Is HmailServer for the likes of me?
SlapheadDiver
Re: Is HmailServer for the likes of me?
Post by SlapheadDiver » 2020-04-16 19:10
Hi
Installed eMclient [free] on my laptop as a trial and on running it it pormpted for an email address so I pasted "Mark@Mark-Personal" and it scanned and reported "The domain cannot be resolved. Check the email address and network connection". I can find no option to give it the servers name or IP address so my guess is it's expecting ind a domain name somewhere on our network and can't? Maybe this is T/bird's problem too?
Maybe it's due to the file server running Win 10 Pro not a server version?
If we can get eMclient running I think I'll stick with it as it appears to offer more than T/bird albeit I'd upgrade to the Pro version
Post by SorenR » 2020-04-16 20:49
SlapheadDiver wrote:
2020-04-16 19:10
Hi
If "Mark-Personal" does not resolve you can enter the IP address of the server.
SlapheadDiver
Post by SlapheadDiver » 2020-04-17 10:20
eMclient - Well that resulted in a slitght curious out come with Mark@192..... sever IP address I got a pop up:
Verify certificate
Clicking on show certificate it shows AkrutoCertificate which is softaware running on the server that syncs my Outlook calendar and contacts to my mobile
Maybe for testing purposes I shd close Akruto and MailCopa's services on the server and see what happens. Possible conflict? If that's what it is then it's only a problem in the transition to HmailServer as bewteen it and eMclient they'll replace MailCopa, Outlook and possibly Akruto
SlapheadDiver
Post by SlapheadDiver » 2020-04-25 19:18
Hi
Finally found a bit of time to try and progress this!
Stopped MailCopa and AkrutoSync on the Server
AVG f/wall still off, sing Win 10 Defender
Using eMclient, account setup, Mark@192..... server IP
Searching database
Initialising search
Obtaining server configuration records
Running
Obtaining MX records
Trying common 'IMAP4' Server configurations
Trying common 'POP3' Server configurations
The correct settings could not be determined. Check email address or Setup account manual
Tried a couple variations on manually setting it up and failed so turned AVG f/wall back on and repeated setting up a new account
Searching database
Initialising search
Running
Obtaining MX records - Asked for p/word then credentials
The correct settings could not be determined. Check email address or password - Slightly different and feels a little closer
Tried Mark@Mark-Personal@ 192......... - Not found
Mark-Personal@ 192......... asked for p/word and credentials
Same error msg: The correct settings could not be determined. Check email address or password
:D Just had another tinker with Thunderbird and hey presto I've an Inbox with emails in it and with AVG F/wall. Now how to replicate that in eMclient
:D eMclient - Opted for manual setup and bingo, emails in my inbox
Restarted MailCopa
Things are looking up, can I send an email?
:( Emails not going out, tried 2 different SMTP addresses, ours and Yahoo's. Error code 10054. A bit more work to do it would seem
Post by SorenR » 2020-04-25 19:23
Enable logging in hMailServer (SMTP, TCP/IP and Debug) and post log...
SlapheadDiver
Post by SlapheadDiver » 2020-04-26 11:52
Morning, had a further 'play' but still no joy. I've set a route up to provide the SMTP address for the email address @ Yahoo I'm currently using for my testing
For some reason I didn't receive any email advising of your reply, just seen it. Set log and tried to send another email thru HS
"DEBUG" 928 "2020-04-26 10:33:26.927" "Creating session 34"
"TCPIP" 928 "2020-04-26 10:33:26.928" "TCP - 192.168.1.127 connected to 192.168.1.121:25."
"DEBUG" 928 "2020-04-26 10:33:26.933" "TCP connection started for session 31"
"SMTPD" 928 31 "2020-04-26 10:33:26.934" "192.168.1.127" "SENT: 220 Yahoo ESMTP"
"SMTPD" 1184 31 "2020-04-26 10:33:26.936" "192.168.1.127" "RECEIVED: EHLO [192.168.1.127]"
"SMTPD" 1184 31 "2020-04-26 10:33:26.937" "192.168.1.127" "SENT: 250-Yahoo[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 928 31 "2020-04-26 10:33:26.939" "192.168.1.127" "RECEIVED: AUTH LOGIN"
"SMTPD" 928 31 "2020-04-26 10:33:26.943" "192.168.1.127" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 1184 31 "2020-04-26 10:33:26.945" "192.168.1.127" "RECEIVED: TWFya0BtYXJrLXBlcnNvbmFs"
"SMTPD" 1184 31 "2020-04-26 10:33:26.946" "192.168.1.127" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 1184 31 "2020-04-26 10:33:26.948" "192.168.1.127" "RECEIVED: ***"
"SMTPD" 1184 31 "2020-04-26 10:33:26.958" "192.168.1.127" "SENT: 235 authenticated."
"SMTPD" 928 31 "2020-04-26 10:33:26.960" "192.168.1.127" "RECEIVED: MAIL FROM:<Mark@mark-personal> SIZE=1226"
"SMTPD" 928 31 "2020-04-26 10:33:26.970" "192.168.1.127" "SENT: 250 OK"
"SMTPD" 1312 31 "2020-04-26 10:33:26.972" "192.168.1.127" "RECEIVED: RCPT TO:<MarkCaPeters@yahoo.co.uk>"
"SMTPD" 1312 31 "2020-04-26 10:33:26.976" "192.168.1.127" "SENT: 250 OK"
"SMTPD" 1312 31 "2020-04-26 10:33:26.978" "192.168.1.127" "RECEIVED: DATA"
"SMTPD" 1312 31 "2020-04-26 10:33:26.979" "192.168.1.127" "SENT: 354 OK, send."
"DEBUG" 1184 "2020-04-26 10:33:28.034" "Could not retrieve PTR record for IP (false)! 192.168.1.127"
"DEBUG" 1184 "2020-04-26 10:33:28.034" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 9844 "2020-04-26 10:33:28.035" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 9844 "2020-04-26 10:33:28.035" "Saving message: {70210D47-0228-4071-8445-91520B0D06D9}.eml"
"DEBUG" 9844 "2020-04-26 10:33:28.037" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 9844 31 "2020-04-26 10:33:28.037" "192.168.1.127" "SENT: 250 Queued (1.064 seconds)"
"DEBUG" 10096 "2020-04-26 10:33:28.039" "Adding task DeliveryTask to work queue SMTP delivery queue"
"SMTPD" 1184 31 "2020-04-26 10:33:28.039" "192.168.1.127" "RECEIVED: QUIT"
"DEBUG" 10112 "2020-04-26 10:33:28.039" "Executing task DeliveryTask in work queue SMTP delivery queue"
"SMTPD" 1184 31 "2020-04-26 10:33:28.039" "192.168.1.127" "SENT: 221 goodbye"
"DEBUG" 10112 "2020-04-26 10:33:28.039" "Delivering message..."
"DEBUG" 1188 "2020-04-26 10:33:28.040" "Ending session 31"
"DEBUG" 10112 "2020-04-26 10:33:28.040" "Applying rules"
"DEBUG" 10112 "2020-04-26 10:33:28.040" "Performing local delivery"
"DEBUG" 10112 "2020-04-26 10:33:28.041" "Local delivery completed"
"DEBUG" 10112 "2020-04-26 10:33:28.070" "Starting external delivery process. Server: smtp.mail.yahoo.com (188.125.73.26), Port: 587, Security: 1, User name: SlapHeadDiver@Yahoo.co.uk"
"DEBUG" 10112 "2020-04-26 10:33:28.071" "Creating session 35"
"TCPIP" 10112 "2020-04-26 10:33:28.071" "Connecting to 188.125.73.26:587..."
"DEBUG" 1188 "2020-04-26 10:33:28.071" "TCP connection started for session 35"
"DEBUG" 1188 "2020-04-26 10:33:28.072" "Performing SSL/TLS handshake for session 35. Verify certificate: False, Expected remote host name: smtp.mail.yahoo.com"
"DEBUG" 1184 "2020-04-26 10:33:28.100" "Saving message: {402089F0-E71D-492C-B016-4CE4DCD82527}.eml"
"DEBUG" 1184 "2020-04-26 10:33:28.107" "Reading messages from database."
"TCPIP" 1184 "2020-04-26 10:33:28.129" "TCPConnection - TLS/SSL handshake failed. Session Id: 35, Remote IP: 188.125.73.26, Error code: 10054, Message: An existing connection was forcibly closed by the remote host"
"DEBUG" 1184 "2020-04-26 10:33:28.130" "Ending session 35"
"DEBUG" 10112 "2020-04-26 10:33:28.130" "External delivery process completed"
"DEBUG" 10112 "2020-04-26 10:33:28.131" "Summarizing delivery result"
"DEBUG" 10112 "2020-04-26 10:33:28.132" "Summarized delivery results"
"DEBUG" 10112 "2020-04-26 10:33:28.132" "SD::RescheduleDelivery_"
"DEBUG" 10112 "2020-04-26 10:33:28.133" "Retrieving retry options."
"DEBUG" 10112 "2020-04-26 10:33:28.134" "Starting rescheduling."
"DEBUG" 10112 "2020-04-26 10:33:28.134" "PersistentMessage::SetNextTryTime()"
"DEBUG" 10112 "2020-04-26 10:33:28.137" "PersistentMessage::~SetNextTryTime()"
"DEBUG" 10112 "2020-04-26 10:33:28.139" "Message rescheduled for later delivery."
"DEBUG" 10104 "2020-04-26 10:35:33.328" "Adding task ExternalFetchTask to work queue External fetch queue"
"DEBUG" 10204 "2020-04-26 10:35:33.329" "Executing task ExternalFetchTask in work queue External fetch queue"
"DEBUG" 10204 "2020-04-26 10:35:33.331" "Retrieving messages from external account Mark@SlapHead"
"DEBUG" 10204 "2020-04-26 10:35:33.332" "Creating session 36"
"TCPIP" 10204 "2020-04-26 10:35:33.365" "Connecting to 188.125.73.25:995..."
"DEBUG" 1184 "2020-04-26 10:35:33.368" "TCP connection started for session 36"
"DEBUG" 1184 "2020-04-26 10:35:33.369" "Performing SSL/TLS handshake for session 36. Verify certificate: False, Expected remote host name: pop.mail.yahoo.com"
"TCPIP" 1184 "2020-04-26 10:35:33.466" "TCPConnection - TLS/SSL handshake completed. Session Id: 36, Remote IP: 188.125.73.25, Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"DEBUG" 1312 "2020-04-26 10:35:34.104" "POP3 External Account: Normal QUIT."
"DEBUG" 928 "2020-04-26 10:35:34.133" "Ending session 36"
"DEBUG" 10204 "2020-04-26 10:35:34.134" "Completed retrieval of messages from external account."
Post by mattg » 2020-04-26 12:08
Run this and post the resulst
viewtopic.php?f=20&t=30914
I think that you have SSL selected for your SMTP relayer, and that should be StartTLS (required) for port 587
SlapheadDiver
Post by SlapheadDiver » 2020-04-26 17:17
Log below. Is there any reason why I'm not receiving an email advising of replies to this thread, I was doing until yesterday? Only saw your msg because I logged in and checked.
2020-04-26   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - AAx                            Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - Maxxxxxxxxxxx                  Enabled: True
        Greylisting:     False
IP RANGES
IP: 192.168.1.100 - 192.168.1.200     Priority: 50     Name: My computer
     POP3:   True !! Protocol DISABLED !!      Antivirus:   True !! ANTIVIRUS NOT CONFIGURED !!
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: False
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Port: 587                                           Loop limit:           5
                     Con. Sec.: SSL/TLS
  Routes:
    Yaxxxxxxxxxxxxxx         - S: Local   R: Local  - Addr: All         (ok)
POP3
 !! Service Not Enabled !!
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
             TLS 1.2 :   True                Verify Remote SSL/TLS Certs:  False
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-04-26.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-04-26.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MSSQL Compact
HMAILSERVER.INI
Data folder:     N:\Internet\hMailServer\Data
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by jimimaseye » 2020-04-26 17:37
This concerns me:
You have your hms replying as if it is a yahoo server. Therefore have your set ptr records our other dns records also stating you are yahoo? If so it wouldn't surprise me that the genuine Yahoo servers address dropping your connection when you connect to them as they will do a check and see you are masquerading as them.
Regarding the handshake failed: as mattg suggested you have your route set as:
Con. Sec.: SSL/TLS
change that to "starttls".
SlapheadDiver
Post by SlapheadDiver » 2020-04-27 11:31
Hi
I changed it to StartTls, stopped and restarted the Service. Sent another Email from eMclient and rec'd a 'undeliverable' very quickly rather than hours later after it had gone thru the retries. The change has made a difference but still not sending.
Ran Diags:
2020-04-27   Hmailserver: 5.6.7-B2425
DOMAINS
        Greylisting:     False
        Greylisting:     False
IP RANGES
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Con. Sec.: StartTLS Required
  Routes:
POP3
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-04-27.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-04-27.log
                        APPLICATION -      .
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by jimimaseye » 2020-04-27 12:09
Do another test and post the resultant logs.
SlapheadDiver
Post by SlapheadDiver » 2020-04-27 13:01
Another test and send the logs? I made the change suggest, did a test and the log I posted followed that test so not sure what doing another test will prove. Sorry am I misunderstanding what it is you want me to do and report?
Post by RvdH » 2020-04-27 14:10
Well i guess it is safe to say, HmailServer is not for the likes of you... :mrgreen:
Post by jimimaseye » 2020-04-27 19:26
2020-04-27 13:01
Because you haven't posted the log, you posted the diagnostic. And you have already stated that your change has changed things (but not yet achieved what you wanted). Without logs we cannot help.
Post by mattg » 2020-04-28 01:30
Also, is your N drive a mapped network drive
SlapheadDiver
Post by SlapheadDiver » 2020-04-28 12:50
Hi
Sorry for the misundersatnding re Diag and the log file. I stopped the HS Service on the Server, renamed today's log at pt I, restarted service and on my laptop sent an email which failed albeit as expected. Stopped Service, renamed log pt II and restarted Service. Below is the log [pt II] showing the attempt to send said email. I hope this helps as I/we seem to be so close to it working and I do appreciate your help. Apologies for the delay in getting back to you, a combination of not receiving emails from this thread anymore advising of replies [but just spotted possible cause] and being well stressed assisting clients re Covid 19 support claims and business issues here in the UK.
Drv N - It's a pair of mirrored drives running in the Server where we hold our data, personal and work
"DEBUG" 8832 "2020-04-28 11:38:21.336" "Application::InitInstance - Configuration loaded."
"DEBUG" 8832 "2020-04-28 11:38:21.337" "Creating work queue Asynchronous task queue"
"DEBUG" 8832 "2020-04-28 11:38:21.337" "Starting work queue Asynchronous task queue"
"DEBUG" 10804 "2020-04-28 11:38:21.337" "Running worker in work queue Asynchronous task queue"
"DEBUG" 2548 "2020-04-28 11:38:21.337" "Running worker in work queue Asynchronous task queue"
"DEBUG" 4704 "2020-04-28 11:38:21.337" "Running worker in work queue Asynchronous task queue"
"DEBUG" 4616 "2020-04-28 11:38:21.337" "Running worker in work queue Asynchronous task queue"
"DEBUG" 32 "2020-04-28 11:38:21.337" "Running worker in work queue Asynchronous task queue"
"DEBUG" 2504 "2020-04-28 11:38:21.337" "Running worker in work queue Asynchronous task queue"
"DEBUG" 6436 "2020-04-28 11:38:21.337" "Running worker in work queue Asynchronous task queue"
"DEBUG" 3084 "2020-04-28 11:38:21.338" "Running worker in work queue Asynchronous task queue"
"DEBUG" 4632 "2020-04-28 11:38:21.338" "Running worker in work queue Asynchronous task queue"
"DEBUG" 1112 "2020-04-28 11:38:21.338" "Running worker in work queue Asynchronous task queue"
"DEBUG" 2516 "2020-04-28 11:38:21.338" "Running worker in work queue Asynchronous task queue"
"DEBUG" 6212 "2020-04-28 11:38:21.338" "Running worker in work queue Asynchronous task queue"
"DEBUG" 8832 "2020-04-28 11:38:21.338" "Started work queue Asynchronous task queue"
"DEBUG" 4184 "2020-04-28 11:38:21.338" "Running worker in work queue Asynchronous task queue"
"DEBUG" 2220 "2020-04-28 11:38:21.338" "Running worker in work queue Asynchronous task queue"
"DEBUG" 6280 "2020-04-28 11:38:21.338" "Running worker in work queue Asynchronous task queue"
"DEBUG" 8832 "2020-04-28 11:38:21.711" "Creating work queue Server queue"
"DEBUG" 8832 "2020-04-28 11:38:21.712" "Starting work queue Server queue"
"DEBUG" 8832 "2020-04-28 11:38:21.712" "Started work queue Server queue"
"DEBUG" 6272 "2020-04-28 11:38:21.712" "Running worker in work queue Server queue"
"DEBUG" 7116 "2020-04-28 11:38:21.712" "Running worker in work queue Server queue"
"DEBUG" 6696 "2020-04-28 11:38:21.712" "Running worker in work queue Server queue"
"DEBUG" 3964 "2020-04-28 11:38:21.712" "Running worker in work queue Server queue"
"DEBUG" 8832 "2020-04-28 11:38:21.712" "Adding task Scheduler to work queue Server queue"
"DEBUG" 8832 "2020-04-28 11:38:21.713" "Adding task IOService to work queue Server queue"
"DEBUG" 3964 "2020-04-28 11:38:21.713" "Executing task Scheduler in work queue Server queue"
"DEBUG" 6696 "2020-04-28 11:38:21.714" "Executing task IOService in work queue Server queue"
"DEBUG" 6696 "2020-04-28 11:38:21.714" "IOService::Start()"
"DEBUG" 8832 "2020-04-28 11:38:21.714" "Creating work queue SMTP delivery queue"
"DEBUG" 8832 "2020-04-28 11:38:21.715" "Starting work queue SMTP delivery queue"
"DEBUG" 2872 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 5796 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 6264 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 10788 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 2988 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 8832 "2020-04-28 11:38:21.715" "Started work queue SMTP delivery queue"
"DEBUG" 8832 "2020-04-28 11:38:21.716" "Adding task SMTPDeliveryManager to work queue Server queue"
"DEBUG" 124 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 2408 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 10472 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 5228 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 9452 "2020-04-28 11:38:21.715" "Running worker in work queue SMTP delivery queue"
"DEBUG" 8832 "2020-04-28 11:38:21.717" "Creating work queue External fetch queue"
"DEBUG" 7116 "2020-04-28 11:38:21.717" "Executing task SMTPDeliveryManager in work queue Server queue"
"DEBUG" 6696 "2020-04-28 11:38:21.717" "Creating session 1"
"DEBUG" 8832 "2020-04-28 11:38:21.718" "Starting work queue External fetch queue"
"DEBUG" 7116 "2020-04-28 11:38:21.719" "SMTPDeliveryManager::Start()"
"DEBUG" 6696 "2020-04-28 11:38:21.719" "Creating session 2"
"DEBUG" 6012 "2020-04-28 11:38:21.719" "Running worker in work queue External fetch queue"
"DEBUG" 8744 "2020-04-28 11:38:21.719" "Running worker in work queue External fetch queue"
"DEBUG" 4736 "2020-04-28 11:38:21.719" "Running worker in work queue External fetch queue"
"DEBUG" 1768 "2020-04-28 11:38:21.719" "Running worker in work queue External fetch queue"
"DEBUG" 8832 "2020-04-28 11:38:21.719" "Started work queue External fetch queue"
"DEBUG" 3320 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 4848 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 7092 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 448 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 7012 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 6696 "2020-04-28 11:38:21.720" "Creating session 3"
"DEBUG" 6112 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 4992 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 1496 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 3868 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 2540 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 9360 "2020-04-28 11:38:21.720" "Running worker in work queue External fetch queue"
"DEBUG" 8832 "2020-04-28 11:38:21.721" "Adding task ExternalFetchManager to work queue Server queue"
"DEBUG" 6696 "2020-04-28 11:38:21.722" "Creating work queue IOCPQueue"
"DEBUG" 6272 "2020-04-28 11:38:21.724" "Executing task ExternalFetchManager in work queue Server queue"
"DEBUG" 6696 "2020-04-28 11:38:21.724" "Starting work queue IOCPQueue"
"DEBUG" 6272 "2020-04-28 11:38:21.724" "ExternalFetchManager::Start()"
"DEBUG" 2392 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.725" "Started work queue IOCPQueue"
"DEBUG" 10688 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 8208 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 11012 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 2012 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.725" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 10684 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 10544 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 9644 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 4480 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 10716 "2020-04-28 11:38:21.725" "Running worker in work queue IOCPQueue"
"DEBUG" 3000 "2020-04-28 11:38:21.726" "Running worker in work queue IOCPQueue"
"DEBUG" 10776 "2020-04-28 11:38:21.726" "Running worker in work queue IOCPQueue"
"DEBUG" 2328 "2020-04-28 11:38:21.726" "Running worker in work queue IOCPQueue"
"DEBUG" 6740 "2020-04-28 11:38:21.726" "Running worker in work queue IOCPQueue"
"DEBUG" 5868 "2020-04-28 11:38:21.726" "Running worker in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.727" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 2012 "2020-04-28 11:38:21.727" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.729" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 5868 "2020-04-28 11:38:21.729" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.730" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 6740 "2020-04-28 11:38:21.730" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 2328 "2020-04-28 11:38:21.730" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.731" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 10776 "2020-04-28 11:38:21.731" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 3000 "2020-04-28 11:38:21.731" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.732" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 10716 "2020-04-28 11:38:21.732" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 4480 "2020-04-28 11:38:21.732" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.733" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 10544 "2020-04-28 11:38:21.733" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 9644 "2020-04-28 11:38:21.733" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 10684 "2020-04-28 11:38:21.733" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:38:21.735" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 11012 "2020-04-28 11:38:21.733" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 8208 "2020-04-28 11:38:21.735" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 10688 "2020-04-28 11:38:21.735" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 2392 "2020-04-28 11:38:21.736" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 2392 "2020-04-28 11:38:36.496" "Creating session 4"
"TCPIP" 2392 "2020-04-28 11:38:36.497" "TCP - 192.168.1.127 connected to 192.168.1.121:143."
"DEBUG" 2392 "2020-04-28 11:38:36.503" "TCP connection started for session 2"
"DEBUG" 8208 "2020-04-28 11:38:36.535" "Reading messages from database."
"DEBUG" 2392 "2020-04-28 11:38:36.542" "Reading messages from database."
"DEBUG" 8208 "2020-04-28 11:38:36.546" "Reading messages from database."
"DEBUG" 2392 "2020-04-28 11:39:07.151" "Creating session 5"
"TCPIP" 2392 "2020-04-28 11:39:07.152" "TCP - 192.168.1.127 connected to 192.168.1.121:25."
"DEBUG" 2392 "2020-04-28 11:39:07.157" "TCP connection started for session 1"
"SMTPD" 2392 1 "2020-04-28 11:39:07.160" "192.168.1.127" "SENT: 220 Yahoo ESMTP"
"SMTPD" 10684 1 "2020-04-28 11:39:07.163" "192.168.1.127" "RECEIVED: EHLO [192.168.1.127]"
"SMTPD" 10684 1 "2020-04-28 11:39:07.164" "192.168.1.127" "SENT: 250-Yahoo[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 8208 1 "2020-04-28 11:39:07.166" "192.168.1.127" "RECEIVED: AUTH LOGIN"
"SMTPD" 8208 1 "2020-04-28 11:39:07.167" "192.168.1.127" "SENT: 334 VXNlcm5hbWU6"
"SMTPD" 2392 1 "2020-04-28 11:39:07.169" "192.168.1.127" "RECEIVED: TWFya0BtYXJrLXBlcnNvbmFs"
"SMTPD" 2392 1 "2020-04-28 11:39:07.170" "192.168.1.127" "SENT: 334 UGFzc3dvcmQ6"
"SMTPD" 8208 1 "2020-04-28 11:39:07.172" "192.168.1.127" "RECEIVED: ***"
"SMTPD" 8208 1 "2020-04-28 11:39:07.183" "192.168.1.127" "SENT: 235 authenticated."
"SMTPD" 8208 1 "2020-04-28 11:39:07.186" "192.168.1.127" "RECEIVED: MAIL FROM:<Mark@mark-personal> SIZE=1208"
"SMTPD" 8208 1 "2020-04-28 11:39:07.195" "192.168.1.127" "SENT: 250 OK"
"SMTPD" 2392 1 "2020-04-28 11:39:07.197" "192.168.1.127" "RECEIVED: RCPT TO:<MarkCaPeters@yahoo.co.uk>"
"SMTPD" 2392 1 "2020-04-28 11:39:07.201" "192.168.1.127" "SENT: 250 OK"
"SMTPD" 10684 1 "2020-04-28 11:39:07.203" "192.168.1.127" "RECEIVED: DATA"
"SMTPD" 10684 1 "2020-04-28 11:39:07.204" "192.168.1.127" "SENT: 354 OK, send."
"DEBUG" 2392 "2020-04-28 11:39:08.256" "Could not retrieve PTR record for IP (false)! 192.168.1.127"
"DEBUG" 2392 "2020-04-28 11:39:08.259" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 6280 "2020-04-28 11:39:08.260" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 6280 "2020-04-28 11:39:08.261" "Saving message: {D4FC333F-C4B4-4A87-B134-7ED7F8019023}.eml"
"DEBUG" 6280 "2020-04-28 11:39:08.269" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 6280 1 "2020-04-28 11:39:08.271" "192.168.1.127" "SENT: 250 Queued (1.046 seconds)"
"SMTPD" 2392 1 "2020-04-28 11:39:08.273" "192.168.1.127" "RECEIVED: QUIT"
"SMTPD" 2392 1 "2020-04-28 11:39:08.274" "192.168.1.127" "SENT: 221 goodbye"
"DEBUG" 7116 "2020-04-28 11:39:08.274" "Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG" 8208 "2020-04-28 11:39:08.274" "Ending session 1"
"DEBUG" 9452 "2020-04-28 11:39:08.275" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 9452 "2020-04-28 11:39:08.276" "Delivering message..."
"DEBUG" 9452 "2020-04-28 11:39:08.280" "Applying rules"
"DEBUG" 9452 "2020-04-28 11:39:08.281" "Performing local delivery"
"DEBUG" 9452 "2020-04-28 11:39:08.281" "Local delivery completed"
"DEBUG" 2392 "2020-04-28 11:39:08.287" "Creating session 6"
"TCPIP" 2392 "2020-04-28 11:39:08.288" "TCP - 192.168.1.127 connected to 192.168.1.121:143."
"DEBUG" 2392 "2020-04-28 11:39:08.290" "TCP connection started for session 4"
"DEBUG" 9452 "2020-04-28 11:39:08.316" "Starting external delivery process. Server: smtp.mail.yahoo.com (188.125.73.26), Port: 587, Security: 3, User name: SlapHeadDiver@Yahoo.co.uk"
"DEBUG" 9452 "2020-04-28 11:39:08.317" "Creating session 7"
"TCPIP" 9452 "2020-04-28 11:39:08.317" "Connecting to 188.125.73.26:587..."
"DEBUG" 10684 "2020-04-28 11:39:08.319" "TCP connection started for session 7"
"DEBUG" 10684 "2020-04-28 11:39:08.352" "Saving message: {6C49F598-A8FE-4859-8030-95DC9783AF72}.eml"
"DEBUG" 2392 "2020-04-28 11:39:08.361" "Reading messages from database."
"SMTPC" 2392 7 "2020-04-28 11:39:08.377" "188.125.73.26" "RECEIVED: 220 smtp.mail.yahoo.com ESMTP ready"
"SMTPC" 2392 7 "2020-04-28 11:39:08.378" "188.125.73.26" "SENT: EHLO Yahoo"
"SMTPC" 10684 7 "2020-04-28 11:39:08.407" "188.125.73.26" "RECEIVED: 250-smtp401.mail.ir2.yahoo.com Hello Yahoo [212.105.160.182])[nl]250-PIPELINING[nl]250-ENHANCEDSTATUSCODES[nl]250-8BITMIME[nl]250-SIZE 41697280[nl]250 STARTTLS"
"SMTPC" 10684 7 "2020-04-28 11:39:08.407" "188.125.73.26" "SENT: STARTTLS"
"SMTPC" 2392 7 "2020-04-28 11:39:08.435" "188.125.73.26" "RECEIVED: 220 2.0.0 Ready to start TLS"
"DEBUG" 2392 "2020-04-28 11:39:08.437" "Performing SSL/TLS handshake for session 7. Verify certificate: False, Expected remote host name: smtp.mail.yahoo.com"
"TCPIP" 2392 "2020-04-28 11:39:08.542" "TCPConnection - TLS/SSL handshake completed. Session Id: 7, Remote IP: 188.125.73.26, Version: TLSv1.2, Cipher: ECDHE-RSA-AES128-GCM-SHA256, Bits: 128"
"SMTPC" 2392 7 "2020-04-28 11:39:08.543" "188.125.73.26" "SENT: EHLO Yahoo"
"SMTPC" 10684 7 "2020-04-28 11:39:08.573" "188.125.73.26" "RECEIVED: 250-smtp401.mail.ir2.yahoo.com Hello Yahoo [212.105.160.182])[nl]250-PIPELINING[nl]250-ENHANCEDSTATUSCODES[nl]250-8BITMIME[nl]250-SIZE 41697280[nl]250 AUTH PLAIN LOGIN XOAUTH2 OAUTHBEARER"
"SMTPC" 10684 7 "2020-04-28 11:39:08.574" "188.125.73.26" "SENT: AUTH LOGIN"
"SMTPC" 2392 7 "2020-04-28 11:39:08.604" "188.125.73.26" "RECEIVED: 334 VXNlcm5hbWU6"
"SMTPC" 2392 7 "2020-04-28 11:39:08.605" "188.125.73.26" "SENT: U2xhcEhlYWREaXZlckBZYWhvby5jby51aw=="
"SMTPC" 11012 7 "2020-04-28 11:39:08.634" "188.125.73.26" "RECEIVED: 334 UGFzc3dvcmQ6"
"SMTPC" 11012 7 "2020-04-28 11:39:08.636" "188.125.73.26" "SENT: ***"
"SMTPC" 10684 7 "2020-04-28 11:39:08.825" "188.125.73.26" "RECEIVED: 235 2.7.0 Authentication successful"
"SMTPC" 10684 7 "2020-04-28 11:39:08.826" "188.125.73.26" "SENT: ***"
"SMTPC" 2392 7 "2020-04-28 11:39:08.904" "188.125.73.26" "RECEIVED: 550 Request failed; Mailbox unavailable"
"SMTPC" 2392 7 "2020-04-28 11:39:08.905" "188.125.73.26" "SENT: QUIT"
"SMTPC" 10684 7 "2020-04-28 11:39:08.935" "188.125.73.26" "RECEIVED: 221 Service Closing transmission"
"DEBUG" 10684 "2020-04-28 11:39:08.936" "Ending session 7"
"DEBUG" 9452 "2020-04-28 11:39:08.937" "External delivery process completed"
"DEBUG" 9452 "2020-04-28 11:39:08.938" "Summarizing delivery result"
"DEBUG" 9452 "2020-04-28 11:39:08.941" "Summarized delivery results"
"DEBUG" 9452 "2020-04-28 11:39:08.942" "SD::SubmitErrorLog_"
"DEBUG" 9452 "2020-04-28 11:39:08.954" "Saving message: {286ED2BD-3BB3-4775-AEF0-8F40F4F0297F}.eml"
"DEBUG" 9452 "2020-04-28 11:39:08.963" "SD::~SubmitErrorLog_"
"DEBUG" 9452 "2020-04-28 11:39:08.964" "Deleting message"
"DEBUG" 9452 "2020-04-28 11:39:08.969" "Deleting message file."
"DEBUG" 7116 "2020-04-28 11:40:10.645" "Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG" 9452 "2020-04-28 11:40:10.646" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 9452 "2020-04-28 11:40:10.647" "Delivering message..."
"DEBUG" 9452 "2020-04-28 11:40:10.648" "Applying rules"
"DEBUG" 9452 "2020-04-28 11:40:10.649" "Performing local delivery"
"DEBUG" 9452 "2020-04-28 11:40:10.665" "Applying rules"
"DEBUG" 9452 "2020-04-28 11:40:10.684" "Saving message: {286ED2BD-3BB3-4775-AEF0-8F40F4F0297F}.eml"
"DEBUG" 9452 "2020-04-28 11:40:10.695" "Reading messages from database."
"DEBUG" 9452 "2020-04-28 11:40:10.700" "Local delivery completed"
"DEBUG" 5236 "2020-04-28 11:40:31.951" "Received stop-request from Windows."
"DEBUG" 5236 "2020-04-28 11:40:31.952" "Application::StopServers() - Removing server work queue"
"DEBUG" 5236 "2020-04-28 11:40:31.954" "WorkQueueManager::RemoveQueue - Server queue"
"DEBUG" 5236 "2020-04-28 11:40:31.955" "Stopping working queue Server queue."
"DEBUG" 5236 "2020-04-28 11:40:31.956" "Interupt and join threads in working queue Server queue"
"DEBUG" 7116 "2020-04-28 11:40:31.957" "Worker exited in work queue Server queue"
"DEBUG" 6272 "2020-04-28 11:40:31.957" "Worker exited in work queue Server queue"
"DEBUG" 3964 "2020-04-28 11:40:31.957" "Worker exited in work queue Server queue"
"DEBUG" 6696 "2020-04-28 11:40:31.957" "IOService::Stop()"
"DEBUG" 8208 "2020-04-28 11:40:31.966" "TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG" 8208 "2020-04-28 11:40:31.967" "Ending session 5"
"DEBUG" 10684 "2020-04-28 11:40:31.968" "TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG" 2392 "2020-04-28 11:40:31.968" "TCP - AcceptEx failed. Error code: 995, Message: The I/O operation has been aborted because of either a thread exit or an application request"
"DEBUG" 5236 "2020-04-28 11:40:31.962" "Still 1 remaining threads in queue Server queue. First task: IOService"
"DEBUG" 6696 "2020-04-28 11:40:31.968" "IOService::DoWork() - removing Queue IOCP Queue"
"DEBUG" 10684 "2020-04-28 11:40:31.970" "Ending session 6"
"DEBUG" 2392 "2020-04-28 11:40:31.970" "Ending session 3"
"DEBUG" 6696 "2020-04-28 11:40:31.971" "WorkQueueManager::RemoveQueue - IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:40:31.972" "Stopping working queue IOCPQueue."
"DEBUG" 6696 "2020-04-28 11:40:31.973" "Interupt and join threads in working queue IOCPQueue"
"DEBUG" 10684 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 2392 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 2012 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 5868 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 6740 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 2328 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 10776 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 3000 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 4480 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 10716 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 10544 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 9644 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 8208 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 10688 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 11012 "2020-04-28 11:40:31.973" "Worker exited in work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:40:31.981" "Still 1 remaining threads in queue IOCPQueue. First task: <Unknown>"
"DEBUG" 5236 "2020-04-28 11:40:32.225" "Still 1 remaining threads in queue Server queue. First task: IOService"
"DEBUG" 6696 "2020-04-28 11:40:32.233" "All threads are joined in queue IOCPQueue."
"DEBUG" 6696 "2020-04-28 11:40:32.233" "WorkQueueManager::RemoveQueue - Stopped IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:40:32.234" "WorkQueueManager::RemoveQueue - Erased IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:40:32.234" "IOService::Stop() - Complete"
"DEBUG" 6696 "2020-04-28 11:40:32.235" "Destructing work queue IOCPQueue"
"DEBUG" 6696 "2020-04-28 11:40:32.476" "Worker exited in work queue Server queue"
"DEBUG" 5236 "2020-04-28 11:40:32.477" "All threads are joined in queue Server queue."
"DEBUG" 5236 "2020-04-28 11:40:32.478" "WorkQueueManager::RemoveQueue - Stopped Server queue"
"DEBUG" 5236 "2020-04-28 11:40:32.479" "WorkQueueManager::RemoveQueue - Erased Server queue"
"DEBUG" 5236 "2020-04-28 11:40:32.480" "Destructing work queue Server queue"
"DEBUG" 5236 "2020-04-28 11:40:32.481" "Application::StopServers() - Clearing caches"
"DEBUG" 5236 "2020-04-28 11:40:32.482" "Application::StopServers() - Destructing IOCP"
"DEBUG" 5236 "2020-04-28 11:40:32.484" "IOService::~IOService - Destructing"
"DEBUG" 5236 "2020-04-28 11:40:32.485" "TCPServer::~TCPServer"
"DEBUG" 5236 "2020-04-28 11:40:32.486" "TCPServer::~TCPServer"
"DEBUG" 5236 "2020-04-28 11:40:32.487" "TCPServer::~TCPServer"
"DEBUG" 5236 "2020-04-28 11:40:32.489" "Ending session 4"
"DEBUG" 5236 "2020-04-28 11:40:32.490" "Ending session 2"
"DEBUG" 5236 "2020-04-28 11:40:32.492" "Application::StopServers() - Destructing DeliveryManager"
"DEBUG" 5236 "2020-04-28 11:40:32.493" "WorkQueueManager::RemoveQueue - SMTP delivery queue"
"DEBUG" 5236 "2020-04-28 11:40:32.494" "Stopping working queue SMTP delivery queue."
"DEBUG" 5236 "2020-04-28 11:40:32.496" "Interupt and join threads in working queue SMTP delivery queue"
"DEBUG" 9452 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 5228 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 10472 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 2408 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 124 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 2988 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 10788 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 6264 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 5796 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 2872 "2020-04-28 11:40:32.496" "Worker exited in work queue SMTP delivery queue"
"DEBUG" 5236 "2020-04-28 11:40:32.506" "Still 3 remaining threads in queue SMTP delivery queue. First task: <Unknown>"
"DEBUG" 5236 "2020-04-28 11:40:32.761" "All threads are joined in queue SMTP delivery queue."
"DEBUG" 5236 "2020-04-28 11:40:32.762" "WorkQueueManager::RemoveQueue - Stopped SMTP delivery queue"
"DEBUG" 5236 "2020-04-28 11:40:32.763" "WorkQueueManager::RemoveQueue - Erased SMTP delivery queue"
"DEBUG" 5236 "2020-04-28 11:40:32.764" "Destructing work queue SMTP delivery queue"
"DEBUG" 5236 "2020-04-28 11:40:32.766" "Application::StopServers() - Destructing FetchManager"
"DEBUG" 5236 "2020-04-28 11:40:32.768" "ExternalFetchManager::~ExternalFetchManager"
"DEBUG" 5236 "2020-04-28 11:40:32.768" "WorkQueueManager::RemoveQueue - External fetch queue"
"DEBUG" 5236 "2020-04-28 11:40:32.770" "Stopping working queue External fetch queue."
"DEBUG" 5236 "2020-04-28 11:40:32.771" "Interupt and join threads in working queue External fetch queue"
"DEBUG" 9360 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 3868 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 2540 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 1496 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 4992 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 6112 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 7012 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 448 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 7092 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 4848 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 3320 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 1768 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 4736 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 8744 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 6012 "2020-04-28 11:40:32.771" "Worker exited in work queue External fetch queue"
"DEBUG" 5236 "2020-04-28 11:40:32.785" "Still 4 remaining threads in queue External fetch queue. First task: <Unknown>"
"DEBUG" 5236 "2020-04-28 11:40:33.041" "All threads are joined in queue External fetch queue."
"DEBUG" 5236 "2020-04-28 11:40:33.042" "WorkQueueManager::RemoveQueue - Stopped External fetch queue"
"DEBUG" 5236 "2020-04-28 11:40:33.043" "WorkQueueManager::RemoveQueue - Erased External fetch queue"
"DEBUG" 5236 "2020-04-28 11:40:33.044" "Destructing work queue External fetch queue"
"DEBUG" 5236 "2020-04-28 11:40:33.044" "ExternalFetchManager::~ExternalFetchManager - Removed queue"
"DEBUG" 5236 "2020-04-28 11:40:33.045" "Application::StopServers() - Destructing Scheduler"
"DEBUG" 5236 "2020-04-28 11:40:33.045" "Application::StopServers() - Destructing Rest"
"DEBUG" 5236 "2020-04-28 11:40:33.046" "WorkQueueManager::RemoveQueue - Maintenance queue"
"DEBUG" 5236 "2020-04-28 11:40:33.046" "Stopping working queue Maintenance queue."
"DEBUG" 5236 "2020-04-28 11:40:33.047" "Interupt and join threads in working queue Maintenance queue"
"DEBUG" 10116 "2020-04-28 11:40:33.047" "Worker exited in work queue Maintenance queue"
"DEBUG" 5076 "2020-04-28 11:40:33.050" "Worker exited in work queue Maintenance queue"
"DEBUG" 6256 "2020-04-28 11:40:33.050" "Worker exited in work queue Maintenance queue"
"DEBUG" 6644 "2020-04-28 11:40:33.050" "Worker exited in work queue Maintenance queue"
"DEBUG" 8848 "2020-04-28 11:40:33.050" "Worker exited in work queue Maintenance queue"
"DEBUG" 5236 "2020-04-28 11:40:33.053" "Still 1 remaining threads in queue Maintenance queue. First task: <Unknown>"
"DEBUG" 5236 "2020-04-28 11:40:33.304" "All threads are joined in queue Maintenance queue."
"DEBUG" 5236 "2020-04-28 11:40:33.305" "WorkQueueManager::RemoveQueue - Stopped Maintenance queue"
"DEBUG" 5236 "2020-04-28 11:40:33.306" "WorkQueueManager::RemoveQueue - Erased Maintenance queue"
"DEBUG" 5236 "2020-04-28 11:40:33.307" "Destructing work queue Maintenance queue"
"DEBUG" 5236 "2020-04-28 11:40:33.308" "WorkQueueManager::RemoveQueue - Asynchronous task queue"
"DEBUG" 5236 "2020-04-28 11:40:33.309" "Stopping working queue Asynchronous task queue."
"DEBUG" 5236 "2020-04-28 11:40:33.310" "Interupt and join threads in working queue Asynchronous task queue"
"DEBUG" 6280 "2020-04-28 11:40:33.310" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 2220 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 4184 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 6212 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 2516 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 1112 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 4632 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 3084 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 6436 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 2504 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 32 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 4616 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 4704 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 2548 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 10804 "2020-04-28 11:40:33.311" "Worker exited in work queue Asynchronous task queue"
"DEBUG" 5236 "2020-04-28 11:40:33.328" "Still 6 remaining threads in queue Asynchronous task queue. First task: <Unknown>"
"DEBUG" 5236 "2020-04-28 11:40:33.581" "All threads are joined in queue Asynchronous task queue."
"DEBUG" 5236 "2020-04-28 11:40:33.582" "WorkQueueManager::RemoveQueue - Stopped Asynchronous task queue"
"DEBUG" 5236 "2020-04-28 11:40:33.582" "WorkQueueManager::RemoveQueue - Erased Asynchronous task queue"
"DEBUG" 5236 "2020-04-28 11:40:33.583" "Destructing work queue Asynchronous task queue"
"DEBUG" 5236 "2020-04-28 11:40:33.584" "Application::ExitInstance - Closing database connection..."
"DEBUG" 5236 "2020-04-28 11:40:33.586" "Application::ExitInstance - Deleting caches..."
Post by jimimaseye » 2020-04-28 12:56
The problem is now with your yahoo account:
Yahoo rejected the delivery. Is the address that you authenticated with correct ("SlapHeadDiver...") ? Is mail enabled for it? (Why dont you try authenticating with MarkCaPeters@yahoo..." assuming that is yours)?
tunis
Post by tunis » 2020-04-28 13:18
Your server name is Yahoo.
Post by jimimaseye » 2020-04-28 13:23
tunis wrote:
2020-04-28 13:18
Ive pointed that out to him already:
2020-04-26 17:37
This concerns me:
Although not ideal it doesnt seem to be that cause of the problem at this stage.
SlapheadDiver
Post by SlapheadDiver » 2020-04-28 13:40
Just to be sure I've checked both the sender's and receiver's addresses, both correct. I've also just logged into the senders email a/c on Yahoo and it's fine too so p/word is ok too
In our current networked email system, MailCopa [MC], the SMTP for this address is set for SSL connection. I had HS set for SSL/TLS originally but has been for the last 24hrs or so 'STARTTLS required'.
Yes Mark....@Yahoo.co.uk is mine too. I cld also try our business address hosted at 1&1
All the email addresses we have are enabled and picked up using POP3 by MC and some also come to our mobiles.
Post by jimimaseye » 2020-04-28 13:51
To be clear......
1, the issue is now ONLY with the address you use to authenticate to yahoo relay with and
2, it is Yahoo that is rejecting it.
It is now nothing to do with your FROM or TO addresses and is nothing to do with Certificates. This is now nothing to do with you Hmailserver configuration beyond using the correct credentials that Yahoo will accept.
As you can see from the log (I previously quoted), HMS AUTHENTICATES, received the 'Authenticated' acknowledgement from Yahoo and then Yahoo issues the 550 rejection. It doesnt even get to the message Data details (is FROM, TO). Change your authentication credentials to use MarkCaPeters (perhaps yahoo simply doesnt like your 'SlapheadDiver' account as allowed for sending emails perhaps). Following on from that you will need to seek help from Yahoo on why they issue "550 Request failed; Mailbox unavailable". This might give you a clue: https://www.google.com/search?q=yahoo+5 ... navailable or https://www.contactyahoohelpdesk.com/ya ... -code-550/ (avoid their rogue support number, though. Ask Yahoo directly is you really need to).
I would still address the issue tat you are calling your server 'Yahoo').
EDIT:
This https://help.yahoo.com/kb/xx-smtp-error ... 26154.html
says:
5xx SMTP error codes
5xx SMTP errors indicate an email could not be delivered due to a permanent problem. You should not retry sending email flagged with a 5xx error. Message delivery can be permanently deferred because:
You're trying to send a message to an invalid email address.
Spamhaus has your IP address listed on a Block List.
Your SMTP connection was rejected.
Your message failed authentication checks against your sending domain's DomainKeys or DKIM policy.
The message contains characteristics that Yahoo Mail won't accept for policy reasons.
You might be rejected due to DKIM or incorrect DNS records (or spoofing as Yahoo server).
SlapheadDiver
Post by SlapheadDiver » 2020-04-28 14:59
A few thinks to look at and try out
Using MailCopa I've sent an email from Slap... address to Mark.... address, exactly same subjust and content and it both sent and rec'd back as it shd be so it would seem to be settings in HS that are not quite right.
I'll report back to advise either it's working or not
Post by jimimaseye » 2020-04-28 15:05
Again, I repeat, this is nothing to do with Hmailserver or even your email client.
Sending to an account on hmailserver may well work. The issue above is about sending out to an external Yahoo address using the route you have set up.
Im not even sure why you have the route set up. Can you explain why?
SlapheadDiver
Post by SlapheadDiver » 2020-04-29 11:05
Hi
Well I tried changing the reciepient address then changing the SMTP to an alternative address but not a Yahoo one. Still no joy but I'll continue to read and reread what is being suggested, maybe a penny will drop and I sort it.
You say it's not a Hmailserver issue but Yahoo. Ok but to me the logic is I have one or more settings/parameters set incorrectly in Hmailserver. The reason for this logic if for no other reason than or current system that I'm trying to replace is MailCopa, running on the same server and is retrieving and sending our emails to the same addresses which to me means it's not a Yahoo issue but settings in HS but I just can't see what and/or where.
I'll keep hunting for the solution inbetween client work
Post by mattg » 2020-04-29 14:59
SMTP relayer
Check your account details and the password
SMTP route >> Why do you have that
SlapheadDiver
Post by SlapheadDiver » 2020-04-29 20:15
Hi Matt
More than likely misunderstanding you but if there is no SMTP set how does HS know where to send it thru i.e. Yahoo smtp, our business email address at 1&1 etc, although at the moment I've only setup one of my Yahoo addresses until I know if HS will work for us
Post by jimimaseye » 2020-04-29 20:25
2020-04-29 20:15
Hi Matt
HMS is a mail server. Like all mail servers, its job is to deliver emails to the worlds recipients directly using SMTP protocol (it uses public DNS MX records to locate them and goes there directly). Routes are only used (mainly) if your personal circumstances prevent it from using the default method of direct deliveries because, for example, your personal internet setup prevents SMTP services running or maybe you want everything to go through another company mail server; they are effectively telling your mail server to use someone elses mail server. So unless you know WHY you want a route (and care to explain it to us), I suspect you dont need it. Ergo, delete it.
I know this thread is long, so lets regroup and ask: what is the situation and need of this server? Do you have a domain? I ask because trying to send a mail from "Mark@mark-personal" to a yahoo, gmail or any other email recipient address is likely to get rejected as the domain ("mark-personal" does not exist and the worlds email servers will know this; if you want to be sending emails to the outside world then you will need to be using a genuine domain address. If, however, you are needing to send 'internal' emails only (ie, users from and to '@mark-personal') then you will not be talking to external email servers and you will not be needing a route or DNS records anyway.
We await your answers.
(You do know I PM'd you, right?)
SlapheadDiver
Post by SlapheadDiver » 2020-04-30 09:45
Hi
Just replied to you PM
Yes it has turned into a very long thread so maybe a recap of what I have and what I'm trying to achieve would be useful
I'm looking to change our current email system for our small office which is:
File server [FS] running Win 10 Pro 64bit [not Server version]
3 PC's / laptops running Win 10 Pro 32/64bit
Software: MailCopa [MC]
Server copy runs on FS which pull downs [POP3] emails from a number of places including business addresses hosted at 1&1, personal ones including yahoo. We don't have a website. Retrieved emails are filed into the appropriate users inbox. The use of filters [rules] allows users to have multiple 'inboxes' to help manage business from personal etc
Client copy runs on the PC's/Laptops reading the emails retrieved by the Server, sending replies and archiving. Users can move emails into other Folders such as Archiving or to another User as Users can see each others folders subject to access rights.
As we stand today HS [running on th Server] is retrieving emails on the one address currently setup and eMclient on my laptop can read them but any email I'm sending from eMclient is not delivering.
SlapheadDiver
Post by SlapheadDiver » 2020-04-30 19:06
Hooray, I believe I have a working system :mrgreen:
Firstly many thanks to all who have contributed to this thread and in particular to jimimaseye who with his assistance via a remote link was able to complete the setup for basically the 2 scenarios I have:
1. Our business email address hosted at 1&1
2. Yahoo email addresses and one other
I will write up a brief outline of the solution just in case it proves useful to another person in the future and post it to this thread
Thanks to all
SlapheadDiver
Post by SlapheadDiver » 2020-05-09 19:59
Hi
I've rec'd an email to say there was a reply on 8th from mjackets and there was a notification when I logged in but I can't find the reply?
Maybe they could post it again?
Mark
Post by jimimaseye » 2020-05-09 20:18
It was spam and has been deleted.
SlapheadDiver
Post by SlapheadDiver » 2020-05-10 11:02
Chuff me, on a user forum? Whatever next? There are some sad individuals about.
Post by RvdH » 2020-05-10 11:13
2020-05-10 11:02
You really are incredible, and not in positive way...
you ask tons of questions, people here which are mostly users like yourself have no obligation to you whatsoever they just try to answer as good as possible with the limited info you provide
Was the message deleted in hmailserver? Try adjusting the 'Spam delete threshold' withing the Anti-spam settings (set it very high if you want all spam, or even beter disable spam checking all together if is'spam you like)
Post by SorenR » 2020-05-10 11:23
2020-05-10 11:13
2020-05-10 11:02
Wooosa Ruud... It was a SPAM post in forum that triggered a notification and Jimmy deleted the post...
Corona getting to you ?
Post by RvdH » 2020-05-10 11:27
:oops:
Lol, ah.... i was under the impression he was talking about a missing mail :mrgreen:
But it still gives him no reason to react like he did, spam (forum)post get deleted, deal with it
SlapheadDiver
Post by SlapheadDiver » 2020-05-10 11:52
Blimey RvdH, all I asked was for the originator to resend his message as I couldn't find it on the forum. Sorry but it hadn't occurred to me that it was Spam as jimimaseye advised. All I wrote was I was surprised that people bothered spamming through a user forum, nothing at all aimed at anyone on this forum. Indeed jimimaseye spent over 2 hours helping me thru an online connection recently.
Sorry but I just don't get what your problem is with me, clearly some misunderstanding. For me it's the 6+ weeks of stressing advising clients on the UK Covid legislation and trying to help them with the survival of their businesses. Many might be furloughed and enjoying the sun but for me others like me it's 7 days a week.
I apologise if you have taken my threads as abusive when they are anything but appreciative
Post by RvdH » 2020-05-10 12:01
2020-05-10 11:52
Probably something get mixed-up up in translation then, to me it looked like 'Chuff me, on a user forum? ' was aimed towards jimimaseye
My bad, it seems i own you a apology :wink:
SlapheadDiver
Post by SlapheadDiver » 2020-05-10 12:28
Not a problem, thank you. I just didn't want to be viewed as being ungrateful
Post by SorenR » 2020-05-10 13:11
2020-05-10 12:28
Well, "chuff" has two meanings. One is "anus/butt" - "get off your chuff and go to work" ... The other is... "Chuff me" ~ "F*ck me" (since the 1940's) - I presume the Australian version of the latter would be "Blimey" :mrgreen:
The old Norse version would be something close to "fjandinn mér óheiðarlega". The Danish version is "For helvede" involving Loke and Angerboda's daughter Hel... Yeah impressive family, Hel's siblings are Fenrir and Jörmungandr.
SlapheadDiver
Re: Is HmailServer for the likes of me?
Post by SlapheadDiver » 2020-05-10 13:32
Hi Soren
I'll have to brush up on my Norse :mrgreen: Thanks for the cultural lesson, dare I add without cauing offence it made me laugh, thank you :lol:
Best wishes
Mark
Post by mattg » 2020-05-10 15:55
2020-05-10 13:11
'Blimey' is not a word in my vocabulary, unless it was short for 'bloody limey' in which case it is an insult against an individual Englishman.
Chuff means 'impress', Chuff me = I'm impressed
I'm Chuffed = I'm happy with that, that's a super outcome
As in
'My dad gave me a new ute for my birthday, I'm chuffed'
Post by RvdH » 2020-05-10 16:05
2020-05-10 15:55
2020-05-10 13:11
Had to lookup Blimey as well :)
in Dutch is would be something like, verdorie :lol:
Post by SorenR » 2020-05-10 17:10
Post by palinka » 2020-05-10 18:16
2020-05-10 15:55
As in
What is a ute?
https://m.youtube.com/watch?v=U7BMCZdXSlk
SlapheadDiver
Post by SlapheadDiver » 2020-05-10 18:25
Hi
All I can say it wasn't intended to be rude, just a turn of phrase used at least in some parts of the UK as is blimey.
I could have written "Flipping heck, on a user forum.......... etc etc" or "I'm surprised to see spam being directed through a user forum"
Interesting and pleasing to see from what was a misunderstanding and taken as a complaint has turned into some friendly chatter and delving into phrases and there uses.
Not just a technical site but one of culture too :mrgreen:
On another lighter note pleased to report that the refurbishment of the rear brake callipers on our MGB Roadster is now complete and ready for refitting, been a busy afternoon.
Many thanks
Mark
SlapheadDiver
Post by SlapheadDiver » 2020-05-10 18:35
Ute - I'm presuming it's a reference to a truck/pick up?
Post by jimimaseye » 2020-05-10 18:42
SlapheadDiver wrote:
2020-05-10 18:25
Blimey. I'm chuffing well chuffed for you. 👌 Not talking bollocks gets things done. No arsing around. :mrgreen:
Welcome to England's English. 🏴󠁧󠁢󠁥󠁮󠁧󠁿
(Ute is short for utility truck and is a style of car. The Aussies cream over them. Like the love child of a family car and a Toyota pickup truck. Eg Think front half of a Ford Mondeo with a flat bed arse end.)
[Entered by mobile. Excuse spelling.]
SlapheadDiver
Post by SlapheadDiver » 2020-05-10 18:57
Thanks jimimaseye, that's another good laugh/chuckle at this end
Post by SorenR » 2020-05-10 20:01
Well...
If a quiz is quizzical, what's a test?
:mrgreen:
Post by jimimaseye » 2020-05-10 20:22
2020-05-10 20:01
Well...
:mrgreen:
Ooh, that's testing....
Post by mattg » 2020-05-11 05:28
Ute = Utility Vehicle
Used by cockies (farmers) and tradies (Tradesmen / Contractors)
Loved by boguns / hoons (young blokes who love burning tyres and money)
Great for dropping burnouts (leaving tyre marks on the road and rubber smoke in the air)
https://www.motoring.com.au/hsv-maloo-r ... ew-107315/
One of the big Aussie bush events is the 'Deni Ute Muster', an annual event held in Deniliquin (South Western NSW)
https://www.deniutemuster.com.au/
Post by palinka » 2020-05-11 21:05
2020-05-11 05:28
Has the same meaning in the US. Donuts are circular burnouts. :mrgreen:
You have coal rollin' ute burnouts over there?
https://www.youtube.com/watch?v=7Jpu7bzzkKc
I love the sound of the turbo.
I used to have a friend that did amateur drag racing. He had the fastest car in the amateur class. He won every race. They moved him into the pro class because he was winning too much and then he lost every race. :lol: But that car was so badass he could drive down the highway at normal highway speed, stomp the gas and the front wheels would leave the ground. No turbo - he had NOx injection. He went through so much of it he became a nitrous dealer to offset the cost. His idiot junkie wife would fill balloons with it and inhale it.
It was an old camero that looked a lot like this:
For going in straight lines really REALLY fast. Not so much for cornering.
Post by SorenR » 2020-05-11 23:37
This is what I play with
This is what it initially was built for ... 40 years ago.
https://www.youtube.com/watch?v=3On6UQt44aY
And ... In the words of D.C.I. Gene Hunt ...
https://www.youtube.com/watch?v=gmifaKiPa6M
Post by mattg » 2020-05-12 01:57
2020-05-11 21:05
No mate, that seems to be a 'Only in America' thing
We've actually stopped building all cars here a few years back. We import them all now, mostly from Asia (Japan, Korea, Thailand and China) and the emphasis there is certainly electric, or low emissions.
We do have a few RAM trucks here, and some F trucks, but rarely bigger than the F100.
Most 'utes' these days are from the Japanese builders, and in fact the Toyota Hilux dual cab is Australia's biggest selling car the last few years.
We do things like bull bars, driving lights, big aerials.
Post by palinka » 2020-05-12 03:46
2020-05-12 01:57
Funny you mention that. My soccer mom neighbor recently traded her soccer mom SUV in for a dual cab ram pickup. I was talking to the husband about it and he said she took one test drive and loved it. The ride quality is more like a car these days. A truck ain't what it used to be. She doesn't have the bull bars and 30 megawatt LED bars (I despise those things - especially on the beach when I'm trying to fish in the DARK). Of course, it doesn't accelerate like his dual motor Tesla. Then again, his Tesla would probably smoke my friend's 1250 hp nitrous injected dragster. Ha! Maybe not, but he'd come close in 1/8th mile.
I would love to have a pickup about 6 days a year. Beyond that I prefer my gas sipping, wind cutting Ford focus. My wife has the twin turbo soccer mom SUV. That's fun to drive once in a while too. Still prefer my focus. It fits me like a glove and I like being low to the ground, feeling the road.
SlapheadDiver
Post by SlapheadDiver » 2020-05-12 09:40
For most of my life a car is 4 wheels and an engine that gets me from A to B, my wife is of the same mind. Don't get me wrong I've always appreciated nice cars but never spent my money on an expensive one and then watch it depreciate.
Then in 2005 we bought a MGB GT for a bit of fun, kept it 8yrs, it was the only car of 3 that was probably looked after. We then decide to change it for a MGB Roadster and eventually found we liked, just happened to have been rebuilt with Hoyle independant suspension front and rear and few other bits and pieces, oh and the 1800 engine was upgraded to a 3.5 V8, it sounds great. We use it all year round, in 2016 did a 2 week road trip ferry to Holland then thru Germany, Italy and Switzerland doing many of the pass in the Alps with friends in their modern sports cars.
For the last 5 years we started doing some club autotests and MG on Track days, typically 4-5 each year, usually with my son and I. We generally do all the maintenance on it.
We were having some engine issues and following Brands Hatch GP circuit track day last August we took the heads off couldn't see what was really causing the issues and decided to take it to a specialist recommended to me by several members. A full rebuild and more than few pounds later it came back, now a 3.9 V8 and bhp up from 150 to 220!
At Bedford track day in early March you could really see and feel the difference in performance. Of course with Covid 19 track days are currently just a memory and we are refurbing the rear brakes and looking to upgrade the front along with one or two other tasks hoping to be able to get out in it soon.
jim.bus
Post by jim.bus » 2020-05-12 13:05
While I have a Lexus LS 460L, I'm not married to it as there are drawbacks to some of the quality of materials and the Lexus Engineers don't even know how to fix some of the items on the car such as when the clock stopped accepting updates to the time either automatically or manually. The Technical Service Bulletin which described the problem said to replace the clock assembly and that stopped me from insisting on the trying my solution which turned out to be the correct solution (I later found where my correct solution had been done in their Forums too). My correct solution was to reboot the firmware by disconnecting the battery and reconnecting the battery. We eventually did that and my solution fixed the problem. I'm now convinced I should probably reboot everything every year or so.
In any event, my concept of powerful engine for a car is one where you can't hear the engine. I call it quiet power. I've had people standing next to my car idling (it's an 8-cylinder) and they were surprised when I indicated my engine was running. I myself one time forgot for a moment to turn off the engine when I got out of the car because you can't tell the engine was running by the lack of sound. And I do not like Turbo Charged engines. They are noisier no matter how much they tout that it still is very quiet. As I keep saying I want RAW POWER not Turbo Charged Power which means less to go wrong, too. I, also, like a car with some metal in it. I don't like the 'tin cans' most cars are like. One thing I immediately noticed about the LS 460L the moment I took possession of it was that I felt like I had a really solid car with metal around me. Everything about the car felt weighty which is one reason why it had to have the horse power and Torque that it has. You only really hear the engine loudly when you give it a lot of gas.
Of course, the Mercedes and Audi's etc. have greater Horse Power and Torque but I'm kind of spoiled on the Luxury brands. Despite the some of the quality flaws the LS 460L had, I still like the so-called Luxury Brands as I still seem to feel there is greater quality there.
SlapheadDiver
Post by SlapheadDiver » 2020-05-12 18:36
The beauty of the MGB [1975] is it's simple technology, no fancy electronics to go wrong or turbos which means my son & I don't need diagnostic computers and the likes.
I can't say it's as quiet as your Lexus, a change of exhaust would make it so but the V8 burble sounds great and never fails to be noticed by young and old a like.
Interesting how this thread has gravitated to motor vehicles :mrgreen: If I have any further questions on Hmailserver I'll begin another thread, wouldn't want to spoil this one :wink:
jim.bus
Post by jim.bus » 2020-05-12 21:53
2020-05-12 18:36
Can't say for sure but 1975 probably is before the heavy usage of computers to control even carburetor. My LS 460L has 65 computers and takes quite awhile comparatively speaking for all of them to shutdown when the ignition is shut off. One very annoying materials lack of quality is the B-Pillar trim. It is made from a fuzzy material and at least a leather like material both of which fray very easily. I have replaced the leather portion once at Lexus expense and within a year or two the same thing happened again. A vinyl piece like is used in the Lexus ES 350 would have been more durable and looked reasonably well. The fuzzy material is just all pilled up with some small holes in them. The reason for this is the poor entry design for the front seats (4-door sedan). I am 6' 2" and I can't get in the car without having to get in with my body right up next to the B-Pillar and likewise getting out. I have to be that far back to be able to get my head in under the top of the doorway. Also Lexus has a feature built in for ease of exit to put the seat all the way back on the seat track which positions anybody into this position up against the B-Pillar if they have this function turned on. The all the way back on Seat Track puts the back of the seat parallel to or possibly slightly behind the B-Pillar thus causing your hip to rub against the B-Pillar as you get in or out of the car which is guaranteed if you have someone parking parallel to you in a parking spot very close to the side of the car.
There are other areas of design stupidity on the car which makes you wonder about the sense of the Lexus Designers such as giving the US version of the car Automatic Rain Sending Wipers without also turning on the Headlights as required in some States but they do so in the European model. And the cost to add the Headlight feature should be nil as it is only a firmware (software) change and already exists for the European model. So, there should be virtually no cost difference to have this feature in the US Model. Can't tell you how many times I forget to turn the headlights on in the day time when it rains (the headlight law is only a few years old and old habits die hard). Sheer stupidity.
Post by palinka » 2020-05-12 22:20
jim.bus wrote:
2020-05-12 21:53
My car has automatic lights (most/all new cars do). You can set it to the usual manual settings or to automatic. Of course, every time I work in the yard my little one jumps in the driver's seat and plays with every knob, button and switch, and I drive around for a week without even noticing the lights are off. :mrgreen:
