Maybe Antispam DNS Blacklist not working
HMailLover2015
Post by HMailLover2015 » 2020-05-06 19:38
Was looking through some posts and noticed that some people talk about log entries when incoming mail is checked against antispam blacklists. I am not seeing these sort of entries in my logs for the DNS Blacklists. All I see is
Spam test: SpamTestDNSBlackLists, Score: 0
Shouldn't there be entries for each blacklist checked?
HMailLover2015
Re: Maybe Antispam DNS Blacklist not working
Post by HMailLover2015 » 2020-05-06 20:56
Addition. Should have put in the original post - even with all logging enabled, I see no entries for Blacklist lookups. Only SURBL entries but nothing for the three configured DNSBL - sorbs, spamcop and spamhaus
Post by jimimaseye » 2020-05-06 23:41
Pay a full log excerpt of a message needing received and processed to delivery where you think the entries should be appearing. Also run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914.
HMailLover2015
Post by HMailLover2015 » 2020-05-07 01:45
Here is the output
[code]2020-05-06   Hmailserver: 5.6.6-B2383
DOMAINS
   "Domain1.com" - amxxxxxxxxxxxxxxx.com          Enabled: False
   "Domain2.com" - caxxxxxxxxxxxxxxxx.orx         Enabled: False
   "Domain3.com" - jxxxxxxxxxxxxx.com             Enabled: True
                                                Algorithm: SHA256  Greylisting: !! ENABLED BUT NOT ACTIVATED!!
                                                Private key: c:\program files\hmailserver\data\dkim.Domain3.com.pem
                                                Selector:    dkim
   "Domain4.com" - jxxxxxxxxxxxxx.net             Enabled: True
                                                Private key: c:\program files\hmailserver\data\dkim.Domain4.com.pem
                                                Selector:    dkim
   "Domain5.com" - jxxxxxxxx.com                  Enabled: True
                                                Private key: c:\program files\hmailserver\data\dkim.Domain5.com.pem
                                                Selector:    dkim
   "Domain6.com" - maxxxxxxxx.xxxx.cx              Enabled: True
        Greylisting:     False
   "Domain7.com" - texxxxxxxxxxxxxxxx.net         Enabled: True
   "Domain8.com" - texxxxxxxxxxxxxxxxx.net        Enabled: True
                                                Private key: c:\program files\hmailserver\data\dkim.Domain8.com.pem
                                                Selector:    dkim
   "Domain9.com" - waxxxxxxxxxxxxxxxxx.com        Enabled: True
        Greylisting:     False
IP RANGES
IP: 127.0.0.1 - 127.0.0.1     Priority: 15     Name: My Computer
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      1
                              Minutes Before Reset:        10080  (168.00 hours, 7.00 days)
                              Minutes to Autoban:          10080  (168.00 hours, 7.00 days)
There is a total of 218 auto-ban IP ranges.
INCOMING RELAYS
MIRRORING         mailmirror@Domain4.com
PROTOCOLS
SMTP
No. Connections:100  No Retries:168 Mins: 60   Plain Text:        False  Bind:
                     Host: Domain6.com         Empty sender:       True  Batch recipients:   100
Max Msg Size:500000  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
                      EXTERNAL.TLD  (ok)       Disc. on invalid:   True  Delivered-To hdr: False
                     Port: 587                 Max number commands: 100  Loop limit:           5
                     Con. Sec.: StartTLS Optional
  Routes:
     No routes defined.
POP3
  No. Connections: 50
IMAP
  No. Connections: 300      Public folder name: #Public       IMAP sort:  True
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  2       Use SPF:            True - 3    Use Spamassassin:   False
  Add X-HmailServer-Spam:     True    Check HELO host:    True - 2
  Add X-HmailServer-Reason:   True    Check MX records:   True - 2
  Add X-HmailServer-Subject:  True    Verify DKIM:        True - 5
              Subject Text: "[SPAM]"
  Spam delete threshold: 1000         Maximum message size: 9999
DNSBL ENTRIES:
                   dnsbl.sorbs.net      Score: 3     Result: 127.0.0.2-14
                   bl.spamcopy.net      Score: 3     Result: 127.0.0.2
                  zen.spamhaus.org      Score: 3     Result: 127.0.0.2-11
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
SSL CERTIFICATES
   Mxxxxxxx.xxxxx.CX
       Certificate: C:\OpenSSL-Win32\bin\mxxxx.cert
       Private key: C:\OpenSSL-Win32\bin\mxxxx.key
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 500   / SMTP   -   SSL/TLS             Cert:  Mxxxxxxx.xxxxx.CX
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert:  Mxxxxxxx.xxxxx.CX
  Paths:-
    Current:  C:\Program Files\hMailServer\Logs\hmailserver_2020-05-06.log
    Error:    C:\Program Files\hMailServer\Logs\ERROR_hmailserver_2020-05-06.log
    Event:    C:\Program Files\hMailServer\Logs\hmailserver_events.log - Last Event: 2020/05/06
    Awstats:  C:\Program Files\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -      .
                        IMAP        -      .
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -      .
SYSTEM TESTS
Database type: MySQL
IPv6 support is not available in operating system.
Backup directory C:\xxxxx is writable.
HMAILSERVER.INI
Program folder:  C:\Program Files\hMailServer\
Database folder:
Data folder:     C:\Program Files\hMailServer\Data
Log folder:      C:\Program Files\hMailServer\Logs
Temp folder:     C:\Program Files\hMailServer\Temp
Event folder:    C:\Program Files\hMailServer\Events
Type=              MYSQL
Username=          root
Port=              3306
Server=            192.168.2.99
Internal=          0
Generated by HMSSettingsDiagnostics v2.00, Hmailserver Forum.
[/code]
and a log entry
"DEBUG"	712	"2020-05-06 19:17:00.773"	"Creating session 2080"
"TCPIP"	712	"2020-05-06 19:17:00.773"	"TCP - 45.142.182.53 connected to 192.168.2.99:25."
"DEBUG"	712	"2020-05-06 19:17:00.773"	"TCP connection started for session 2068"
"SMTPD"	712	2068	"2020-05-06 19:17:00.773"	"45.142.182.53"	"SENT: 220 Mxxxxxxx.xxxxx.CX ESMTP"
"SMTPD"	3888	2068	"2020-05-06 19:17:00.898"	"45.142.182.53"	"RECEIVED: EHLO jezqb.telegram.org"
"SMTPD"	3888	2068	"2020-05-06 19:17:00.898"	"45.142.182.53"	"SENT: 250-Mxxxxxxx.xxxxx.CX[nl]250-SIZE 500000000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	3232	2068	"2020-05-06 19:17:01.023"	"45.142.182.53"	"RECEIVED: MAIL FROM:<info@PK8AN.enterpriserentacar.ca>"
"SMTPD"	3232	2068	"2020-05-06 19:17:01.023"	"45.142.182.53"	"SENT: 250 OK"
"SMTPD"	3888	2068	"2020-05-06 19:17:01.148"	"45.142.182.53"	"RECEIVED: RCPT TO:<kxxxx@xxxx.com>"
"SMTPD"	3888	2068	"2020-05-06 19:17:01.164"	"45.142.182.53"	"SENT: 250 OK"
"SMTPD"	1896	2068	"2020-05-06 19:17:01.273"	"45.142.182.53"	"RECEIVED: DATA"
"SMTPD"	1896	2068	"2020-05-06 19:17:01.273"	"45.142.182.53"	"SENT: 354 OK, send."
"DEBUG"	712	"2020-05-06 19:17:01.398"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	2484	"2020-05-06 19:17:01.398"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	2484	"2020-05-06 19:17:01.398"	"Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG"	2484	"2020-05-06 19:17:01.398"	"Spam test: SpamTestHeloHost, Score: 0"
"DEBUG"	2484	"2020-05-06 19:17:01.679"	"Spam test: SpamTestMXRecords, Score: 0"
"DEBUG"	2484	"2020-05-06 19:17:01.679"	"Spam test: SpamTestSPF, Score: 0"
"DEBUG"	2484	"2020-05-06 19:17:01.679"	"Total spam score: 0"
"DEBUG"	2484	"2020-05-06 19:17:01.679"	"SURBL: Execute"
"DEBUG"	2484	"2020-05-06 19:17:01.679"	"SURBL: Found URL: telegram.org"
"DEBUG"	2484	"2020-05-06 19:17:01.679"	"SURBL: Found URL: aptrk1.com"
"DEBUG"	2484	"2020-05-06 19:17:01.679"	"SURBL: Found URL: imgur.com"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"SURBL: 3 unique addresses found."
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"SURBL: Lookup: aptrk1.com.multi.surbl.org"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"SURBL: Lookup: imgur.com.multi.surbl.org"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"SURBL: Lookup: telegram.org.multi.surbl.org"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"SURBL: Match not found"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"Spam test: SpamTestSURBL, Score: 0"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"Spam test: SpamTestDKIM, Score: 0"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"Total spam score: 0"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"Executing event OnAcceptMessage"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"Event completed"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"Saving message: {1D3505D6-8C9F-4DC3-B505-14D381B7C0CB}.eml"
"DEBUG"	2484	"2020-05-06 19:17:01.695"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	2484	2068	"2020-05-06 19:17:01.695"	"45.142.182.53"	"SENT: 250 Queued (0.256 seconds)"
"DEBUG"	3540	"2020-05-06 19:17:01.695"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	3820	"2020-05-06 19:17:01.695"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	3820	"2020-05-06 19:17:01.695"	"Delivering message..."
"APPLICATION"	3820	"2020-05-06 19:17:01.695"	"SMTPDeliverer - Message 12168787: Delivering message from info@PK8AN.enterpriserentacar.ca to kxxxx@xxxx.com. File: C:\Program Files\hMailServer\Data\{1D3505D6-8C9F-4DC3-B505-14D381B7C0CB}.eml"
"DEBUG"	3820	"2020-05-06 19:17:01.695"	"Applying rules"
"DEBUG"	3820	"2020-05-06 19:17:01.695"	"Copying mail contents"
"DEBUG"	3820	"2020-05-06 19:17:01.695"	"Saving message: {7B17D3CB-DD22-4D6F-AD0A-DB29EF37D33A}.eml"
"DEBUG"	3820	"2020-05-06 19:17:01.695"	"Requesting SMTPDeliveryManager to start message delivery"
"DEBUG"	3820	"2020-05-06 19:17:01.695"	"Performing local delivery"
"DEBUG"	3540	"2020-05-06 19:17:01.711"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	1356	"2020-05-06 19:17:01.711"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	1356	"2020-05-06 19:17:01.711"	"Delivering message..."
"APPLICATION"	1356	"2020-05-06 19:17:01.711"	"SMTPDeliverer - Message 12168788: Delivering message from info@PK8AN.enterpriserentacar.ca to mxxxxxxx@xxxxxx.net. File: C:\Program Files\hMailServer\Data\{7B17D3CB-DD22-4D6F-AD0A-DB29EF37D33A}.eml"
"DEBUG"	1356	"2020-05-06 19:17:01.711"	"Applying rules"
"DEBUG"	1356	"2020-05-06 19:17:01.711"	"Performing local delivery"
"DEBUG"	1356	"2020-05-06 19:17:01.711"	"Saving message: {7B17D3CB-DD22-4D6F-AD0A-DB29EF37D33A}.eml"
"DEBUG"	1356	"2020-05-06 19:17:01.711"	"Local delivery completed"
"APPLICATION"	1356	"2020-05-06 19:17:01.711"	"SMTPDeliverer - Message 12168788: Message delivery thread completed."
"DEBUG"	3820	"2020-05-06 19:17:01.758"	"Applying rules"
"DEBUG"	3820	"2020-05-06 19:17:01.758"	"Saving message: {1D3505D6-8C9F-4DC3-B505-14D381B7C0CB}.eml"
"SMTPD"	3888	2068	"2020-05-06 19:17:01.820"	"45.142.182.53"	"RECEIVED: QUIT"
"SMTPD"	3888	2068	"2020-05-06 19:17:01.820"	"45.142.182.53"	"SENT: 221 goodbye"
"DEBUG"	3232	"2020-05-06 19:17:01.820"	"Ending session 2068"
"DEBUG"	3820	"2020-05-06 19:17:01.820"	"Local delivery completed"
"APPLICATION"	3820	"2020-05-06 19:17:01.820"	"SMTPDeliverer - Message 12168787: Message delivery thread completed."
Post by RvdH » 2020-05-07 08:31
HMailLover2015 wrote:
2020-05-06 19:38
No
Post by jimimaseye » 2020-05-07 09:57
Why do you have this? :
INCOMING RELAYS
That effectively stops everything from being checked anyway. (It will always result in Zero).https://www.hmailserver.com/documentati ... omingrelay
Remove this setting and retry (unless you have a valid reason why you have set it in the first place).
Post by mattg » 2020-05-07 11:01
2020-05-07 08:31
2020-05-06 19:38
No
I get them as TCP/IP entries in 5.7
"TCPIP"	66088	"2020-05-07 18:49:09.300"	"DNS lookup: xxx.xxx.xxx.xxx.bl.spamcop.net, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:09.600"	"DNS lookup: xxx.xxx.xxx.xxx.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:10.129"	"DNS lookup: xxx.xxx.xxx.xxx.b.barracudacentral.org, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:10.425"	"DNS lookup: xxx.xxx.xxx.xxx.cbl.abuseat.org, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:11.020"	"DNS lookup: xxx.xxx.xxx.xxx.aspews.ext.sorbs.net, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:11.597"	"DNS lookup: xxx.xxx.xxx.xxx.dnsbl.sorbs.net, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:11.832"	"DNS lookup: xxx.xxx.xxx.xxx.ubl.unsubscore.com, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:11.864"	"DNS lookup: xxx.xxx.xxx.xxx.sbl.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:13.068"	"DNS lookup: xxx.xxx.xxx.xxx.zz.countries.nerd.dk, 1 addresses found: 127.0.3.72, Match: False"
"TCPIP"	66088	"2020-05-07 18:49:13.630"	"DNS lookup: xxx.xxx.xxx.xxx.hostkarma.junkemailfilter.com, 2 addresses found: 127.0.0.1, 127.0.1.1, Match: False"
"TCPIP"	66088	"2020-05-07 18:49:14.222"	"DNS lookup: xxx.xxx.xxx.xxx.all.bl.blocklist.de, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:14.488"	"DNS lookup: xxx.xxx.xxx.xxx.all.spamrats.com, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:15.066"	"DNS lookup: xxx.xxx.xxx.xxx.ix.dnsbl.manitu.net, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:15.347"	"DNS lookup: xxx.xxx.xxx.xxx.dnsbl-1.uceprotect.net, 0 addresses found: (none), Match: False"
"TCPIP"	66088	"2020-05-07 18:49:15.925"	"DNS lookup: xxx.xxx.xxx.xxx.torexit.dan.me.uk, 0 addresses found: (none), Match: False"
HMailLover2015
Post by HMailLover2015 » 2020-05-07 17:21
2020-05-07 09:57
INCOMING RELAYS
It has been removed and now I see entries in the log for spam checking
"DEBUG"	2612	"2020-05-07 11:15:44.148"	"Creating session 7175"
"TCPIP"	2612	"2020-05-07 11:15:44.148"	"TCP - 54.149.191.236 connected to 192.168.2.99:25."
"DEBUG"	2612	"2020-05-07 11:15:44.148"	"TCP connection started for session 7174"
"SMTPD"	2612	7174	"2020-05-07 11:15:44.148"	"54.149.191.236"	"SENT: 220 mxxxxxx.cx ESMTP"
"SMTPD"	3232	7174	"2020-05-07 11:15:44.273"	"54.149.191.236"	"RECEIVED: EHLO outbound-191-236.usw2.aws.post.pinterest.com"
"SMTPD"	3232	7174	"2020-05-07 11:15:44.289"	"54.149.191.236"	"SENT: 250-mxxxxxx.cx[nl]250-SIZE 500000000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	1896	7174	"2020-05-07 11:15:44.383"	"54.149.191.236"	"RECEIVED: MAIL FROM:<bounces-508132907865363009@notifications.pinterest.com>"
"TCPIP"	1896	"2020-05-07 11:15:48.101"	"DNS lookup: 236.191.149.54.dnsbl.sorbs.net, 0 addresses found: (none), Match: False"
"TCPIP"	1896	"2020-05-07 11:15:48.133"	"DNS lookup: 236.191.149.54.bl.spamcopy.net, 0 addresses found: (none), Match: False"
"TCPIP"	1896	"2020-05-07 11:15:48.180"	"DNS lookup: 236.191.149.54.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"DEBUG"	1896	"2020-05-07 11:15:48.180"	"Spam test: SpamTestDNSBlackLists, Score: 0"
"DEBUG"	1896	"2020-05-07 11:15:48.289"	"Spam test: SpamTestHeloHost, Score: 0"
"DEBUG"	1896	"2020-05-07 11:15:48.351"	"Spam test: SpamTestMXRecords, Score: 0"
"DEBUG"	1896	"2020-05-07 11:15:48.492"	"Spam test: SpamTestSPF, Score: 0"
"DEBUG"	1896	"2020-05-07 11:15:48.492"	"Total spam score: 0"
"SMTPD"	1896	7174	"2020-05-07 11:15:48.492"	"54.149.191.236"	"SENT: 250 OK"
"SMTPD"	1896	7174	"2020-05-07 11:15:48.586"	"54.149.191.236"	"RECEIVED: RCPT TO:<ixxx@jxxxxxx.cxx>"
"SMTPD"	1896	7174	"2020-05-07 11:15:48.586"	"54.149.191.236"	"SENT: 250 OK"
"SMTPD"	712	7174	"2020-05-07 11:15:49.383"	"54.149.191.236"	"RECEIVED: DATA"
"SMTPD"	712	7174	"2020-05-07 11:15:49.383"	"54.149.191.236"	"SENT: 354 OK, send."
"DEBUG"	3888	"2020-05-07 11:15:49.695"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	2484	"2020-05-07 11:15:49.695"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	2484	"2020-05-07 11:15:49.695"	"SURBL: Execute"
"DEBUG"	2484	"2020-05-07 11:15:49.695"	"SURBL: Found URL: pinterest.com"
"DEBUG"	2484	"2020-05-07 11:15:49.711"	"SURBL: Found URL: w3.org"
"DEBUG"	2484	"2020-05-07 11:15:49.711"	"SURBL: Found URL: pinimg.com"
"DEBUG"	2484	"2020-05-07 11:15:49.711"	"SURBL: 3 unique addresses found."
"DEBUG"	2484	"2020-05-07 11:15:49.711"	"SURBL: Lookup: pinimg.com.multi.surbl.org"
"DEBUG"	2484	"2020-05-07 11:15:49.867"	"SURBL: Lookup: pinterest.com.multi.surbl.org"
"DEBUG"	2484	"2020-05-07 11:15:50.008"	"SURBL: Lookup: w3.org.multi.surbl.org"
"DEBUG"	2484	"2020-05-07 11:15:50.195"	"SURBL: Match not found"
"DEBUG"	2484	"2020-05-07 11:15:50.195"	"Spam test: SpamTestSURBL, Score: 0"
"DEBUG"	2484	"2020-05-07 11:15:50.242"	"DKIM: Message passed validation."
"DEBUG"	2484	"2020-05-07 11:15:50.242"	"Spam test: SpamTestDKIM, Score: 0"
"DEBUG"	2484	"2020-05-07 11:15:50.242"	"Total spam score: 0"
"DEBUG"	2484	"2020-05-07 11:15:50.242"	"Executing event OnAcceptMessage"
"DEBUG"	2484	"2020-05-07 11:15:50.242"	"Event completed"
"DEBUG"	2484	"2020-05-07 11:15:50.242"	"Saving message: {152B5F8E-DDDB-4F55-850F-799E94187AC6}.eml"
"DEBUG"	2484	"2020-05-07 11:15:50.242"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	2484	7174	"2020-05-07 11:15:50.242"	"54.149.191.236"	"SENT: 250 Queued (0.768 seconds)"
"DEBUG"	3540	"2020-05-07 11:15:50.242"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	1904	"2020-05-07 11:15:50.242"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	1904	"2020-05-07 11:15:50.242"	"Delivering message..."
"APPLICATION"	1904	"2020-05-07 11:15:50.242"	"SMTPDeliverer - Message 12170004: Delivering message from bounces-508132907865363009@notifications.pinterest.com to ixxx@jxxxxxx.cxx. File: C:\Program Files\hMailServer\Data\{152B5F8E-DDDB-4F55-850F-799E94187AC6}.eml"
"DEBUG"	1904	"2020-05-07 11:15:50.258"	"Applying rules"
"DEBUG"	1904	"2020-05-07 11:15:50.258"	"Copying mail contents"
"DEBUG"	1904	"2020-05-07 11:15:50.258"	"Saving message: {B9A25180-D4A2-49DD-BFFB-940ECC6C6A2B}.eml"
"DEBUG"	1904	"2020-05-07 11:15:50.258"	"Requesting SMTPDeliveryManager to start message delivery"
"DEBUG"	1904	"2020-05-07 11:15:50.258"	"Performing local delivery"
"DEBUG"	3540	"2020-05-07 11:15:50.258"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	1356	"2020-05-07 11:15:50.273"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	1356	"2020-05-07 11:15:50.273"	"Delivering message..."
"APPLICATION"	1356	"2020-05-07 11:15:50.273"	"SMTPDeliverer - Message 12170005: Delivering message from bounces-508132907865363009@notifications.pinterest.com to mxxx@jxxxx.xxx. File: C:\Program Files\hMailServer\Data\{B9A25180-D4A2-49DD-BFFB-940ECC6C6A2B}.eml"
"DEBUG"	1356	"2020-05-07 11:15:50.273"	"Applying rules"
"DEBUG"	1356	"2020-05-07 11:15:50.273"	"Performing local delivery"
"DEBUG"	1356	"2020-05-07 11:15:50.273"	"Saving message: {B9A25180-D4A2-49DD-BFFB-940ECC6C6A2B}.eml"
"DEBUG"	1356	"2020-05-07 11:15:50.273"	"Local delivery completed"
"APPLICATION"	1356	"2020-05-07 11:15:50.273"	"SMTPDeliverer - Message 12170005: Message delivery thread completed."
"DEBUG"	1904	"2020-05-07 11:15:50.289"	"Applying rules"
"DEBUG"	1904	"2020-05-07 11:15:50.289"	"Applying rule xxx"
"DEBUG"	1904	"2020-05-07 11:15:50.289"	"Saving message: {152B5F8E-DDDB-4F55-850F-799E94187AC6}.eml"
"DEBUG"	1904	"2020-05-07 11:15:50.351"	"Reading messages from database."
"DEBUG"	1904	"2020-05-07 11:15:50.367"	"Local delivery completed"
"APPLICATION"	1904	"2020-05-07 11:15:50.367"	"SMTPDeliverer - Message 12170004: Message delivery thread completed."
"SMTPD"	3232	7174	"2020-05-07 11:15:55.352"	"54.149.191.236"	"RECEIVED: QUIT"
"SMTPD"	3232	7174	"2020-05-07 11:15:55.352"	"54.149.191.236"	"SENT: 221 goodbye"
What exactly does the incoming relay section do - what is it used for? Apparently this is left over from the original installation and configuration many years and many versions ago..... Not sure why that was set.....
Post by palinka » 2020-05-07 20:06
2020-05-07 17:21
Trusted relay, so no spam checking. Would be used for example for another relay that accepts messages from an automated machine incapable of authentication. Or any other trusted source like a backup mx.
Post by SorenR » 2020-05-07 20:42
2020-05-07 17:21
The technical explanation is... Every time an email is processed by a SMTP Server/Relay a "Received: ...." line is added to the email headers.
The normal SPAM checking procedure is to process the LAST "Received: ...." header as this is 99.999% the originating mailserver.
By adding a "trusted relay" you tell hMailServer to process the "Received: ...." header BEFORE the LAST.
A practical use is for example a Backup MX that will intercept emails if the main server is unavailable. When the connection to the main server is regained, emails will start to arrive. Since there is no point in SPAM checking the LAST "Received: ...." header as this is the Backup MX, the setting tells hMailServer that IF mail is from Backup MX please check the server BEFORE that.
In your case there would be NO server BEFORE the LAST so that is why your server did not SPAM check mails.
Post by jimimaseye » 2020-05-07 21:37
2020-05-07 17:21
Thought it would. Good.
2020-05-07 17:21
The answer was in the link to the documentation I posted. It explains it there.
