@jimimaseye
Now it would be veeeery nice to have a blacklist rule for recieving mails from external adresses.
I dont have the skills to write such a script..
I think you only need some things in the blacklist for sending to external adresses, right?
How to reject incoming mail according to Blacklist
- jimimaseye
- Moderator
Re: HOW TO: Allow or block some accounts sending external email
If you have antispam setup and using Spamassassin it already has a blacklist function that you can use (this is the easiest method and will also benefit from al the other feature of spamassassin too viewtopic.php?f=21&t=28133 )
From a script you will find some clues in here: viewtopic.php?f=20&t=29306
A rough cut (untested):
Create a Distribution list called "Blacklist" in each domain and enter the from addresses that you went to reject from. (DONT let the existence of this list be known to your users!). If the from address of the email is found in any blacklist that belongs to the domain of any of the users the emial is destined for then the mail will be rejected outright.
If oClient.Username = "" Then
Dim k, i, j, aUsername, oApp, oDomain, oDistributionList
Call oApp.Authenticate("Administrator", "*secret password*")
For j = 0 To oMessage.Recipients.Count -1
If oMessage.Recipients(j).IsLocalUser Then
aUsername = Split(oClient.Username,"@")
Set oDomain = oApp.Domains.ItemByName(aUsername(1))
For k = 0 To oDomain.DistributionLists.Count -1
If lcase(oDomain.DistributionLists.Item(k).Address) = lcase("Blacklist@" & aUsername(1)) Then
Set oDistributionList = oDomain.DistributionLists.Item(k)
if oDistributionList.Active then
For i = 0 To oDistributionList.Recipients.Count -1
If lcase(oDistributionList.Recipients.Item(i).RecipientAddress) = lcase(oMessage.fromaddress) Then
Result.Value = 2
Result.Message = "We dont like you."
Exit Sub
Exit For
Re: How to reject incoming mail according to Blacklist
Thank you very much!
I will test it
I will test it
It doesnt work for me..
My whole Sub OnSMTPData(oClient, oMessage) looks like that:
(I use the NonSenders Script which works fine
First of all i get this error Message when i check the Syntax:
So i changed k to k2 , i to i2 and so on.
so my script look like that now:
Now the Syntax Check is ok.
But The Script doesnt work..
If i send a Mail from one external account to my test account that is in the distribution list "NonRecievers@" the mail arrives and i get this error:
Line 43 is this one:
And I think this error occours because in Line 42
It should not split the oClient.Username but the address of the recipient, right??
But it have no idea how to solve this..
If oClient.Username <> "" and instr(oClient.Username, "@") > 0 Then
Call oApp.Authenticate("Administrator", "*********")
If lcase(oDomain.DistributionLists.Item(k).Address) = lcase("NonSenders@" & aUsername(1)) Then
If (Not oMessage.Recipients(j).IsLocalUser) Then
If lcase(oDistributionList.Recipients.Item(i).RecipientAddress) = lcase(oClient.Username) Then
Result.Value = 2
Result.Message = "You are only allowed to send internally"
EventLog.Write(oClient.Username+" hat probiert eine externe Nachricht zu versenden. Dies wurde unterbunden.")
Exit Sub
Exit For
If lcase(oDomain.DistributionLists.Item(k).Address) = lcase("NonRecievers@" & aUsername(1)) Then
Result.Value = 2
Exit Sub
Exit For
"ERROR" 4236 "2017-11-26 13:08:42.951" "Script Error: Source: Microsoft VBScript compilation error - Error: 800A0411 - Description: Name redefined - Line: 37 Column: 10 - Code: Dim k, i, j, aUsername, oApp, oDomain, oDistributionList"
Result.Value = 2
Exit Sub
Exit For
Dim k2, i2, j2, aUsername2, oApp2, oDomain2, oDistributionList2
Set oApp2 = CreateObject("hMailServer.Application")
Call oApp2.Authenticate("Administrator", "*********")
For j2 = 0 To oMessage.Recipients.Count -1
If oMessage.Recipients(j2).IsLocalUser Then
aUsername2 = Split(oClient.Username,"@")
Set oDomain2 = oApp2.Domains.ItemByName(aUsername2(1))
For k2 = 0 To oDomain2.DistributionLists.Count -1
If lcase(oDomain2.DistributionLists.Item(k2).Address) = lcase("NonRecievers@" & aUsername2(1)) Then
Set oDistributionList2 = oDomain2.DistributionLists.Item(k2)
if oDistributionList2.Active then
For i2 = 0 To oDistributionList2.Recipients.Count -1
If lcase(oDistributionList2.Recipients.Item(i2).RecipientAddress) = lcase(oMessage.fromaddress) Then
Result.Value = 2
Exit Sub
Exit For
"ERROR" 2280 "2017-11-26 13:16:45.350" "Script Error: Source: Microsoft VBScript runtime error - Error: 800A0009 - Description: Subscript out of range: '[number: 1]' - Line: 43 Column: 12 - Code: (null)"
- jimimaseye
- Moderator
Result.Value = 2
Exit Sub
Exit For
aUsername = Split(oMessage.Recipients(j).address,"@")
Result.Value = 2
Exit Sub
Exit For
