IP Blacklist - Block IPs (very basic but effective)
Post by percepts » 2014-09-02 18:04
Add following code to your Eventhandlers.vbs file in OnClientConnect so you have as follows:
Sub OnClientConnect(oClient)
 Dim IP
 IP = oClient.IPAddress
 Select Case IP
  Case _
   "1.1.1.1" _
  ,"2.2.2.2" _
  ,"3.3.3.3" _
  Result.Value = 1
  EventLog.Write ("Blacklist IP blocked: " & IP )
 End Select
For each IP you want to block, just duplicate last IP line and overtype with latest IP to block.
Don't forget to Reload Scripts in hMailAdmin for it to become effective.
glenluo
Re: IP Blacklist - Block IPs (very basic but effective)
Post by glenluo » 2014-09-20 09:10
Can use below to block single IP or IP range
Const BadIPGroup ="220.246.55.*|220.247.*.*|220.248.*.*|183.13.*.*"
If IsForbidIP(BadIPGroup) = True Then
   Result.Value = 2
   Result.Message = "IP in blacklist,server rejected!"
Function IsForbidIP(vBadIP)
   Dim counter, arrIPPart, arrBadIP, arrBadIPPart, i, j
   arrBadIP = Split(vBadIP, "|")
   arrIPPart = Split(oClient.IPAddress,".")
   For i = 0 To UBound(arrBadIP)
        counter = 0
        arrBadIPPart = Split(arrBadIP(i),".")
        For j = 0 To UBound(arrIPPart)
            If(arrBadIPPart(j)) = "*" or Cstr(arrIPPart(j)) = Cstr(arrBadIPPart(j)) Then
               counter = counter + 1
        If counter = 4 Then
           IsForbidIP = True
           Exit Function
    IsForbidIP = False
LesD
Post by LesD » 2017-07-17 10:20
Result.Value = 2
Is that value 2 above not a mistake?
The documentation defines values 0 and 1 only.
Post by jimimaseye » 2017-07-17 10:40
LesD wrote:
Result.Value = 2
Correct. Its accept or reject only.
(At the time of 'connect' no smtp conversation has commenced and so there is no possible way of giving an explanation for rejection).
LesD
Post by LesD » 2017-07-18 06:43
jimimaseye wrote:(At the time of 'connect' no smtp conversation has commenced and so there is no possible way of giving an explanation for rejection).
How is that? Surely hMS does not just disconnect. It must issue a 5xx message or similar so I would expect my 'message' to be added.
Post by RvdH » 2017-07-18 08:29
Why 'must' it issue a 5xx message or similar?
https://www.hmailserver.com/documentati ... entconnect
LesD
Post by LesD » 2017-07-18 15:36
I just thought it was 'the done thing' but you are of course right.....
I have written my own routine based on the above examples and tested it by putting in my own IP and indeed the connection was unceremoniously dropped. - Thunderbird was most upset about it!
I will post the code shortly but want to run it a bit longer just in case of problems.
I have read some other threads on this topic and have seen mention of using DNSBL for the blocking so I tried setting up a private one on one of my own domains and it was very simple!
So now I am not sure which way to go. The DNSBL is much more elegant and does not require any fiddling with code (much safer) while updating the DNS is a bit more long winded (have to log into my domain registrar's account, find the domain and add a record to the DNS.)
(Most elegant and convenient would be a Blacklist facility iwithn hMS but I have seen that Martin is not keen on including it).
LesD
Post by LesD » 2017-07-21 12:29
Here is my code. It has been running for a few days and I tested it by putting in my own IP.
' Check current connection IP against list.  Returns true if IP is banned
	If IsBadIP(BadIP,oClient) Then
		Result.Value = 1 ' 0 = accept connection; 1 = reject
		EventLog.Write "Client IP " & oClient.IPAddress & " rejected. Part of blacklist range " & BadIP
		Exit Sub
	Result.Value = 0 ' 0 = accept connection; 1 = reject
Function IsBadIP(BadIP,oClient)
' BadIP: Returns IP range to which the client IP matches
' Add IP or IP range below using separator: |
' Each block is defined as either a single IP or the last lart can be defined as a range
' e.g. 67.212.82.1|67.212.82.98-102
' 67.212.82.98-102=search engine registration
	Const BadIPList ="67.212.82.98-102"
	Dim aIPClientParts, IPClientInt, aBadIPList, aBadIPPart, aBadIPRange, IntStart, IntEnd, i
' Split up blacklist into individual IP values
	aBadIPList = Split(BadIPList, "|")
' Split up client IP into 4 parts and convert to integer value
	aIPClientParts = Split(oClient.IPAddress,".")
	IPClientInt = IPtoInt(aIPClientParts(0), aIPClientParts(1), aIPClientParts(2), aIPClientParts(3))
' Now process each bad IP value (or range)
	For i = 0 To UBound(aBadIPList)
	  ' Split blacklisted IP into 4 parts
		aBadIPParts = Split(aBadIPList(i),".")
	  ' The 4th part (index 3) could be a single number or a range in the form nnn-mmm
	  ' so try and split it
		aBadIPRange = Split(aBadIPParts(3),"-")
	  ' Define Start and End IPs:
	  ' If there is no range then define both the same
		if UBound(aBadIPRange) = 0 then
		  ' Convert IP parts to long integer
			IntStart = IPtoInt(aBadIPParts(0), aBadIPParts(1), aBadIPParts(2), aBadIPParts(3))
			IntEnd = IntStart
		else
		  ' There is a range - start and end differ
			IntStart = IPtoInt(aBadIPParts(0), aBadIPParts(1), aBadIPParts(2), aBadIPRange(0))
			IntEnd = IPtoInt(aBadIPParts(0), aBadIPParts(1), aBadIPParts(2), aBadIPRange(1))
		end if
	  ' Is client IP within the range?
		if IPClientInt >= IntStart and IPClientInt <= IntEnd then
			IsBadIP = True
		  ' Return IP range in which found
			BadIP = aBadIPList(i)
			Exit Function
	  ' IP is not in range
' All OK
	IsBadIP = False
	BadIP = ""
Function IPtoInt(IP0, IP1, IP2, IP3)
	Dim arrIPClient
' Convert 4 parts to integer
    IPtoInt = IP3 + IP2*256 + IP1*256*256 + IP0*256*256*256
'WriteLog "IPtoInt", "IPaddress=" & IP0 & "." & IP1 & "." & IP2 & "." & IP3 & " Int=" & IPtoInt
Post by RvdH » 2017-07-21 12:47
Guess this can be made faster (regex) and simplified...check my signature for IpRangeRegex generator
	Dim strRegEx
	strRegEx="^67\.212\.82\.(9[8-9])$|" &_
			 "^67\.212\.82\.(1(0[0-1]))$|" &_
			 "^67\.212\.82\.102$"
	If Lookup(strRegEx, oClient.IPAddress) Then
		Result.Value = 1
	End if
		.Global = False
		.Pattern = strRegEx
		.IgnoreCase = True
		Lookup = .Test(strMatch)
Post by SorenR » 2017-08-02 15:48
Never thought the day would come... I'm now officially spamlisting Symantec... :wink:
"SMTPD"	1472	4038	"2017-08-02 08:04:59.115"	"216.82.251.13"	"SENT: 220 mx.acme.inc ESMTP"
"SMTPD"	1472	4038	"2017-08-02 08:04:59.318"	"216.82.251.13"	"RECEIVED: EHLO mail1.bemta12.messagelabs.com"
"SMTPD"	1472	4038	"2017-08-02 08:04:59.334"	"216.82.251.13"	"SENT: 250-mx.acme.inc[nl]250 SIZE"
"SMTPD"	1472	4038	"2017-08-02 08:04:59.537"	"216.82.251.13"	"RECEIVED: MAIL FROM:<heifner.deleon@grupobimbo.com>"
"SMTPD"	1472	0	"2017-08-02 08:04:59.537"	"TCP"	"DNS lookup: 13.251.82.216.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"SMTPD"	1472	0	"2017-08-02 08:04:59.537"	"TCP"	"DNS lookup: 13.251.82.216.b.barracudacentral.org, 0 addresses found: (none), Match: False"
"SMTPD"	1472	0	"2017-08-02 08:04:59.537"	"TCP"	"DNS lookup: 13.251.82.216.bl.spamcop.net, 0 addresses found: (none), Match: False"
"SMTPD"	1472	4038	"2017-08-02 08:05:00.537"	"216.82.251.13"	"SENT: 250 OK"
"SMTPD"	1472	4038	"2017-08-02 08:05:00.740"	"216.82.251.13"	"RECEIVED: RCPT TO:<louise@acme.inc>"
"SMTPD"	1472	4038	"2017-08-02 08:05:00.740"	"216.82.251.13"	"SENT: 250 OK"
"SMTPD"	1472	4038	"2017-08-02 08:05:00.943"	"216.82.251.13"	"RECEIVED: DATA"
"SMTPD"	1472	4038	"2017-08-02 08:05:00.959"	"216.82.251.13"	"SENT: 354 OK, send."
"SMTPD"	3972	4038	"2017-08-02 08:05:03.865"	"216.82.251.13"	"SENT: 250 Queued (2.875 seconds)"
"SMTPD"	3128	4038	"2017-08-02 08:05:09.068"	"216.82.251.13"	"RECEIVED: QUIT"
"SMTPD"	3128	4038	"2017-08-02 08:05:09.068"	"216.82.251.13"	"SENT: 221 goodbye"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.131"	"216.82.251.6"	"SENT: 220 mx.acme.inc ESMTP"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.334"	"216.82.251.6"	"RECEIVED: EHLO mail1.bemta12.messagelabs.com"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.334"	"216.82.251.6"	"SENT: 250-mx.acme.inc[nl]250 SIZE"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.537"	"216.82.251.6"	"RECEIVED: MAIL FROM:<heifner.deleon@grupobimbo.com>"
"SMTPD"	1472	0	"2017-08-02 08:05:24.537"	"TCP"	"DNS lookup: 6.251.82.216.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"SMTPD"	1472	0	"2017-08-02 08:05:24.537"	"TCP"	"DNS lookup: 6.251.82.216.b.barracudacentral.org, 0 addresses found: (none), Match: False"
"SMTPD"	1472	0	"2017-08-02 08:05:24.537"	"TCP"	"DNS lookup: 6.251.82.216.bl.spamcop.net, 0 addresses found: (none), Match: False"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.553"	"216.82.251.6"	"SENT: 250 OK"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.741"	"216.82.251.6"	"RECEIVED: RCPT TO:<louise@acme.inc>"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.756"	"216.82.251.6"	"SENT: 250 OK"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.944"	"216.82.251.6"	"RECEIVED: DATA"
"SMTPD"	1472	4040	"2017-08-02 08:05:24.959"	"216.82.251.6"	"SENT: 354 OK, send."
"SMTPD"	3972	4040	"2017-08-02 08:05:26.537"	"216.82.251.6"	"SENT: 250 Queued (1.547 seconds)"
"SMTPD"	3892	4040	"2017-08-02 08:05:31.741"	"216.82.251.6"	"RECEIVED: QUIT"
"SMTPD"	3892	4040	"2017-08-02 08:05:31.741"	"216.82.251.6"	"SENT: 221 goodbye"
MessageLabs Inc. : 216.82.240.0 - 216.82.255.255
RegEx: ^216\.82\.(2(4[0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$
http://www.analyticsmarket.com/freetools/ipregex
Yes, my daughter is currently blonde, but that does not justify this domain... "@grupobimbo.com" ... Hmm...
      ' More code ...
      If Not (oMessage.HeaderValue("X-hMailServer-Spam") = "YES") Then
         ' 216.82.240.0 - 216.82.255.255 = MessageLabs Inc. (Symantec Inc.)
         strRegEx = "^216\.82\.(2(4[0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$"
         If Lookup(strRegEx, oClient.IPAddress) Then Call SPAMList(oMessage)
      ' More code ...
         .Global = False
         .Pattern = strRegEx
         .IgnoreCase = True
   Sub SPAMList(oMessage)
      oMessage.HeaderValue("X-hMailServer-Reason-0") = "SPAMlisted - (Score: 5)"
      oMessage.HeaderValue("X-hMailServer-Reason-Score") = 5
Post by RvdH » 2017-08-02 16:22
SorenR wrote: Yes, my daughter is currently blonde, but that does not justify this domain... "@grupobimbo.com" ... Hmm...
:lol: :lol: :lol:
A bit harsh to block/mark all mail that derived from Symantec/messagelabs like that because of a single message... what if a spam mail arrives to you from a gmail account?
	case "google.com"
		oRegEx.Pattern= "^64\.18\.([0-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^64\.233\.(1([6-8][0-9]|9[0-1]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^66\.102\.([0-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^66\.249\.(8[0-9]|9[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^72\.14\.(1(9[2-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^74\.125\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^108\.177\.([8-9]|1[0-5])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^173\.194\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^207\.126\.(1(4[4-9]|5[0-9]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^209\.85\.(1(2[8-9]|[3-9][0-9])|2([0-4][0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^216\.58\.(1(9[2-9])|2([0-1][0-9]|2[0-3]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^216\.239\.(3[2-9]|[4-5][0-9]|6[0-3])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^172\.217\.([0-9]|[1-2][0-9]|3[0-1])\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$|" &_
						"^108\.177\.(9[6-9]|1([0-1][0-9]|2[0-7]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$"
:shock: :wink:
Post by SorenR » 2017-08-02 17:53
:lol: :lol: :lol:
:shock: :wink:
Nah...
Symantec.Core (MessageLabs) sending me SPAM is like the police trying to sell me a stolen car ... :mrgreen:
Post by RvdH » 2017-08-02 19:04
SorenR wrote: Nah...
lol, if you look at it like that i have to say you are right :mrgreen: :lol:
