Error when running "Diagnostics"
when I run "Diagnostics" in hMail Admin, I receive an error:
ExceptionType: COMException
HelpLine:
Message: Exception from HRESULT: 0x800403E9
Source: Interop.hMailServer
StackTrace: at hMailServer.DiagnosticsClass.PerformTests()
at hMailServer.Administrator.ucDiagnostics.buttonPerformTests_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
TargetSite: hMailServer.DiagnosticResults PerformTests()
hMail version: 5.6.4-B2283, Win7 x64
If I remember correctly, this worked in a former version of hMail on the same system.
Any ideas?
Thanks and regards
Agatha
HelpLine:
Any ideas?
Thanks and regards
Agatha
- jimimaseye
- Moderator
Re: Error when running "Diagnostics"
Check your certificates.
Do you have HMS set to use them (SSL)? IF so, is the path to them correct?
Check the certificate: is it THERE? is it readable? Is it configured correctly?
https://www.google.co.uk/search?q=hmail ... server.com
No, I do not use SSL within hMail and i do not have any certificates on this server.
Settings->Advanced->SSL certificates: No entries
Settings->Advanced->SSL/TLS: "Verify remote ..." is unchecked, "Versions" are all checked.
And thanks for the google link - I searched "800403E9" within the forum and didn´t get this result. But only results relating to scripting errors (wrong password).
- jimimaseye
- Moderator
Good luck.
As you can see from the search results there is not one single cause so you may just have to do some heavy reading and work through them.
Well, I am quite sure, that I did not change any permissions. And Apache works fine too.
I read "viewtopic.php?t=27567#p170518", but as far as I see, my configuration is OK. Especially the service has no problems with windows permissions.
So I think it might be more likely a problem with a recently added feature in hMail (which occurs under certain circumstances).
I do not really need this function, as everything works fine. But it might be a bug. And my configuration might be a hint, to resolve this issue.
When you run the diagnostics please leave the 'Outbound port 25 test hostname' as the default 'mail.hmailserver.com'
I did both: I left the default value as well as I used a custom one.
None of them worked.
It is strange in so far, as everything works fine (pop, imap, smtp, http). It seems, hmail just failes to create the output form.
In SMTP relayer under delivery of email, what do you have set for the 'remote host name', 'remote TCP/IP port' and the 'connection security'
I use hMS as a local mailserver, that pulls and sends mails from/to a provider. Therefor the remote host name is the smtp address of this provider. Port is 465 and connection security is SSL/TLS.In SMTP relayer under delivery of email, what do you have set for the 'remote host name', 'remote TCP/IP port' and the 'connection security'
And I do not have any problems with sending or receiving mails. No errors in the log files - nothing. And I am quite sure that diagnostics already worked on this server in this configuration (of course, I am not fully sure, sometimes you change something "small" and forget it - but basically neither OS, database nor Apache were changed. No Windows users or privileges or the hMail service were changed either).
In my opinion, only two things have changed since then: Windows updates (.net??) and hMS. But I guess, I am not the only one who runs hMS in this configuration, so it seems not to be a common problem.
The basic question is, if it is a problem in the configuration of hMS or more likely a problem with Windows.
The problem is that the diagnostics don't work if you set the outgoing port to 465 in SMTP relayer.
If you want to show the diagnostics, change the port, run the diagnostics and then put the port back to where it is.
It seems this has been broken a few versions. I'll ensure that it is update on github.
Indeed. That´s the problem.The problem is that the diagnostics don't work if you set the outgoing port to 465 in SMTP relayer.
Thank you for the explanation!
