I had the issue, that our ISP changed his mail configuration and we had to change the pop3 hostname and the users passwords in all th 238 external accounts of our hmail installation. I found some useful postings here like (thanks to percepts, jimimaseye, Bladeinger, Bill48105 and others....):
viewtopic.php?f=20&t=18303
viewtopic.php?f=20&t=24810&p=201594&hilit=csv#p149923
Since my day as a programmer are long ago (BASIC on a VC20, Pascal on Apple and some sort of C, C++ on Unix) I was glad to have some kind of templates here that helped me. I coded something, that was suitable in my situation (each account has exactly one external account, for example), but it worked for me and perhaps somebody else has the same issue and some programming professionals can correct/improve the code:
'vbs script to update external accounts from a textfile into hmail server
'C. Thönny
'inspired by percepts, jimimaseye, Bladeinger, Bill48105 and others....
' see https://www.hmailserver.com/forum/viewtopic.php?f=20&t=18303
' and https://www.hmailserver.com/forum/viewtopic.php?f=20&t=24810&p=201594&hilit=csv#p149923
Dim user
Dim domain
Dim password
Dim tmp
Dim obDomain
Dim obAccount
Dim obExtAccount
Dim c
Dim obApp
Call obApp.Authenticate("superuser", "extremlytopsecretpassword")
' get the text file with data, make sure it exists
Set obFSO=CreateObject("Scripting.FileSystemObject")
Set obTextFile=obFSO.OpenTextFile("C:\scripts\mails.csv",1)
' open a log file for writing, make sure, it exists
Set obLogFile=obFSO.OpenTextFile("c:\scripts\hmailtest.log",2)
' process the data file and count the data lines
c=0
MsgBox("Beginning ....")
Do while obTextFile.AtEndOfStream <> True
c=c+1
data=split(obTextFile.Readline,",")
tmp=split(data(0),"@")
user=tmp(0)
domain=tmp(1)
password=data(2)
obLogFile.Write("Dataset "&c&":"&"user: "&user&"@"&domain&" pass:" &password &"----------")
'process the data:
'Locate the domain we want to add the account to
Set obDomain = obApp.Domains.ItemByName(domain)
On Error Resume Next
Set obAccount = obDomain.Accounts.ItemByAddress(data(0))
if err.number <> 0 then
obLogFile.Writeline("FAIL, probably doesn't exist in hmail Accounts? ")
else
Set obExtAccount=obAccount.FetchAccounts.Item(0)
if StrComp(obExtAccount.username,data(0)) <> 0 then obLogFile.Write("---------------------------------------------CAUTION, Missmatch of Account and external Account:" & obAccount.Address)
obExtAccount.ServerAddress="new.pop3server.isp"
obExtAccount.Password=password
'do something else like:
'obExtAccount.DaysToKeepMessages=0
'obExtAccount.Enabled=False
obExtAccount.Save()
obLogFile.Writeline("Success External Account " & obExtAccount.Username)
end if
Loop
obLogFile.WriteLine("Ready, processed "& c & " external Accounts")
obLogFile.Close
obTextFile.Close
MsgBox(" ... ready. That's all, folks")
any improvements appreciate
