Install hMailserver with mysql on a different port
RogerK
Post by RogerK » 2020-05-21 16:02
Apologies for this basic question, I have searched through discussions and documentation
for some time, but without success.
I need to install hMailserver with mySQL running on a different port from 3066 (for complex reasons)
The normal installation procedure fails at the point where a database connection is attempted
Is there a workaround for this. I would be happy to create the external database first if that helps/
Many thanks
Re: Install hMailserver with mysql on a different port
Post by Dravion » 2020-05-21 17:04
Change it after Installation:
In hMailServer.INI
Port=1234
RogerK
Post by RogerK » 2020-05-21 17:25
Thanks a lot, Dravion, that has moved me on a little.
But now when I try to connect through the Admin console, there is an error
message - cannot find the hmailserver database - because this has not been
configured yet with its own password etc.
I need to make the port change earlier on somehow
Post by mattg » 2020-05-21 17:53
If you have data back it up - select all options including compression
Then re-run the hamilserver installer with the .ini file changed
It SHOULD just install a blank database if hmailserver.ini also has correct credentials for MYSQL in it
RogerK
Post by RogerK » 2020-05-21 19:38
More progress, I started afresh, I think an earlier version of the MySQL installer may have confused
matters, so I deleted that too.
Now I go through the hMailer database screens ok,
Then Finalising Installation - -please wait whilst the setup performs post-installation
tasks.
Initialising hMailserver database ...
Bar progresses to about 60% complete, then the process hangs
Looking at mysql, I see the hMailserver database and a "tables" entry, but no tables created
There is no data in the tables that matters. I have another server with hMailserver running ok,
is it worth trying to populate the tables with the contents of this?
Post by mattg » 2020-05-22 00:57
No you can't create the tables - hMailserver does that
Sounds like permissions issue on the remote MySQL database
If you want to see the sql and test the commands
./hMailserver/DBScripts/
but you should let hMailserver 'make' the tables for real
