Passing message content to a database
RogerK
Post by RogerK » 2020-04-17 08:37
I am looking for a way of passing incoming message content to a mySQL database
and I am wondering if hMailserver can do this.
The requirement is for one email account only. A script will extract contents of messages
and populate fields in the database. Preferred language for script will be PHP.
At this stage I am just trying to establish how easy this will be to achieve with hMailserver.
Thank you,
Roger K
Re: Passing message content to a database
Post by SorenR » 2020-04-17 09:29
RogerK wrote:
2020-04-17 08:37
Thank you,
Roger K
In hMailServer...
Create account,
Edit account and create RULE to Run Function "DumpToMySQLWithPHP" on receipt of new mail
In eventhandlers.vbs add something like...
Function DumpToMySQLWithPHP(oMessage)
    Const Verbose = 0
    Dim oCMD : Set oCMD = CreateObject("WScript.Shell")
    oCMD.Run "<path-to>\PHP.EXE <path-to>\DumpToMySQLWithPHP.php " & oMessage.filename, Verbose, True
oMessage.Filename = <path-to>\<filename>.EML and it lists the location and filename of the raw email.
NOW... IF YOU had taken 5 minutes to read the documentation I could have saved 10 minutes doing YOUR job!
Post by palinka » 2020-04-17 14:38
To be fair, I could not find an example of external scripting as such in the documentation.
Also, to be very, very fair, Soren is rarely a grumpy dude and is one of the best and most prolific contributors here. :mrgreen:
However, a simple search would have brought up lots of results. Taking one of Soren's examples: http://hmailserver.com/forum/viewtopic.php?f=21&t=33566
Its probably a lot easier to do the whole thing in vbs since you have to use it anyway. hMailServer COM has a built in database execution object. So the easiest way would be to create a table in the hMailServer database and use the COM database object. Then you can retrieve the data using php or whatever you want.
From Soren's example, I put this together:
Private Const PASSWORD = "########"
Function GetDatabaseObject()
   Set GetDatabaseObject = oApp.Database
Sub DumpToMySQLWithPHP(oClient, oMessage)
   strSQL = "INSERT INTO your_message_table (timestamp,ipaddress,from,message) VALUES (NOW(),'" & oClient.IPAddress & "','" & oMessage.FromAddress & "','" & oMessage.HTMLBody & "');"
   Call oDB.ExecuteSQL(strSQL)
You'll need to create the table first. In the example above there are 4 columns. Change that to whatever suits your needs. This is still called by rule.
RogerK
Post by RogerK » 2020-04-19 00:24
Many thanks, this is just what I need. I have not used VBS for a long time, but I can see that it might be easier than PHP
Post by mattg » 2020-04-19 17:56
