Accessing hMaillServer's DCOM-OutOfProc server from native code is by far the most complex scenario, but to save
time and headache, here is a working example how to do it the native way (not the only possible way, but a good
starting point).
Notice: We need the same prequesites as for the VB.NET and C# Sharp Tutorials, so you should study the C#
and linked Guides to fullfill the needed requirements: viewtopic.php?f=21&t=31507
If everything works as expected, you should see a new Console Window which looks like this
A working, native C/C++ Visual Studio 2017 Project with compiled Exe is avaiable as attachement.
The compiled Exe requires the IP adress: 192.168.203.89 to find your remote hMailServer, but you can
change and replace it with your ip or hostname.
Howto: C/C++ DCOM-Remote access from your own native Win32/Win64 Program
- Attachments
- ConsoleDCOM.7z
- (56.55 KiB) Downloaded 296 times
