Problem with OnSMTPData filter script
bagu
Post by bagu » 2020-10-06 14:27
I have this on my EventHandler.vbs :
Function ListedInAbuseIPDB(strIP) : ListedInAbuseIPDB = false
	With CreateObject("AbuseIPDBComponent.AbuseIPDBRestClient")
		.SetApiKey("MyAPIKey")
		.SetMaxConfidenceScore(40)
		.SetMaxAgeInDays(90)
		On Error Resume Next
		ListedInAbuseIPDB = .BlockEndpoint(strIP)
		If (ListedInAbuseIPDB) then
			'EventLog.Write("AbuseIPDB Score:" & .GetConfidenceScore(strIP))
		If Err.Number <> 0 Then
			'EventLog.Write("AbuseIPDB Error: " & Err.Description)
		On Error Goto 0
	' GeoIP
	Dim geoip
	Result.Value = 0
	set geoip = CreateObject("GeoIPCOMEx.GeoIPEx")
	geoip.set_db_path("D:\geoip\")
	geoip.find_by_addr(oClient.IPAddress)
	country = geoip.country_code
	Select Case country
		Case "AE","AG","AL","AR","AZ","BA","BB","BD","BG","BN","BO","BR","BY","BZ","CM","CI","CN","CO","CZ","DO","EC","EE","EG","GE","GH","GR","GT","HK","ID","IL","IN","IR","IS","JO","JP","KE","KH","KR","KZ","LA","LB","LT","MA","MD","MG","MO","MN","MV","MW","MX","MY","MZ","NC","NE","NG","NI","NP","PA","PE","PK","PH","PY","RO","RU","RS","RW","SA","SC","SD","SG","SI","SK","SV","TH","TJ","TT","TR","TW","TZ","UA","UG","UZ","VE","VN","ZA","ZM"
			Result.Value = 1
			EventLog.Write("Geo-IP (country) rejected:" & vbTab & vbTab & vbTab & oClient.IPAddress & ":" & oClient.Port & vbTab & geoip.country_code & vbTab & geoip.country_name)
		Case Else
			If (oClient.IPAddress = "127.0.0.1") Then Exit Sub '** Localhost
			If (Left(oClient.IPAddress, 9) = "172.16.0.") Then Exit Sub '** Local LAN clients
			If ((oClient.Port = 993) And (country <> "FR") AND (country <> "LN")) Then
				EventLog.Write("Geo-IP (port) rejected:" & vbTab & vbTab & vbTab & oClient.IPAddress & ":" & oClient.Port & vbTab & geoip.country_code & vbTab & geoip.country_name)
				Result.Value = 1
				Exit Sub
			If (oClient.Port <> 25) Then
				If ListedInAbuseIPDB(oClient.IPAddress) Then
					EventLog.Write("AbuseIPDB rejected:" & vbTab & vbTab & vbTab & vbTab & oClient.IPAddress & ":" & oClient.Port & vbTab & country & vbTab & geoip.country_name)
					Result.Value = 1
					Exit Sub
	End Select
'   End Sub
'   Sub OnSMTPData(oClient, oMessage)
	Result.Value = 0
	blockedVarLenEnd = Array(".bid", ".best", ".casa", ".club", ".com.au", ".cn", ".cyou", ".date", ".loan", ".md", ".ml", ".science", ".site", ".stream", ".top", ".trade", ".ua", ".br", ".review", ".website", ".win", ".xyz", ".top", "octelio.emsecure.net", "hosting-by.directwebhost.org", ".pro", ".icu", ".ru", "plateformpro.fr", ".pro", ".online", ".guru", ".world", ".live", ".today", ".digital", ".co", ".monster", ".pt", ".work", ".network", ".buzz", ".io", "sbcglobal.net", "maxijob.net")
	For Each bEmail in blockedVarLenEnd
		If right(oMessage.FromAddress,len(bEmail)) = bEmail Then
			Result.Value = 1
			EventLog.Write("OnSMTPData rejected:" & vbTab & vbTab & vbTab & oClient.IPAddress & ":" & oClient.Port & vbTab & oMessage.FromAddress)
			Exit Sub
			EventLog.Write("OnSMTPData accepted:" & vbTab & vbTab & vbTab & oClient.IPAddress & ":" & oClient.Port & vbTab & oMessage.FromAddress)
As you can see, in the OnSMTPData section, .monster may be blocked.
But, i have this on my logs :
6924 "2020-10-06 02:34:17.453" "OnSMTPData accepted: 89.144.29.9:25 root.canal-secret=secret@bringerdaring.monster"
Can you help me to understand how this can happen ?
Re: Problem with OnSMTPData filter script
Post by palinka » 2020-10-06 15:33
bagu wrote:
2020-10-06 14:27
	Result.Value = 0
			Result.Value = 1
			Exit Sub
I'm not the vbs expert, so don't blame me if I send you off on a wild goose chase. :lol:
Is there an error log? You haven't declared the variables. That always ends up with errors in my logs.
Are any other messages getting blocked by this script?
bagu
Post by bagu » 2020-10-06 15:39
No problem.
There is no error message. That's why it strange.
But, i think i may rewrite the OnSMTPData as this :
	Result.Value = 0
			Result.Value = 1
			Exit Sub
Because (i'm not a vbs expert too), i think the "OnSMTPData accepted" should only happen if the loop (each/Next) don't match anything.
But i'm not sure it's the right solution
P.S. : It's not my script, and i don't know how to make a good vbs script, so i only try to adapt what i find for my own purpose
Post by palinka » 2020-10-06 16:16
I would use regex. That may only be because i know i could make it work.
Also, are you sure that declaring result value = 0 at the top is not what's tripping you up?
Post by SorenR » 2020-10-06 16:33
Perhaps a bit simpler?
And NO, I chose on purpose NOT to include your blocklist - that one you can do yourself. It's standard RegEx using standard RegEx rules. :mrgreen:
      .Pattern = strRegEx
      .Global = bGlobal
      .MultiLine = True
      .IgnoreCase = True
   Dim strRegEx, Match, Matches
   ' Reject "From:"
   strRegEx = "(Sweetme)|(Kira Johns)|(July Girl)|(Hot Mama)|(Little Miss)|" & _
              "(Baby Boobs)|(Booby Girl)|(Booby Booms)|" & _
              "(\.bid|\.kim|\.men|\.top|\.win|\.xyz|\.zip)(|\>)$"
   Set Matches = oLookup(strRegEx, oMessage.From, False)
   If Matches.Count > 0 Then
      For Each Match In Matches
         Result.Value = 1
         Exit Sub
NB:! There is a "False" passed in oLookup so only ONE match will be returned despite the "For Each Match In Matches" ... :wink:
bagu
Post by bagu » 2020-10-06 17:09
I'm not familiar with regex.
That's why i don't use it (an error can come sooooo quick if there is a mistake in regex ^^)
