Windows God Mode = Control Panel on steroids.
Post by SorenR » 2018-01-31 18:43
Not so much a tutorial, more a way to "bend" your Windows.
Verified on Vista Home Premium, Windows 10 Home and Windows 10 Pro.
Create a directory locally, on a network share, on a USB key or on a CD/DVD - it does not really matter where... Name it:
GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
For those OS'es that it supports, the name will appear as "GodMode" and the icon will look like Control Panel.
Have fun ;-)
tunis
Re: Windows God Mode = Control Panel on steroids.
Post by tunis » 2018-02-01 14:32
I have used it sens Windows 7.
It almost a must whit Windows 8 and 10.
Or make a cmd file whit the command "control" to open old control panel in windows 10.
Post by jimimaseye » 2018-02-01 14:46
Yeah but..... what does it do?
tunis
Post by tunis » 2018-02-01 16:49
jimimaseye wrote:Yeah but..... what does it do?
Gives you all control panel settings in one long list.
Post by mattg » 2018-02-01 17:02
even some that you can't access through control panel
