Personal URIBL
Personal URIBL
Post by palinka » 2022-05-04 00:20
pURIBL (aka palinka URIBL :D )
https://github.com/palinkas-jo-reggelt/ ... ver_pURIBL
The script is built on top of Soren's dynamic black/white list script. (Thanks!)
Basically it works like this:
1) scrapes spam messages (messages with spam score over delete threshold) and inserts URIs into the pURIBL database
2) checks incoming messages against URIs in the pURIBL database
It also comes with a php web admin.
EventHandlers.vbs:
Option Explicit
Private Const DeleteThreshold = 7                             'hMailServer spam delete threshold
Private Const hMSPASSWORD = "SuperSecrecthMailServerPassword" 'hMailServer COM password (Administrator password)
Private Const hMSdbPW = "SuperSecretDatabasePassword"         'hMailServer MySQL database user password
Private Const pURIBLURITable = "hm_puribluri"                 'pURIBL URI table name
Private Const pURIBLDomTable = "hm_puribldom"                 'pURIBL domain table name
Private Const PublicSuffix = "C:\Program Files (x86)\hMailServer\Events\public_suffix_list.vbs" 'Path to public_suffix_list.vbs
Private pURIBLDict : Set pURIBLDict = CreateObject("Scripting.Dictionary")
		.Pattern = strRegEx
		.Global = False
		.MultiLine = True
		.IgnoreCase = True
		.Pattern = strRegEx
		.Global = bGlobal
		.MultiLine = True
		.IgnoreCase = True
Function GetDatabaseObject()
	Call oApp.Authenticate("Administrator", hMSPASSWORD)
	Set GetDatabaseObject = oApp.Database
Function Include(sInstFile)
	Dim f, s, oFSO
	On Error Resume Next
	If oFSO.FileExists(sInstFile) Then
		Set f = oFSO.OpenTextFile(sInstFile)
		s = f.ReadAll
		f.Close
		ExecuteGlobal s
	On Error Goto 0
	Set f = Nothing
	Set oFSO = Nothing
Sub BlackList(oMessage, strMatch, iScore)
    Dim i, Done : Done = False
    If CInt(oMessage.HeaderValue("X-hMailServer-Reason-Score")) > 0 Then
        i = CInt(oMessage.HeaderValue("X-hMailServer-Reason-Score"))
        oMessage.HeaderValue("X-hMailServer-Spam") = "YES"
        i = 0
	oMessage.HeaderValue("X-hMailServer-Blacklist") = "YES"
	oMessage.HeaderValue("X-hMailServer-Reason-0") = "BlackListed - (Score: " & iScore & ")"
	oMessage.HeaderValue("X-hMailServer-Reason-Score") = iScore + i
    i = 1
    Do Until Done
        If (oMessage.HeaderValue("X-hMailServer-BlackList-" & i) = "") Then
            oMessage.HeaderValue("X-hMailServer-BlackList-" & i) = strMatch
            Exit Do
            i = i + 1
    Loop
Function GetMainDomain(strDomain)
	Dim strRegEx, Match, Matches
	Dim TestDomain, DomainParts, a, i, PubSuffMatch
	Include(PublicSuffix)
	DomainParts = Split(strDomain,".")
	a = UBound(DomainParts)
	If a > 1 Then
		TestDomain = DomainParts(1)
		For i = 2 to a
			TestDomain = TestDomain & "." & DomainParts(i)
	ElseIf a = 1 Then
		Exit Function
	Set Matches = oLookup(PubSufRegEx, TestDomain, False)
	For Each Match In Matches
		PubSuffMatch = True
	If PubSuffMatch Then
		GetMainDomain = DomainParts(0) & "." & TestDomain
		GetMainDomain = GetMainDomain(TestDomain)
Function ExcludeHead(strStr)
	Dim Head
	If InStr(strStr, "</HEAD>") Then Head = "</HEAD>" Else If InStr(strStr, "</head>") Then Head = "</head>" Else Head = "</Head>"
	If InStr(strStr, Head) > 0 Then
		ExcludeHead = Right(strStr, ((Len(strStr)) - (InStr(strStr, Head) + 7)))
		ExcludeHead = strStr
'###   pURIBL MySQL Table Structure   ###'
' CREATE TABLE IF NOT EXISTS hm_puribluri (
	' id int(11) NOT NULL AUTO_INCREMENT,
	' uri text NOT NULL,
	' timestamp datetime NOT NULL,
	' adds mediumint(9) NOT NULL,
	' hits mediumint(9) NOT NULL,
	' active tinyint(1) NOT NULL,
	' PRIMARY KEY (id),
	' UNIQUE KEY uri (uri) USING HASH
' ) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4;
' COMMIT;
' CREATE TABLE IF NOT EXISTS hm_puribldom (
	' domain text NOT NULL,
	' shortcircuit tinyint(1) NOT NULL,
	' PRIMARY KEY (id),
	' UNIQUE KEY uri (domain) USING HASH
' COMMIT;
Function pURIBLRegEx(pURIBLDict, pType) : pURIBLRegEx = ""
	Dim strData, pID, pRecord, pURL, pSQL
	Dim oRecord, oDB : Set oDB = CreateObject("ADODB.Connection")
	oDB.Open "Driver={MariaDB ODBC 3.1 Driver}; Server=localhost; Database=hmailserver; User=hmailserver; Password=" & hMSdbPW & ";"
	If oDB.State <> 1 Then
		EventLog.Write( "pURIBLRegEx - ERROR: Could not connect to database" )
		pURIBLRegEx = "VOID"
		Exit Function
	pURIBLDict.RemoveAll
	If pType = "DOM" Then
		pSQL = "SELECT * FROM " & pURIBLDomTable & " WHERE shortcircuit = 1;"
		pRecord = "domain"
		pSQL = "SELECT * FROM " & pURIBLURITable & " WHERE active = 1;"
		pRecord = "uri"
	Set oRecord = oDB.Execute(pSQL)
	Do Until oRecord.EOF
		pID = CStr(Trim(oRecord("id")))
		pURL = CStr(Trim(oRecord(pRecord)))
		If (pURL <> "") Then
			strData = strData & pURL & "|"
			pURIBLDict.Add pID, pURL
		oRecord.MoveNext
	Loop
	If (Trim(strData) <> "") Then
		pURIBLRegEx = Left(strData,Len(strData)-1)
		EventLog.Write("ERROR: pURIBLEDomRegEx: Database returned no records")
	Set oRecord = Nothing
	oDB.Close
	Set oDB = Nothing
Function pURIBLStat(pURIBLDict, oMatchValue, pType)
	Dim strSQL, oDB, objKey, pTable
		EventLog.Write( "pURIBLStat - ERROR: Could not connect to database" )
		pURIBLStat = "VOID"
		Exit Function
	If pType = "DOM" Then pTable = pURIBLDomTable Else pTable = pURIBLURITable
	For Each objKey In pURIBLDict
		If Lookup(CStr(pURIBLDict(objKey)), oMatchValue) Then
			strSQL = "UPDATE " & pTable & " SET timestamp = NOW(), hits = (hits + 1) WHERE id = '" & CStr(objKey) & "';"
			Call oDB.Execute(strSQL)
			Exit For
	Set oDB = Nothing
	REM - Exclude authenticated users test
	If (oClient.Username <> "") Then Exit Sub
	Dim oMatch, oMatchCollection
	Dim Done
	REM - Blacklist on pURIBL
	Dim pURIBLBlacklistScore : pURIBLBlacklistScore = 4 'Blacklist Score
	Done = False
	Do Until Done
		REM - Blacklist on pURIBL Domain match - plain text body
		strRegEx = pURIBLRegEx(pURIBLDict, "DOM")
		If strRegEx <> "VOID" Then
			Set oMatchCollection = oLookup(strRegEx, oMessage.Body, False)
			For Each oMatch In oMatchCollection
				Call pURIBLStat(pURIBLDict, oMatch.Value, "DOM")
				Call BlackList(oMessage, "pURIBL Dom = '" & oMatch.Value & "'", pURIBLBlacklistScore)
				Exit Do
		REM - Blacklist on pURIBL Domain match - HTML body
			Set oMatchCollection = oLookup(strRegEx, ExcludeHead(oMessage.HTMLBody), False)
				Exit Do
		REM - Blacklist on pURIBL URI match - plain text body
		strRegEx = pURIBLRegEx(pURIBLDict, "URI")
				Call pURIBLStat(pURIBLDict, oMatch.Value, "URI")
				Call BlackList(oMessage, "pURIBL URI = '" & oMatch.Value & "'", pURIBLBlacklistScore)
				Exit Do
		REM - Blacklist on pURIBL URI match - HTML body
				Exit Do
		Done = True
	Loop
Sub OnDeliveryStart(oMessage)
	REM - Populate pURIBL
	If oMessage.HeaderValue("X-hMailServer-Reason-Score") <> "" Then
		If CInt(oMessage.HeaderValue("X-hMailServer-Reason-Score") >= DeleteThreshold) Then
			Dim strSQL, strSQLD, oDB : Set oDB = GetDatabaseObject
			Dim strRegExD, MatchD, MatchesD
			strRegEx = "(\b((https?(:\/\/|%3A%2F%2F))((([a-zA-Z0-9-]+)\.)+[a-zA-Z0-9-]+)(:\d+)?((?:\/[\+~%\/\.\w\-_]*)?\??(?:[\-\+=&;%@\.\w_]*)#?(?:[\.\!\/\\\w]*))?)\b)"
			Set Matches = oLookup(strRegEx, oMessage.Body, True)
				strSQL = "INSERT INTO " & pURIBLURITable & " (uri,timestamp,adds,active) VALUES ('" & Match.SubMatches(0) & "',NOW(),1,1) ON DUPLICATE KEY UPDATE adds=(adds+1),timestamp=NOW();"
				Call oDB.ExecuteSQL(strSQL)
				strRegExD = "(?:^https?)(?::\/\/|%3A%2F%2F)(?:[^@\/\n]+@)?([^:\/%?\n]+)"
				Set MatchesD = oLookup(strRegExD, Match.SubMatches(0), True)
				For Each MatchD In MatchesD
					strSQLD = "INSERT INTO " & pURIBLDomTable & " (domain,timestamp,adds,shortcircuit) VALUES ('" & GetMainDomain(MatchD.SubMatches(0)) & "',NOW(),1,1) ON DUPLICATE KEY UPDATE adds=(adds+1),timestamp=NOW();"
					Call oDB.ExecuteSQL(strSQLD)
			Set Matches = oLookup(strRegEx, oMessage.HTMLBody, True)
Re: Personal URIBL
Post by palinka » 2022-05-04 15:50
Updated for bug fixes and housekeeping.
Re: Personal URIBL
Post by palinka » 2022-05-15 21:30
I'm working on an "offline" version that gets called from task scheduler. Its almost done. Anyway, a log is created that contains log stuff, including URIs found in messages. A notification is sent with the log attached.
Anyway, the log attachment is triggering Sanesecurity.Jurlbl.b1c735.UNOFFICIAL in ClamAV so hmailserver deletes the attachment. :?
Is there a good strategery for dealing with this OTHER THAN dumping jurlbl from freshclam?
Re: Personal URIBL
Post by palinka » 2022-05-18 19:22
Offline version now up on github. What it does:
1) Loops through messages in user defined HAM and SPAM folders.
1a) If HAM folder, it inspects messages younger than (user defined) N days for links that match the pURI-BL list. If a hit is found, the message is fed to SpamC for bayes training as spam and the message is moved to the spam folder.
1b) If SPAM folder, it inspects messages younger than N days. If message has spam score greater than delete threshold, it inspects the message for URIs and adds them to the database.
2) Creates custom spamassassin rule "pURIBL.cf" and puts it into SA config dir.
3) Writes debug output to file and emails it to user (which hmailserver+clamAV+sanesecurity promptly deletes due to virus detection :lol: :lol: :lol: )
Run nightly from task scheduler, preferably before any other script that results in restarting spamassassin so the custom rule file will be loaded.
glenluo
Re: Personal URIBL
Post by glenluo » 2022-05-21 13:24
You can build your own DBL easily if your like. dns.he.net support subdomain.
For example:
dbl.mydomian.com NS ns1.he.net
dbl.mydomian.com NS ns2.he.net
Then add A record:
phishing.com.dbl.mydomian.com A 127.0.0.2
hacker.com.dbl.mydomian.com A 127.0.0.2
Re: Personal URIBL
Post by palinka » 2022-05-22 03:13
glenluo wrote:
2022-05-21 13:24
For example:
Then add A record:
I was looking for something like that but they all were too complicated for me. I'll check it out in the morning. Thanks.
Re: Personal URIBL
Post by palinka » 2022-05-22 18:01
glenluo wrote:
2022-05-21 13:24
For example:
Then add A record:
I just had a look (was drinking beer last night :D ) and he.net appears to be no different than my current dns service - dynu.com. I can add these records already. The question is, how do I return an answer without a dns server installed on my side?
glenluo
Re: Personal URIBL
Post by glenluo » 2022-05-23 04:36
At your hmailserver,DBL,you add dbl.mydomian.com
Just try it. You can easily have your own DBL just like: dbl.spamhaus.org
Re: Personal URIBL
Post by palinka » 2022-05-23 13:05
glenluo wrote:
2022-05-23 04:36
I get that. But somehow, I need to answer the request. Also, its not just a domain, its a full URL:
bad.domain.tld.dbl.mydomain.com
https://bad.domain.tld/some?other_gibberish/in+a.url.dbl.mydomain.com
Those records have to be individual zones? Do URLs have to be url-encoded? How does hmailserver transmit SURBL requests? This is the stuff I don't know about.
Re: Personal URIBL
Post by palinka » 2022-05-23 13:25
I just did some reading at surbl.org and it appears that only FQDNs are checked. NOT URIS. This is an important distinction because there are some legit FQDNs that host bad content. For example, google forms and google docs.
My pURI-BL looks at actual URLs for exact match AND domains for partial match on a URL.
All bad urls get recorded and the "main domain" gets recorded as domain. Main domain means the TLD as parsed from the public suffix list plus one level down. You have the option of short circuiting the main domain if it appears to be sufficiently spammy (that is subjective and up to the admin - but its usually an easy decision). Short circuit means if the domain is found as a partial match on a URL, the message is marked as a spam hit. This way you can have legit domains AND bad content listed from the same domain.
I don't think this is possible via dns query.
glenluo
Re: Personal URIBL
Post by glenluo » 2022-05-23 14:08
I think DBL checks something like: bad.domain.tld.dbl.mydomain.com
I only block the main domain and subdomain,you can build your own dns server too.
Re: Personal URIBL
Post by palinka » 2022-05-23 15:10
glenluo wrote:
2022-05-23 14:08
That's what I'm trying to avoid! :D
Re: Personal URIBL
Post by palinka » 2022-05-23 15:17
glenluo wrote:
2022-05-23 14:08
Now that I think about it, I could roll this together with my "catchspam" database. I just have to figure out how to script adding and deleting zone records. And I could even offer it publicly, because there's no impact on my server at all. :D
