Fix-Script: ReRegister hMailServer's Registry entries
Post by Dravion » 2018-12-18 11:18
If you see this Error while using hMailAdmin
you can use this script to fix the Error
This will ReRegister hMailServer 32-Bit (official Version) Registry entries to setup defaults
Usage:
1) Download the attached hmsreg.zip file and unpack it
2) Rightclick hmsreg.bat and run "As Administrator" and wait until repair is done
Now you should be able again to use hMailAdmin again and login into hMailServer as Admin.
hmsreg.zip
(719 Bytes) Downloaded 108 times
Re: Fix-Script: ReRegister hMailServer's Registry entries
Post by Dravion » 2019-01-31 08:27
Updated version - Use this
The Script needs Windwos Admin permissions.
If you doubleclick it without Admin permissions it will raise a UAC Confirm Dialog.
Diffrence between the first version.
The first version simply reregistered the hMailServer COM Object, but this version now first unregister if something is still registred and reregister it
after unregistration.
hmsreg2.7z
(643 Bytes) Downloaded 101 times
