Check Service Status, Take Action, Notify
Post by palinka » 2019-02-24 18:24
POWERSHELL script to check service status, take action and notify.
The script basically uses telnet to check port 25. I didn't bother with the telnet commands because what I discovered was that if hmailserver is either STOPPED or PAUSED, the return value will be a timeout (actively refused connection on ip.ad.dr.ess:25). I figure this way, it doesn't matter what caused the malfunction because we're looking for the outcome to tell us that something is wrong.
It checks status 3 times with 5 minutes inbetween before taking action. If after the third try, its still not possible to communicate with port 25, it will attempt to restart the service and also send a notification. Then it will wait 60 seconds and check service status. If the service is not running, it will send another notification.
Obviously, if there is a problem with hmailserver, you won't be able to send an email via hmailserver, so notifications will be sent via outside smtp service. I tested it with gmail. I also send notifications via my sms gateway. Just delete that part if you don't want to use it.
Run from task scheduler.
hMSStatusActionNotify.ps1
$ErrorActionPreference = 'silentlycontinue'
$remotehost = "localhost"
$port = 25
$ServiceName = 'hMailServer'
$EmailFrom = "user@gmail.com"
$EmailTo = "user@gmail.com"
$SMTPServer = "smtp.gmail.com"
$SMTPAuthUser = "user@gmail.com"
$SMTPAuthPass = "TopSecretPassword"
# Open telnet
$socket = new-object System.Net.Sockets.TcpClient($remoteHost, $port)
# If connection refused, wait X seconds and try again
if($socket -eq $null) {
	Start-Sleep -seconds 300
		# If connection refused, restart HMS service and send notification about restart
			Restart-Service $ServiceName
			# Send Notification via Gmail
				$Subject = "Windows Service Failure"
				$Body = "ATTENTION! MyServer reporting that the hMailServer service is being RESTARTED due to a fault. Check status NOW."
				$SMTPClient = New-Object Net.Mail.SmtpClient($SmtpServer, 587)
				$SMTPClient.EnableSsl = $true
				$SMTPClient.Send($EmailFrom, $EmailTo, $Subject, $Body)
			# Send Notification via SMS
				$uri = "https://smsgateway/index.php/plugin/rest_api/send_sms?phoneNumber=1234567890&message=ATTENTION! hMailServer service is being RESTARTED due to a fault. Check status NOW."
				$response = Invoke-RestMethod -Uri $uri
			# Wait X seconds, check status of service - if not running, give up trying and send notification re service fault
			Start-Sleep -seconds 60
			(get-service $ServiceName).Refresh()
			if ((get-service $ServiceName).Status -ne 'Running')
				$Body = "ATTENTION! MyServer reporting that the hMailServer service is not running. Check status NOW."
				$uri = "https://smsgateway/index.php/plugin/rest_api/send_sms?phoneNumber=1234567890&message=ATTENTION! MyServer reporting that the hMailServer service is not running. Check status NOW."
Re: Check Service Status, Take Action, Notify
Post by palinka » 2019-03-25 01:17
Minor changes to address error in (get-service $ServiceName).Refresh() plus a little cleanup.
$port = 25
$EmailFrom = "notify@gmail.com"
$EmailTo = "1234567890@tmomail.net"
$SMTPAuthUser = "notify@gmail.com"
$SMTPAuthPass = "SuperSecretPassword"
# check telnet for communication
# if no communication, send email warning
	$Body = "ATTENTION! hMailServer service is being RESTARTED due to a fault. Check status NOW."
# wait 5 minutes
# check telnet communication again to make sure its not a temporary network error
# check telnet communication one last time to make sure its not a temporary network error
# now restart hmailserver service
# wait 1 minute
# refresh service status
# if service still not running, send notification
				$Body = "ATTENTION! hMailServer service failed to restart and is not running. Check status NOW."
Post by katip » 2019-03-25 08:40
Thanks, looks like a useful script.
There is a small tool here (free & portable):
http://www.den4b.com/products/shutter
once it helped me to restart a server which randomly lost network connection every few days (never been able to find out what the problem was), if ping fails.
it does a number of other things.
Post by palinka » 2019-03-27 11:10
katip wrote:
2019-03-25 08:40
Cool. I just looked. Winamp LOL. I had a winamp radio station a long time ago. All Johnny Cash all the time. He has such a YUUUGE discography you could listen for a week without hearing the same song. :mrgreen:
I actually have a version of this script for all the major services on my server. They run every 15 minutes. This one for hmailserver is different. I run it only once a day at 12:15 am, 15 minutes after my hmailserver backup script (Jimi's backup & clear down).
I have a peculiar issue where sometimes hmailserver hangs on shutdown. So checking for service status = not running doesn't work because the service is running, but it's not working. That's why instead i check for communication by telnet. I found a powershell script that communicates by telnet. I stripped out all the unnecessary stuff so it just looks to make a connection. If no communication then it means hmailserver got hung.
In the version that gets run every 15 minutes with all the other services, it simply notifies me without taking any action (it looks for service status, not telnet). I set it up that way so it doesn't attempt to restart during a backup. And anyway, hmailserver is so rock solid, if it weren't for this one single issue that only happens during backup, i really wouldn't need to check anything at all. That one has never been triggered in the few months I've been using it. I doubt it will ever be triggered.
But I'll have a closer look at the one you posted. The ping thing could be very useful.
Post by palinka » 2019-10-02 23:09
For some reason, hmailserver got hung up last night and my telnet script didn't work. I suspect that's because it possibly successfully connected, but didn't act. Instead of just true/false on connection, this version looks at the output of connecting, which should be 220 mail.example.com. If connection fails, or if your smtp banner doesn't come up, then it goes through the same routine of restarting, etc.
Powershell:
# USER VARIABLES
$StartTime = (Get-Date 00:30) # check telnet start time - sometime after nightly backup ends
$EndTime = (Get-Date 23:50) # check telnet end time - sometime before nightly backup begins
$Banner = 'mail.example.com' # hMailServer smtp banner
$ServiceName = 'hMailServer' # name of hMailServer service - installation default
$StreamFile = 'C:\scripts\checkstate\telnetout.txt' # location of test output (temporary file)
$Now = Get-Date
Function CkTelnet {
	$Socket = New-Object System.Net.Sockets.TcpClient('localhost', 25)
	If ($Socket)
	{	$Stream = $Socket.GetStream()
		$Writer = New-Object System.IO.StreamWriter($Stream)
		$Buffer = New-Object System.Byte[] 1024
		$Encoding = New-Object System.Text.AsciiEncoding
	ForEach ($Command in $Commands)
		{ $Writer.WriteLine($Command)
		  $Writer.Flush()
	Start-Sleep -seconds (2)
	$Result = ""
	While($Stream.DataAvailable)
	{	$Read = $Stream.Read($Buffer, 0, 1024)
		$Result += ($Encoding.GetString($Buffer, 0, $Read)) | Out-File $StreamFile
Function CkSvcMail($Body) {
	$EmailFrom = "notification@gmail.com"
	$SMTPAuthUser = "notification@gmail.com"
	$SMTPAuthPass = "supersecretpassword"
# Check if being called during backup period, if yes, exit.
if ($Now -gt $EndTime){exit}
elseif ($Now -lt $StartTime){exit}
else {
	# Test telnet connection, if success then exit, if failure then wait 1 minute and try again
	CkTelnet
	If (Test-Path $StreamFile){
		$TestResult = Get-Content $StreamFile | Out-String
		Remove-Item -Path $StreamFile
		If ($TestResult -match $Banner){exit}
	Else {
		$Body = "ATTENTION! hMailServer is NOT RESPONDING to telnet commands. Check status NOW."
		CkSvcMail $Body
		# Test telnet connection, if success then exit, if failure then restart service
		CkTelnet
		Else {
			$Body = "ATTENTION! $ServiceName service is being RESTARTED due to a fault. Check status NOW!"
			CkSvcMail $Body
			# Wait 1 minute after service restart, refresh, then if running, exit, otherwise try restart again
			if ((get-service $ServiceName).Status -ne 'Running'){
				$Body = "ATTENTION! $ServiceName service is being RESTARTED due to a fault - 2nd attempt. Check status NOW!"
				CkSvcMail $Body
				# Wait 1 minute after service restart, refresh, then if still not running, give up
					$Body = "ATTENTION! $ServiceName service could not be started. Check status NOW!"
					CkSvcMail $Body
Post by palinka » 2019-11-12 21:18
Updated to cover a logic/sequence of events issue.
# USER VARIABLES
$StartTime = (Get-Date 00:20)                # check telnet start time - sometime after nightly backup ends
$EndTime = (Get-Date 23:55)                  # check telnet end time - sometime before nightly backup begins
$Banner = 'mail.mydomain.tld'                # hMailServer SMTP banner
$StreamFile = "$PSScriptRoot\telnetout.txt"  # location of test output (temporary file)
$Now = Get-Date
Function CkTelnet {
	If ($Socket)
		  $Writer.Flush()
	$Result = ""
Function RestartRoutine {
	CkSvcMail $Body
		CkSvcMail $Body
			CkSvcMail $Body
Function SecondTry {
	CkSvcMail $Body
	CkTelnet
		Else {RestartRoutine}
If ($Now -gt $EndTime){exit}
ElseIf ($Now -lt $StartTime){exit}
Else {
	CkTelnet
		Else {SecondTry}
	Else {SecondTry}
Post by palinka » 2020-10-08 16:31
Refreshed for 2020... :D
.SYNOPSIS
	Test telnet on hMailServer
.DESCRIPTION
	Uses telnet to ensure hMailServer properly functioning
.FUNCTIONALITY
	1) Telnets in to hMailServer and checks for 220 Banner
	2) If banner found, exit
	3) If banner not found then wait, check again, if still not found then restart hMailServer service
	4) Sends notification messages by email and SMS
.NOTES
	Run every 5 minutes via task scheduler
.EXAMPLE
<###   USER VARIABLES   ###>
$AvoidBackup  = $True             # if true, script will not run during backup routine in case hMailServer is shut down during backup
$StartTime    = Get-Date '00:30'  # run script start time - sometime after nightly backup ends
$EndTime      = Get-Date '23:55'  # run script end time - sometime before nightly backup begins
$Banner       = 'mydomain.tld'    # hMailServer smtp banner
$ServiceName  = 'hMailServer'     # name of hMailServer service (installation default is 'hMailServer')
$Timeout      = 5                 # number of minutes to try service shutdown or startup before giving up
<###   EMAIL VARIABLES   ###>
$EmailFrom    = "notification.acct@gmail.com"
$SMTPAuthUser = "notification.acct@gmail.com"
$SMTPPort     = 587
$UseSSL       = $True
$UseEmail     = $True
<###   GAMMU SMS VARIABLES   ###>
$SMSNumber    = "1234567890"
$SMSDRC       = "C:\gammu\bin\smsdrc"
$UseSMS       = $True
<#  Start Script  #>
$Now = Get-Date
Function CkTelnet {
	If ($Socket)
		  $Writer.Flush()
	$Result = ""
Function Notify($Body){
	If ($UseEmail){CkSvcMail $Body}
	If ($UseSMS){CkSvcSMS $Body}
	$Subject = "$ServiceName Service Failure"
	$SMTPClient = New-Object Net.Mail.SmtpClient($SMTPServer, $SMTPPort)
	$SMTPClient.EnableSsl = $UseSSL
Function CkSvcSMS($Body) {
	& cmd.exe /c gammu-smsd-inject -c $SMSDRC TEXT $SMSNumber -text $Body
	<#  Send notification, then restart service  #>
	Notify "ATTENTION! $ServiceName service is being RESTARTED due to a fault. Check status NOW!"
	<#  Shutdown Routine  #>
	$BeginShutdown = Get-Date
	Do {
		Stop-Service $ServiceName
		Start-Sleep -Seconds 60
		(Get-Service $ServiceName).Refresh()
		$ServiceStatus = (Get-Service $ServiceName).Status
	} Until (((New-Timespan -Start $BeginStartup -End (Get-Date)).Minutes -gt $Timeout) -or ($ServiceStatus -eq "Stopped"))
	If ($ServiceStatus -ne "Stopped"){
		Notify "$ServiceName could not be stopped during restart process. Check status NOW."
		Exit
	<#  Startup Routine  #>
	$BeginStartup = Get-Date
	Do {
		Start-Service $ServiceName
	} Until (((New-Timespan -Start $BeginStartup -End (Get-Date)).Minutes -gt $Timeout) -or ($ServiceStatus -eq "Running"))
	If ($ServiceStatus -ne "Running"){
		Notify "$ServiceName could not be started during restart process. Check status NOW."
		Exit
	<#  Send notification, then wait 60 seconds and try telnet again  #>
	Notify "ATTENTION! hMailServer is NOT RESPONDING to telnet commands. Check status NOW."
	<#  Test telnet connection, if success then exit, if failure then restart service  #>
	CkTelnet
		If ($TestResult -match $Banner){Exit}
Function TryTelnet {
	<#  Test telnet connection, if success then exit, if failure then wait 1 minute and try again  #>
	CkTelnet
		Else {SecondTry}
	Else {SecondTry}
<#  Check if script should not run during backup  #>
If ($AvoidBackup){
	<#  If not being called during backup period, then run it  #>
	If (($StartTime.TimeOfDay -le $Now.TimeOfDay) -and ($EndTime.TimeOfDay -ge $Now.TimeOfDay)) {
		TryTelnet
<#  If script should run all the time, then just do it  #>
} Else {
	TryTelnet
