Cannot recieve emails
GeobhMail
Post by GeobhMail » 2018-07-04 12:05
The response was:
The recipient server did not accept our requests to connect. Learn more at https://support.google.com/mail/answer/7720 [mail.cladda.xyz. 154.70.1.16: timed out]
My hMailServer is behind a router, i have done port forwarding for 25/587/465/995/993/110/143 ports.
I have also set up SSL using openSSL.
I can connect to my server on all the ports from cmd on all the ports using
openssl s_client -connect mail.cladda.xyz:25
mxToolbox SMTP Test returns:
Connecting to 154.70.1.16
7/4/2018 5:00:29 AM Connection attempt #1 - Unable to connect after 15 seconds. [15.00 sec]
LookupServerv2 15001ms
Where do i dig
Regards
Geob
Re: Cannot recieve emails
Post by jimimaseye » 2018-07-04 13:04
Do telnet tests to your address on port 25 from:
a, a WAN side machine
b, a LAN side machine, not the server, to LAN address of the server.
If they connect, then enable SMTP and APPLICATION logging, try to send in another email and then view the results of the log (post them here). Also run this and post the results: viewtopic.php?f=20&t=30914
GeobhMail
Post by GeobhMail » 2018-07-04 16:36
telnet tests only return 220 mail.cladda.xyz ESMTP with None/STARTTLS(Optiona)/STARTTLS(Required) Connection security types.
Dead with SSL/TLS Connection security chosen.
Post by jimimaseye » 2018-07-04 16:41
2018-07-04 13:04
GeobhMail
Post by GeobhMail » 2018-07-04 16:44
"SMTPD"	13340	146	"2018-07-04 17:34:10.996"	"154.70.1.16"	"SENT: 220 mail.cladda.xyz ESMTP"
"SMTPD"	16524	146	"2018-07-04 17:37:41.259"	"154.70.1.16"	"RECEIVED: ehlo mail.cladda.xyz"
"SMTPD"	16524	146	"2018-07-04 17:37:41.259"	"154.70.1.16"	"SENT: 250-mail.cladda.xyz[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	16524	146	"2018-07-04 17:38:04.732"	"154.70.1.16"	"RECEIVED: mail from:georgeobera@gmail.com"
"SMTPD"	16524	146	"2018-07-04 17:38:04.732"	"154.70.1.16"	"SENT: 250 OK"
"SMTPD"	16524	146	"2018-07-04 17:38:37.673"	"154.70.1.16"	"RECEIVED: rcpt to:support@cladda.xyz"
"SMTPD"	16524	146	"2018-07-04 17:38:37.675"	"154.70.1.16"	"SENT: 250 OK"
"SMTPD"	16524	146	"2018-07-04 17:39:39.112"	"154.70.1.16"	"RECEIVED: data"
"SMTPD"	16524	146	"2018-07-04 17:39:39.113"	"154.70.1.16"	"SENT: 354 OK, send."
"SMTPD"	5964	146	"2018-07-04 17:40:35.619"	"154.70.1.16"	"SENT: 250 Queued (56.500 seconds)"
"APPLICATION"	11016	"2018-07-04 17:40:35.622"	"SMTPDeliverer - Message 92: Delivering message from georgeobera@gmail.com to support@cladda.xyz. File: M:\Programs\hMailServer\Data\{ED30DAED-1524-4F89-9BF4-D32A49165E0A}.eml"
"APPLICATION"	11016	"2018-07-04 17:40:35.672"	"SMTPDeliverer - Message 92: Message delivery thread completed."
GeobhMail
Post by GeobhMail » 2018-07-04 16:47
Delivers a blank message though, no Subject, no From, no Email body
Post by jimimaseye » 2018-07-04 18:03
2018-07-04 13:04
And
Isnt the problem that you cannot send OUT emails?
If so, send a test email out (FROM hmailserver) - wait 90 seconds, and post the results.
GeobhMail
Post by GeobhMail » 2018-07-04 18:57
Sending is fine, i can send to both internal and external accounts, but cannot receive from external accounts.
Internal to Internal accounts is received with SSL/TLS Connection security type. HMS does not support STARTTLS it says.
Post by mattg » 2018-07-05 00:49
Do you have a certificate installed??
GeobhMail wrote:
2018-07-04 12:05
Could mean that you have a self signed certificate, but it may just mean that you've installed OpenSSL. I can't tell.
For the forth time
2018-07-04 13:04
If you did that when first asked we would have more of an idea of what is wrong.
It could be cert related, or port security, or protocol or cipher or....
Help us to help you please.
The diagnostics requested are de-identified, and you can vet them before you post them.
