URL send to SURBL
tunis
URL send to SURBL
Post by tunis » 2020-01-23 09:32
Hello, I saw that the URL for SURBL lookup sometimes is faulty.
Here is an example from my log.
"DEBUG"	3168	"2020-01-23 08:09:03.919"	"SURBL: Execute"
"DEBUG"	3168	"2020-01-23 08:09:03.919"	"SURBL: Found URL: webbdagarna.se"
"DEBUG"	3168	"2020-01-23 08:09:03.919"	"SURBL: Found URL: trippus.se"
"DEBUG"	3168	"2020-01-23 08:09:03.919"	"SURBL: Found URL: rebelandbird.com)conversionista"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: conversionista.com)bleckout"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: bleckout.co)"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: nitor.com"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: storykit.io"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: umbraco.com)"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: zenloop.com"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: siteimprove.com)adform"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: adform.com)"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: ugglamassage.se)"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: stickerapp.se)"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: kakdegsfabriken.se)"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: idg.se"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Found URL: twitter.com"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: 16 unique addresses found."
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Lookup: adform.com).multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Lookup: bleckout.co).multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Lookup: conversionista.com)bleckout.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:03.935"	"SURBL: Lookup: idg.se.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.075"	"SURBL: Lookup: kakdegsfabriken.se).multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.075"	"SURBL: Lookup: nitor.com.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.207"	"SURBL: Lookup: rebelandbird.com)conversionista.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.207"	"SURBL: Lookup: siteimprove.com)adform.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.207"	"SURBL: Lookup: stickerapp.se).multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.207"	"SURBL: Lookup: storykit.io.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.287"	"SURBL: Lookup: trippus.se.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.456"	"SURBL: Lookup: twitter.com.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.563"	"SURBL: Lookup: ugglamassage.se).multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.563"	"SURBL: Lookup: umbraco.com).multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.563"	"SURBL: Lookup: webbdagarna.se.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.610"	"SURBL: Lookup: zenloop.com.multi.surbl.org"
"DEBUG"	3168	"2020-01-23 08:09:04.790"	"SURBL: Match not found"
Some URL contains ")", that not should be there.
Is anybody else got this in the logs?
Re: URL send to SURBL
Post by jimimaseye » 2020-01-23 09:58
Ideally, you should find the email that contains the link in the body to see how that link is formed. Then we can determine if it is a parsing issue (and therefore potentially problematic) or just a display issue with the actual url being correctly parsed and checked as required.
Can you find examples?
tunis
Post by tunis » 2020-01-23 11:07
I checked the email and all links are like this one.
href="https://dmd.idg.se/x/c/?LU.RbsMgDPyVvtCnqQ0hbMokq2q3L1gf9jgRQAldDJEDivb1DLLJtnQn_3w6DbLNCB3vmz7PILnseSbgont_EXmCKcZlfT2ft207kR3srLwZHJmTDnhJEb90WmNAJm.bwuT7v.BJtsd9qXBRbvTwaYfBqFGRV6xt7jHo7ynMWHAtVlvcH6kA.1Mv1vhgb4JdO.KBCndlFgojKUQb999rSKQtWEM7RWtcQrCo3PznHXy0PkI1aHgrsoGPGuBwPNxKgF8A38"
This redirects to rebelandbird.com "rebelandbird.com)conversionista".
Post by mattg » 2020-01-28 01:20
I noticed some with square braces too
hMailserver should remove all braces / brackets before sending to SURBL testing
Post by RvdH » 2020-01-28 13:47
What HMS version?
I think te regex used to detect URL's for SURBL checking is faulty,
https://github.com/hmailserver/hmailser ... BL.cpp#L43
Or does BOOST use some weird/custom regex?
Post by SorenR » 2020-01-28 16:03
2020-01-28 13:47
What HMS version?
https://www.regular-expressions.info/boost.html
Post by RvdH » 2020-01-28 20:58
OK, as it seems BOOST needs some weird extra escaping
But i would say, using a regex like: (?:https?:\\/\\/)([^\\?&><\\[\\(#\\\\ \\\"'\\/\\)\\]]*) would solve the issues, see example here: https://regexr.com/4t4ap
Post by palinka » 2020-01-28 21:28
2020-01-28 20:58
Could the X-Spam-Report (bad) formatting also be caused by a malformed regex? It appears to delete line breaks from the report.
Post by RvdH » 2020-01-28 21:44
2020-01-28 21:28
2020-01-28 20:58
No
Have been trying to fix that as well, but i am unable to find where that goes wrong, looks like the spam report and hmailserver use different line-endings and thus destroying the spam report formatting
https://github.com/hmailserver/hmailserver/issues/115
https://github.com/hmailserver/hmailserver/issues/138
Post by RvdH » 2020-01-29 02:42
tunis wrote:
2020-01-23 11:07
Redirect? Is mailserver supposed to follow redirect url's? I doubt it does, so that seems to be a wrong example and assumption
Post by RvdH » 2020-01-29 04:44
This regex thingy is keeping me awake :)
Instead of defining every character that is NOT allowed, like:
(?:https?:\/\/)(?:[^@\s]+@)?(?:www\.)?([^\?:#<>\s{}[\]()\/\\'\"]+)
https://regexr.com/4t4u3
Wouldn't it be easier to specify what characters are allowed? (eg: alphanumeric, dot and dash)
(?:https?:\/\/)(?:[^@\s]+@)?(?:www\.)?([\w\-\.]+)
https://regexr.com/4t4u6
Post by mattg » 2020-01-29 04:48
I have a government newsletter sent to me yesterday
@ RvdH, I'll PM you both the log, plus the source of the email
I'm using 5.7.0-B2497 (x64) = absolute bleeding edge
tunis
Post by tunis » 2020-01-29 10:18
2020-01-29 02:42
tunis wrote:
2020-01-23 11:07
All link (except two) in that email are like this and I get lots of SURBL checks for that email. Look at the first post.
Is hmailServer doing any encoding that course and the link encode to a readable link?
tunis
Post by tunis » 2020-01-29 12:39
I tried to resend that email and then it's only find the URL I found.
"DEBUG"	2684	"2020-01-29 11:23:04.817"	"SURBL: Execute"
"DEBUG"	2684	"2020-01-29 11:23:04.833"	"SURBL: Found URL: idg.se"
"DEBUG"	2684	"2020-01-29 11:23:04.833"	"SURBL: Found URL: ugglamassage.se"
"DEBUG"	2684	"2020-01-29 11:23:04.833"	"SURBL: Found URL: stickerapp.se"
"DEBUG"	2684	"2020-01-29 11:23:04.833"	"SURBL: 3 unique addresses found."
"DEBUG"	2684	"2020-01-29 11:23:04.833"	"SURBL: Lookup: idg.se.multi.surbl.org"
"DEBUG"	2684	"2020-01-29 11:23:04.972"	"SURBL: Lookup: stickerapp.se.multi.surbl.org"
"DEBUG"	2684	"2020-01-29 11:23:05.004"	"SURBL: Lookup: ugglamassage.se.multi.surbl.org"
"DEBUG"	2684	"2020-01-29 11:23:05.035"	"SURBL: Match not found"
I found more emails with ")" in the log, but I can't find that URL in emails. In some emails like in the first post I can't even find the domain name.
Post by RvdH » 2020-01-29 15:51
Base64 Encoded maybe?
This regex ain't never gonna be 100% i think, to much quirks
Post by SorenR » 2020-01-29 18:42
2020-01-28 21:44
2020-01-28 21:28
2020-01-28 20:58
No
Looking at this from a different angle... Windows use CRLF and Unix use LF... I found myself in a situation where only half of a .BAT file would work labal wise (Compiling BOOST 1.72) and I ended up converting all .BAT files from LF line endings to CRLF line endings.
https://www.hmailserver.com/forum/viewt ... ST#p216909
On the other hand SpamAssassin have had dealings with the CRLF/LF policy before... And... Since 90% of SpamAssassin developers use Unix they don't really care about Windows ;-)
https://bz.apache.org/SpamAssassin/show_bug.cgi?id=4068
Post by RvdH » 2020-01-30 10:41
Please stay on topic, this post is about SURBL url detection
I think the 'best' regex i have come up and tested is:
(?:(?>https?)?(?>:\/\/|\%3A\%2F\%2F))(?:www\.)?([a-z0-9\-\.\=\r\n]+)
To have a perfect regex seems impossible, as the are so many possibilities with formatting, encoding, line-breaks in the e-mail source
You can test this regexp by using the online testers like: https://regex101.com/ and/or https://regexr.com/ using PCRE with the flags: case insensitive, global
Copy paste the regex above and simply paste the e-mail message source, (almost ;)) all occurrences of urls in the mails should be highlighted
I have posted a pull request for martin, now just hope he's still around ;)
https://github.com/hmailserver/hmailserver/pull/312
Post by RvdH » 2020-01-30 12:45
@tunis
If your signature is right you are still using 5.6.x, right?
I have a 5.6.8-B2494.24 build (at the usual place) using the above regex if you like to give it a test run
tunis
Post by tunis » 2020-01-30 15:45
@RvdH
I updated hmailServer almost the same email came again without ")".
"DEBUG"	1116	"2020-01-30 13:22:53.636"	"SURBL: Execute"
"DEBUG"	1116	"2020-01-30 13:22:53.636"	"SURBL: Found URL: webbdagarna.se"
"DEBUG"	1116	"2020-01-30 13:22:53.636"	"SURBL: Found URL: trippus.se"
"DEBUG"	1116	"2020-01-30 13:22:53.636"	"SURBL: Found URL: rebelandbird.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: conversionista.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: bleckout.co"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: socialview.se"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: nitor.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: storykit.io"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: umbraco.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: creuna.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: zenloop.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: siteimprove.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: adform.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: mis.se"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: comprend.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Found URL: stickermule.com"
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: 16 unique addresses found."
"DEBUG"	1116	"2020-01-30 13:22:53.652"	"SURBL: Lookup: adform.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:53.831"	"SURBL: Lookup: bleckout.co.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:53.863"	"SURBL: Lookup: comprend.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:53.988"	"SURBL: Lookup: conversionista.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.131"	"SURBL: Lookup: creuna.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.262"	"SURBL: Lookup: mis.se.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.294"	"SURBL: Lookup: nitor.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.309"	"SURBL: Lookup: rebelandbird.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.356"	"SURBL: Lookup: siteimprove.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.372"	"SURBL: Lookup: socialview.se.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.403"	"SURBL: Lookup: stickermule.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.450"	"SURBL: Lookup: storykit.io.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.481"	"SURBL: Lookup: trippus.se.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.607"	"SURBL: Lookup: umbraco.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.716"	"SURBL: Lookup: webbdagarna.se.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.763"	"SURBL: Lookup: zenloop.com.multi.surbl.org"
"DEBUG"	1116	"2020-01-30 13:22:54.794"	"SURBL: Match not found"
I still wonder how it detects URLs? I can't find more than 2-3 domain and SURBL find 16. But no ")" is found now. :D
Post by RvdH » 2020-01-30 16:39
tunis wrote:
2020-01-30 15:45
@RvdH
Cool 8)
It literally takes the mail (source!) and tries to lookup url entries in it line by line, this could be in the headers, plain text part, html part (incl style blocks)
Maybe you should try what i described above, eg: take the mail source and paste it into https://regex101.com/ and/or https://regexr.com/ using described regex, all occurrences of urls in the mails should be highlighted
tunis
Post by tunis » 2020-01-30 16:59
2020-01-30 16:39
I have taken the source of the email and the URLs are not there but SURBL find them.
Post by RvdH » 2020-01-30 17:02
Can you pm the source to me so i could have a look?
I am a bit surprised to see 16 matches and lookups, especially because a hardcoded limit of 15 is defined in the code
const int maxURLsToProcess = 15;
:o
Post by palinka » 2020-01-30 18:21
2020-01-30 17:02
:o
0-15 = 16 iterations. :D
Post by RvdH » 2020-01-30 19:12
2020-01-30 18:21
2020-01-30 17:02
:o
:oops:
Post by RvdH » 2020-03-07 16:55
This change is now included in latest artifact for 5.7.x
