' EventHandler script used to check mail attachments on VirusTotal fired from hMailServer
' The script do the following things:
' cycle the message attachments
' save them in a temp folder
' compute a MD5 checksum fo the attachment and delete the temporary file
' query VirusTotal API to check if the MD5 is present
' parse the json response and
' if empty response write to eventlog
' if valid response and response_code is "0", the file is not present in VirusTotal, only write the event log
' if positives <>"0" the file is known to VirusTotal as dangerous, so the attachment is removed and the
' mail subject tagged with the custom prefix
' Version 1.0 2017/07/20
' Go to OnAcceptMessage sub and define the following constants
' Const tempPath = "e:\hMailServer\events\temp\" ' existing path where the attachments will be temporarly stored
' Const apikey ="you virustotal api key, got after registration"
' Const prefix = "[VIRUSTOTAL-REMOVED-ATTACHMENT] " ' a prefix injected before original mail subject if dangerous attachment found and removed
' Functions to compute MD5
' source https://stackoverflow.com/questions/10198690/how-to-generate-md5-using-vbscript-in-classic-asp thanks to "SgtWilko"
function md5hashBytes(aBytes)
Dim MD5
set MD5 = CreateObject("System.Security.Cryptography.MD5CryptoServiceProvider")
MD5.Initialize()
'Note you MUST use computehash_2 to get the correct version of this method, and the bytes MUST be double wrapped in brackets to ensure they get passed in correctly.
md5hashBytes = MD5.ComputeHash_2( (aBytes) )
end function
function sha1hashBytes(aBytes)
Dim sha1
set sha1 = CreateObject("System.Security.Cryptography.SHA1Managed")
sha1.Initialize()
sha1hashBytes = sha1.ComputeHash_2( (aBytes) )
end function
function sha256hashBytes(aBytes)
Dim sha256
set sha256 = CreateObject("System.Security.Cryptography.SHA256Managed")
sha256.Initialize()
sha256hashBytes = sha256.ComputeHash_2( (aBytes) )
end function
function sha256HMACBytes(aBytes, aKey)
Dim sha256
set sha256 = CreateObject("System.Security.Cryptography.HMACSHA256")
sha256.Initialize()
sha256.key=aKey
sha256HMACBytes = sha256.ComputeHash_2( (aBytes) )
end function
function stringToUTFBytes(aString)
Dim UTF8
Set UTF8 = CreateObject("System.Text.UTF8Encoding")
stringToUTFBytes = UTF8.GetBytes_4(aString)
end function
function bytesToHex(aBytes)
dim hexStr, x
for x=1 to lenb(aBytes)
hexStr= hex(ascb(midb( (aBytes),x,1)))
if len(hexStr)=1 then hexStr="0" & hexStr
bytesToHex=bytesToHex & hexStr
next
end function
Function BytesToBase64(varBytes)
With CreateObject("MSXML2.DomDocument").CreateElement("b64")
.dataType = "bin.base64"
.nodeTypedValue = varBytes
BytesToBase64 = .Text
'Special version that produces the URLEncoded variant of Base64 used in JWTs.
Function BytesToBase64UrlEncode(varBytes)
BytesToBase64UrlEncode = replace(replace(replace(replace(replace(.Text,chr(13),""),chr(10),""),"+", "-"),"/", "_"),"=", "")
Function GetBytes(sPath)
With CreateObject("Adodb.Stream")
.Type = 1 ' adTypeBinary
.Open
.LoadFromFile sPath
.Position = 0
GetBytes = .Read
.Close
' Class used to parse Json response
' source http://demon.tw/my-work/vbs-json.html
Class VbsJson
'Author: Demon
'Date: 2012/5/3
'Website: http://demon.tw
Private Whitespace, NumberRegex, StringChunk
Private b, f, r, n, t
Private Sub Class_Initialize
Whitespace = " " & vbTab & vbCr & vbLf
b = ChrW(8)
f = vbFormFeed
r = vbCr
n = vbLf
t = vbTab
Set NumberRegex = New RegExp
NumberRegex.Pattern = "(-?(?:0|[1-9]\d*))(\.\d+)?([eE][-+]?\d+)?"
NumberRegex.Global = False
NumberRegex.MultiLine = True
NumberRegex.IgnoreCase = True
Set StringChunk = New RegExp
StringChunk.Pattern = "([\s\S]*?)([""\\\x00-\x1f])"
StringChunk.Global = False
StringChunk.MultiLine = True
StringChunk.IgnoreCase = True
'Return a JSON string representation of a VBScript data structure
'Supports the following objects and types
'| VBScript | JSON |
'| Dictionary | object |
'| Array | array |
'| String | string |
'| Number | number |
'| True | true |
'| False | false |
'| Null | null |
Public Function Encode(ByRef obj)
Dim buf, i, c, g
Set buf = CreateObject("Scripting.Dictionary")
Select Case VarType(obj)
Case vbNull
buf.Add buf.Count, "null"
Case vbBoolean
If obj Then
buf.Add buf.Count, "true"
buf.Add buf.Count, "false"
Case vbInteger, vbLong, vbSingle, vbDouble
buf.Add buf.Count, obj
Case vbString
buf.Add buf.Count, """"
For i = 1 To Len(obj)
c = Mid(obj, i, 1)
Select Case c
Case """" buf.Add buf.Count, "\"""
Case "\" buf.Add buf.Count, "\\"
Case "/" buf.Add buf.Count, "/"
Case b buf.Add buf.Count, "\b"
Case f buf.Add buf.Count, "\f"
Case r buf.Add buf.Count, "\r"
Case n buf.Add buf.Count, "\n"
Case t buf.Add buf.Count, "\t"
Case Else
If AscW(c) >= 0 And AscW(c) <= 31 Then
c = Right("0" & Hex(AscW(c)), 2)
buf.Add buf.Count, "\u00" & c
buf.Add buf.Count, c
End Select
Case vbArray + vbVariant
g = True
buf.Add buf.Count, "["
For Each i In obj
If g Then g = False Else buf.Add buf.Count, ","
buf.Add buf.Count, Encode(i)
buf.Add buf.Count, "]"
Case vbObject
If TypeName(obj) = "Dictionary" Then
g = True
buf.Add buf.Count, "{"
For Each i In obj
buf.Add buf.Count, """" & i & """" & ":" & Encode(obj(i))
buf.Add buf.Count, "}"
Err.Raise 8732,,"None dictionary object"
Case Else
buf.Add buf.Count, """" & CStr(obj) & """"
End Select
Encode = Join(buf.Items, "")
'Return the VBScript representation of ``str(``
'Performs the following translations in decoding
'| JSON | VBScript |
'| object | Dictionary |
'| array | Array |
'| string | String |
'| number | Double |
'| true | True |
'| false | False |
'| null | Null |
Public Function Decode(ByRef str)
Dim idx
idx = SkipWhitespace(str, 1)
If Mid(str, idx, 1) = "{" Then
Set Decode = ScanOnce(str, 1)
Private Function ScanOnce(ByRef str, ByRef idx)
Dim c, ms
idx = SkipWhitespace(str, idx)
c = Mid(str, idx, 1)
If c = "{" Then
idx = idx + 1
Set ScanOnce = ParseObject(str, idx)
Exit Function
ElseIf c = "[" Then
idx = idx + 1
ScanOnce = ParseArray(str, idx)
Exit Function
ElseIf c = """" Then
idx = idx + 1
ScanOnce = ParseString(str, idx)
Exit Function
ElseIf c = "n" And StrComp("null", Mid(str, idx, 4)) = 0 Then
idx = idx + 4
ScanOnce = Null
Exit Function
ElseIf c = "t" And StrComp("true", Mid(str, idx, 4)) = 0 Then
idx = idx + 4
ScanOnce = True
Exit Function
ElseIf c = "f" And StrComp("false", Mid(str, idx, 5)) = 0 Then
idx = idx + 5
ScanOnce = False
Exit Function
Set ms = NumberRegex.Execute(Mid(str, idx))
If ms.Count = 1 Then
idx = idx + ms(0).Length
ScanOnce = CDbl(ms(0))
Exit Function
Err.Raise 8732,,"No JSON object could be ScanOnced"
Private Function ParseObject(ByRef str, ByRef idx)
Dim c, key, value
Set ParseObject = CreateObject("Scripting.Dictionary")
If c = "}" Then
Exit Function
ElseIf c <> """" Then
Err.Raise 8732,,"Expecting property name"
idx = idx + 1
Do
key = ParseString(str, idx)
If Mid(str, idx, 1) <> ":" Then
Err.Raise 8732,,"Expecting : delimiter"
idx = SkipWhitespace(str, idx + 1)
Set value = ScanOnce(str, idx)
ParseObject.Add key, value
If c = "}" Then
Exit Do
ElseIf c <> "," Then
Err.Raise 8732,,"Expecting , delimiter"
If c <> """" Then
idx = idx + 1
Loop
idx = idx + 1
Private Function ParseArray(ByRef str, ByRef idx)
Dim c, values, value
Set values = CreateObject("Scripting.Dictionary")
If c = "]" Then
idx = idx + 1
ParseArray = values.Items
Exit Function
Do
values.Add values.Count, value
If c = "]" Then
Exit Do
idx = idx + 1
Loop
idx = idx + 1
Private Function ParseString(ByRef str, ByRef idx)
Dim chunks, content, terminator, ms, esc, char
Set chunks = CreateObject("Scripting.Dictionary")
Do
Set ms = StringChunk.Execute(Mid(str, idx))
If ms.Count = 0 Then
Err.Raise 8732,,"Unterminated string starting"
content = ms(0).Submatches(0)
terminator = ms(0).Submatches(1)
If Len(content) > 0 Then
chunks.Add chunks.Count, content
If terminator = """" Then
Exit Do
ElseIf terminator <> "\" Then
Err.Raise 8732,,"Invalid control character"
esc = Mid(str, idx, 1)
If esc <> "u" Then
Select Case esc
Case """" char = """"
Case "\" char = "\"
Case "/" char = "/"
Case "b" char = b
Case "f" char = f
Case "n" char = n
Case "r" char = r
Case "t" char = t
Case Else Err.Raise 8732,,"Invalid escape"
End Select
idx = idx + 1
char = ChrW("&H" & Mid(str, idx + 1, 4))
idx = idx + 5
chunks.Add chunks.Count, char
Loop
ParseString = Join(chunks.Items, "")
Private Function SkipWhitespace(ByRef str, ByVal idx)
Do While idx <= Len(str) And _
InStr(Whitespace, Mid(str, idx, 1)) > 0
idx = idx + 1
Loop
SkipWhitespace = idx
End Class
' functions to query url
Function BinaryToString(Binary)
Dim I,S
For I = 1 to LenB(Binary)
S = S & Chr(AscB(MidB(Binary,I,1)))
BinaryToString = S
Function getURL(URL)
'Create an Http object, use any of the four objects
Dim Http
Dim origHTML
' Set Http = CreateObject("Microsoft.XMLHTTP")
' Set Http = CreateObject("MSXML2.ServerXMLHTTP")
Set Http = CreateObject("MSXML2.ServerXMLHTTP.3.0")
' Set Http = CreateObject("WinHttp.WinHttpRequest.5.1")
'' Set Http = CreateObject("WinHttp.WinHttpRequest")
'Set Http = CreateObject("Microsoft.XmlHttp")
' Set Http = CreateObject("microsoft.xmlhttp")
'Send request To URL
Http.Open "POST", URL, FALSE
Http.Send ""
'Get response data As a string
getURL = BinaryToString(Http.ResponseBody)
'BinaryGetURL = Http.ResponseText
set Httpd = nothing
' EventHandler
Const apikey ="your api key"
Const prefix = "[VIRUSTOTAL] "
Dim oAttachment
dim filesys
dim fil
dim tempName
For oAttachment = 0 to oMessage.Attachments.Count-1
Set filesys = CreateObject("Scripting.FileSystemObject")
tempname = tempPath & filesys.GetTempName '& "_" & oMessage.Attachments(oAttachment).Filename
oMessage.Attachments(oAttachment).SaveAs(tempname)
dim hash
hash = bytesToHex(md5hashBytes(GetBytes(tempname)))
set fil = filesys.GetFile(tempname)
fil.Delete
set fil = Nothing
set filesys = Nothing
EventLog.Write ("Checking attachment in VirusTotal: " _
& oMessage.Attachments(oAttachment).Filename & " Size : " _
& oMessage.Attachments(oAttachment).Size & " Computed MD5 : " & hash)
' Test for undesirable attachments
Dim retVal
retVal = getURL("https://www.virustotal.com/vtapi/v2/file/report?apikey=" & apikey & "&resource=" & hash)
If IsNull(retVal) or retVal = "" then
EventLog.Write ("*** EMPTY response from VirusTotal")
else
EventLog.Write ("VirusTotal response: <" & retVal & ">")
' get response data
Set json = New VbsJson
Set o = json.Decode(retVal)
dim resp
dim posit
resp = o("response_code")
posit = o("positives")
if resp = "1" then
if posit <>"0" then
oMessage.Subject = prefix & oMessage.Subject
' Log in event log
EventLog.Write ("Email Rejected: Attachment unacceptable: " _
& oMessage.Attachments(oAttachment).Size & " VirusTotal SHA : " & o("sha256"))
oMessage.Attachments(oAttachment).Delete()
oMessage.Save()
else
EventLog.Write ("Attachment present in VirusTotal but SAFE: " _
end if
else
EventLog.Write ("Attachment not present in VirusTotal: " _
& oMessage.Attachments(oAttachment).Filename)
end if
end if
Result.Value = 0
