Unix style "tail -f" written in VBS. *APPLIED*
Proof-of-Concept code here:
https://www.hmailserver.com/forum/viewt ... 67#p212967
Practical use and further adaptation of code in this thread. Thanks.
Re: Unix style "tail -f" written in VBS. *APPLIED*
Minor changes.
Option Explicit
'********** Configuration **********
' COM authentication
Private Const PASSWORD = "VerySecretPassword"
' Misc. settings
Private Const intInterval = "2" ' Event trigger interval in seconds.
Private Const strComputer = "." ' Nodename/Computer name
Private Const FOR_READING = 1
'********** Functions **********
Function tailFile(strFileName)
Dim intCurrLine, intNewNumLines, strReadLine, strRegEx, arrReadLine
Dim oFSO, oFile
Set oFile = oFSO.OpenTextFile(strFileName, FOR_READING)
intNewNumLines = 0
intCurrLine = 0
Do Until oFile.AtEndOfStream
intCurrLine = intCurrLine + 1
If intCurrLine <= intLastRunLineinFile Then
oFile.skipline
strReadLine = oFile.ReadLine
' THIS IS WHERE THE FUN BEGINS ==>
WScript.echo strReadLine
strRegEx = "(Unknown user)|(Origin Banned)|(mechanism not supported)|(Authentication failed)"
If Lookup(strRegEx, strReadLine) Then
.AddRecipient "Postmaster", "postmaster@acme.inc"
.FromAddress = "postmaster@acme.inc"
.HeaderValue("To") = Chr(34) & "Postmaster" & Chr(34) & " <postmaster@acme.inc>"
.HeaderValue("From") = Chr(34) & "Postmaster" & Chr(34) & " <postmaster@acme.inc>"
.Subject = "log_tail.vbs found something"
.Body = strReadLine
.Save
' ==> THIS IS WHERE THE FUN ENDS
intNewNumLines = intNewNumLines + 1
Loop
If intCurrLine < intLastRunLineinFile Then
' The number of lines on this scan was less than the last run so resetting the num lines in file
intLastRunLineinFile = intCurrLine
intLastRunLineinFile = intLastRunLineinFile + intNewNumLines
oFile.close
Set oFile = Nothing
Set oFSO = Nothing
Function get_NumLinesInFile(strFileName)
Dim intTotalNumLines
Dim oFSO, oFile
intTotalNumLines = 0
oFile.skipline
intTotalNumLines = intTotalNumLines + 1
Loop
oFile.close
Set oFile = Nothing
Set oFSO = Nothing
get_NumLinesInFile = intTotalNumLines
Function get_DefaultLogFileName(stdDrive, strFolder)
Dim oLog, i, arrArgsLine
Set oLog = CreateObject("hMailServer.Logging")
get_DefaultLogFileName = oLog.CurrentDefaultLog
Set oLog = Nothing
arrArgsLine = Split(get_DefaultLogFileName, "\")
strDrive = arrArgsLine(0)
If UBound(arrArgsLine) > 1 Then
For i = 1 To UBound(arrArgsLine)-1
strFolder = strFolder & "\\" & arrArgsLine(i)
.Pattern = strRegEx
.Global = False
.MultiLine = True
.IgnoreCase = True
.Pattern = strRegEx
.Global = bGlobal
.MultiLine = True
.IgnoreCase = True
'********** Main Code **********
Dim strLongFileName, strDrive, strFolder, strQuery, intLastRunLineinFile, colEvents
Dim oWMIService, oEvent, oTargetInst
' Read logfile
strLongFileName = get_DefaultLogFileName(strDrive, strFolder)
intLastRunLineinFile = get_NumLinesInFile(strLongFileName)
' Build interface to WMI
strQuery = "Select * From __InstanceOperationEvent Within " & intInterval & _
" Where Targetinstance Isa 'CIM_DataFile' And TargetInstance.Drive='" & strDrive & _
"' And TargetInstance.Path='" & strFolder & "'"
Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colEvents = oWMIService.ExecNotificationQuery(strQuery)
' Event management
Do
Set oEvent = colEvents.NextEvent()
Set oTargetInst = oEvent.TargetInstance
Select Case oEvent.Path_.Class
Case "__InstanceDeletionEvent"
If 0 = StrComp(oTargetInst.Name, strLongFileName, 1) Then
WScript.echo oTargetInst.Name & " has been deleted. Exiting."
WScript.quit
Case "__InstanceModificationEvent"
tailFile(oTargetInst.Name)
Case "__InstanceCreationEvent"
If 0 = StrComp(Left(oTargetInst.Name, 12), Left(strLongFileName, 12), 1) Then
WScript.echo oTargetInst.Name & " has been created. Loading new logfile."
strLongFileName = oTargetInst.Name
intLastRunLineinFile = 0
End Select
Loop
WScript.quit
Fixed problem motoring logfiles. If an error log was created the code would follow the error log and not the regular log.
Option Explicit
' Misc. settings
Dim oFSO, oFile
intNewNumLines = 0
intCurrLine = 0
oFile.skipline
.Subject = "hm_tail.vbs found something"
.Body = strReadLine
.Save
Loop
oFile.close
Set oFile = Nothing
Set oFSO = Nothing
Dim oFSO, oFile
oFile.skipline
Loop
oFile.close
Set oFile = Nothing
Set oFSO = Nothing
Set oLog = Nothing
Function get_FileName(strFileName)
Dim oFSO, oFile
Set oFile = oFSO.GetFile(strFileName)
get_FileName = oFSO.GetFileName(oFile)
Set oFile = Nothing
Set oFSO = Nothing
.Pattern = strRegEx
.Global = False
.MultiLine = True
.IgnoreCase = True
.Pattern = strRegEx
.Global = bGlobal
.MultiLine = True
.IgnoreCase = True
' Read logfile
' Event management
Do
WScript.quit
If 0 = StrComp(Left(get_FileName(oTargetInst.Name), 12), Left(get_FileName(strLongFileName), 12), 1) Then
End Select
Loop
WScript.quit
Trying to understand how this works. What passes "strFileName"? A trigger? Loads at startup? Scheduled task? I don't get that part.
I just came up with a clever use case for this. I just noticed my mom autobanned herself from too many password tries. I'd like to be notified when that happens again, which will definitely happen again soon.
It's quite simple. It's sort of like creating a "stored procedure" on a database table. If you change, add or delete data in the table you trigger the procedure.
This will tell WMI to monitor a specific folder:
Select * From __InstanceOperationEvent Within 2
Where Targetinstance Isa 'CIM_DataFile' And TargetInstance.Drive='C:'
And TargetInstance.Path='\hmailserver\logs'
Set oWMIService = GetObject("winmgmts:{impersonationLevel=impersonate}!\\.\root\cimv2")
Left column on this page lists the events that can be monitored..
https://docs.microsoft.com/en-us/window ... etionevent
And... strFileName is not really used
I'm currently testing a version where SnowShoe, LashBack and Out-of-Area logins are banned. All based on hmailserver_<date>.log with TCPIP logging activated. The option in hMailServer to keep logfiles open have no affect on the functionality.
I found that I need a function in Eventhandlers.vbs to check IF an IPAddress has been banned somewhere between TCPIP Connect and the event OnClientConnect/OnHELO. Banning an ongoing connection will NOT disconnect it automatically.
I have ran this for some time...got e few mails, would be nice to have the previous line (or previous few lines) included in the mail as well, now i still have to lookup that line in the logfile myself
You'll just have to figure out how to make a 5 line floating buffer
One application I can see for this is looking for SnowShoe/LashBack/GeoIP blocking to update a firewall in real-time - or perhaps for statistical purposes. The advantage is you can change it all you want, start/stop it all day long and even if it fails it will NOT affect hMailServer.
I've been playing with those three to AutoBan but TCPIP will register when a banned IP connect so it generates a lot of traffic
or https://gallery.technet.microsoft.com/s ... 1749f42f21RvdH wrote: ↑2019-06-28 20:38Something like this?![]()
https://stackoverflow.com/questions/341 ... 6#34187866
Now with a 10 line Ring Buffer in case the last 10 lines are needed.
Option Explicit
Private Const PASSWORD = "Secret-Secret-Secret"
' Misc. settings
Private Const RING_COUNT = 10
'********** Classes **********
Class ringBuffer
Private buffer
Private indexNext
Private size
Public Sub Class_Initialize
resize 1
'RESIZE THE BUFFER, OLD DATA IS LOST
Public Sub resize(numElements)
size = Int(numElements)
If size < 1 Then size = 1
ReDim buffer(size-1)
indexNext = 0
'ADD AN ELEMENT TO RING BUFFER OVERWRITING OLD DATA
Public Function add(element)
buffer(indexNext) = element
indexNext = wrapIndex(indexNext + 1)
'GET PREVIOUS ELEMENT WITH DISTANCE i FROM NEWEST ELEMENT
Public Function getPrev(i)
getPrev = buffer( wrapIndex(indexNext-1-i) )
'MAKES AN INDEX TO RING BUFFER FROM 0 TO BUFFER SIZE-1
'if index is outside the ring buffer,
'then it will wrap it around so it goes inside the buffer
Public Function wrapIndex(i)
If i >= size Then
wrapIndex = i Mod size
ElseIf i < 0 Then
wrapIndex = (i + size * (Int(1 + Abs(i/size)))) Mod size
wrapIndex = i
'BECAUSE...
Public Sub testWrapIndex(indexLow, indexHigh)
Dim s, i
s = "size" & vbTab & Size & vbCrLf & "i" & vbTab & "wrapped" & vbCrLf
For i = indexLow To indexHigh
s = s & i & vbTab & wrapIndex(i) & vbCrLf
WScript.echo s
End Class
Dim i, intCurrLine, intNewNumLines, strBody, strRegEx, arrReadLine
Dim oFSO, oFile
intNewNumLines = 0
intCurrLine = 0
oFile.skipline
oRing.add(oFile.ReadLine)
WScript.echo oRing.getPrev(0)
If Lookup(strRegEx, oRing.getPrev(0)) Then
strBody = ""
For i = RING_COUNT-1 To 0 Step -1
strBody = strBody & vbCrLf & oRing.getPrev(i)
.Body = strBody
.Save
Loop
oFile.close
Set oFile = Nothing
Set oFSO = Nothing
Dim oFSO, oFile
oFile.skipline
Loop
oFile.close
Set oFile = Nothing
Set oFSO = Nothing
' ByRef is used to update the global variables.
Function get_DefaultLogFileName(ByRef stdDrive, ByRef strFolder)
Set oLog = Nothing
Dim oFSO, oFile
Set oFile = Nothing
Set oFSO = Nothing
.Pattern = strRegEx
.Global = False
.MultiLine = True
.IgnoreCase = True
.Pattern = strRegEx
.Global = bGlobal
.MultiLine = True
.IgnoreCase = True
Dim oWMIService, oEvent, oTargetInst, oRing
Set oRing = New ringBuffer
oRing.resize RING_COUNT
Do
WScript.quit
End Select
Loop
WScript.quit
Exactly!
LOL
LOL
I already implemented my found solution, it was off sometimes, eg: mails containing way more lines as the supposed 5
your seem to work much better, thx!
I have added some auto-ban functions inside hm_tail.vbs, i'll like it!
Make sure you replace {backup-mx-ip} and {domain-to-be-blocked} variables
dim intUnique : intUnique = 0
' Find Unique Indentifier
strRegEx = "^(?:\S+\s){2}(\S+)"
Set Matches = oLookup(strRegEx, oRing.getPrev(1), true)
If Matches.Count > 0 Then intUnique = Matches(0).Submatches(0)
Set Matches = Nothing
' find domains to block
strRegEx = "(\<.+\@.*(?:{domain-to-be-blocked}).+\>)"
If lookup(strRegEx, oRing.getPrev(1)) then
Dim strIp : strIp = ""
Dim strEmailAddress : strEmailAddress = ""
Dim Matches
' Find ip
strRegEx = "\b((?:(?:[0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5])\.){3}(?:[0-9]|[1-9][0-9]|1[0-9]{2}|2[0-4][0-9]|25[0-5]))\b"
Set Matches = oLookup(strRegEx, oRing.getPrev(1), false)
If Matches.Count > 0 Then strIp = Matches(0).Value
' Find Emailaddress
strRegEx = "\b(\w+([\-\+\.\']\w+)*\@\w+([\-\.]\w+)*\.\w+([\-\.]\w+)*)\b"
If Matches.Count > 0 Then strEmailAddress = Matches(0).Value
If (strIp <> "" And strEmailAddress <> "" And lookup("\b(" & intUnique & ")\b", oRing.getPrev(0))) then
strRegEx = "^({backup-mx-ip})$"
' Filter out backup MX's
If Not Lookup(strRegEx, strIp) Then
Call AutoBan(strIp, strEmailAddress, 1, "ww")
If lookup("\b(" & intUnique & ")\b", oRing.getPrev(0)) then
.Subject = "hm_tail.vbs found something (" & intUnique & ")"
.Body = strBody
.Save
