.BAT FILE TO SEND EMAIL
billyhughes_2015
Post by billyhughes_2015 » 2015-07-28 17:26
All,
I am running software that monitors various programs on pc to see if they are running properly. I would like to create a .bat file that will send a message from hmail, when this software calls the .bat file. I have tried with no success so far. Preferably a script that populates the email and sends it with no user interaction so that after hours I will get a notification if something is running correctly.
Hopefully this makes sense. :?:
Thank you,
Re: .BAT FILE TO SEND EMAIL
Post by jimimaseye » 2015-07-28 18:09
Use BLAT.EXE. I do. http://www.blat.net/
Usage:
blat.exe -mailfrom %emailFrom% -to %emailRecipient% -body "%body%" -subject "%subj%" -server localhost
Or you could go a bit more complicated and do your own script. This will get you started (CHECK IT and MODIFY IT YOURSELF before using for correct parameters etc):
VBSEmailer.vbs
rem *  This script is a result of testing to create a method alternative to using Blat.exe
rem *
rem *  It needed to be able to calling to send an email whilst being unreliant/outside of hmailserver API.
rem *  In particular it was necessary to be able to attach a Text file (eg, Log file) that would
rem *  be attached to the sending emial and appear 'Inline' (as was possible with Blat).
rem *
rem * The conclusion is that this WORKS!  But it doesnt give anything more/better than what Blat does.  :-)
rem *  (It was just a proof of concept).
rem *
rem * It is CALLED by VBSEmailer.bat (which passes all the parameters)
SendFrom = WScript.Arguments.Named("SendFrom")
SendFromAddress = WScript.Arguments.Named("SendFromAddress")
SendSubject = WScript.Arguments.Named("SendSubject")
SendAddRecipient = WScript.Arguments.Named("SendAddRecipient")
SendBody = WScript.Arguments.Named("SendBody")
SendFile = WScript.Arguments.Named("SendFile")
Dim strLogFileName
strLogFileName = "C:\Users\Administrator\Documents\BatchFiles\emailer.log"
if SendFile <> "" then
	SendFileTrim = objFSO.GetFileName(SendFile)
if objFSO.FileExists(strLogFileName) Then
 Set myLog = objFSO.OpenTextFile(strLogFileName, 8 , True)
 Set myLog = objFSO.CreateTextFile(strLogFileName)
 End if
myLog.WriteLine now & " ------------Start of Session-----------------"
myLog.WriteLine "Sending " & SendFile & " to " & SendAddRecipient
myLog.WriteLine "Subject: " & SendSubject
myLog.WriteLine "From: " & SendFromAddress
myLog.WriteLine "Attached text file: " & SendFile
Const cdoSendUsingPickup = 1 'Send message using the local SMTP service pickup directory.
Const cdoSendUsingPort = 2 'Send the message using the network (SMTP over the network).
Const cdoAnonymous = 0 'Do not authenticate
Const cdoBasic = 1 'basic (clear-text) authentication
Const cdoNTLM = 2 'NTLM
Set objMessage = CreateObject("CDO.Message")
objMessage.Subject = SendSubject
objMessage.From = SendFrom
objMessage.To = SendAddRecipient
objMessage.TextBody = SendBody
objMessage.Configuration.Fields.Item _
("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
'Name or IP of Remote SMTP Server
("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "192.168.0.200"  ' <-- your server hostname or IP address
("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = cdoBasic
'Your UserID on the SMTP server
("http://schemas.microsoft.com/cdo/configuration/sendusername") = "sendinguser@yourdomain.com"
'Your password on the SMTP server
("http://schemas.microsoft.com/cdo/configuration/sendpassword") = "secretpassword"
'Server port (typically 25)
("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
'Use SSL for the connection (False or True)
("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = False
objMessage.Configuration.Fields.Update
'==End remote SMTP server configuration section==
Dim iBp1
Dim iBp2
Set iBp1 = objMessage.BodyPart
Set Flds = iBp1.Fields
Flds("urn:schemas:mailheader:content-type") = "text/html"
Flds.Update
Set iBp2 = iBp1.AddBodyPart
With iBp2
   .ContentMediaType        = "text/plain"
   .ContentTransferEncoding = "quoted-printable"
   Set Flds = iBp2.Fields
   Flds("urn:schemas:mailheader:content-disposition") = "attachment; filename="""&SendFileTrim&""""
   Flds.Update
   Set Stm = .GetDecodedContentStream
   Stm.LoadFromFile SendFile
   Stm.Flush
Stm.Close
Set Stm = Nothing
objMessage.Send
myLog.WriteLine now & " -------------End of Session------------------"
myLog.WriteLine "**********************************"
myLog.Close
The above can be called with the following bat:
echo off
cls
rem *
rem *
rem *
rem * It calls VBSEmailer.vbs to do the work (which also logs to Emailer.log)
set emailRecipient="defaultreceipient@yourdomain.com"
set /p "emailRecipient=Email Recipient [%emailRecipient%]--> "
set emailFrom="defaultsender@yourdomain.com"
set /p "emailFrom=Email FROM [%emailFrom%]--> "
set subj="TEST default subject"
set /p "subj=Subject: [%subj%]--> "
echo %subj%
set SendFile="d:\backups\Backup_2015-04-17-200000.log"
set /p "SendFile=Attachment [%SendFile%]--> "
set body=Here is some random body text.
set /p "body=Body Text: [%body%]--> "
cscript.exe //NoLogo VBSEmailer.vbs /SendFrom:%emailFrom% /SendFromAddress:%emailFrom% /SendAddRecipient:%emailRecipient% /SendSubject:"%subj%" /SendBody:"%body%" /SendFile:%SendFile%
Better still, go for BLAT. :-)
The above is offered to you as A CLUE on how you can acheive things but you will need to read, understand and adapt the methods to suit your monitoring processes.
billyhughes_2015
Post by billyhughes_2015 » 2015-07-28 18:14
Thank you jimimaseye for the quick response.
I'll give blat a try and let you know.
Thanks,
Post by jimimaseye » 2015-07-28 19:25
Cheers
alescan
Post by alescan » 2016-03-02 16:40
I don't know if you solved the problem but i post my solution anyway:
I use powershell function to send the email that is more simpler for me and call the script form a .bat
Here the powershell file mail.ps1
Function Send-EMail {
    Param (
        [Parameter(`
            Mandatory=$true)]
        [String]$EmailTo,
        [Parameter(`
            Mandatory=$true)]
        [String]$Subject,
        [Parameter(`
            Mandatory=$true)]
        [String]$Body,
        [Parameter(`
            Mandatory=$true)]
        [String]$Password
		$EmailFrom = "user@domain"
        $SMTPServer = "HMAIL IP"
        $SMTPMessage = New-Object System.Net.Mail.MailMessage($EmailFrom,$EmailTo,$Subject,$Body)
        $SMTPClient = New-Object Net.Mail.SmtpClient($SmtpServer, 25)
        $SMTPClient.EnableSsl = $true
        $SMTPClient.Credentials = New-Object System.Net.NetworkCredential($EmailFrom, $Password);
        $SMTPClient.Send($SMTPMessage)
        Remove-Variable -Name SMTPClient
        Remove-Variable -Name Password
} #End Function Send-EMail
Send-EMail -EmailTo "EMAIL@TO" -Body "YOUR MESSAGE" -Subject "YOUR SUBHECT" -password "accountFROMpsw"
the -password option is the password for the sender email account
and you call it from send.bat
powershell.exe C:\Users\Administrator\Desktop\mail.ps1
Hope could be helpful
Post by jimimaseye » 2016-03-02 19:27
Cheers Alescan, good for those that have powershell at their disposal. THat mean we have offered 3 options (VBS, a readymade EXE and powershell) now - variety is good.
Do you have a version that attaches files (and maybe also places them inline? (The VBS above does similar for guidance))
alescan
Post by alescan » 2016-03-03 11:02
If you want to attach a file is very simple, on the las line you add the option -attachment
So it become
    Param (
        [Parameter(`
            Mandatory=$true)]
        [String]$EmailTo,
        [Parameter(`
            Mandatory=$true)]
        [String]$Subject,
        [Parameter(`
            Mandatory=$true)]
        [String]$Body,
        [Parameter(`
            Mandatory=$true)]
        [String]$Password
        $new_file="path to file"
Send-EMail -EmailTo "EMAIL@TO" -Body "YOUR MESSAGE" -Subject "YOUR SUBHECT" -password "accountFROMpsw" -attachment $new_file
Post by jimimaseye » 2016-03-03 11:21
Do you have to edit that .PS1 script every time (to enter whatever 'sender', 'subject', 'body' 'attachment' etc) before you then call it with the BAT? Is there not a way to make it universal so the parameters can be entered at time of calling from the BAT ?
Porngpisey
Post by Porngpisey » 2017-03-14 08:49
Hi alescan,
I just follow your instruction but i have a problem as in the attached file.
Do i have to configure the powershell.exe?
Best regards,
PS
alescan
Post by alescan » 2017-03-14 09:32
Is a powershell security error, type this first (https://technet.microsoft.com/en-us/lib ... 76961.aspx):
Set-ExecutionPolicy Unrestricted
so you tell PS to run every script.
Now that you can run your script.
cusegrad1998
Post by cusegrad1998 » 2017-08-30 23:30
I tried doing the powershell script and am getting the following error. looks like a syntax error, but i copied exactly the code from before. Here's the error? any ideas?
Missing closing ')' in expression.
At C:\ibex\utils\extract\dailymail.ps1:7 char:13
+ <<<< Mandatory=$true)]
+ CategoryInfo : ParserError: (CloseParenToken:TokenId) [], Parse
Exception
+ FullyQualifiedErrorId : MissingEndParenthesisInExpression
Code I am using is below:
Param (
[Parameter('
Mandatory=$true)]
[String]$EmailTo,
[Parameter('
Mandatory=$true)]
[String]$Subject,
[Parameter('
Mandatory=$true)]
[String]$Body,
[Parameter('
Mandatory=$true)]
[String]$Password
$EmailFrom = "pturnbull@harriscomputer.com"
$SMTPServer = "mail.harriscomputer.com"
$new_file="C:\ibex\utils\extract\Logs\DailyAuthReports.zip"
Send-EMail -EmailTo "xxxxx" -Body "This is your daily automated access logs delivery" -Subject "Daily Logs" -password "xxxxx" -attachment $new_file
Post by jimimaseye » 2017-08-30 23:41
I dont know about scripting in powershell but I note that your script uses standard apostrophes ' ' where as the original one uses back-apostrophes ` `
ie
yours:
    Param (
        [Parameter('
            Mandatory=$true)]
        [String]$EmailTo,
        [Parameter('
            Mandatory=$true)]
Original from Alescan:
    Param (
        [Parameter(`
            Mandatory=$true)]
        [String]$EmailTo,
        [Parameter(`
            Mandatory=$true)]
Perhaps its them?
tunis
Post by tunis » 2017-08-31 08:50
Your error says: MissingEndParenthesisInExpression
Why are end parenthesis missing?
You are missing apostrophes after $true.
Param (
[Parameter('
Mandatory=$true')]
[String]$EmailTo,
[Parameter('
Mandatory=$true')]
[String]$Subject,
[Parameter('
Mandatory=$true')]
[String]$Body,
[Parameter('
Mandatory=$true')]
[String]$Password
cusegrad1998
Post by cusegrad1998 » 2017-08-31 16:12
Thanks for the assistance. I'm nearly there. the ` was the first issue you helped solve, now it just can't find the named parameter -attachment. (and yes, i triple checked the mapped drive location to the attachment). Been staring at this for an hour now...
new error message = Send-EMail : A parameter cannot be found that matches parameter name 'attachment'.
At C:\ibex\utils\extract\dailymail.ps1:32 char:184
Here's the new code im using:
Param (
[Parameter(`
Mandatory=$true)]
[String]$EmailTo,
[Parameter(`
Mandatory=$true)]
[String]$Subject,
[Parameter(`
Mandatory=$true)]
[String]$Body,
[Parameter(`
Mandatory=$true)]
[String]$Password,
[Parameter(`
Mandatory=$true)]
[String]$new_file
$EmailFrom = "xxxxxx@harriscomputer.com"
$SMTPServer = "mail.xxxxx.com"
$SMTPMessage = New-Object System.Net.Mail.MailMessage($EmailFrom,$EmailTo,$Subject,$Body,$new_file)
$new_file="C:\ibex\utils\extract\Logs\DailyAuthLog.xls"
} #End
Send-EMail -EmailTo "xxxxxxx" -Body "This is your daily automated eRx access logs delivery" -Subject "Daily eRx Logs" -password "xxxxx" -attachment $new_file
tunis
Post by tunis » 2017-08-31 16:59
cusegrad1998 wrote:new error message = Send-EMail : A parameter cannot be found that matches parameter name 'attachment'.
In your script the parameter name is new_file, also you have declared $new_file in the end off the function.
Try this
Param (
[Parameter(`
Mandatory=$true)]
[String]$EmailTo,
[Parameter(`
Mandatory=$true)]
[String]$Subject,
[Parameter(`
Mandatory=$true)]
[String]$Body,
[Parameter(`
Mandatory=$true)]
[String]$Password,
[Parameter(`
Mandatory=$true)]
[String]$Attachment
$SMTPMessage = New-Object System.Net.Mail.MailMessage($EmailFrom,$EmailTo,$Subject,$Body,$Attachment)
} #End
Send-EMail -EmailTo "xxxxxxx" -Body "This is your daily automated eRx access logs delivery" -Subject "Daily eRx Logs" -Password "xxxxx" -Attachment "C:\ibex\utils\extract\Logs\DailyAuthLog.xls"
cusegrad1998
Post by cusegrad1998 » 2017-08-31 22:34
So, I was finally able to get this thing to work. had to add a few lines of code to actually "add" the referenced attachment to the SMTP call. Final code that is working looks like this.
I highlighted the lines of code I added. Thanks for all the help!
Param (
[Parameter(`
Mandatory=$true)]
[String]$EmailTo,
[Parameter(`
Mandatory=$true)]
[String]$Subject,
[Parameter(`
Mandatory=$true)]
[String]$Body,
[Parameter(`
Mandatory=$true)]
[String]$Password,
[Parameter(`
Mandatory=$true)]
[String]$Attachment
$EmailFrom = "xxxx@xxxx"
$SMTPServer = "xxxx.xxxx.com"
$Att = New-Object System.Net.Mail.Attachment($Attachment)
$SMTPMessage.Attachments.add($Att)
} #End
Send-EMail -EmailTo "xxxx@xxx.com" -Body "This is your daily automated eRx access logs delivery" -Subject "Daily eRx Logs" -Password "xxxxxxx" -Attachment "C:\ibex\utils\extract\Logs\DailyAuthReports.zip"
Post by mattg » 2017-09-01 01:00
Just noticed the eRX....
You are from my world, Aussie Healthcare..
cusegrad1998
Post by cusegrad1998 » 2017-09-01 01:15
Mattg, I feel your pain. :x
