Is there a logfile for antispam results :?:
brutzler
Post by brutzler » 2020-05-17 20:15
I have configured antispam on my hmailserver (5.6.7-B2425)
I defined a rule, that spam-emails are sent to a different email if the ranking is too high.
As the rule did some mails, I know, that it is basicly working.
But can I see somewhere a protocol of the work of antispam? I searched the logfiles, but without success.
BTW: Using hMailserver Administrator, i see in the menu-tree a red circle with a crossed line at the folder of Antispam. Is this ok?
Looks like the program wants to tell me, that antispam is not active...
regards/brutzler
Re: Is there a logfile for antispam results :?:
Post by palinka » 2020-05-17 20:40
What exactly would you like to see?
brutzler
Post by brutzler » 2020-05-17 22:04
I would like to see infos from the spam-scanned mails:
- what spam ranking did they get
- what action did hMailserver with the Mails.
Because it looks like, that hmailserver (I use it for POP all my email-accounts from my provider to my local (h)mail-server with IMAP-accounts) does not pop any more all emails since I activated antispam.
Post by palinka » 2020-05-17 22:41
You could log stuff to the event log. Put this code in OnAcceptMessage in EventHandlers.vbs:
	REM - Log spam reasons
	Dim Reason1, Reason2, Reason3, Reason4, Reason5, Reason6, Reason7
	If (oMessage.HeaderValue("X-hMailServer-Spam") = "YES") Then
		EventLog.Write ("########   SPAM RECEIVED   ########")
		EventLog.Write ("Total Spam Score   : " & oMessage.HeaderValue("X-hMailServer-Reason-Score"))
		EventLog.Write ("Spam From          : " & oMessage.From)
		EventLog.Write ("Spam Envelope From : " & oMessage.FromAddress
		EventLog.Write ("Spam To            : " & oMessage.Recipients(0).Address)
		If (oMessage.HeaderValue("X-hMailServer-Reason-0") <> "") Then EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-0"))
		If (oMessage.HeaderValue("X-hMailServer-Reason-1") <> "") Then EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-1"))
		If (oMessage.HeaderValue("X-hMailServer-Reason-2") <> "") Then EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-2"))
		If (oMessage.HeaderValue("X-hMailServer-Reason-3") <> "") Then EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-3"))
		If (oMessage.HeaderValue("X-hMailServer-Reason-4") <> "") Then EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-4"))
		If (oMessage.HeaderValue("X-hMailServer-Reason-5") <> "") Then EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-5"))
		If (oMessage.HeaderValue("X-hMailServer-Reason-6") <> "") Then EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-6"))
		If (oMessage.HeaderValue("X-hMailServer-Reason-7") <> "") Then EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-7"))
Or you could set up a custom log.
brutzler
Post by brutzler » 2020-05-17 22:55
OK
thanks for sharing the code.
I tried my best:
Searching for the file:
-> C:\Program Files (x86)\hMailServer\Events\EventHandlers.vbs
Its the right one, or?
Open it with notepad++ in admin mode, copy the lines from you:
'   Sub OnAcceptMessage(oClient, oMessage)
'   End Sub
Then going to scripts, activate them and reload the scripts.
After this I get an error-log:
"ERROR"	10172	"2020-05-17 22:48:33.043"	"Script Error: Source: Kompilierungsfehler in Microsoft VBScript - Error: 800A03EE - Description: ')' erwartet - Line: 14 Column: 64 - Code: 		EventLog.Write ("Spam Envelope From : " & oMessage.FromAddress"
"ERROR"	10172	"2020-05-17 22:48:33.046"	"Severity: 2 (High), Code: HM5016, Source: ScriptServer::LoadScripts, Description: File: C:\Program Files (x86)\hMailServer\Events\EventHandlers.vbs[nl]Script Error: Source: Kompilierungsfehler in Microsoft VBScript - Error: 800A03EE - Description: ')' erwartet - Line: 14 Column: 64 - Code: 		EventLog.Write ("Spam Envelope From : " & oMessage.FromAddress"
Oh, i see, there is a bracket missing at the end. I add the bracket and repeat the script loading:
Next error message:
"ERROR"	5756	"2020-05-17 22:53:09.637"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 10 Column: 1 - Code: (null)"
"ERROR"	5756	"2020-05-17 22:53:09.637"	"Severity: 2 (High), Code: HM5016, Source: ScriptServer::LoadScripts, Description: File: C:\Program Files (x86)\hMailServer\Events\EventHandlers.vbs[nl]Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 10 Column: 1 - Code: (null)"
for this I have no solution
brutzler
Post by brutzler » 2020-05-17 23:01
oh, me fool..
should remove the comment marks in front of the sub...
Now there is no error log on reloading the scripts.
But which sort of protocol has to be activated for the events?
- Application
- SMTP
- POP3
- IMAP
- TCP/IP
- Debug
- AWstats
Post by palinka » 2020-05-18 00:18
brutzler wrote:
2020-05-17 23:01
oh, me fool..
Yes. 👍
- Application
- SMTP
- POP3
- IMAP
- TCP/IP
- Debug
- AWstats
None. OnAcceptMessage is a scripting trigger so it will do whatever you tell it to do.
brutzler
Post by brutzler » 2020-05-18 01:55
Hmmm..
I thought your script should write into a logfile, right?
But I do not find any :-(
Where (Which folder) should it be, and what should be the filename?
Post by mattg » 2020-05-18 03:39
That script writes to the hMailserver eventlog
typically
C:\Program Files (x86)\hMailServer\logs\hmailserver_events.log
But you can change that
brutzler
Post by brutzler » 2020-05-18 08:06
I did not change anything regarding path/filename.
But there is no hmailserver_events.log
Scripts are activated and syntaxcheck is ok.
Is "reload scripts" enough, or do I have to restart the whole hmailserver-service?
Post by palinka » 2020-05-18 09:35
Reload is enough.
Hmailserver won't create the log until it has a need to. If hmailserver_events.log doesn't exist yet, that means you haven't received any spam since you enabled the script. Or, more precisely, hmailserver has not scored any messages as spam yet. :D
No spam. That's a nice lifestyle. I like that. It makes me think of sipping an exotic drink from a coconut shell on a tropical beach. :mrgreen:
brutzler
Post by brutzler » 2020-05-18 11:14
When will this script be activated?
The script is called "Sub OnAcceptMessage(oClient, oMessage)"
In my opinion it is executed on every received email. Or not?
Because I thought the same and added a line at the beginning of the sub, where hmailserver should write a dummytext into the logfile.
EventLog.Write ("########   Mail RECEIVED   ########")  <===================================== added by brutzler
And there is still no logfile.
Post by palinka » 2020-05-18 11:28
brutzler wrote:
2020-05-18 11:14
Correct. Actually, all messages.
That should write to the event log on every message.
If you go to the settings for scripts, do you have VBScript selected?
Are you receiving mail? Try sending yourself a message.
Also, I'm not sure if this affects the event log or not, but do you have logging enabled?
Post by jimimaseye » 2020-05-18 11:48
No it won't work because if this:
brutzler wrote:
2020-05-17 22:04
Because it looks like, that hmailserver (I use it for POP all my email-accounts from my provider....
That sub section is only for direct smtp delivered messages.
You should try moving it to the 'onexternaldownload' section.
brutzler
Post by brutzler » 2020-05-18 12:02
OK, transferring the code from "OnAcceptMessage" to "OnExternalAccount" I get my added line for every mail in the expected file.
(After this i removed this testline.)
But the code from palinka is not working.
I get an error message:
"ERROR"	9332	"2020-05-18 11:55:12.702"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 31 Column: 1 - Code: (null)"
And line 31 is the following:
   Sub OnExternalAccountDownload(oFetchAccount, oMessage, sRemoteUID)
>>line31>>	If (oMessage.HeaderValue("X-hMailServer-Spam") = "YES") Then
		EventLog.Write ("Spam Envelope From : " & oMessage.FromAddress)
BTW jimimaseye:
onexternaldownload == OnExternalAccountDownload???
Post by jimimaseye » 2020-05-18 12:15
brutzler wrote:
2020-05-18 12:02
jimimaseye:
Yes.
Do a test. Remove the IF condition clause just to see if you get logging. Post the entire contents of your script file please.
More reference to subs: https://www.hmailserver.com/documentati ... ce_scripts
brutzler
Post by brutzler » 2020-05-18 12:46
the script is logging in deed:
out of the hmailserver_event.log
9280	"2020-05-18 12:04:22.508"	"########   SPAM RECEIVED   ########"
9280	"2020-05-18 12:04:22.510"	"Total Spam Score   : 10"
9280	"2020-05-18 12:04:22.511"	"Spam From          : Hermenegild <hermenegildnphnxjp@papernom.com>"
9280	"2020-05-18 12:04:22.512"	"Spam Envelope From : hermenegildnphnxjp@papernom.com"
9280	"2020-05-18 12:04:22.513"	"Spam To            : xxxx@yyyyyyyyyy.de"
9280	"2020-05-18 12:04:22.517"	"Spam Reason        : Sender domain does not have any MX records. - (Score: 2)"
9280	"2020-05-18 12:04:22.518"	"Spam Reason        : Rejected by SURBL. - (Score: 3)"
9280	"2020-05-18 12:04:22.519"	"Spam Reason        : Rejected by DKIM. - (Score: 5)"
That is what I expected.
But sometimes I have some entries in the "ERROR_hmailserver_2020-05-18.log"
"ERROR"	9332	"2020-05-18 12:01:18.717"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 31 Column: 1 - Code: (null)"
Thats what I showed you in the last posts.
Until now, I could not figure out, when and why.
Runtime Error means for me, that something is wrong in the code. But when I look at the hmailserver_event.log, the code looks working.
Here the entire script:
'   End Sub
'   Sub OnSMTPData(oClient, oMessage)
'   End Sub
'   End Sub
'   End Sub
'   End Sub
'   End Sub
'   Sub OnBackupCompleted()
'   End Sub
'   Sub OnError(iSeverity, iCode, sSource, sDescription)
'   End Sub
'   Sub OnDeliveryFailed(oMessage, sRecipient, sErrorMessage)
'   End Sub
Post by SorenR » 2020-05-18 14:08
If you add a line
On Error Resume Next
just after the line "REM - Log spam reasons" the error will magically go away - it will not solve the issue, but the error will go away.
There is something fundamentally wrong somewhere and I'm wondering if the problem is oMessage not being initialised by hMailServer so it becomes an empty object.
Post by jimimaseye » 2020-05-18 14:40
2020-05-18 14:08
+1
And if true it's likely that the testing of the headers (as initially required) will not be possible in this section.
Post by palinka » 2020-05-18 14:44
2020-05-18 14:40
2020-05-18 14:08
+1
What could cause this? I don't think any configuration error could be the cause.
Post by jimimaseye » 2020-05-18 15:13
I think an error in hmailserver itself although I'm pretty sure a similar solution was proposed and adapted a couple of weeks ago for someone else. Maybe someone has an account that uses external downloads to do a test of the omessage object. Also perhaps test against 5.7.
Post by SorenR » 2020-05-18 15:45
I would not be surprised if oMessage only get populated when there are mails waiting...
Looking at events.cpp I came across this...
         if (pMessage)
            sEventCaller.Format(_T("OnExternalAccountDownload(HMAILSERVER_FETCHACCOUNT, HMAILSERVER_MESSAGE, \"%s\")"), sRemoteUIDCopy.c_str());
         else
            sEventCaller.Format(_T("OnExternalAccountDownload(HMAILSERVER_FETCHACCOUNT, Nothing, \"%s\")"), sRemoteUIDCopy.c_str());
so ... maybe ... "If oMessage Is Nothing Then Exit Sub" ??
https://developer.rhino3d.com/guides/rh ... mpty-null/
Post by jimimaseye » 2020-05-18 17:51
Should work.
I use this method in the diag script and, funnily enough, I have just had to change it for another occurence of this method (line 1138).
so
   If not oMessage is Nothing and oMessage.HeaderValue("X-hMailServer-Spam") = "YES" Then
EDIT: Come to think of it I have encountered this very issue before with 'OnExternalAccountDownload' and catered for it with this method in my production scripts. But forgot.
Post by palinka » 2020-05-18 18:15
Can delete this line too.
Its a remnant from where I copied it.
brutzler
Post by brutzler » 2020-05-18 19:30
hmailserver with the "on error resume next" -line did now run for 8h.
Thats the result of the hmailserver_events.log
Very often I have only the "SPAM RECEIVED" -line:
To say: the log-file has atm ~ 12000 lines. And there are 50 detailed spam messages. The rest is only the "SPAM RECEIVED" -line
2856	"2020-05-18 15:41:56.016"	"########   SPAM RECEIVED   ########"
2856	"2020-05-18 15:41:56.031"	"########   SPAM RECEIVED   ########"
2856	"2020-05-18 15:41:56.047"	"########   SPAM RECEIVED   ########"
9280	"2020-05-18 15:41:56.250"	"########   SPAM RECEIVED   ########"
9280	"2020-05-18 15:41:56.250"	"Total Spam Score   : 10"
9280	"2020-05-18 15:41:56.250"	"Spam From          : Gisbert <gisbertetthffk@lawapass.com>"
9280	"2020-05-18 15:41:56.250"	"Spam Envelope From : gisbertetthffk@lawapass.com"
9280	"2020-05-18 15:41:56.250"	"Spam To            : xxxxx@yyyyyyyy.de"
9280	"2020-05-18 15:41:56.250"	"Spam Reason        : Rejected by SURBL. - (Score: 3)"
9280	"2020-05-18 15:41:56.250"	"Spam Reason        : Rejected by DKIM. - (Score: 5)"
9280	"2020-05-18 15:41:56.250"	"Spam Reason        : Sender domain does not have any MX records. - (Score: 2)"
4328	"2020-05-18 15:43:57.665"	"########   SPAM RECEIVED   ########"
4328	"2020-05-18 15:43:57.680"	"########   SPAM RECEIVED   ########"
4328	"2020-05-18 15:43:57.696"	"########   SPAM RECEIVED   ########"
4328	"2020-05-18 15:43:57.712"	"########   SPAM RECEIVED   ########"
4328	"2020-05-18 15:43:57.727"	"########   SPAM RECEIVED   ########"
9332	"2020-05-18 15:44:58.692"	"########   SPAM RECEIVED   ########"
9332	"2020-05-18 15:44:58.708"	"########   SPAM RECEIVED   ########"
9332	"2020-05-18 15:44:58.723"	"########   SPAM RECEIVED   ########"
9332	"2020-05-18 15:44:58.739"	"########   SPAM RECEIVED   ########"
You think, I should modify this line too?
Post by jimimaseye » 2020-05-18 19:38
I posted the code you should use in my last post.
Post by palinka » 2020-05-18 19:38
Yes.
brutzler
Post by brutzler » 2020-05-18 20:44
2020-05-18 19:38
I tried and again the error messages with the runtime error:
"ERROR"	2060	"2020-05-18 20:42:51.670"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 31 Column: 3 - Code: (null)"
Error messages accur in "ERROR_hmailserver_2020-05-18.log" as soon as i load the script and on every POP-run
Post by jimimaseye » 2020-05-18 21:27
Show the script please.
Also did you 'reload' the script after changing it?
brutzler
Post by brutzler » 2020-05-18 21:35
I copied it directly from your post.
And YES, I reloaded the script.
   'If (oMessage.HeaderValue("X-hMailServer-Spam") = "YES") Then
brutzler
Post by brutzler » 2020-05-18 21:49
Hey,
just one idea:
As I told you, I make POP3 from my external provider.
Just right now on testing the Anti-Spam and not to lose any important email, I configured the external account that the emails are not deleted at once, but stay for one day.
I see, in the "normal" log, that the external account tells me, there are 12 "old" emails, and after this I get 12 of the error messages.
Maybe that is the reason?
"DEBUG"	8840	"2020-05-18 21:37:45.300"	"Adding task ExternalFetchTask to work queue External fetch queue"
"DEBUG"	3396	"2020-05-18 21:37:45.300"	"Executing task ExternalFetchTask in work queue External fetch queue"
"DEBUG"	3396	"2020-05-18 21:37:45.300"	"Retrieving messages from external account xxx@yyy.de"
"DEBUG"	3396	"2020-05-18 21:37:45.300"	"Creating session 1189"
"DEBUG"	9632	"2020-05-18 21:37:45.316"	"TCP connection started for session 1189"
"DEBUG"	9632	"2020-05-18 21:37:45.316"	"Performing SSL/TLS handshake for session 1189. Verify certificate: True, Expected remote host name: pop.provider.de"
"DEBUG"	9632	"2020-05-18 21:37:45.347"	"Certificate verification succeeded for session 1189."
"POP3C"	9632	1189	"2020-05-18 21:37:45.597"	"222.222.222.111"	"RECEIVED: +OK POP server ready H mieue153 1M41Sw-1jalZ40zrs-045kD7"
"POP3C"	9632	1189	"2020-05-18 21:37:45.597"	"222.222.222.111"	"SENT: USER xxx@yyy.de"
"POP3C"	9276	1189	"2020-05-18 21:37:45.612"	"222.222.222.111"	"RECEIVED: +OK password required for user "xxx@yyy.de""
"POP3C"	9276	1189	"2020-05-18 21:37:45.612"	"222.222.222.111"	"SENT: ***"
"POP3C"	9276	1189	"2020-05-18 21:37:45.644"	"222.222.222.111"	"RECEIVED: +OK mailbox "xxx@yyy.de" has 12 messages (1310985 octets) H mieue153"
"POP3C"	9276	1189	"2020-05-18 21:37:45.644"	"222.222.222.111"	"SENT: UIDL"
"POP3C"	2060	1189	"2020-05-18 21:37:45.659"	"222.222.222.111"	"RECEIVED: +OK[nl]1 1M2vjm-1jdtb1jDw-003KDanl]2 1MWil6-1jYQX0cSO-00X7Ei[nl]3 1Mog5B-1jHG373VYP-00p3OK[nl]4 1MJmvv-1jLP5J09sH-00KAwN[nl]5 1MMFRG-1jJU7Q3aaM-00JKtM[nl]6 1Mhks2-1j5xhW00dU-0dk0i[nl]7 1MfIAH-1j7sW0zNL-00gm1M[nl]8 1MEn2D-1jpm0W0Tz1-00GtB[nl]9 1M8A4J1jekRK0Zv-005Ij[nl]10 1MKawm-1jME6c3YWS00KvTn[nl]11 1N3smG-1isF63Upc-00zrSa[nl]12 1MP0nc-1jQt9F0ypI-00PJAi[nl]."
"DEBUG"	2060	"2020-05-18 21:37:45.659"	"Executing event OnExternalAccountDownload"
"ERROR"	2060	"2020-05-18 21:37:45.659"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 31 Column: 3 - Code: (null)"
"DEBUG"	2060	"2020-05-18 21:37:45.675"	"Event completed"
"DEBUG"	2060	"2020-05-18 21:37:45.675"	"Executing event OnExternalAccountDownload"
"ERROR"	2060	"2020-05-18 21:37:45.675"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 31 Column: 3 - Code: (null)"
"DEBUG"	2060	"2020-05-18 21:37:45.690"	"Event completed"
"DEBUG"	2060	"2020-05-18 21:37:45.690"	"Executing event OnExternalAccountDownload"
"ERROR"	2060	"2020-05-18 21:37:45.690"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 31 Column: 3 - Code: (null)"
"DEBUG"	2060	"2020-05-18 21:37:45.706"	"Event completed"
"DEBUG"	2060	"2020-05-18 21:37:45.706"	"Executing event OnExternalAccountDownload"
"ERROR"	2060	"2020-05-18 21:37:45.706"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 31 Column: 3 - Code: (null)"
"ERROR"	2060	"2020-05-18 21:37:45.722"	"Script Error: Source: Laufzeitfehler in Microsoft VBScript - Error: 800A01A8 - Description: Objekt erforderlich: 'oMessage' - Line: 31 Column: 3 - Code: (null)"
"DEBUG"	2060	"2020-05-18 21:37:45.722"	"Event completed"
"DEBUG"	2060	"2020-05-18 21:37:45.722"	"Executing event OnExternalAccountDownload"
"DEBUG"	2060	"2020-05-18 21:37:45.737"	"Event completed"
"DEBUG"	2060	"2020-05-18 21:37:45.737"	"POP3 External Account: Normal QUIT."
"POP3C"	2060	1189	"2020-05-18 21:37:45.737"	"222.222.222.111"	"SENT: QUIT"
"POP3C"	9384	1189	"2020-05-18 21:37:45.753"	"222.222.222.111"	"RECEIVED: +OK POP server signing off"
"DEBUG"	9384	"2020-05-18 21:37:45.753"	"Ending session 1189"
"DEBUG"	3396	"2020-05-18 21:37:45.753"	"Completed retrieval of messages from external account."
Post by palinka » 2020-05-18 21:55
2020-05-18 15:45
         if (pMessage)
         else
brutzler wrote:
2020-05-18 21:49
Hey,
just one idea:
Sounds about right. Try "If oMessage Is Nothing Then Exit Sub".
Try this
		Exit Sub
	Else If oMessage.HeaderValue("X-hMailServer-Spam") = "YES" Then
brutzler
Post by brutzler » 2020-05-18 22:01
2020-05-18 21:55
Already added..
But imho, this is then enough, or? No need for the marked line.
   'If not oMessage is Nothing and oMessage.HeaderValue("X-hMailServer-Spam") = "YES" Then   <-------------------------------------
waiting for results... :-)
Post by palinka » 2020-05-18 22:03
brutzler wrote:
2020-05-18 22:01
2020-05-18 21:55
Already added..
I edited my post while you were posting - see my last post.
brutzler
Post by brutzler » 2020-05-18 22:05
I see.... :lol:
OK, you have an additional "else"
Post by jimimaseye » 2020-05-18 22:20
Try this:
   If not oMessage is Nothing then
	END IF
brutzler
Post by brutzler » 2020-05-18 22:21
2020-05-18 21:55
Try this
		Exit Sub
Compiling error. :mrgreen:
I suggest a second "End If"
Post by palinka » 2020-05-18 22:38
brutzler wrote:
2020-05-18 22:21
2020-05-18 21:55
Try this
		Exit Sub
No, it's ElseIf. I always get ElseIf and Else If confused.
brutzler
Post by brutzler » 2020-05-18 22:49
imho a lot of possibilities.
But looks good now.
Log working as expected. and no error messages.
Finaly question for my interest:
Is there any documentation for all possible sub-classes of 'oMessage'
I have seen the following:
- oMessage.HeaderValue
- oMessage.From
- oMessage.FromAddress
- oMessage.Recipients(0).Address
Think there is more....
BTW:
:!: :!: :!: Big Thanks for your help :!: :!: :!:
Post by jimimaseye » 2020-05-18 22:51
Post by palinka » 2020-05-18 22:55
You can probably start with the link at the top that says "documentation". :lol:
Post by mattg » 2020-05-19 01:05
2020-05-18 15:45
Yes correct
And also once for EACH message waiting
Post by jimimaseye » 2020-05-19 01:27
Yes. As previously determined.
[quoteoMessage - The message which has been downloaded. If the message has already been downloaded before, this parameter will be Nothing / Null][/quote]
https://www.hmailserver.com/documentati ... ntdownload
Post by SorenR » 2020-05-19 10:50
Just had a weird experience...
In the beginning of my EventHandlers.vbs I set several constants, one is named "PASSWORD" and is the password of my Amin user for when doing "Call m_oApp.Authenticate(ADMIN, PASSWORD)"...
I changed my GMail account today from automatic forward to allowing POP access and created an "External account" on my account.
When there is new mail in my GMail I get this:
"ERROR"	1432	"2020-05-19 10:25:54.669"	"Script Error: Source: Microsoft VBScript runtime error - Error: 800A0411 - Description: Name redefined: 'PASSWORD' - Line: 11 Column: 0 - Code: (null)"
So I did a Search/Replace All in my script changing PASSWORD to PASSWD ...
The error is now gone ... (o)(O) ... WTF ??? hMailServer (RvdH+) 5.6.8-B2505.27
Post by SorenR » 2020-05-19 12:32
Ok, the PASSWORD problem is now verified by this code snippet
There is NO "Dim password" anywhere in my script!
    '   Any messages?
        Exit Sub
        If Not IsEmpty(password) Then EventLog.Write("FetchAccount=" & oFetchAccount.Username & " Password=" & password)
Output is the email address and the password (!!) so the variable "password" is equal to "oFetchAccount.Password" ... Hmm ... Am I missing something?
Post by SorenR » 2020-05-19 13:26
Anyways - my script.
    Dim i, Done, strTo, strOriginalTo
    '   Safeguard ON ;-)
    Rem On Error Resume Next
    '   Any messages?
    '   Got SPAM?
        EventLog.Write ("Spam (Header) From            : " & oMessage.From)
        EventLog.Write ("Spam (Header) To              : " & oMessage.To)
        EventLog.Write ("Spam (Header) Cc              : " & oMessage.Cc)
        '   Extract Envelope addressing = SMTP conversation, non-spoofable.
            If (i = 0) Then
                strTo = oMessage.Recipients(i).Address
                strOriginalTo = oMessage.Recipients(i).OriginalAddress
                strTo = strTo & ", " & oMessage.Recipients(i).Address
                strOriginalTo = strOriginalTo & ", " & oMessage.Recipients(i).OriginalAddress
        EventLog.Write ("Spam (Envelope) From          : " & oMessage.FromAddress)
        EventLog.Write ("Spam (Envelope) To            : " & strTo)
        EventLog.Write ("Spam (Envelope) To (Original) : " & strOriginalTo)
        '   List all results of hMailServer SPAM detections, 0 to howevermanydefined
        i = 1 : Done = False
        Do Until Done
            If (oMessage.HeaderValue("X-hMailServer-Reason-" & i) = "") Then Exit Do
            EventLog.Write ("Spam Reason        : " & oMessage.HeaderValue("X-hMailServer-Reason-" & i))
            i = i + 1
            '   Failsafe ;-)
            If i = 20 Then Done = True
        Loop
    '   Safeguard OFF ;-)
    Rem On Error GoTo 0
Post by palinka » 2020-05-19 14:51
2020-05-19 12:32
Interesting. A new toy to play with. :D
