Dynamic Black/Whitelists in your script.
Post by SorenR » 2019-02-10 00:26
I have been using this feature a while now and it is brilliant. I used to modify my Black/Whitelists directly in my script and reload/restart every time. Not anymore.
Data is located in an XML file in the Events directory and I use Microsoft XML Notepad 2007 to edit the XML file across my SMB network.
Sample VBScript.
Option Explicit
'   COM authentication
Private Const PASSWORD = "*********"
'   XMLDATA file is located in .\hMailServer\Events\
Private Const XMLDATA = "dynamic-lists.xml"
      .Pattern = strRegEx
      .Global = False
      .MultiLine = True
      .IgnoreCase = True
      .Pattern = strRegEx
      .Global = bGlobal
      .MultiLine = True
      .IgnoreCase = True
Function HTMLClean(strHTML)
   ' <!-- ... -->   PHP: "(<!--[^>]*-->)"      JavaScript: "(<!--[\s\S]*?-->)"
   ' /*   ...  */   PHP: "(\/\*)[^>]*(\*\/)"   JavaScript: "(\/\*)[\s\S]*?(\*\/)"
   ' <!--[\\s\\S]*?(?:-->)?<!---+>?|<!(?![dD][oO][cC][tT][yY][pP][eE]|\\[CDATA\\])[^>]*>?|<[?][^>]*>?
      .Pattern = "(<style[\s\S]*?style>)|(\/\*[\s\S]*?\*\/)|(<[\s\S]*?>)"
      .Global = True
      .MultiLine = True
      .IgnoreCase = True
      HTMLClean = .Replace(strHTML, "")
Function LoadXML(XMLFile)
   Dim oXML : Set oXML = CreateObject("MSXML2.DOMDocument")
   oXML.Load(oApp.Settings.Directories.EventDirectory & "\" & XMLFile)
   If oXML.parseError <> 0 Then
      EventLog.Write( "XML ERROR - errorCode - " & oXML.parseError.errorCode ) ' Returns a long integer error code
      EventLog.Write( "XML ERROR - reason    - " & oXML.parseError.reason )    ' Returns a string explaining the reason for the error
      EventLog.Write( "XML ERROR - line      - " & oXML.parseError.line )      ' Returns a long integer representing the line number for the error
      EventLog.Write( "XML ERROR - linePos   - " & oXML.parseError.linePos )   ' Returns a long integer representing the line position for the error
      EventLog.Write( "XML ERROR - srcText   - " & oXML.parseError.srcText )   ' Returns a string containing the line that caused the error
      EventLog.Write( "XML ERROR - url       - " & oXML.parseError.url )       ' Returns the url pointing the loaded document
      EventLog.Write( "XML ERROR - filePos   - " & oXML.parseError.filePos )   ' Returns a long integer file position of the error
   Set LoadXML = oXML
Function LoadXMLNode(oXML, MyNode) : LoadXMLNode = ""
   Dim Match, Matches, strTXT
   Set Matches = oXML.selectNodes(MyNode)
   strTXT = ""
   For Each Match In Matches
      strTXT = strTXT & Match.text & "|"
   If (Trim(strTXT) <> "") Then
      LoadXMLNode = Left(strTXT,Len(strTXT)-1)
      EventLog.Write( "ERROR: Empty string from LoadXMLNode(oXML, " & MyNode & ")" )
   Dim oXML : Set oXML = LoadXML(XMLDATA)
   Dim strRegEx
   '   Whitelist HELO
   strRegEx = LoadXMLNode(oXML, "//Whitelist/HELO")
   If Lookup(strRegEx, oClient.HELO) Then
      Exit Sub
   '   Reject HELO
   strRegEx = LoadXMLNode(oXML, "//Reject/HELO")
      Result.Value = 2
      Result.Message = "5.3.0 CODE01 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   Dim strRegEx, Match, Matches
   '   Reject "Subject:"
   strRegEx = LoadXMLNode(oXML, "//Reject/Subject")
   Set Matches = oLookup(strRegEx, oMessage.Subject, False)
      Result.Value = 2
      Result.Message = "5.3.0 CODE02 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   '   Blacklist "Body:"
   strRegEx = LoadXMLNode(oXML, "//Blacklist/Bodytxt")
   Set Matches = oLookup(strRegEx, oMessage.Body, False)
      Result.Value = 2
      Result.Message = "5.3.0 CODE03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
   Set Matches = oLookup(strRegEx, HTMLClean(oMessage.HTMLBody), False)
      Result.Value = 2
      Result.Message = "5.3.0 CODE04 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
The layout of the XML file is how I use it. <Root> is top level and should not be changed. <Reject>, <Blacklist>, <Whitelist> you can change any way you like HOWEVER the XML syntax is case sensitive so if you create <ACME> with elements of <Explosive>TNT</Explosive> and <explosive>Nitro</explosive> doing a lookup on "//ACME/Explosive" will ONLY list TNT!
IF you edit the XMLDATA file with a text editor... Well, there are some limitations you should be aware of.. The text representation of reserved letters are:
&lt;   <
&gt;   >
&amp;  &
&quot; "
&apos; '
Sample XMLDATA file
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<Root>
  <Reject>
    <HELO>(0\.0\.0\.0)</HELO>
    <HELO>(127(?:\.[0-9]{1,3}){3})</HELO>
    <HELO>^(masscan)$</HELO>
    <HELO>^(ylmf\-pc)$</HELO>
    <From>(Sweetme)|(Kira Johns)|(July Girl)|(Hot Mama)|(Little Miss)</From>
    <From>(Baby Boobs)|(Booby Girl)|(Booby Booms)</From>
    <Subject>^(yo|hi|sup|hello|greets|hey t?here)(!?)(.?)(8?-?\)?)?$</Subject>
  </Reject>
  <Blacklist>
    <X-Envelope-From>^(.*\@.*bitcoin.*)$</X-Envelope-From>
    <From>(Tim Kristiansen)</From>
    <Bodytxt>(I have a proposal)</Bodytxt>
    <Bodytxt>(You are receiving this email because you opted in via our website)</Bodytxt>
    <IPRange>^216\.82\.(2(4[0-9]|5[0-5]))\.([0-9]|[1-9][0-9]|1([0-9][0-9])|2([0-4][0-9]|5[0-5]))$</IPRange>
  </Blacklist>
  <Whitelist>
    <X-Envelope-From>^(security\@facebookmail\.com)$</X-Envelope-From>
    <X-Envelope-From>^(noreply\@fitnessworld\.com)$</X-Envelope-From>
    <From>(account-update\@amazon\.com)</From>
    <From>(\@id\.apple\.com)</From>
    <HELO>^(VVS-WEB)[0-9]{2}(\.localdomain)$</HELO>
    <HELO>^(app)[0-9]{2}(-shippii-com)$</HELO>
    <HELO>^(LouisesMatebookX)$</HELO>
    <HELO>^(LAPTOP08MT84VB)$</HELO>
  </Whitelist>
  <Ransomeware>
    <Bodytxt>(https://dl.dropboxusercontent.com/s/)</Bodytxt>
    <Bodytxt>(https://www.dropbox.com/meta_dl/)</Bodytxt>
  </Ransomeware>
</Root>
There are two types of people in this world:
1) Those who can extrapolate from incomplete data
Re: Dynamic Black/Whitelists in your script.
Post by palinka » 2019-02-10 01:47
Installed. I'm not sure how useful the rest will be, but the reject on helo will slay a lot of spammers.
Post by SorenR » 2019-02-10 14:54
2019-02-10 01:47
The code in OnSMTPData(oClient, oMessage) I have in OnHELO(oClient) but since OnHELO(oClient) is not in the official build, I placed the code there. The benefit of moving it to OnHELO(oClient) is AUTH is done AFTER OnHELO(oClient) and BEFORE OnSMTPData(oClient, oMessage) ... :wink:
Post by SorenR » 2019-02-10 15:26
This will filter out ANY non-RFC compliant HELO/EHLO greeting. There are a lot of SPAM BOTs and infected clients/servers that can be captured using this.
This is NOT a foolproof test and valid servers/clients MAY fail. That's why you MUST use a Whitelist BEFORE this test.
I experience Outlook 365 clients sometimes identify themselves with the machine name and not the FQDN. I believe this is a problem with DHCP service. I have made entries in my Whitelist to compensate for this. Also, skip this test for clients on my LAN.
Valid greetings are: FQDN, [192.168.0.1] and [IPv6:fe80::1]
Non-Valid greetings are: masscan, localhost, ylmf-pc, WIN-82VNUNPK9RO
   '   Validate HELO/EHLO greeting
      Result.Value = 2
      Result.Message = SMTPCode(Result.Value) & " CODE03 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
      Exit Sub
Post by palinka » 2019-02-10 17:13
I get a lot of these:
2019-02-10 01:02:22.199 RECEIVED: EHLO 24-121-219-54.erkacmtk02.com.sta.suddenlink.net
It's a valid fqdn, i suppose. But it's bot net crap from a dynamic ip. SA filters them fine, but it would be great to reject them altogether.
Post by SorenR » 2019-02-10 21:31
2019-02-10 17:13
This appear the most I can cut it down and still not cripple suddenlink.net completely.
<Root>
<Reject>
<HELO>^(.*\.com\.sta\.suddenlink\.net)$</HELO>
</Reject>
</Root>
Post by palinka » 2019-02-10 21:53
Oh, sorry, no. I didn't mean they all come from suddenlink. They come from all over, every and any ISP but using the host name of the ISP's IP address. Some are static IPs as well ("STATIC" being part of the hostname).
2019-02-10 01:02:43.777	RECEIVED: MAIL FROM: <GeraldScott@suddenlink.net>
RECEIVED: EHLO 120.pool90-71-49.dynamic.orange.es
2019-02-10 01:55:41.518	RECEIVED: MAIL FROM: <JoshuaPatterson@orange.es>
RECEIVED: EHLO soetemanfc.nl
2019-02-10 02:02:13.921	RECEIVED: MAIL FROM: <MarkMoore@soetemanfc.nl>
RECEIVED: EHLO static-74-214-35-42.cpe.metrocast.net
2019-02-10 03:20:51.826	RECEIVED: MAIL FROM: <BrianMiller@metrocast.net>
RECEIVED: EHLO static-74-101-171-218.nycmny.fios.verizon.net
2019-02-10 03:47:20.016	RECEIVED: MAIL FROM: <RalphDavis@verizon.net>
RECEIVED: EHLO cityhotelsootmarsum.nl
2019-02-10 03:56:52.849	RECEIVED: MAIL FROM: <ScottMartinez@cityhotelsootmarsum.nl>
RECEIVED: EHLO 68-112-54-79.static.hlrg.nc.charter.com
2019-02-10 04:19:07.528	RECEIVED: MAIL FROM: <BillyCarter@charter.com>
RECEIVED: EHLO vandepoltours.nl
2019-02-10 04:39:20.121	RECEIVED: MAIL FROM: <GregoryRussell@vandepoltours.nl>
RECEIVED: EHLO nuvanwerknaarwerk.nl
2019-02-10 05:13:54.390	RECEIVED: MAIL FROM: <RoyWilson@nuvanwerknaarwerk.nl>
And so on and so forth. The pattern is in the from address: Capital first letter first name, capital first letter last name. Obviously they're spoofed addresses. Most are in the form of host name of the IP like "120.pool90-71-49.dynamic.orange.es".
Like I said, SA deals with them effectively because they are all or nearly all very high level malicious spam. Lots of viruses and "meet me" sex links. It would be great if they could be rejected. Not sure how that could be done. The only way I can think of is to check if the domain has a working mail server, but that could take a bunch of resources, I would imagine.
For example, I looked up static-74-214-35-42.cpe.metrocast.net on mxtoolbox.com. IP does match hostname, but when I do smpt dialogue test, it comes back with a timeout.
But then again, cityhotelsootmarsum.nl is/has a working mail server. They probably don't know they've been compromised.
Post by SorenR » 2019-02-10 23:23
This is for IPv4 only. I must admit I have not seen one of those in a VERY VERY long time...
   Dim a
   a = Split(oClient.IPAddress, ".")
   If (InStr(1, oClient.HELO, a(3) & "-" & a(2) & "-" & a(1) & "-" & a(0), 1) > 0) Then
      Result.Value = 2
      Result.Message = "530 CODE10 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
   End
I presume this...
came from 79.54.112.68 :wink:
Post by SorenR » 2019-02-11 00:36
Had a closer look at my raw SMTP logs ... oops ... I do get them, but they are denied as sender and recipient are the same and my domain require authentication.
Hmm... I got 1 Friday, 2 Saturday and today at 5 PM it really took off...
I see some of them have the IP address the "right way"
"SMTPD" 2764 142 "2019-02-10 18:19:48.276" "89.64.17.153" "RECEIVED: EHLO 89-64-17-153.dynamic.chello.pl"
and some of them have the IP address the "reverse way"
"SMTPD" 2792 162 "2019-02-10 19:37:56.236" "178.150.135.53" "RECEIVED: EHLO 53.135.150.178.triolan.net"
I have just added this to my EventHandlers.vbs, lets see if it works...
   Dim a, strRegEx
   strRegEx = "(" & a(3) & "-" & a(2) & "-" & a(1) & "-" & a(0) & ")|(" & a(0) & "-" & a(1) & "-" & a(2) & "-" & a(3) & ")"
      Result.Value = 2
      Exit Sub
Post by palinka » 2019-02-11 03:17
2019-02-11 00:36
   Dim a, strRegEx
      Result.Value = 2
      Exit Sub
This looks really good. Good idea to use the dashes.
Does this require the new unofficial version of hmailserver?
Post by SorenR » 2019-02-11 03:23
2019-02-11 03:17
2019-02-11 00:36
   Dim a, strRegEx
      Result.Value = 2
      Exit Sub
You can add this to OnHELO or OnSMTPData, preferably after a HELO Whitelist, if you have one.
Post by palinka » 2019-02-11 03:45
2019-02-11 03:23
Post by SorenR » 2019-02-11 03:49
"SMTPD"	2052	3	"2019-02-11 01:27:19.137"	"191.19.107.164"	"SENT: 220 mx.acme.inc ESMTP"
"SMTPD"	2052	3	"2019-02-11 01:27:19.418"	"191.19.107.164"	"RECEIVED: EHLO 191-19-107-164.user.vivozap.com.br"
"SMTPD"	2052	3	"2019-02-11 01:27:19.528"	"191.19.107.164"	"SENT: 554 5.3.0 CODE10 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
"SMTPD"	2052	3	"2019-02-11 01:27:19.793"	"191.19.107.164"	"RECEIVED: HELO 191-19-107-164.user.vivozap.com.br"
"SMTPD"	2052	3	"2019-02-11 01:27:19.825"	"191.19.107.164"	"SENT: 554 5.3.0 CODE10 Your access to this mail system has been rejected due to the sending MTA's poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate means."
Post by palinka » 2019-02-11 11:38
From this morning.
SMTPD  –  83  –  66.167.205.6 ?
2019-02-11 00:54:11.603	RECEIVED: EHLO h-66-167-205-6.snva.ca.dynamic.globalcapacity.com
2019-02-11 00:54:32.821	SENT: 554 530 CODE10 Your access to this mail system has been rejected due to the sending MTAs poor reputation. If you believe that this failure is in error, please contact the intended recipient via alternate
SMTPD  –  114  –  199.36.111.220 ?
2019-02-11 01:49:10.329	SENT: 220 mydomain
2019-02-11 01:49:10.954	RECEIVED: EHLO 26-108-144-198.customer.rigidtech.net
2019-02-11 01:49:50.755	SENT: 250-mydomain
250-SIZE 20480000
250-STARTTLS
250 HELP
2019-02-11 01:49:51.075	RECEIVED: MAIL FROM: <JamesBoyd@rigidtech.net>
2019-02-11 01:49:51.341	SENT: 250 OK
SMTPD  –  173  –  97.96.158.36 ?
2019-02-11 03:19:00.883	SENT: 220 mydomain
2019-02-11 03:19:01.398	RECEIVED: EHLO 097-096-158-036.biz.spectrum.com
2019-02-11 03:19:22.686	SENT: 250-mydomain
250-SIZE 20480000
250-STARTTLS
250 HELP
2019-02-11 03:19:23.139	RECEIVED: MAIL FROM: <FrederickJordan@spectrum.com>
2019-02-11 03:19:23.280	SENT: 250 OK
One worked. One had a different ip than the domain name, the other inserted 0's into the domain to make the ip portion all 3 digits. Weird.
Post by SorenR » 2019-02-11 13:59
This should take care of;
1: 127-0-0-1
2: 127-000-000-001
3: 1-0-0-127
4: 001-000-000-127
   Dim a, b(3), i, strRegEx
   For i = 0 to 3
      b(i) = Right("00" & a(i),3)
   strRegEx = "(" & a(0) & "-" & a(1) & "-" & a(2) & "-" & a(3) & ")|" &_
              "(" & b(0) & "-" & b(1) & "-" & b(2) & "-" & b(3) & ")|" &_
              "(" & a(3) & "-" & a(2) & "-" & a(1) & "-" & a(0) & ")|" &_
              "(" & b(3) & "-" & b(2) & "-" & b(1) & "-" & b(0) & ")"
      Result.Value = 2
      Exit Sub
Post by palinka » 2019-02-12 11:51
Thanks!
Re: Dynamic Black/Whitelists in your script. Feb. 12. SECURITY UPDATE
Post by SorenR » 2019-02-12 18:39
This is potentially an IMPORTANT update.
If a lookup in the XML file returns "", the RegEx Lookup/oLookup WILL MATCH EVERYTHING.
The change is altering
---> Function LoadXMLNode(oXML, MyNode) : LoadXMLNode = ""
to
---> Function LoadXMLNode(oXML, MyNode) : LoadXMLNode = "THIS CANNOT BE EMPTY"
I came across this today as I deleted all "From" elements from node "Blacklist" this morning, leaving no results for LoadXMLNode(oXML, "//Blacklist/From").
   strTXT = ""
Post by palinka » 2019-02-15 19:44
Sneaky buggers using dots now.
Received: from 33.net-3-2.embou.es (33.net-94.228.2.isbl.embou.net [94.228.2.33])
Post by SorenR » 2019-02-16 00:03
Deleted my last post... this fell into the trap: mail-oln040092254091.outbound.protection.outlook.com
spamhaus do have some bugs :mrgreen:
Post by palinka » 2019-02-16 15:29
2019-02-16 00:03
Aye. Good for me. I have too many projects lined up this weekend anyway. :D
Post by SorenR » 2019-02-19 02:09
Been running this isLashBack() function over the weekend...
The listings are determined objectively and systematically. Only IPs that send email to specially-created, LashBack owned-and-monitored email addresses (unsubscribe probes) -- that are used only on suppression lists -- are blacklisted.
You know, these SPAM mails where the "unsubscribe" button don't really seem to function properly.
Function isLashBack(strIP) : isLashBack = False
   Dim a, strLookup
   a = Split(strIP, ".")
      strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".ubl.unsubscore.com")
   If (InStr(1, strLookup, "127.0.0.2", 1) > 0) Then isLashBack = True
Function isSnowShoe(strIP) : isSnowShoe = False
   Dim a, strLookup
      strLookup = .DNSLookup(a(3) & "." & a(2) & "." & a(1) & "." & a(0) & ".zen.spamhaus.org")
   If (InStr(1, strLookup, "127.0.0.3", 1) > 0) Then isSnowShoe = True
Sub OnClientConnect(oClient)
   '   LashBack SPAM detection
   If isLashBack(oClient.IPAddress) Then
      Result.Value = 1
      Exit Sub
   '   SnowShoe SPAM detection
   If isSnowShoe(oClient.IPAddress) Then
      Result.Value = 1
      Exit Sub
Between this and the SnowShoe function, my server is having an easy life.
I have changed the SnowShoe function for the rare event that sbl.spamhaus.org would return 127.0.0.2 AND 127.0.0.3. We only need to check for 127.0.0.3.
Post by mattg » 2019-02-19 03:37
I've been using ubl.unsubscore.com as an RBL for a long time
It had it set to 1, but checking a few this morning, SpamAssassin normally rejects these, and no other RBL picks them up
Think I'll increase my score for this RBL
Post by SorenR » 2019-03-13 13:42
Latest addition is an UCE list ... Let's see if I can piss some people off :mrgreen:
Oh and... To stop the complaints from coming, they need to stop the SPAM mails from coming :mrgreen:
I have added to my XML "directory"
  <UCE>
    <namesilo>^(mail\.danzamor\.com)$</namesilo>
    <namesilo>^(mail\.downpic\.com)$</namesilo>
    <namesilo>^(mail\.rememberbeherenow\.com)$</namesilo>
    <namesilo>^(mail\.makze\.com)$</namesilo>
    <namesilo>^(mail\.retpem\.com)$</namesilo>
    <namesilo>^(mail\.genpip\.com)$</namesilo>
    <namesilo>^(mail\.kalosive\.com)$</namesilo>
    <namesilo>^(mail\.luckydaeon\.com)$</namesilo>
    <namesilo>^(mail\.3dmeditation\.com)$</namesilo>
    <namesilo>^(mail\.leinno\.com)$</namesilo>
    <namesilo>^(mail\.ssdspace\.com)$</namesilo>
    <namecheap>^(.*\.icu)$</namecheap>
  </UCE>
"namesilo" and "namecheap" are the registrars :twisted: IP addresses are all over the world.
NOTE: For a very long time I have received UCE/SPAM from tld ".icu" ... ONLY ... When I start receiving something else from an ".icu" domain, I MAY change away from using a wildcard.
When doing a Whois on the domains they are "redacted for privacy" thus the only usable information is the Abuse Contact Email. And so be it ... :mrgreen:
To: Whois Abuse Contact <abuse@????>
Cc: Danish Consumer Ombudsman <int@spamXXXX.dk>, Federal Trade Commission (FTC) <spam@uceXXXX.gov>
Bcc: Automated UCE/SPAM Defence <spam@acme.inc>
Function ReturnUCEMail(oMessage, strContact)
'   Forbrugerombudsmanden,         dansk@spamXXXX.dk
'   Danish Consumer Ombudsman,       int@spamXXXX.dk
'   Federal Trade Commission (FTC), spam@uceXXXX.gov
'   https://api.hackertarget.com/whois/?q=google.com
'   find email in text: strRegEx = "([\w.]+)\@(\w+\.\w+)(\.\w+)?"
      .HeaderValue("Message-ID") = "<" & CreateGUID & ">"
      .FromAddress = "spam@acme.inc"
      .AddRecipient "Whois Abuse Contact", strContact
      .AddRecipient "Danish Consumer Ombudsman", "int@spamXXXX.dk"
      .AddRecipient "Federal Trade Commission (FTC)", "spam@uceXXXX.gov"
      .AddRecipient "Automated UCE/SPAM Defence", "spam@acme.inc"
      .HeaderValue("To") = """Whois Abuse Contact""" & " <" & strContact & ">"
      .HeaderValue("Cc") = """Danish Consumer Ombudsman""" & " <int@spamXXXX.dk>, " & """Federal Trade Commission (FTC)""" & " <spam@uceXXXX.gov>"
      .HeaderValue("From") = """Automated UCE/SPAM Defence""" & " <spam@acme.inc>"
      .Subject = "Returning unused UCE/SPAM"
      .Body = "Thanks for trying, but we are NOT interested! The original sender (whom you are protecting) is violating EU GDPR law."
      .Attachments.Add(oMessage.Filename)
      .Save
   Done = False
   If (oMessage.HeaderValue("X-hMailServer-Spam") <> "YES") Or Whitelisted Then Done = True
   Do Until Done
      '   abuse@namesilo.com
      strRegEx = LoadXMLNode(oXML, "//UCE/namesilo")
         Call ReturnUCEMail(oMessage, "abuse@namesiloXXXX.com")
      If Matches.Count > 0 Then Exit Do
      '   abuse@namecheap.com
      strRegEx = LoadXMLNode(oXML, "//UCE/namecheap")
         Call ReturnUCEMail(oMessage, "abuse@namecheapXXXX.com")
      Exit Do
   Loop
Post by mattg » 2019-03-14 03:45
nice
I think I shall play with that concept
Post by SorenR » 2019-03-14 18:13
2019-03-14 03:45
nice
I hit a showstopper on the continued development... The "Whois Abuse Contact" was actually a picture :evil:
Option Explicit
Dim sURL, sHTML, sWhois, Match, Matches, Email, Emails
sURL = "https://www.whois.com/whois/" & "exvoice.icu"
With CreateObject("MSXML2.ServerXMLHTTP.6.0")
   .setoption(2) = (.getoption(2) & " - SXH_SERVER_CERT_IGNORE_ALL_SERVER_ERRORS")
   .open "GET", sURL, False
   .setrequestheader "User-Agent", "online link validator (http://www.dead-links.com/)"
   .send ("")
   sHTML = .ResponseText
   .Pattern = "(?:<pre class=""df-raw"" id=""registryData"">)([\s\S]*?)(?:<\/pre>)"
   .Global = True
   .MultiLine = True
   .IgnoreCase = True
   Set Matches = .Execute(sHTML)
   sWhois = Match.Value
   WScript.Echo sWhois
      .Pattern = "([\w.]+)\@(\w+\.\w+)(\.\w+)?"
      .Global = True
      .MultiLine = True
      .IgnoreCase = True
      Set Emails = .Execute(sWhois)
   For Each Email In Emails
      WScript.Echo Email.Value
Post by mattg » 2019-03-15 01:36
So those who allow spam bots on their networks don't like to be spammed by bots... :shock:
Post by SorenR » 2019-03-15 16:04
Well, after feeding Namecheap and Namesilo a handsome number of "unused UCE/SPAM" email they've responded.
Namecheap Legal & Abuse Team have consolidated all the domains into one case and are actively looking into it. They recognise the domains are listed in SURBL and Spamhaus DBL and ask for 48 hours to investigate.
Namesilo however... Have returned 7 almost identical messages and I really feel they insult my intelligence. This is the latest and shortest reply.
we are only the domain name registrar and cannot validate or remove the content posted on the site.
This can be done by the hosting company of the website, which you can look up on this website: https://www.whoishostingthis.com/
Once you know the hosting provider, please look up their company information and contact them with the case.
You can also use the following pages to report the website:
Malware: https://safebrowsing.google.com/safebro ... t_badware/
Scam and Fraud: https://secure.nclforms.org/nficweb/Onl ... tForm.aspx
You may also discuss the case with your local law enforcement officer to seek help.
NameSilo Abuse Team
NameSilo Abuse Portal powered by Freshdesk 22604:175916
I now need to figure out what to do in the future as this obviously was a waste of time. Contacting the hosting company will not give me the identity of the spammer for me to report and if they terminate the contract the spammer only moves to another hosting company.
Terminating the domain is by far the most efficient action to take against the spammer.
Post by jimimaseye » 2019-03-15 20:31
The problem there is they cannot terminate the domain because the domain will have been bought by the spammer and as such he will own it. The Host can disconnect the hosting service however as that will be a contravention of the terms. The spammer can't take his domain and set up in any other hosts where he wishes to. It is unlikely that you will determine who the spammer is. Only by moving the services from one host to the next will the spammer get fed up and decease.
Post by SorenR » 2019-03-16 01:37
2019-03-15 20:31
Well... I read the Terms and Conditions :mrgreen:
Namecheap, Inc. Registration Agreement
This Registration Agreement ("Agreement") sets forth the terms and conditions of your use of domain name registration and related services ("Services").
bla bla bla
4. Service(s) provided at will and termination of service(s)
We may reject your domain name registration application or elect to discontinue providing Service(s) to you for any reason within 30 days of a Service initiation or a Service renewal. Outside of this period, we may terminate or suspend the Service(s) at any time for cause, which, without limitation, includes registration of prohibited domain name(s), abuse of the Services, payment irregularities, material allegations of illegal conduct, or if your use of the Services involves us in a violation of any Internet Service Provider's ("ISP's") acceptable use policies, including the transmission of unsolicited bulk email in violation of the law. You agree that if we terminate or suspend the Services provided to you under this Agreement, that we may then, at our option, make either ourselves or a third party the beneficiary of Services which are substantially similar to those which were previously providing to you and that any reference in this Agreement to termination or suspension of the Services to you includes this option. If we have grounds to terminate or suspend Service(s) with respect to one domain name or in relation to other Service(s) provided through your account, we may terminate or suspend all Service(s) provided through your account, including Service(s) to other domain names maintained by you with us. No fee refund will be made when there is a suspension or termination of Service(s) for cause. At any time and for any reason, we may terminate the Services thirty (30) days after we send notice of termination via mail or email, at our option, to the WHOIS contact information provided in association with your domain name registration. Following notice of termination other than for cause, you must transfer your domain name or risk that we may delete your domain name or suspend or modify Services to it. If we terminate Services for a reason other than cause, we will attempt to refund your fees. You further acknowledge and agree that your registration of a domain name is subject to suspension, cancellation or transfer by any ICANN procedure, by any registrar or registry administrator procedures approved by an ICANN-adopted policy, to correct mistakes by us, another registrar or the registry administrator in administering the domain name or for the resolution of disputes concerning the domain name. You agree that your failure to comply completely with the terms and conditions of this agreement and any Namecheap rule or policy may be considered by Namecheap to be a material breach of this agreement and that Namecheap may provide you with notice of such breach either in writing or electronically (i.e. email). In the event you do not provide Namecheap with material evidence that you have not breached your obligations to Namecheap within ten (10) business days, Namecheap may terminate its relationship with you and take any remedial action available to Namecheap under the applicable laws. Such remedial action may be implemented without notice to you and may include, but is not limited to, canceling the registration of any of your domain names and discontinuing any services provided by Namecheap to you.
https://www.namecheap.com/legal/domains ... ement.aspx
Post by jimimaseye » 2019-03-16 01:51
That is the namecheap TnC. I thought you were taking about namesilo that were being non helpful.
Post by SorenR » 2019-03-16 02:19
2019-03-16 01:51
Namesilo have similar wording in their Terms and Conditions.
https://www.namesilo.com/terms.php Chapter 5, section vi
Maybe I should write them an email and remind them :mrgreen:
Post by jimimaseye » 2019-03-16 02:22
2019-03-16 02:19
2019-03-16 01:51
Certainly wouldn't hurt.
Post by SorenR » 2019-03-17 14:31
SUCCESS! It turns out those guys at Namecheap are awesome!
Domains are still listed in Whois BUT! mxtoolbox cannot find the suspended ones so it appear they have no DNS records. :mrgreen:
Thank you for your email.
While the following domain names are registered with Namecheap, they are hosted with another company:
acceptmiss.icu
almonlycian.icu
fruitweed.icu
gratefulcode.icu
hurtsail.icu
huttap.icu
limitedjest.icu
nascapacify.icu
springbeg.icu
tolerantload.icu
That is why we cannot check the logs for the domains and confirm if they are involved in sending unsolicited bulk emails.
However, it seems the domain names are listed in Spamhaus DBL and SURBL. Since we consider them to be trusted organizations, we opened a case regarding the domain names. Please allow us about 48 hours for our further investigation.
Additionally, please be informed that the following domain names have been suspended:
bozoiritis.icu
choosemyth.icu
comeheptad.icu
fulltool.icu
grantithiel.icu
gutflecky.icu
journalfear.icu
judgmentrub.icu
jutelysias.icu
kiddokumasi.icu
penzaabbrev.icu
pivotkitted.icu
rundumper.icu
sampjellib.icu
scandalarmy.icu
shaleburton.icu
slaminn.icu
slotflu.icu
spaetucket.icu
wasteupcast.icu
Thank you for letting us know about the issue.
Regards,
Xxxxxx Xx. (redacted by SorenR according to GDPR)
Legal & Abuse Department
Namecheap Team
Ticket Details
Ticket ID: JBB-179-XXXXX (redacted by SorenR according to GDPR)
Department: Domains -- Legal and Abuse
Type: Issue
Status: Awaiting Client Response
Priority: High
Helpdesk: https://support.namecheap.com/index.php?
Post by SorenR » 2019-03-20 12:05
While Namecheap came back to me with yet another list of domains they have suspended, I have had NO LUCK with Namesilo. Those fcukers are just persistant.
The Whois entries for the domains in question are protected by PrivacyGuardian.org and I had a look at them. They may disclose the identity of the registrant in case of fraud or misuse (like UCE and SPAM) so I launced a complaint on the PrivacyGuardian.org website ... Using a reply mail not registered with Namesilo...
Can't really say I'm surprised...
Domains in question: danzamor.com, downpic.com, rememberbeherenow.com, makze.com, retpem.com, genpip.com, kalosive.com, luckydaeon.com, 3dmeditation.com, leinno.com, ssdspace.com
First occurance of UCE/SPAM from above domains was May 5'th 2018. They have been rock solid since, so I have actually used them to finetune my "defences".
Sent: 19. marts 2019 13:54
To: abuse@acme.inc
Cc: abuse@namesilo.com
Subject: Re: PrivacyGuardian.org Abuse Form - 23773
we are only the domain name registrar and cannot validate or control the content of emails. You will need to contact the email provider of the domain owner. To find out the email provider we recommend to use this site: https://www.whoishostingthis.com/ Once you know the email provider, please look up the company to find out their contact information and report the issue to them to take care of.
To limit the number of spam landing in your mailbox please follow these instructions:
Check your email account to see if it provides a tool to filter out potential spam or to channel spam into a bulk email folder. You might want to consider these options when you're choosing which Internet Service Provider (ISP) or email service to use.
Limit your exposure. You might decide to use two email addresses — one for personal messages and one for shopping, newsletters, chat rooms, coupons and other services. You also might consider using a disposable email address service that forwards messages to your permanent account. If one of the disposable addresses begins to receive spam, you can shut it off without affecting your permanent address.
Also, try not to display your email address in public. That includes on blog posts, in chat rooms, on social networking sites, or in online membership directories. Spammers use the web to harvest email addresses.
Check privacy policies and uncheck boxes. Check the privacy policy before you submit your email address to a website. See if it allows the company to sell your email to others. You might decide not to submit your email address to websites that won't protect it.
When submitting your email address to a website, look for pre-checked boxes that sign you up for email updates from the company and its partners. Some websites allow you to opt out of receiving these mass emails.
Choose a unique email address. Your choice of email addresses may affect the amount of spam you receive. Spammers send out millions of messages to probable name combinations at large ISPs and email services, hoping to find a valid address. Thus, a common name such as jdoe may get more spam than a more unique name like j26d0e34. Of course, there is a downside - it's harder to remember an unusual email address.
Hackers and spammers troll the internet looking for computers that are not protected by up-to-date security software. When they find unprotected computers, they try to install hidden software – called malware – that allows them to control the computers remotely. Many thousands of these computers linked together make up a “botnet ,“ a network used by spammers to send millions of emails at once. Millions of home computers are part of botnets. In fact, most spam is sent this way.
Do not let spammers use your computer. You can help reduce the chances that your computer will become part of a botnet: Use good computer security practices and disconnect from the internet when you're away from your computer. Hackers can’t get to your computer when it’s not connected to the internet. Be cautious about opening any attachments or downloading files from emails you receive. Don't open an email attachment — even if it looks like it's from a friend or coworker — unless you are expecting it or you know what it is. If you send an email with an attached file, include a message explaining what it is.
Download free software only from sites you know and trust. It can be appealing to download free software – like games, file-sharing programs, and customized toolbars. But remember that free software programs may contain malware.
Report Spam to the Federal Trade Commission at spam@uce.gov and at https://www.spamcop.net/anonsignup.shtml
Read more about reporting spam on this page: https://en.wikipedia.org/wiki/Spam_reporting
Hope you find this helpful!
NameSilo Abuse Team
NameSilo Abuse Portal powered by Freshdesk 23773:175916
Post by mattg » 2019-03-21 01:12
Ha ha
They think that you are a noob
If only they knew
Post by SorenR » 2019-03-21 15:48
2019-03-21 01:12
Ha ha
If only they knew
I've just sent a recent list to Namecheap today ... :mrgreen:
"Last seen","Domain","Hits","First seen"
"2019-03-16 18:59:39","airway.icu","2","2019-03-16 18:59:29"
"2019-03-20 15:17:55","armeye.icu","2","2019-03-20 15:17:46"
"2019-03-17 02:28:53","ashgo.icu","2","2019-03-17 02:28:49"
"2019-03-19 09:33:22","basissalad.icu","2","2019-03-19 09:33:09"
"2019-03-19 21:34:49","beginsense.icu","2","2019-03-19 21:34:44"
"2019-03-18 19:32:06","belongfreeze.icu","2","2019-03-18 19:31:56"
"2019-03-16 03:42:03","billpace.icu","2","2019-03-16 03:41:50"
"2019-03-17 22:37:56","biteview.icu","2","2019-03-17 22:37:45"
"2019-03-19 10:50:11","blameforge.icu","2","2019-03-19 10:50:03"
"2019-03-20 00:46:57","blastshame.icu","2","2019-03-20 00:46:47"
"2019-03-21 02:21:54","blessscore.icu","2","2019-03-21 02:21:48"
"2019-03-17 19:35:10","blowseal.icu","2","2019-03-17 19:35:01"
"2019-03-20 10:36:04","budgeinn.icu","2","2019-03-20 10:35:52"
"2019-03-16 20:41:08","capbed.icu","2","2019-03-16 20:40:54"
"2019-03-18 03:52:24","choptop.icu","4","2019-03-18 03:52:16"
"2019-03-15 21:04:09","clublog.icu","2","2019-03-15 21:04:00"
"2019-03-17 18:57:46","cordlean.icu","2","2019-03-17 18:57:41"
"2019-03-19 13:48:50","courtfirst.icu","2","2019-03-19 13:48:46"
"2019-03-18 16:02:25","creditexpect.icu","4","2019-03-18 16:02:14"
"2019-03-21 08:43:59","cycleagency.icu","2","2019-03-21 08:43:50"
"2019-03-17 04:31:48","daypop.icu","2","2019-03-17 04:31:43"
"2019-03-15 21:57:38","debtlast.icu","2","2019-03-15 21:57:31"
"2019-03-20 03:09:35","decayadd.icu","2","2019-03-20 03:09:30"
"2019-03-19 19:10:57","driftvirus.icu","2","2019-03-19 19:10:50"
"2019-03-18 01:59:36","drumdry.icu","2","2019-03-18 01:59:28"
"2019-03-18 05:43:37","eatshot.icu","2","2019-03-18 05:43:32"
"2019-03-20 01:28:28","fainteject.icu","2","2019-03-20 01:28:19"
"2019-03-19 20:02:35","fairypitch.icu","2","2019-03-19 20:02:29"
"2019-03-16 09:43:51","fanfew.icu","2","2019-03-16 09:43:42"
"2019-03-18 04:22:03","filmcare.icu","3","2019-03-18 04:18:01"
"2019-03-20 05:40:00","fleetmix.icu","2","2019-03-20 05:39:53"
"2019-03-20 14:28:50","forumleg.icu","2","2019-03-20 14:28:45"
"2019-03-21 07:54:01","freshair.icu","1","2019-03-21 07:54:01"
"2019-03-19 16:48:19","fruitslave.icu","4","2019-03-19 16:48:08"
"2019-03-17 01:32:34","funcan.icu","2","2019-03-17 01:32:28"
"2019-03-16 19:55:48","furtap.icu","2","2019-03-16 19:55:44"
"2019-03-15 23:00:56","getfine.icu","2","2019-03-15 23:00:47"
"2019-03-16 17:45:45","godbuy.icu","4","2019-03-16 17:45:22"
"2019-03-20 16:03:35","growfat.icu","2","2019-03-20 16:03:27"
"2019-03-18 15:19:49","igniteoutput.icu","2","2019-03-18 15:19:45"
"2019-03-20 04:31:11","jellycow.icu","2","2019-03-20 04:31:02"
"2019-03-21 07:01:04","jewelwin.icu","1","2019-03-21 07:01:04"
"2019-03-15 18:03:55","juryscan.icu","2","2019-03-15 18:03:43"
"2019-03-21 12:57:56","kidillness.icu","3","2019-03-21 12:52:21"
"2019-03-17 21:29:53","kidtile.icu","2","2019-03-17 21:29:42"
"2019-03-19 22:57:34","layerstill.icu","2","2019-03-19 22:57:26"
"2019-03-21 03:30:54","lootingcash.icu","2","2019-03-21 03:30:48"
"2019-03-20 09:48:51","lossboy.icu","2","2019-03-20 09:48:44"
"2019-03-17 23:34:55","lovebush.icu","2","2019-03-17 23:34:48"
"2019-03-17 14:11:48","manlie.icu","2","2019-03-17 14:11:43"
"2019-03-18 01:07:47","mildsoul.icu","2","2019-03-18 01:07:42"
"2019-03-18 00:19:37","moodsuit.icu","2","2019-03-18 00:19:32"
"2019-03-16 12:41:29","navymark.icu","2","2019-03-16 12:41:22"
"2019-03-17 12:13:16","newbad.icu","2","2019-03-17 12:13:01"
"2019-03-20 08:07:50","newspin.icu","2","2019-03-20 08:07:45"
"2019-03-17 03:30:53","nutinn.icu","2","2019-03-17 03:30:44"
"2019-03-19 17:42:56","offerwrong.icu","2","2019-03-19 17:42:48"
"2019-03-21 04:16:24","officesalad.icu","4","2019-03-21 04:16:10"
"2019-03-17 11:08:51","oilpot.icu","2","2019-03-17 11:08:45"
"2019-03-16 23:27:30","oldrow.icu","2","2019-03-16 23:27:23"
"2019-03-18 23:02:45","outputethics.icu","2","2019-03-18 23:02:41"
"2019-03-19 04:38:09","packetcoerce.icu","2","2019-03-19 04:38:04"
"2019-03-16 13:42:51","pieedge.icu","2","2019-03-16 13:42:46"
"2019-03-18 02:56:49","poolurge.icu","2","2019-03-18 02:56:44"
"2019-03-18 18:13:33","prisoninside.icu","3","2019-03-18 18:13:08"
"2019-03-21 05:49:46","rabbitcause.icu","1","2019-03-21 05:49:46"
"2019-03-21 09:43:14","relievesocial.icu","1","2019-03-21 09:43:14"
"2019-03-18 23:55:59","rescuehammer.icu","4","2019-03-18 23:55:33"
"2019-03-20 08:56:53","richkidz.icu","2","2019-03-20 08:56:46"
"2019-03-20 19:41:51","roarpat.icu","2","2019-03-20 19:41:47"
"2019-03-16 11:41:53","rocksofa.icu","2","2019-03-16 11:41:46"
"2019-03-16 22:27:46","shylot.icu","2","2019-03-16 22:27:40"
"2019-03-21 10:22:50","softsubject.icu","2","2019-03-21 10:22:46"
"2019-03-15 19:03:48","sourmenu.icu","1","2019-03-15 19:03:48"
"2019-03-19 23:43:08","sparekoran.icu","2","2019-03-19 23:42:41"
"2019-03-13 15:03:45","springbeg.icu","1","2019-03-13 15:03:45"
"2019-03-19 01:26:55","squashcellar.icu","2","2019-03-19 01:26:48"
"2019-03-19 12:50:00","steepdecay.icu","2","2019-03-19 12:49:50"
"2019-03-18 04:56:13","stemlion.icu","2","2019-03-18 04:56:08"
"2019-03-18 22:20:06","stickychance.icu","2","2019-03-18 22:19:49"
"2019-03-20 16:58:35","stripoil.icu","2","2019-03-20 16:58:28"
"2019-03-21 04:59:00","suburbproper.icu","2","2019-03-21 04:58:49"
"2019-03-15 19:51:39","tapspy.icu","2","2019-03-15 19:51:32"
"2019-03-20 18:56:00","tensetap.icu","2","2019-03-20 18:55:48"
"2019-03-16 02:39:10","tiebaby.icu","2","2019-03-16 02:39:00"
"2019-03-19 03:05:55","tranceemploy.icu","2","2019-03-19 03:05:41"
"2019-03-19 18:26:38","unclevalid.icu","2","2019-03-19 18:26:30"
"2019-03-16 10:41:33","userfear.icu","2","2019-03-16 10:41:29"
"2019-03-20 07:18:08","vannet.icu","2","2019-03-20 07:17:56"
"2019-03-17 05:33:46","vanowe.icu","1","2019-03-17 05:33:46"
"2019-03-16 01:44:01","vatmoon.icu","2","2019-03-16 01:43:56"
"2019-03-19 16:02:01","virusuncle.icu","4","2019-03-19 16:01:20"
"2019-03-16 08:26:36","zonefolk.icu","2","2019-03-16 08:26:30"
Post by SorenR » 2019-03-22 00:47
Birds flying high
You know how I feel
Sun in the sky
You know how I feel
Breeze driftin' on by
You know how I feel
It's a new dawn
It's a new day
It's a new life
For me
And I'm feeling good
I'm feeling good
22 more domains suspended... :mrgreen:
Re: Dynamic Black/Whitelists in your script. V2.0
Post by SorenR » 2020-04-24 22:58
Major rewrite... Dropped the XML file and converted to MySQL - now with statistics.
Events.rar
(5.34 KiB) Downloaded 466 times
Post by palinka » 2020-04-25 03:16
This is cool. But there's no simple way to add new entries. That was the beauty of the xml: open, edit, save, close. Simple!
If I can find some time, I'll whip up a php editor for this. I basically have a template already from my firewall ban and other projects.
But I'm curious, why the change?
Post by palinka » 2020-04-25 03:21
Also, for those of us still using the xml, a quick search brought up this:
MySQL Query:
LOAD XML LOCAL INFILE '/pathtofile/file.xml' INTO TABLE my_tablename(personal_number, firstname, ...);
(obviously haven't tried it yet)
Post by SorenR » 2020-04-25 13:29
2020-04-25 03:16
This makes housekeeping a lot easier without using multiple technologies. I could probably have done it with the XML file but SQL is much easier and faster.
I was trying to use "named groups" in RegExp but it's not supported by VBScript so that is the reason I use Scripting.Dictionary.
"UPDATE " & DBTABLE & " SET lastused = NOW(), hits = (hits + 1) WHERE id = " & a(i) & ";"
Post by palinka » 2020-04-25 14:06
Awesome. I already log that stuff using my Database connection log, along with other things.
Working on the php now. If my 6 year old can leave me alone, I should have it done tout de suite. NO PROMISES! :mrgreen:
Post by palinka » 2020-04-26 03:28
Here you go, buddy. Let me know if you like it.
* For searching, there are drop down boxes for function and field. They autopopulate.
* You can edit existing entries or add new ones.
* Password protected :)
I didn't install it yet. Only the database to create this php thing. But its cool. I think I'm going to do it.
Any bugs, let me know.
black-white_lists_php_admin.zip
(7.92 KiB) Downloaded 433 times
Post by palinka » 2020-04-26 03:34
oops, need to fix the pagination. I'll do it tomorrow. It works if you don't search for anything, so you can still see how it works in the meantime.
Post by SorenR » 2020-04-26 12:38
2020-04-26 03:34
Nice... Can you kill the "href=" and keep tables fixed with?
Post by palinka » 2020-04-26 14:13
2020-04-26 12:38
2020-04-26 03:34
Sure, but I need a link somewhere for editing. Maybe I'll put the link on ID instead.
Fixed width no problem either, but variable helps with mobile viewpoint. Try it on your phone.
Edit - just tried it on my phone first time. Meh... The data column screws up the view port. Maybe I can make it wrap.
Post by palinka » 2020-04-26 16:15
Try this one.
* Added fixed cell width on index.php (wrapping sorta kinda works - doesn't break words, but there's enough width to break at hyphens. YMMV)
* Fixed pagination
* Added change active state on edit.php
* Added ID column on index.php
* Moved hyperlink to edit entry from Data to ID
black-white_lists_php_admin_v2.zip
(8.08 KiB) Downloaded 453 times
Post by SorenR » 2020-04-26 17:08
2020-04-26 16:15
Try this one.
* Fixed pagination
Can you add a drop-down "default sort field" ascending/descending ?
ID being the primary key should be first column AND default sort order - ascending.
Perhaps clicking on column header can select sort field and ask for ascending/descending.
Post by SorenR » 2020-04-26 17:11
Post by palinka » 2020-04-26 17:56
2020-04-26 17:08
2020-04-26 16:15
Try this one.
* Fixed pagination
Jaaaaa..... might take a while. I have to go top off my already bulging pantry. Food shortages looming here.
Post by SorenR » 2020-04-26 19:10
2020-04-26 17:56
While you have been working on that, I have been working on this.... :mrgreen:
Mulching Reed, after leaving it for 1 week I'll hit the area with Roundup... Farmer grade Roundup... 1.6 liter per 10 ha :mrgreen:
The pump is there to lower water level in the pond... 4 stroke engine... 30.000 liter / hour. :mrgreen:
Post by palinka » 2020-04-26 21:27
2020-04-26 19:10
I grew up on a farm. That stuff is not for mixing in a bucket and spraying by hand. It must be applied precisely. Be careful. :!:
Anyway... shopping done. I think I could lock the doors and not leave for 6 months at this point. My "bunker" is full. Now if I can just keep the kids from raiding the snack shelf. :evil:
Back to work!
Post by SorenR » 2020-04-26 22:08
2020-04-26 21:27
2020-04-26 19:10
Back to work!
Roundup unjustly got a bad rep... It's the safest product out there and the retail "garden" version 120 g/l you can almost drink - I'm told it tastes really really bad but it won't kill you... I opted for the 480 g/l as I figured the 720 g/l was overkill. I expect the 1 liter bottle I ordered will last me 5 years. I had to order from Poland as only pro's can order that concentration locally. 8)
Post by palinka » 2020-04-26 22:15
LOL! No candy in this house except at Halloween and Easter. :mrgreen:
11.5 months candy-free.
Post by SorenR » 2020-04-28 02:49
Been scavenging The 'Net...
Code works on Apache and IIS with reference to hostname/ip address holding MySQL database.
It's 2:40 in the morning and my brain is tired... It won't save changes but it can delete fine.. I think I'm not seeing the obvious..
temp.rar
(59.83 KiB) Downloaded 391 times
Post by SorenR » 2020-04-28 10:53
2020-04-28 02:49
Well. I missed the obvious ;-)
Now, how to make it INSERT ???
temp.rar
(59.84 KiB) Downloaded 387 times
Post by SorenR » 2020-04-28 11:29
This framework has potential ;-)
framework.rar
(143.21 KiB) Downloaded 391 times
Post by palinka » 2020-04-28 23:20
2020-04-28 10:53
2020-04-28 02:49
This one looks good to me. Just add insert table to the top of the page. :D
Post by palinka » 2020-04-28 23:47
Hmmm... not as easy as it sounds. I broke the tabledit js. I'm somewhere between poor and non-existent when it comes to js. :(
Post by palinka » 2020-04-29 00:06
OK, back on track. Add this under the container div near the top:
<?php
if (isset($_GET['insert_function'])) {$insert_function = mysqli_real_escape_string($connect, $_GET['insert_function']);} else {$insert_function="";}
if (isset($_GET['insert_field'])) {$insert_field = mysqli_real_escape_string($connect, $_GET["insert_field"]);} else {$insert_field="";}
if (isset($_GET['insert_data'])) {$insert_data = mysqli_real_escape_string($connect, $_GET["insert_data"]);} else {$insert_data="";}
if (isset($_GET['insert_active'])) {$insert_active = mysqli_real_escape_string($connect, $_GET["insert_active"]);} else {$insert_active="";}
if ((!empty($insert_function)) && (!empty($insert_field)) && (!empty($insert_data))){
	$insert_query = "INSERT INTO hm_mylists (function,field,data,hits,lastused,active) VALUES ('".$insert_function."','".$insert_field."','".$insert_data."',0,NOW(),'".$insert_active."');";
	mysqli_query($connect, $insert_query);
	header("Location: ./index.php");
    <table class="table">
     <thead>
      <tr>
       <th>Function</th>
       <th>Field</th>
       <th>Data</th>
       <th>Active</th>
       <th>Submit</th>
      </tr>
     </thead>
     <tbody>
		<tr>
			<form action='index.php' method='GET' onsubmit='return confirm(\"Are you sure you want to add this entry?\");'>
			<td>
				<input type='text' size='20' name='insert_function'>
			</td>
			<td>
				<input type='text' size='20' name='insert_field'>
			</td>
			<td>
				<input type='text' size='40' name='insert_data'>
			</td>
			<td>
				<select name='insert_active'>
					<option value=1>Yes</option>
					<option value=0>No</option>
				</select>
			</td>
			<td>
				<input type='submit' name='submit' value='Submit' >
			</td>
			</form>
		</tr>
     </tbody>
    </table>
This is for your 2nd one here: http://hmailserver.com/forum/viewtopic. ... 67#p220067
Hmmm... alert "Are you sure....?" is not working. But it inserts just fine. Main table functions work also.
