Unable to send mail to some domains
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-15 04:35
Hi, thaks for the time to help me, the problem I have its in my Hmailsever, I have multiple domains, When I try to send mails in the 90% of the time I dont have any problem, but one client its having error to send to some domains, the problem is if I send the mail from gmail to the email with the "problem" its recived, but if I send the mail from any domain on my HM it does not.
the mail its stuck. I attach the image
this is the log after I send the mail.
Thks
"TCPIP"	7344	"2020-05-14 20:11:01.709"	"TCP - 192.168.1.254 connected to 192.168.1.13:587."
"DEBUG"	7344	"2020-05-14 20:11:01.711"	"TCP connection started for session 19"
"SMTPD"	7344	19	"2020-05-14 20:11:01.712"	"192.168.1.254"	"SENT: 220 softcame.com ESMTP"
"DEBUG"	7748	"2020-05-14 20:11:01.735"	"Reading messages from database."
"SMTPD"	7344	19	"2020-05-14 20:11:01.743"	"192.168.1.254"	"RECEIVED: EHLO [10.212.134.200]"
"SMTPD"	7344	19	"2020-05-14 20:11:01.744"	"192.168.1.254"	"SENT: 250-softcame.com[nl]250-SIZE 150000000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	7752	19	"2020-05-14 20:11:01.765"	"192.168.1.254"	"RECEIVED: AUTH LOGIN"
"SMTPD"	7752	19	"2020-05-14 20:11:01.766"	"192.168.1.254"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	7668	19	"2020-05-14 20:11:01.787"	"192.168.1.254"	"RECEIVED: ZWNhbnR1QHNvZnRjYW1lLmNvbQ=="
"SMTPD"	7668	19	"2020-05-14 20:11:01.787"	"192.168.1.254"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	7344	19	"2020-05-14 20:11:01.809"	"192.168.1.254"	"RECEIVED: ***"
"SMTPD"	7344	19	"2020-05-14 20:11:01.812"	"192.168.1.254"	"SENT: 235 authenticated."
"SMTPD"	7752	19	"2020-05-14 20:11:01.833"	"192.168.1.254"	"RECEIVED: MAIL FROM:<ecantu@softcame.com> SIZE=28020"
"SMTPD"	7752	19	"2020-05-14 20:11:01.836"	"192.168.1.254"	"SENT: 250 OK"
"SMTPD"	7748	19	"2020-05-14 20:11:01.859"	"192.168.1.254"	"RECEIVED: RCPT TO:<ariel.mendoza@1stcb.com>"
"SMTPD"	7748	19	"2020-05-14 20:11:01.862"	"192.168.1.254"	"SENT: 250 OK"
"SMTPD"	7668	19	"2020-05-14 20:11:01.884"	"192.168.1.254"	"RECEIVED: DATA"
"SMTPD"	7668	19	"2020-05-14 20:11:01.923"	"192.168.1.254"	"SENT: 354 OK, send."
"DEBUG"	7752	"2020-05-14 20:11:01.982"	"Could not retrieve PTR record for IP (false)! 192.168.1.254"
"DEBUG"	7752	"2020-05-14 20:11:01.983"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	7412	"2020-05-14 20:11:01.984"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	7412	"2020-05-14 20:11:01.985"	"Executing event OnAcceptMessage"
"DEBUG"	7412	"2020-05-14 20:11:02.020"	"Event completed"
"DEBUG"	7412	"2020-05-14 20:11:02.021"	"Saving message: {5F151295-F427-4A43-B909-8B2A5C807527}.eml"
"DEBUG"	7412	"2020-05-14 20:11:02.028"	"Requesting SMTPDeliveryManager to start message delivery"
"SMTPD"	7412	19	"2020-05-14 20:11:02.028"	"192.168.1.254"	"SENT: 250 Queued (0.063 seconds)"
"DEBUG"	7440	"2020-05-14 20:11:02.030"	"Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG"	8044	"2020-05-14 20:11:02.031"	"Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG"	8044	"2020-05-14 20:11:02.031"	"Delivering message..."
"APPLICATION"	8044	"2020-05-14 20:11:02.032"	"SMTPDeliverer - Message 2334684: Delivering message from ecantu@softcame.com to ariel.mendoza@1stcb.com. File: C:\Program Files (x86)\hMailServer\Data\{5F151295-F427-4A43-B909-8B2A5C807527}.eml"
"DEBUG"	8044	"2020-05-14 20:11:02.034"	"Applying rules"
"DEBUG"	8044	"2020-05-14 20:11:02.034"	"Performing local delivery"
"DEBUG"	8044	"2020-05-14 20:11:02.035"	"Local delivery completed"
"DEBUG"	8044	"2020-05-14 20:11:02.035"	"Signing message using DKIM..."
"SMTPD"	7752	19	"2020-05-14 20:11:02.052"	"192.168.1.254"	"RECEIVED: QUIT"
"SMTPD"	7752	19	"2020-05-14 20:11:02.052"	"192.168.1.254"	"SENT: 221 goodbye"
"DEBUG"	7344	"2020-05-14 20:11:02.053"	"Ending session 19"
"TCPIP"	8044	"2020-05-14 20:11:02.055"	"DNS MX lookup: 1stcb.com"
"TCPIP"	8044	"2020-05-14 20:11:02.056"	"DNS - MX Result: 2 IP addresses were found."
"DEBUG"	8044	"2020-05-14 20:11:02.057"	"Starting external delivery process. Server: smtp02.fcserv.com (65.156.191.207), Port: 25, Security: 0, User name: "
"DEBUG"	8044	"2020-05-14 20:11:02.057"	"Creating session 23"
"TCPIP"	8044	"2020-05-14 20:11:02.058"	"Connecting to 65.156.191.207:25..."
"DEBUG"	7344	"2020-05-14 20:11:02.062"	"TCP connection started for session 23"
"DEBUG"	7748	"2020-05-14 20:11:02.120"	"Creating session 24"
"TCPIP"	7748	"2020-05-14 20:11:02.121"	"TCP - 192.168.1.254 connected to 192.168.1.13:143."
"DEBUG"	7748	"2020-05-14 20:11:02.123"	"TCP connection started for session 20"
"DEBUG"	7668	"2020-05-14 20:11:02.331"	"Saving message: {133A073A-4B95-4B23-A208-B7F2C91BAD08}.eml"
"DEBUG"	7748	"2020-05-14 20:11:02.617"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:02.874"	"Creating session 25"
"TCPIP"	7668	"2020-05-14 20:11:02.874"	"TCP - 185.143.75.81 connected to 192.168.1.13:25."
"DEBUG"	7668	"2020-05-14 20:11:02.876"	"Client connection from 185.143.75.81 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7668	"2020-05-14 20:11:02.877"	"Ending session 21"
"DEBUG"	7748	"2020-05-14 20:11:03.380"	"Reading messages from database."
"DEBUG"	7344	"2020-05-14 20:11:04.145"	"Reading messages from database."
"DEBUG"	7344	"2020-05-14 20:11:07.730"	"Creating session 26"
"TCPIP"	7344	"2020-05-14 20:11:07.731"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7344	"2020-05-14 20:11:07.733"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7344	"2020-05-14 20:11:07.734"	"Ending session 22"
"DEBUG"	7668	"2020-05-14 20:11:15.575"	"Creating session 27"
"TCPIP"	7668	"2020-05-14 20:11:15.576"	"TCP - 45.142.195.15 connected to 192.168.1.13:25."
"DEBUG"	7668	"2020-05-14 20:11:15.578"	"Client connection from 45.142.195.15 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7668	"2020-05-14 20:11:15.578"	"Ending session 25"
"DEBUG"	7344	"2020-05-14 20:11:16.592"	"Creating session 28"
"TCPIP"	7344	"2020-05-14 20:11:16.593"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7344	"2020-05-14 20:11:16.595"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7344	"2020-05-14 20:11:16.595"	"Ending session 26"
"DEBUG"	7748	"2020-05-14 20:11:22.812"	"Creating session 29"
"DEBUG"	7752	"2020-05-14 20:11:22.812"	"Creating session 30"
"TCPIP"	7748	"2020-05-14 20:11:22.813"	"TCP - 189.202.37.138 connected to 192.168.1.13:143."
"TCPIP"	7752	"2020-05-14 20:11:22.813"	"TCP - 189.202.37.138 connected to 192.168.1.13:110."
"DEBUG"	7748	"2020-05-14 20:11:22.815"	"TCP connection started for session 24"
"DEBUG"	7752	"2020-05-14 20:11:22.815"	"TCP connection started for session 10"
"DEBUG"	7344	"2020-05-14 20:11:23.149"	"Reading messages from database."
"DEBUG"	7344	"2020-05-14 20:11:24.760"	"Ending session 10"
"DEBUG"	7752	"2020-05-14 20:11:25.717"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:27.626"	"Creating session 31"
"TCPIP"	7668	"2020-05-14 20:11:27.627"	"TCP - 45.142.195.7 connected to 192.168.1.13:25."
"DEBUG"	7668	"2020-05-14 20:11:27.627"	"Client connection from 45.142.195.7 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7668	"2020-05-14 20:11:27.627"	"Ending session 27"
"DEBUG"	7668	"2020-05-14 20:11:27.663"	"Reading messages from database."
"DEBUG"	7444	"2020-05-14 20:11:28.293"	"No messages to index."
"DEBUG"	7752	"2020-05-14 20:11:28.501"	"Reading messages from database."
"DEBUG"	7752	"2020-05-14 20:11:29.851"	"Reading messages from database."
"DEBUG"	7752	"2020-05-14 20:11:30.626"	"Reading messages from database."
"DEBUG"	7752	"2020-05-14 20:11:31.052"	"Creating session 32"
"TCPIP"	7752	"2020-05-14 20:11:31.053"	"TCP - 189.154.196.223 connected to 192.168.1.13:110."
"DEBUG"	7752	"2020-05-14 20:11:31.055"	"TCP connection started for session 30"
"DEBUG"	7752	"2020-05-14 20:11:31.304"	"Creating session 33"
"TCPIP"	7752	"2020-05-14 20:11:31.305"	"TCP - 189.154.196.223 connected to 192.168.1.13:110."
"DEBUG"	7752	"2020-05-14 20:11:31.306"	"TCP connection started for session 32"
"DEBUG"	7748	"2020-05-14 20:11:31.387"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:31.424"	"Ending session 30"
"DEBUG"	7344	"2020-05-14 20:11:31.836"	"Ending session 32"
"DEBUG"	7668	"2020-05-14 20:11:31.851"	"Creating session 34"
"TCPIP"	7668	"2020-05-14 20:11:31.852"	"TCP - 45.142.195.15 connected to 192.168.1.13:25."
"DEBUG"	7668	"2020-05-14 20:11:31.854"	"Client connection from 45.142.195.15 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7668	"2020-05-14 20:11:31.854"	"Ending session 31"
"DEBUG"	7344	"2020-05-14 20:11:32.097"	"The read operation failed. Bytes transferred: 0 Remote IP: 65.156.191.207, Session: 23, Code: 2, Message: End of file"
"DEBUG"	7344	"2020-05-14 20:11:32.098"	"Ending session 23"
"DEBUG"	8044	"2020-05-14 20:11:32.098"	"External delivery process completed"
"DEBUG"	8044	"2020-05-14 20:11:32.099"	"Starting external delivery process. Server: smtp01.fcserv.com (65.124.74.24), Port: 25, Security: 0, User name: "
"DEBUG"	8044	"2020-05-14 20:11:32.099"	"Creating session 35"
"TCPIP"	8044	"2020-05-14 20:11:32.100"	"Connecting to 65.124.74.24:25..."
"DEBUG"	7668	"2020-05-14 20:11:32.103"	"TCP connection started for session 35"
"DEBUG"	7748	"2020-05-14 20:11:32.679"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:33.044"	"Creating session 36"
"TCPIP"	7668	"2020-05-14 20:11:33.045"	"TCP - 31.170.51.83 connected to 192.168.1.13:25."
"DEBUG"	7668	"2020-05-14 20:11:33.051"	"TCP connection started for session 34"
"SMTPD"	7668	34	"2020-05-14 20:11:33.052"	"31.170.51.83"	"SENT: 220 softcame.com ESMTP"
"DEBUG"	7344	"2020-05-14 20:11:33.063"	"Creating session 37"
"TCPIP"	7344	"2020-05-14 20:11:33.064"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7344	"2020-05-14 20:11:33.066"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7344	"2020-05-14 20:11:33.066"	"Ending session 28"
"DEBUG"	7668	"2020-05-14 20:11:33.345"	"Reading messages from database."
"SMTPD"	7748	34	"2020-05-14 20:11:34.083"	"31.170.51.83"	"RECEIVED: EHLO [31.170.51.83]"
"SMTPD"	7748	34	"2020-05-14 20:11:34.083"	"31.170.51.83"	"SENT: 250-softcame.com[nl]250-SIZE 150000000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	7752	34	"2020-05-14 20:11:34.936"	"31.170.51.83"	"RECEIVED: AUTH LOGIN"
"SMTPD"	7752	34	"2020-05-14 20:11:34.950"	"31.170.51.83"	"SENT: 334 VXNlcm5hbWU6"
"DEBUG"	7668	"2020-05-14 20:11:35.026"	"Reading messages from database."
"SMTPD"	7668	34	"2020-05-14 20:11:35.797"	"31.170.51.83"	"RECEIVED: Y2RlbGFnYXJ6YUBpbmRleGNoaWh1YWh1YS5vcmcubXg="
"SMTPD"	7668	34	"2020-05-14 20:11:35.797"	"31.170.51.83"	"SENT: 334 UGFzc3dvcmQ6"
"DEBUG"	7668	"2020-05-14 20:11:36.117"	"Reading messages from database."
"SMTPD"	7748	34	"2020-05-14 20:11:36.625"	"31.170.51.83"	"RECEIVED: ***"
"SMTPD"	7748	34	"2020-05-14 20:11:36.669"	"31.170.51.83"	"SENT: 535 Authentication failed. Restarting authentication process."
"DEBUG"	7752	"2020-05-14 20:11:36.799"	"Creating session 38"
"TCPIP"	7752	"2020-05-14 20:11:36.800"	"TCP - 200.68.143.199 connected to 192.168.1.13:110."
"DEBUG"	7752	"2020-05-14 20:11:36.805"	"TCP connection started for session 33"
"DEBUG"	7668	"2020-05-14 20:11:37.289"	"Reading messages from database."
"DEBUG"	7344	"2020-05-14 20:11:37.355"	"The read operation failed. Bytes transferred: 0 Remote IP: 200.68.143.199, Session: 33, Code: 2, Message: End of file"
"DEBUG"	7344	"2020-05-14 20:11:37.355"	"Ending session 33"
"DEBUG"	7344	"2020-05-14 20:11:37.496"	"The read operation failed. Bytes transferred: 0 Remote IP: 31.170.51.83, Session: 34, Code: 2, Message: End of file"
"DEBUG"	7344	"2020-05-14 20:11:37.497"	"Ending session 34"
"DEBUG"	7668	"2020-05-14 20:11:38.419"	"Creating session 39"
"TCPIP"	7668	"2020-05-14 20:11:38.420"	"TCP - 94.232.157.212 connected to 192.168.1.13:25."
"DEBUG"	7668	"2020-05-14 20:11:38.425"	"TCP connection started for session 36"
"SMTPD"	7668	36	"2020-05-14 20:11:38.426"	"94.232.157.212"	"SENT: 220 softcame.com ESMTP"
"DEBUG"	7748	"2020-05-14 20:11:38.575"	"Reading messages from database."
"SMTPD"	7752	36	"2020-05-14 20:11:39.286"	"94.232.157.212"	"RECEIVED: EHLO [94.232.157.212]"
"SMTPD"	7752	36	"2020-05-14 20:11:39.286"	"94.232.157.212"	"SENT: 250-softcame.com[nl]250-SIZE 150000000[nl]250-AUTH LOGIN[nl]250 HELP"
"DEBUG"	7668	"2020-05-14 20:11:39.327"	"Reading messages from database."
"DEBUG"	7748	"2020-05-14 20:11:39.581"	"Ending session 4"
"DEBUG"	7748	"2020-05-14 20:11:39.597"	"Creating session 40"
"TCPIP"	7748	"2020-05-14 20:11:39.597"	"TCP - 70.120.179.54 connected to 192.168.1.13:143."
"DEBUG"	7748	"2020-05-14 20:11:39.599"	"TCP connection started for session 29"
"DEBUG"	7748	"2020-05-14 20:11:39.676"	"Creating session 41"
"TCPIP"	7748	"2020-05-14 20:11:39.677"	"TCP - 70.120.179.54 connected to 192.168.1.13:143."
"DEBUG"	7748	"2020-05-14 20:11:39.679"	"TCP connection started for session 40"
"SMTPD"	7748	36	"2020-05-14 20:11:39.890"	"94.232.157.212"	"RECEIVED: AUTH LOGIN"
"SMTPD"	7748	36	"2020-05-14 20:11:39.890"	"94.232.157.212"	"SENT: 334 VXNlcm5hbWU6"
"DEBUG"	7668	"2020-05-14 20:11:40.061"	"Reading messages from database."
"SMTPD"	7752	36	"2020-05-14 20:11:40.451"	"94.232.157.212"	"RECEIVED: Y2RlbGFnYXJ6YQ=="
"SMTPD"	7752	36	"2020-05-14 20:11:40.452"	"94.232.157.212"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	7752	36	"2020-05-14 20:11:41.061"	"94.232.157.212"	"RECEIVED: ***"
"SMTPD"	7752	36	"2020-05-14 20:11:41.095"	"94.232.157.212"	"SENT: 535 Authentication failed. Restarting authentication process."
"DEBUG"	7668	"2020-05-14 20:11:41.145"	"Reading messages from database."
"DEBUG"	7344	"2020-05-14 20:11:41.475"	"The read operation failed. Bytes transferred: 0 Remote IP: 94.232.157.212, Session: 36, Code: 2, Message: End of file"
"DEBUG"	7344	"2020-05-14 20:11:41.476"	"Ending session 36"
"DEBUG"	7748	"2020-05-14 20:11:41.548"	"Reading messages from database."
"DEBUG"	7344	"2020-05-14 20:11:41.853"	"Creating session 42"
"TCPIP"	7344	"2020-05-14 20:11:41.854"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7344	"2020-05-14 20:11:41.856"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7344	"2020-05-14 20:11:41.856"	"Ending session 37"
"DEBUG"	7668	"2020-05-14 20:11:41.930"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:42.286"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:42.685"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:42.751"	"Creating session 43"
"TCPIP"	7668	"2020-05-14 20:11:42.751"	"TCP - 185.143.75.81 connected to 192.168.1.13:25."
"DEBUG"	7668	"2020-05-14 20:11:42.753"	"Client connection from 185.143.75.81 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7668	"2020-05-14 20:11:42.754"	"Ending session 39"
"DEBUG"	7344	"2020-05-14 20:11:43.102"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:43.458"	"Reading messages from database."
"DEBUG"	7752	"2020-05-14 20:11:43.897"	"Creating session 44"
"TCPIP"	7752	"2020-05-14 20:11:43.897"	"TCP - 177.236.12.178 connected to 192.168.1.13:110."
"DEBUG"	7752	"2020-05-14 20:11:43.900"	"TCP connection started for session 38"
"DEBUG"	7668	"2020-05-14 20:11:43.960"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:11:44.203"	"Reading messages from database."
"DEBUG"	7344	"2020-05-14 20:11:44.296"	"Ending session 38"
"DEBUG"	7668	"2020-05-14 20:11:44.326"	"Creating session 45"
"TCPIP"	7668	"2020-05-14 20:11:44.327"	"TCP - 45.142.195.7 connected to 192.168.1.13:25."
"DEBUG"	7668	"2020-05-14 20:11:44.329"	"Client connection from 45.142.195.7 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7668	"2020-05-14 20:11:44.330"	"Ending session 43"
"DEBUG"	7344	"2020-05-14 20:11:58.310"	"Creating session 46"
"TCPIP"	7344	"2020-05-14 20:11:58.311"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7344	"2020-05-14 20:11:58.313"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7344	"2020-05-14 20:11:58.313"	"Ending session 42"
"DEBUG"	7752	"2020-05-14 20:12:02.134"	"The read operation failed. Bytes transferred: 0 Remote IP: 65.124.74.24, Session: 35, Code: 2, Message: End of file"
"DEBUG"	7752	"2020-05-14 20:12:02.135"	"Ending session 35"
"DEBUG"	8044	"2020-05-14 20:12:02.136"	"External delivery process completed"
"DEBUG"	8044	"2020-05-14 20:12:02.137"	"Summarizing delivery result"
"DEBUG"	8044	"2020-05-14 20:12:02.137"	"Summarized delivery results"
"DEBUG"	8044	"2020-05-14 20:12:02.137"	"SD::RescheduleDelivery_"
"DEBUG"	8044	"2020-05-14 20:12:02.138"	"Retrieving retry options."
"DEBUG"	8044	"2020-05-14 20:12:02.138"	"Starting rescheduling."
"APPLICATION"	8044	"2020-05-14 20:12:02.139"	"SMTPDeliverer - Message 2334684: Message could not be delivered. Scheduling it for later delivery in 10 minutes."
"DEBUG"	8044	"2020-05-14 20:12:02.139"	"PersistentMessage::SetNextTryTime()"
"DEBUG"	7344	"2020-05-14 20:12:02.155"	"Reading messages from database."
"DEBUG"	8044	"2020-05-14 20:12:02.173"	"PersistentMessage::~SetNextTryTime()"
"DEBUG"	8044	"2020-05-14 20:12:02.175"	"Message rescheduled for later delivery."
"APPLICATION"	8044	"2020-05-14 20:12:02.175"	"SMTPDeliverer - Message 2334684: Message delivery thread completed."
"DEBUG"	7668	"2020-05-14 20:12:03.211"	"Reading messages from database."
"DEBUG"	7668	"2020-05-14 20:12:03.950"	"Reading messages from database."
"DEBUG"	7748	"2020-05-14 20:12:18.482"	"Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG"	7412	"2020-05-14 20:12:18.482"	"Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG"	7412	"2020-05-14 20:12:18.528"	"DKIM: Message passed validation."
"DEBUG"	7412	"2020-05-14 20:12:18.529"	"Spam test: SpamTestDKIM, Score: 0"
"DEBUG"	7412	"2020-05-14 20:12:18.529"	"Creating session 53"
"TCPIP"	7412	"2020-05-14 20:12:18.530"	"Connecting to 127.0.0.1:783..."
"DEBUG"	7748	"2020-05-14 20:12:18.531"	"TCP connection started for session 53"
"DEBUG"	7748	"2020-05-14 20:12:18.531"	"Sending message to SpamAssassin. Session 53, File: C:\Program Files (x86)\hMailServer\Data\{7FBD6C70-6CFE-43E4-AD88-BACD1A5F44B9}.eml"
"DEBUG"	7752	"2020-05-14 20:12:18.807"	"Creating session 54"
"TCPIP"	7752	"2020-05-14 20:12:18.808"	"TCP - 45.142.195.7 connected to 192.168.1.13:25."
"DEBUG"	7752	"2020-05-14 20:12:18.810"	"Client connection from 45.142.195.7 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7752	"2020-05-14 20:12:18.810"	"Ending session 48"
"DEBUG"	7752	"2020-05-14 20:12:22.331"	"Creating session 55"
"TCPIP"	7752	"2020-05-14 20:12:22.332"	"TCP - 45.142.195.15 connected to 192.168.1.13:25."
"DEBUG"	7752	"2020-05-14 20:12:22.334"	"Client connection from 45.142.195.15 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7752	"2020-05-14 20:12:22.334"	"Ending session 54"
"DEBUG"	7752	"2020-05-14 20:12:22.550"	"Creating session 56"
"TCPIP"	7752	"2020-05-14 20:12:22.551"	"TCP - 185.143.75.81 connected to 192.168.1.13:25."
"DEBUG"	7752	"2020-05-14 20:12:22.553"	"Client connection from 185.143.75.81 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7752	"2020-05-14 20:12:22.553"	"Ending session 55"
"DEBUG"	7344	"2020-05-14 20:12:23.577"	"Creating session 57"
"TCPIP"	7344	"2020-05-14 20:12:23.578"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7344	"2020-05-14 20:12:23.580"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7344	"2020-05-14 20:12:23.584"	"Ending session 49"
"DEBUG"	7752	"2020-05-14 20:12:24.213"	"Creating session 58"
"TCPIP"	7752	"2020-05-14 20:12:24.214"	"TCP - 40.92.21.106 connected to 192.168.1.13:25."
"DEBUG"	7752	"2020-05-14 20:12:24.220"	"TCP connection started for session 56"
"SMTPD"	7752	56	"2020-05-14 20:12:24.221"	"40.92.21.106"	"SENT: 220 softcame.com ESMTP"
"SMTPD"	7752	56	"2020-05-14 20:12:24.316"	"40.92.21.106"	"RECEIVED: EHLO NAM12-BN8-obe.outbound.protection.outlook.com"
"SMTPD"	7752	56	"2020-05-14 20:12:24.317"	"40.92.21.106"	"SENT: 250-softcame.com[nl]250-SIZE 150000000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	7668	56	"2020-05-14 20:12:24.477"	"40.92.21.106"	"RECEIVED: MAIL FROM:<Pepepizzaguerrero@outlook.com> SIZE=12966 AUTH=<>"
"TCPIP"	7668	"2020-05-14 20:12:24.546"	"DNS lookup: 106.21.92.40.zen.spamhaus.org, 0 addresses found: (none), Match: False"
"TCPIP"	7668	"2020-05-14 20:12:24.607"	"DNS lookup: 106.21.92.40.bl.spamcop.net, 0 addresses found: (none), Match: False"
"DEBUG"	7444	"2020-05-14 20:12:28.300"	"No messages to index."
"DEBUG"	7344	"2020-05-14 20:12:32.351"	"Creating session 59"
"TCPIP"	7344	"2020-05-14 20:12:32.351"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7344	"2020-05-14 20:12:32.354"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7344	"2020-05-14 20:12:32.354"	"Ending session 57"
"DEBUG"	7752	"2020-05-14 20:12:32.913"	"Creating session 60"
"TCPIP"	7752	"2020-05-14 20:12:32.914"	"TCP - 189.154.196.223 connected to 192.168.1.13:110."
"DEBUG"	7752	"2020-05-14 20:12:32.916"	"TCP connection started for session 52"
"DEBUG"	7752	"2020-05-14 20:12:33.054"	"Creating session 61"
"TCPIP"	7752	"2020-05-14 20:12:33.054"	"TCP - 189.154.196.223 connected to 192.168.1.13:110."
"DEBUG"	7752	"2020-05-14 20:12:33.056"	"TCP connection started for session 60"
"DEBUG"	7752	"2020-05-14 20:12:33.277"	"Ending session 52"
"DEBUG"	7748	"2020-05-14 20:12:33.643"	"Ending session 60"
"DEBUG"	7752	"2020-05-14 20:12:35.567"	"Creating session 62"
"TCPIP"	7752	"2020-05-14 20:12:35.568"	"TCP - 45.142.195.7 connected to 192.168.1.13:25."
"DEBUG"	7752	"2020-05-14 20:12:35.585"	"Client connection from 45.142.195.7 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7752	"2020-05-14 20:12:35.585"	"Ending session 58"
"DEBUG"	7752	"2020-05-14 20:12:37.153"	"Ending session 53"
"DEBUG"	7412	"2020-05-14 20:12:37.154"	"Spam test: SpamTestSpamAssassin, Score: 0"
"DEBUG"	7412	"2020-05-14 20:12:37.154"	"Total spam score: 0"
"DEBUG"	7412	"2020-05-14 20:12:37.155"	"Executing event OnAcceptMessage"
"DEBUG"	7412	"2020-05-14 20:12:37.158"	"Event completed"
"DEBUG"	7412	"2020-05-14 20:12:37.158"	"Saving message: {7FBD6C70-6CFE-43E4-AD88-BACD1A5F44B9}.eml"
Re: Unable to send mail to some domains
Post by mattg » 2020-05-15 04:44
SMTPD lines at the top of that log is your hMailserver receiving the message
Below what you have posted will be some SMTPC lines that show hMailserver trying to send the message on
Can you show those please
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-15 05:00
this is the entire log, by the way Im sending the mail, not receiving
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-15 05:04
this line its the connection
but I dont find the smtp connection or something.
Post by mattg » 2020-05-15 05:39
ecantu@softcame.com wrote:
2020-05-15 05:00
Yes
SMTPD shows your hmailserver RECEIVING the message (from your mail client)
There will be some SMTPC lines further down
SMTPC is your hMailserver sending the message on to the recipient's mail server (or at least the next server on the way to the recipient)
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-15 05:44
I think thats the problem I dont find any SMTPC lines, the Hm retry 3 times and then the Error message.
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-15 05:56
this is the code in the 3rd try, I'm looking the 4528
"APPLICATION"	4528	"2020-05-14 21:50:32.177"	"SMTPDeliverer - Message 2334742: Delivering message from ecantu@softcame.com to ariel.mendoza@1stcb.com. File: C:\Program Files (x86)\hMailServer\Data\{A492D2D1-8046-4B31-9F3B-F1BC7A610749}.eml"
"DEBUG"	4528	"2020-05-14 21:50:32.178"	"Applying rules"
"DEBUG"	4528	"2020-05-14 21:50:32.179"	"Performing local delivery"
"DEBUG"	4528	"2020-05-14 21:50:32.179"	"Local delivery completed"
"TCPIP"	4528	"2020-05-14 21:50:32.183"	"DNS MX lookup: 1stcb.com"
"TCPIP"	4528	"2020-05-14 21:50:32.197"	"DNS - MX Result: 2 IP addresses were found."
"DEBUG"	4528	"2020-05-14 21:50:32.197"	"Starting external delivery process. Server: smtp02.fcserv.com (65.156.191.207), Port: 25, Security: 0, User name: "
"DEBUG"	4528	"2020-05-14 21:50:32.198"	"Creating session 145"
"TCPIP"	4528	"2020-05-14 21:50:32.198"	"Connecting to 65.156.191.207:25..."
"DEBUG"	7504	"2020-05-14 21:50:32.202"	"TCP connection started for session 145"
"DEBUG"	7504	"2020-05-14 21:50:32.910"	"Creating session 146"
"TCPIP"	7504	"2020-05-14 21:50:32.911"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7504	"2020-05-14 21:50:32.913"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7504	"2020-05-14 21:50:32.913"	"Ending session 142"
"DEBUG"	7976	"2020-05-14 21:50:44.885"	"Creating session 147"
"TCPIP"	7976	"2020-05-14 21:50:44.886"	"TCP - 45.142.195.7 connected to 192.168.1.13:25."
"DEBUG"	7976	"2020-05-14 21:50:44.888"	"Client connection from 45.142.195.7 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7976	"2020-05-14 21:50:44.888"	"Ending session 144"
"DEBUG"	7976	"2020-05-14 21:50:47.928"	"Creating session 148"
"TCPIP"	7976	"2020-05-14 21:50:47.929"	"TCP - 45.142.195.15 connected to 192.168.1.13:25."
"DEBUG"	7976	"2020-05-14 21:50:47.931"	"Client connection from 45.142.195.15 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7976	"2020-05-14 21:50:47.931"	"Ending session 147"
"DEBUG"	7976	"2020-05-14 21:50:48.232"	"Creating session 149"
"TCPIP"	7976	"2020-05-14 21:50:48.233"	"TCP - 185.143.75.81 connected to 192.168.1.13:25."
"DEBUG"	7976	"2020-05-14 21:50:48.235"	"Client connection from 185.143.75.81 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7976	"2020-05-14 21:50:48.236"	"Ending session 148"
"DEBUG"	7976	"2020-05-14 21:50:49.307"	"Creating session 150"
"TCPIP"	7976	"2020-05-14 21:50:49.307"	"TCP - 141.98.80.48 connected to 192.168.1.13:25."
"DEBUG"	7976	"2020-05-14 21:50:49.309"	"Client connection from 141.98.80.48 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7976	"2020-05-14 21:50:49.310"	"Ending session 149"
"DEBUG"	7504	"2020-05-14 21:50:49.320"	"Creating session 151"
"TCPIP"	7504	"2020-05-14 21:50:49.321"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7504	"2020-05-14 21:50:49.323"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7504	"2020-05-14 21:50:49.324"	"Ending session 146"
"DEBUG"	7504	"2020-05-14 21:50:49.384"	"Creating session 152"
"TCPIP"	7504	"2020-05-14 21:50:49.384"	"TCP - 200.68.140.220 connected to 192.168.1.13:143."
"DEBUG"	7504	"2020-05-14 21:50:49.386"	"TCP connection started for session 143"
"DEBUG"	7504	"2020-05-14 21:50:57.340"	"Creating session 153"
"TCPIP"	7504	"2020-05-14 21:50:57.355"	"TCP - 189.156.59.236 connected to 192.168.1.13:110."
"DEBUG"	7504	"2020-05-14 21:50:57.358"	"TCP connection started for session 140"
"DEBUG"	7504	"2020-05-14 21:50:58.108"	"Creating session 154"
"TCPIP"	7504	"2020-05-14 21:50:58.109"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7504	"2020-05-14 21:50:58.111"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7504	"2020-05-14 21:50:58.111"	"Ending session 151"
"DEBUG"	7504	"2020-05-14 21:50:58.303"	"Ending session 140"
"DEBUG"	9028	"2020-05-14 21:50:58.335"	"No messages to index."
"DEBUG"	7976	"2020-05-14 21:51:02.236"	"The read operation failed. Bytes transferred: 0 Remote IP: 65.156.191.207, Session: 145, Code: 2, Message: End of file"
"DEBUG"	7976	"2020-05-14 21:51:02.237"	"Ending session 145"
"DEBUG"	4528	"2020-05-14 21:51:02.238"	"External delivery process completed"
"DEBUG"	4528	"2020-05-14 21:51:02.238"	"Starting external delivery process. Server: smtp01.fcserv.com (65.124.74.24), Port: 25, Security: 0, User name: "
"DEBUG"	4528	"2020-05-14 21:51:02.239"	"Creating session 155"
"TCPIP"	4528	"2020-05-14 21:51:02.239"	"Connecting to 65.124.74.24:25..."
"DEBUG"	7504	"2020-05-14 21:51:02.241"	"TCP connection started for session 155"
"DEBUG"	7504	"2020-05-14 21:51:04.588"	"Creating session 156"
"TCPIP"	7504	"2020-05-14 21:51:04.589"	"TCP - 189.237.67.151 connected to 192.168.1.13:110."
"DEBUG"	7504	"2020-05-14 21:51:04.591"	"TCP connection started for session 153"
"DEBUG"	7976	"2020-05-14 21:51:04.959"	"Reading messages from database."
"DEBUG"	7976	"2020-05-14 21:51:05.080"	"Creating session 157"
"TCPIP"	7976	"2020-05-14 21:51:05.081"	"TCP - 45.142.195.15 connected to 192.168.1.13:25."
"DEBUG"	7976	"2020-05-14 21:51:05.083"	"Client connection from 45.142.195.15 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7976	"2020-05-14 21:51:05.084"	"Ending session 150"
"DEBUG"	7504	"2020-05-14 21:51:12.354"	"Creating session 158"
"TCPIP"	7504	"2020-05-14 21:51:12.354"	"TCP - 189.202.37.138 connected to 192.168.1.13:110."
"DEBUG"	7976	"2020-05-14 21:51:12.354"	"Creating session 159"
"TCPIP"	7976	"2020-05-14 21:51:12.354"	"TCP - 189.202.37.138 connected to 192.168.1.13:143."
"DEBUG"	7504	"2020-05-14 21:51:12.354"	"TCP connection started for session 156"
"DEBUG"	7976	"2020-05-14 21:51:12.354"	"TCP connection started for session 152"
"DEBUG"	7976	"2020-05-14 21:51:14.099"	"Ending session 156"
"DEBUG"	7504	"2020-05-14 21:51:14.503"	"Creating session 160"
"TCPIP"	7504	"2020-05-14 21:51:14.503"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7504	"2020-05-14 21:51:14.505"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7504	"2020-05-14 21:51:14.511"	"Ending session 154"
"DEBUG"	7976	"2020-05-14 21:51:21.351"	"Creating session 161"
"TCPIP"	7976	"2020-05-14 21:51:21.351"	"TCP - 45.142.195.7 connected to 192.168.1.13:25."
"DEBUG"	7976	"2020-05-14 21:51:21.355"	"Client connection from 45.142.195.7 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7976	"2020-05-14 21:51:21.355"	"Ending session 157"
"DEBUG"	7504	"2020-05-14 21:51:22.594"	"Creating session 162"
"TCPIP"	7504	"2020-05-14 21:51:22.603"	"TCP - 189.154.196.223 connected to 192.168.1.13:110."
"DEBUG"	7504	"2020-05-14 21:51:22.612"	"TCP connection started for session 158"
"DEBUG"	7504	"2020-05-14 21:51:22.711"	"Creating session 163"
"TCPIP"	7504	"2020-05-14 21:51:22.712"	"TCP - 189.154.196.223 connected to 192.168.1.13:110."
"DEBUG"	7504	"2020-05-14 21:51:22.714"	"TCP connection started for session 162"
"DEBUG"	7976	"2020-05-14 21:51:23.003"	"Ending session 158"
"DEBUG"	7976	"2020-05-14 21:51:23.015"	"Creating session 164"
"TCPIP"	7976	"2020-05-14 21:51:23.016"	"TCP - 200.68.140.220 connected to 192.168.1.13:143."
"DEBUG"	7976	"2020-05-14 21:51:23.017"	"TCP connection started for session 159"
"DEBUG"	7976	"2020-05-14 21:51:23.290"	"Ending session 162"
"DEBUG"	7504	"2020-05-14 21:51:23.319"	"Creating session 165"
"TCPIP"	7504	"2020-05-14 21:51:23.319"	"TCP - 45.142.195.8 connected to 192.168.1.13:587."
"DEBUG"	7504	"2020-05-14 21:51:23.322"	"Client connection from 45.142.195.8 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7504	"2020-05-14 21:51:23.322"	"Ending session 160"
"DEBUG"	7976	"2020-05-14 21:51:26.041"	"Creating session 166"
"TCPIP"	7976	"2020-05-14 21:51:26.042"	"TCP - 200.68.140.220 connected to 192.168.1.13:143."
"DEBUG"	7976	"2020-05-14 21:51:26.046"	"TCP connection started for session 164"
"DEBUG"	7976	"2020-05-14 21:51:27.698"	"Creating session 167"
"TCPIP"	7976	"2020-05-14 21:51:27.698"	"TCP - 185.143.75.81 connected to 192.168.1.13:25."
"DEBUG"	7976	"2020-05-14 21:51:27.700"	"Client connection from 185.143.75.81 was not accepted. Blocked either by IP range or by connection limit."
"DEBUG"	7976	"2020-05-14 21:51:27.700"	"Ending session 161"
"DEBUG"	7504	"2020-05-14 21:51:32.259"	"The read operation failed. Bytes transferred: 0 Remote IP: 65.124.74.24, Session: 155, Code: 2, Message: End of file"
"DEBUG"	7504	"2020-05-14 21:51:32.259"	"Ending session 155"
"DEBUG"	4528	"2020-05-14 21:51:32.259"	"External delivery process completed"
"DEBUG"	4528	"2020-05-14 21:51:32.259"	"Summarizing delivery result"
"DEBUG"	4528	"2020-05-14 21:51:32.263"	"Summarized delivery results"
"DEBUG"	4528	"2020-05-14 21:51:32.268"	"SD::RescheduleDelivery_"
"DEBUG"	4528	"2020-05-14 21:51:32.271"	"Retrieving retry options."
"DEBUG"	4528	"2020-05-14 21:51:32.272"	"Aborting delivery."
"APPLICATION"	4528	"2020-05-14 21:51:32.272"	"SMTPDeliverer - Message 2334742: Message could not be delivered. Returning error log to sender."
"DEBUG"	4528	"2020-05-14 21:51:32.272"	"AWStats::LogDeliveryFailure"
"DEBUG"	4528	"2020-05-14 21:51:32.274"	"AWStats::LogDeliveryFailure"
"DEBUG"	4528	"2020-05-14 21:51:32.274"	"Message not rescheduled for later delivery."
"DEBUG"	4528	"2020-05-14 21:51:32.275"	"SD::SubmitErrorLog_"
"DEBUG"	4528	"2020-05-14 21:51:32.291"	"Saving message: {09A306AA-0672-43E8-B6DD-025232972287}.eml"
"DEBUG"	4528	"2020-05-14 21:51:32.329"	"SD::~SubmitErrorLog_"
"DEBUG"	4528	"2020-05-14 21:51:32.330"	"Deleting message"
"DEBUG"	4528	"2020-05-14 21:51:32.349"	"Deleting message file."
"APPLICATION"	4528	"2020-05-14 21:51:32.350"	"SMTPDeliverer - Message 2334742: Message delivery thread completed."
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-15 06:06
I made some test with some smtp test sites and have this result, I dont know how gmail can send the mail and this other sites dont.
Post by mattg » 2020-05-16 09:22
The IP addresses shown in those images doesn't match what I get https://intodns.com/1stcb.com
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-19 23:12
Anny sugestion?
Post by palinka » 2020-05-19 23:32
2020-05-15 06:06
Is this you?
Pref Hostname          IP Address     ISP
10   smtp01.fcserv.com 65.124.74.24   CenturyLink Communications, LLC (AS209)
10   smtp02.fcserv.com 65.156.191.207 CenturyLink Communications, LLC (AS209)
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-19 23:36
The problem is I try to send the mail and got this error.
My Hmailserver dont send the mail. but only with this domain (1stcb.com)
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-19 23:37
The ip are the mx record of that domain. but Im the sender not the receiver.
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-19 23:41
This is a new test and this are the results, but if I send the mail from Gmail its delivered.
Post by mattg » 2020-05-20 09:41
2020-05-19 23:36
Then surely the problem is that ONE domain, not your hmailserver
ecantu@softcame.com
Post by ecantu@softcame.com » 2020-05-20 17:02
I think the same, but why the mail can be sended from Gmail and from Hmail not?
Post by palinka » 2020-05-20 19:01
I don't think its limited to that one domain.
Maybe antivirus is interfering.
