hmail with roundcube
gantoua
Post by gantoua » 2020-02-07 01:17
hi. i install the hmailserver on windows 2012r2 server and roundcube for webmail in another server on ubuntu. how I can allow users to change their password through in roundcube; i install the plugin tou change password but i can't do it. Thanks very much and sorry for my english.
Re: hmail with roundcube
Post by mattg » 2020-02-07 01:55
roundcube password change relies on DCOM, which will only work if roundcube is installed on the same server that hMailserver is installed on. Normally on IIS, but I think that apache on the windows server should also work.
Post by SorenR » 2020-02-07 03:48
Well, actually YOU CAN run Roundcube on a 'nix box and hMailServer on a Win box... I do it with a little help from Andreas Tunberg (I do not know if he is the brother of Greta ... )
https://github.com/tunis78
You WILL need to install the Webportal for hMailServer on the Windows box. It WILL NOT need Internet access but it WILL need permission granted for the Roundcube Server.
The modified plugins for Roundcube will use a "custom driver" to allow the Plugin to proxy requests to the hMailServer Webportal.
It works for me since mid 2018 on Roundcube 1.3.3 - I run my web-stuff on an older NAS and have been a bit challenged by the PHP versions lately.
Oops... It seems I have broken part of it when I installed 5.6.8 and overwritten the PHPWebAdmin folder on IIS... Now I know what to do this weekend :mrgreen:
EDIT... Files restored but need to correct fileaccess/IIS access rights and I have no remote terminal with me. :roll:
Post by mattg » 2020-02-07 04:06
2020-02-07 03:48
..a little help from Andreas Tunberg (I do not know if he is the brother of Greta ... )
tunis78
Perhaps he is Greta's father :mrgreen:
I do think that this may be our regular 'tunis'
Post by mattg » 2020-02-07 04:19
2020-02-07 03:48
Where do I find this 'Webportal for hMailServer'
Post by SorenR » 2020-02-07 04:20
2020-02-07 04:06
2020-02-07 03:48
tunis78
The one and only.
Found this... password changer for hMailserver using Tunis' "remote_hm" stuff on Unix.
https://www.hmailserver.com/forum/viewtopic.php?t=30844
Post by SorenR » 2020-02-07 04:22
2020-02-07 04:19
2020-02-07 03:48
Er... It's the PHPWebAdmin that comes with hMailServer. :wink:
tunis
Post by tunis » 2020-02-07 09:35
First, I'm not related to Greta.
I use nginx and php on my hMailserver and I had only uncomment this "com.allow_dcom = true" in php.ini.
Copy required files to your www catalog.
There is instruction in config.inc.dist in all plugins I made.
Post by SorenR » 2020-02-07 17:05
tunis wrote:
2020-02-07 09:35
Oh AND !!! Do remember to add the IP address of your Roundcube server to the "hm_rc*.php" files copied to the PHPWebAdmin directory. If not you'll get a "403 Forbidden" in Roundcube or a "You are not permitted" if you link directly from your browser.
Me... 20 minutes ago...
