Howto: VB.NET DCOM-Remote access from your own .NET App
Post by Dravion » 2017-07-24 11:06
This is basicly the same Howto as allready described in:
viewtopic.php?f=21&t=31507
Because its VB.NET (NOT the same as VBScript or VBA! it looks a bit diffrent
See the code below:
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
Dim tServerType As Type
Dim remoteServer As hMailServer.Application
Try
'Retrieve hMailServer.Application Type info
tServerType = Type.GetTypeFromProgID("hMailServer.Application", ed_server.Text)
'Create an instance of the remote server object locally.
remoteServer = Activator.CreateInstance(tServerType)
'Authenticate against hMailServer
remoteServer.Authenticate(ed_username.Text, ed_password.Text)
'Now we are authenticated, we can operate with hMailServer Service
remoteServer.Connect()
'Get hMailServers VersionInfo
Dim strhMsVersion As String
strhMsVersion = remoteServer.Version
MessageBox.Show(strhMsVersion, $"Info")
Catch errCom As COMException
MessageBox.Show(errCom, $"Info")
Catch err As Exception
MessageBox.Show($"Error 2 xxxx", $"Info")
End Try
Working VS2017 VB.NET Project attached
VB.NET_WindowsApp1.7z
(66.11 KiB) Downloaded 278 times
