword, strDomain)
   Dim obDomain
   Dim obAccounts
   Dim obNewAccount
   Set obAccounts = obDomain.Accounts
   Set obNewAccount = obAccounts.Add()
   obNewAccount.Address = strUsername & "@" & strDomain 'username
   obNewAccount.Password = strPassword 'password
   obNewAccount.Active = 1 'activates user
   obNewAccount.Maxsize = 0 'sets mailbox size, 0=unlimited
   obNewAccount.Save() 'saves account
   Set obNewAccount = Nothing
   Set obAccounts = Nothing
The CSV file needs to be in the following format:
EntryType,Field1,Field2,Field3
The EntryType can be one of two options, User or Alias. If the EntryType is User, then:
EntryType = User
Field1 = Uername
Field2 = Password
Field3 = DqmainName
If the EntryType is Alias, then:
EntryType = Alias
Field1 = AliasName
Field2 = ForwardingEmail
Field3 = DomainName
So, for example, if you had the following CSV file:
User,tjones,mypassword,jones.com
Alias,tommy,tjones@jones.com,jones.com
This would create a user names tjones@jones.com in the jones.com domain and an alias tommy@jones.com which will forward all e-mail to tjones@jones.com in the jones.com domain.
Good Luck !
Re: Batch Add Users and/or Aliases from CSV file
Post by mattg » 2013-05-24 01:01
Thanks Percepts - good work
Version 2 : Batch Add Users and/or Aliases from CSV file
Post by percepts » 2013-05-24 18:38
** Version 2 just has minor change to write duplicates to hmailserver_events.log **
Option Explicit
Dim Elog
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Dim failed
Dim added
failed = 0
added = 0
Set Elog = CreateObject("hMailServer.EventLog")
       Case "User"
       Case "Alias"
    End Select
     Elog.Write("Failed add (probably duplicate)" & Chr(34) & vbTab & Chr(34) & strNewAlias(0) & "," & strNewAlias(1) & "," & strNewAlias(2) & "," & strNewAlias(3))
     failed = failed + 1
     err.Clear
     added = added + 1
Loop
On Error goto 0
Elog.Write("Added Sucessfully    = " & added)
Elog.Write("Failed or Duplicates = " & failed)
Wscript.Echo ("Added Sucessfully    = " & added & VbNewLine & "Failed or Duplicates = " & failed & VbNewLine & VbNewLine & "See hmailserver_events.log for list of duplicates(if any)")
   Dim obDomain
   Dim obAliases
   Dim obNewAlias
   Dim obDomain
   Dim obAccounts
   Dim obNewAccount
EntryType = User
Field1 = Uername
Field2 = Password
Field3 = DqmainName
EntryType = Alias
Field1 = AliasName
Field3 = DomainName
Good Luck !
mukeshb
Post by mukeshb » 2013-06-28 19:46
thanks for script, I can add 285 account in one click, great work. one questions, after I add all 285 account how can I verify account in administration panel? I can not see any account created there. but I get message "successful 285 fail 0 "
Post by percepts » 2013-06-28 21:22
restart hmail service or you can just wait for the cache to be reloaded. Unfotunately the script doesn't do this for you.
mukeshb
Post by mukeshb » 2013-07-01 17:59
is there any script for add domain also, because adding user does not add domain also. I need to resolve that issue. so I can add all this users.
Version 3 : Batch Add Users and/or Aliases from CSV file
Post by percepts » 2013-07-01 19:54
** Version 3 auto adds domains if they don't exist **
N.B. hmailServer defaults for domain are used when a domain is added. If you don't want defaults you must edit domain options in Admin panel after running script or modify script to set options you require on add.
This script adds Users and/or Aliases from a CSV file to your hMailServer installation. If the domain for an account doesn't exist, then it is added before adding the account which uses it.
The modifications include authorisation for hMailServer 5.x.x and also error trapping so that script will continue processing input file when duplicates are found. Domains are added if they don't exist. A popup summary of duplicates (already in HMS) and counts is produced.
** N.B. 1 ** You need to set your password into the Authentication step on approx line 20 of following code
** N.B. 2 ** You need to set your CSV filename on approx line 22 of following code with correct path of where it is.
Option Explicit
Dim Elog
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Dim failed
Dim added
Dim domainsAdded
failed = 0
added = 0
domainsAdded = 0
Call obBaseApp.Authenticate("Administrator","mypassword") '*** N.B. 1. set your administrator password in this line
       Case "User"
       Case "Alias"
    End Select
     Elog.Write("Failed add (probably duplicate)" & Chr(34) & vbTab & Chr(34) & strNewAlias(0) _
     failed = failed + 1
     err.Clear
     added = added + 1
Loop
On Error goto 0
Elog.Write("Domains Added Sucessfully   = " & domainsAdded)
Elog.Write("Accounts Added Sucessfully   = " & added)
Elog.Write("Failed or Duplicate Accounts  = " & failed)
Wscript.Echo ("Domains Added Sucessfully    = " & domainsAdded & VbNewLine _
                  & "Accounts Added Sucessfully   = " & added & VbNewLine _
                  & "Failed or Duplicate Accounts  = " & failed & VbNewLine & VbNewLine _
                  & "See hmailserver_events.log for list of duplicates (if any)")
   Dim obDomain
   Dim obAliases
   Dim obNewAlias
   'obBaseApp.Aliases.Refresh()
   AddDomain strDomain
   Dim obDomain
   Dim obAccounts
   Dim obNewAccount
   'obBaseApp.Accounts.Refresh()
Sub AddDomain(strDomain)
 Dim obNewDomain
 Set obNewDomain = obBaseApp.Domains.Add()
 obNewDomain.Name = strDomain
 obNewDomain.Active = True
 obNewDomain.Save()
 If err.Number = 0 Then
  domainsAdded = domainsAdded + 1
 err.Clear
 obBaseApp.Domains.Refresh()
EntryType = User
Field1 = Uername
Field2 = Password
Field3 = DqmainName
EntryType = Alias
Field1 = AliasName
Field3 = DomainName
Good Luck !
mukeshb
Post by mukeshb » 2013-07-01 20:19
perfect, thanks, question? do I need to use txt file or I can use csv file?
according to line : "Set objTextFile = objFSO.OpenTextFile("AddAccounts.txt", ForReading) 'N.B. 2. Set your CSV path/filename in this line" I need txt file, do I need to format it in any order to add domain?
thank, again, sorry, I am asking stupide questions, but I know null about scripting.
sorry, one more time, if I am asking in wrong post.
wow, it works, I didn't receive any acknowledgment message but, I can see all accounts. I use csv file.
you guys are rock.
can I add field 4 for account full name and field 5 for email forward address
Post by percepts » 2013-07-01 20:39
The format of the input file hasn't changed.
you can put rows in the file in any sequence you like.
The filename extension can be txt or csv or anything else. It just needs to be a plain text (ascii) file.
However, the fields must be comma separated and not some other character.
And the file isn't treated like a csv file with text qualifiers. If you put text qualifiers such as " then they will go into the database as part of account name which may cause failure so don't use text qualifiers in csv file.
Post by percepts » 2013-07-01 20:43
mukeshb wrote: wow it works, I didn't receive any acknowledgment message but, I can see all accounts. I use csv file.
you guys are rock.
you should have seen a popup with domain and account add counts.
mukeshb
Post by mukeshb » 2013-07-01 20:49
sorry, I spoke too soon, I did receive pop up,
mukeshb
Post by mukeshb » 2013-07-01 21:03
to add mail forward for some account can I add filed 4 for it, or I need to use alias section of this script? if I need to use alias section from this script do I need to change any thing in my csv file?
mukeshb
Post by mukeshb » 2013-07-01 21:13
can we make EntryType,Field1,Field2,Field3, Field 4, field 5,
Field 1= username, filed 2= password, field 3= domain name, field 4 = user full name, field 5 = email forwarding address,
I know I am asking too much, but it makes lot easier to migrate from another server.
Thanks.
Post by percepts » 2013-07-01 21:32
yes you can add more fields(columns) to the input file if you like. You should also look at http://www.hmailserver.com/documentatio ... ct_account which gives you all the property names you can add in the adduser sub of the script.
Post by percepts » 2013-07-01 22:32
note that in hmail persons name is held as two properties, personfirstname and personlastname and not fullname as you are suggesting. I would suggest splitting before input to this script.
Re: Version 3 : Batch Add Users and/or Aliases from CSV file
Post by percepts » 2013-07-16 14:03
** Version 4 - mod to create domain for an alias being added to missing domain**
This script adds Users and/or Aliases from a CSV file to your hMailServer installation. If the domain for an account/alias doesn't exist, then it is added before adding the account which uses it.
N.B. when a domain is added the hmailserver defaults are used for the domain. If you require anything other than the dafaults you must either edit the domain settings after this script has run or modify the script to use your own defaults.
The modifications include authorisation for hMailServer 5.x.x and also error trapping so that script will continue processing input file when duplicates are found. Domains are added if they don't exist. A popup summary of duplicates (already in HMS) and counts is produced. Any duplicates found are written to hmailserver_events.log with the summary count.
Option Explicit
Dim Elog
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Dim failed
Dim added
Dim domainsAdded
failed = 0
added = 0
domainsAdded = 0
Call obBaseApp.Authenticate("Administrator","password") '*** N.B. 1. set your administrator password in this line
       Case "User"
       Case "Alias"
    End Select
     failed = failed + 1
     err.Clear
     added = added + 1
Loop
On Error goto 0
   AddDomain strDomain
   Dim obDomain
   Dim obAliases
   Dim obNewAlias
   AddDomain strDomain
   Dim obDomain
   Dim obAccounts
   Dim obNewAccount
   Dim obNewDomain
   obNewDomain.Save()
   err.Clear
EntryType = User
Field1 = Uername
Field2 = Password
Field3 = DqmainName
EntryType = Alias
Field1 = AliasName
Field3 = DomainName
Good Luck !
iuliandr
Post by iuliandr » 2013-08-27 17:32
Hello and thank you for this script. Is there a possibility to also link users to Active Directory from within the script or the txt file? For example I have a single domain.local and all the added users would have the same login as the AD log. Could you please (if possible) guide me in the right direction?
Post by percepts » 2013-08-27 18:10
Assumption is you know how to program in VBScript and understand the Com API and the DB structure. If you don't then too bad.
See http://www.hmailserver.com/documentatio ... ct_account
You need to add three values in the adduser section of script and obviously modify input file structure and handling of its values in script. Should be obvious to anyone with a modicum of programming knowledge.
IsAD
ADDomain
ADUsername
benipelednet
Post by benipelednet » 2014-10-22 11:28
Good script - Thank you.
i wont to add "first name" & "last name" to hmailserver.
i was edit the script (below) and i get error "Failed or duplicate accounts"
Does anyone have an idea?
Thank you.
#####the script#####
Option Explicit
Dim Elog
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Dim failed
Dim added
Dim domainsAdded
failed = 0
added = 0
domainsAdded = 0
Call obBaseApp.Authenticate("Administrator","MKnet123") '*** N.B. 1. set your administrator password in this line
Set objTextFile = objFSO.OpenTextFile("user.csv", ForReading) 'N.B. 2. Set your CSV path/filename in this line
Case "User"
Case "Alias"
End Select
failed = failed + 1
err.Clear
added = added + 1
Loop
On Error goto 0
AddDomain strDomain
Dim obDomain
Dim obAliases
Dim obNewAlias
Sub AddUser(strUsername, strPassword, strDomain, strPersonFirstName, strPersonLastName)
AddDomain strDomain
Dim obDomain
Dim obAccounts
Dim obNewAccount
obNewAccount.PersonFirstName = PersonFirstName 'First name
obNewAccount.PersonLastName = PersonLastName 'Last name
Dim obNewDomain
obNewDomain.Save()
err.Clear
Post by percepts » 2014-10-22 15:02
two things I can see from a basic look at your code are that you have not included your new variables in the call to adduser and you have placed the move of inputs to user after the user account save so they will never be added.
You must do your own debugging of your own code.
jr3151006
Post by jr3151006 » 2014-12-09 22:32
If you allows me, here is the script v6 with the option to specify FirstName/LastName
'#####the script#####
'# The EntryType can be one of two options, User or Alias. If the EntryType is User, then:
'# EntryType = User
'# Field1 = Uername
'# Field2 = Password
'# Field3 = DqmainName
'# If the EntryType is Alias, then:
'# EntryType = Alias
'# Field1 = AliasName
'# Field2 = ForwardingEmail
'# Field3 = DomainName
'# To add USERS, for example, your CSV file should have the structured information (type, strUsername, strPassword, strDomain, strPersonFirstName, strPersonLastName), like below:
'# User,tjones,mypassword,jones.com,Tommy,Jones
'# To add ALIAS, for example, your CSV file should have the structured information (type, strAlias, strAliasUsername, strDomain), like below:
'# Alias,tommy,tjones@jones.com,jones.com
'# This would create a user names tjones@jones.com in the jones.com domain and an alias tommy@jones.com which will forward all e-mail to tjones@jones.com in the jones.com domain.
Option Explicit
Dim Elog
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Dim failed
Dim added
Dim domainsAdded
failed = 0
added = 0
domainsAdded = 0
'# Custom Variables regarding HMAIL admin password and file to be read
Dim hAdminpwd
Dim CSVFile
hAdminpwd = "#hMail@2015"
CSVFile = "bulk.csv"
Call obBaseApp.Authenticate("Administrator",hAdminpwd) '*** N.B. 1. set your administrator password in this line
Set objTextFile = objFSO.OpenTextFile(CSVFile, ForReading) 'N.B. 2. Set your CSV path/filename in this line
       Case "User"
          AddUser strNewAlias(1), strNewAlias(2), strNewAlias(3),strNewAlias(4),strNewAlias(5)
       Case "Alias"
    End Select
     failed = failed + 1
     err.Clear
     added = added + 1
Loop
On Error goto 0
'# Usefull functions
   AddDomain strDomain
   Dim obDomain
   Dim obAliases
   Dim obNewAlias
   AddDomain strDomain
   Dim obDomain
   Dim obAccounts
   Dim obNewAccount
   obNewAccount.PersonFirstName = strPersonFirstName
   obNewAccount.PersonLastName = strPersonLastName
   Dim obNewDomain
   obNewDomain.Save()
   err.Clear
Post by jimimaseye » 2017-08-10 12:25
Version 7.
Includes the fix for adding first name and last name. Also has modifications to make the 1st field ("alias or "user") case insensitive and ignores any leading and trailing spaces against each input field
'# EntryType = User
'# Field1 = Uername
Option Explicit
Dim Elog
Dim obBaseApp
Dim objFSO
Dim objTextFile
Dim strNewAlias,i
Dim failed
Dim added
Dim domainsAdded
failed = 0
added = 0
domainsAdded = 0
Dim hAdminpwd
Dim CSVFile
    Select Case lcase(trim(strNewAlias(0)))
       Case "user"
          AddUser trim(strNewAlias(1)), trim(strNewAlias(2)), trim(strNewAlias(3)),trim(strNewAlias(4)),trim(strNewAlias(5))
       Case "alias"
          AddAlias trim(strNewAlias(1)), trim(strNewAlias(2)), trim(strNewAlias(3))
    End Select
     failed = failed + 1
     err.Clear
     added = added + 1
Loop
On Error goto 0
   AddDomain strDomain
   Dim obDomain
   Dim obAliases
   Dim obNewAlias
   AddDomain strDomain
   Dim obDomain
   Dim obAccounts
   Dim obNewAccount
   Dim obNewDomain
   obNewDomain.Save()
   err.Clear
iorx
Post by iorx » 2017-11-20 02:51
You just became the hero of the day for me! :D
I had to setup a temporary e-mailserver for about 40 users. This script made my day (night more of). Thanks a bunch!
A quick structured CSV and all boxes was up and running, including First and Last name. Sad that not IMAP client can pick this up from the server though.
Made some minor modifications: Separator from "," to ";" and maxsize for the mailboxes to 8192MB.
I'll buy you a beverage of choice if you pass through Stockholm, Sweden anytime. Or, you got a paypal or similar I can contribute to?
Post by mattg » 2017-11-20 03:08
iorx wrote:Sad that not IMAP client can pick this up from the server though.
viewtopic.php?f=21&t=31549
Is that what you mean?
iorx
Post by iorx » 2017-11-20 04:21
uhu? Nice, had no idea! My google-fu is getting weak i presume.
Primary its iPhönes, mail and Android, Gmail, built in mail clients who's going to access the boxes. But I'll definitely do a little research finding this out.
Brgs,
ilpanos
Post by ilpanos » 2018-01-12 13:56
Is there a way to also add external accounts?
I am asking this because I see at the documentation of com_object_account that FetchAccounts is listed as read-only.
Post by jimimaseye » 2018-01-12 15:13
The collection has an ADD option https://www.hmailserver.com/documentati ... chaccounts
And fetchaccount Save() option to write any new/amended entries.
screenman47
Post by screenman47 » 2019-05-03 13:20
The script above works perfectly for me and my users. I have automated their adding of aliases in my system. BUT is there a script for the other way round - DELETE - the aliases from the system once they have finished with them. I do not write VBS scripts so no experience there.
Post by jimimaseye » 2019-05-03 13:38
screenman47 wrote:
2019-05-03 13:20
SEARCH facility is great: https://www.hmailserver.com/forum/viewt ... tive+users
