Writing subject in header to log
CraigT
Post by CraigT » 2020-04-09 04:40
Hi all..
Does anyone know of a script that will write the subject header into the server log when an email is delivered to a mailbox. Unfortunately, certain persons have been deleting critical emails from their mailbox and then claiming they never received them. This would make delivery stand out. I assume that it may be simple but my knowledge of the inner workings and VB is limited.
Virinum
Re: Writing subject in header to log
Post by Virinum » 2020-04-09 07:43
Add this to your EventHandlers.vbs
    EventLog.Write oMessage.Subject
CraigT
Post by CraigT » 2020-04-10 05:44
CraigT
Post by CraigT » 2020-04-15 10:45
Having implemented the code I found that it created a separate event log with just the subject line showing. After a bit of research I inserted a line above to display the From Address
    EventLog.Write oMessage.FromAddress
which actually worked!
The separate log is good from the admin point of view as it removes the server log chatter. I have been trying to find the To Address to add to the log, so it was From: Subject:To and then make it a daily log the same as the hMailserver log. I have a PowerShell script to zip up the files after a month.
Any help appreciated.
Virinum
Post by Virinum » 2020-04-15 11:39
https://www.hmailserver.com/documentati ... ct_message
Recipients is a list. You have to loop over all recipients. Something like this (not tested):
  Dim i, logMessage
  logMessage = oMessage.FromAddress & ": " & oMessage.Subject & ": "
    If (i = 0) Then
      logMessage = logMessage & oMessage.Recipients(i).OriginalAddress
      logMessage = logMessage & ", " & oMessage.Recipients(i).OriginalAddress
  EventLog.Write logMessage
And for the daily log I've used this PowerShell script some time ago (executed every day at 0:00):
$yesterday = (get-date).AddDays(-1).ToString("yyyy-MM-dd")
$path = "C:\Program Files (x86)\hMailServer\Logs"
$originalfile = "$path\hmailserver_events.log"
$newfile = "$path\hmailserver_events_$yesterday.log"
if ((Test-Path $originalfile) -And -Not (Test-Path $newfile)) {
    Rename-Item -Path $originalfile -NewName $newfile
CraigT
Post by CraigT » 2020-04-15 11:59
Once again...thanks. Gives me something to play with, and also learn.
CraigT
Post by CraigT » 2020-04-16 11:27
The code works well. The rotate log code can be used for other log files with a little modification. Once again thanks.
Post by SorenR » 2020-04-16 11:49
Often simple is good... I was thinking of offering my own approach but the 200+ lines of code can wait until your VBScript improves ;-)
CraigT
Post by CraigT » 2020-04-17 10:13
That's OK. I need to look at it. My background goes back to COBOL, Fortran, GWBasic and lately Bascom for micros. Once I get an understanding, it will make it a lot easier. :D
