Help needed:said: 530 SMTP authentication is required
kestrup
Post by kestrup » 2020-04-23 10:11
Hi
When i add domain name number 3, I get these errors from the frontend spamgateway SMTP (ScroolOutF1)
Only whit one domain on the HMailserver it works.
Apr 23 09:56:09 unassigned postfix/smtpd[1782]: NOQUEUE: reject: RCPT from mail-yb1-f173.google.com[209.85.219.173]: 550 5.1.1 user@lyngbakken.dk: Recipient address rejected: undeliverable address: host 192.168.1.210[192.168.1.210] said: 530 SMTP authentication is required. (in reply to RCPT TO command); from=user@gmail.com to=user@lyngbakken.dk proto=ESMTP helo=mail-yb1-f173.google.com
/Kenneth
Re: Help needed:said: 530 SMTP authentication is required
Post by jimimaseye » 2020-04-23 10:35
Your email is going to google servers (that is not a hmailserver error).
The dns records for lyngbakken.dk are not configured for pointing to your server as you want them to.
Post by SorenR » 2020-04-23 10:53
kestrup wrote:
2020-04-23 10:11
Hi
/Kenneth
That message comes from ScrollOutF1 ?
hMailServer is installed on 192.168.1.210 ?
You are a TDC customer ?
Det er ikke meget du har givet os at arbejde med!
Jeg gætter på du ikke har oprettet/enablet domæne lyngbakken.dk og dit IP Range derfor kræver authentication for External to External... Tæt på?
Post by Dravion » 2020-04-23 12:31
It looks like you are behind a NAT-Router, which is connected to the Public Internet.
Your Local Network ip address is obviously auto configured by your NAT-Router (to a 24-Bit Subnet like this: 192.168.x.y)
Problem is, your Subnet is only known to our local Office/Company/House Local Network but not visible to the public internet, except by
the public ip address of your NAT-Router which is also setup as Dynamic ip address (DHCP) by your Broadband Internet Service Provider (ISP).
Unfortunately, a dynamic, public ip address was often used by Spammers so most Email Hosters like Gmail or Yahoo doesn't allow directly sent
Emails by a Dynamic ip address is mostly rejected in general, because in the early days of the Internet a lot of Spam came from such dynamic ip addresses.
You have two options:
1) Get a Static ip address and run your SMTP-Appliance on it on the public internet
2) Use a SMTP Relay server / Smart Host on your SMTP-Appliance
Post by SorenR » 2020-04-23 16:48
Dravion wrote:
2020-04-23 12:31
In other words... You have no clue... If you bothered to check you'd see that Kenneth already have a static address. It is obvious from the rDNS.
From that single message - and the fact I downloaded ScrollOutF1 to check it out - it is safe to assume the following Config:
Google --> TDC Customer Router --> PC w/ Debian Unix/ScrollOutF1 --> PC w/ Windows/hMailServer
or..
209.85.219.173 --> 93.161.89.15 / 192.168.1.1 --> ??? --> 192.168.1.210
Post by Dravion » 2020-04-23 17:57
Yeah, Sherlock.
Looks totally like a public internet address :lol:
Post by SorenR » 2020-04-23 20:55
Dravion wrote:
2020-04-23 17:57
Yeah, Sherlock.
Post by Dravion » 2020-04-24 10:36
2020-04-23 20:55
Dravion wrote:
2020-04-23 17:57
Yeah, Sherlock.
You are right.
Changing the hMailServer ip range to allow External to Local delivery could help.
Post by SorenR » 2020-04-24 14:23
Dravion wrote:
2020-04-24 10:36
2020-04-23 20:55
Dravion wrote:
2020-04-23 17:57
Yeah, Sherlock.
You are right.
Something is fishy with the IP Ranges ... Maybe...
Assuming default IP Ranges ...
- IF "lyngbakken.dk" is defined in hMailServer then it should be "External to Local" delivery.
- IF on the other hand "lyngbakken.dk" is NOT defined in hMailServer then it is "External to External" delivery and then everything is working as intended - but not as expected. :mrgreen:
It may be worth mentioning that there is a "backup-mx" in DNS that point to a Microsoft cloud server.
Anyways, OP seems to have gone AWOL. :wink:
