HMailserver - Move Database
LVTS
Post by LVTS » 2020-05-21 18:26
Hello there,
I wanted to move my HMailserver database to SQL. I opened the Database Set-up application and filled out the appropiate information but at the final step I receive this error message:
Starting task...
Please wait while updating database settings...
Error:
The MySQL client (libmysql.dll, 32 bit) could not be loaded.
hMailServer needs this file to be able to connect to MySQL.
The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.
Path: C:\Program Files (x86)\hMailServer\Bin\libmysql.dll
Does anyone known where I can obtain a clean version of the libmysql.dll file? So I can complete this process?
Many Thanks.
Re: HMailserver - Move Database
Post by palinka » 2020-05-21 18:59
Its not included so you have to get it from your database provider. For example, I'm using MariaDB, so I looked up my version, then went to MariaDB's downloads section, downloaded the zip version of MariaDB, opened the zip, found and extracted libmysql.dll to hmailserver's bin folder.
LVTS
Post by LVTS » 2020-05-21 19:12
Hi there,
Thank you for your reply. I have downloaded the ZIP install for mySQL and found the file. I put the file into the bin folder but I am still getting the same message.
Many Thanks.
Post by Dravion » 2020-05-21 21:34
You need the 32-Bit variant of libmysql.dll v5.7.30
and you need MySQL 8.x to allow legacy Connection.
LVTS
Post by LVTS » 2020-05-21 22:35
According to phpMyAdmin I am using Server version: 8.0.20 - MySQL Community Server - GPL.
I don't know if I am looking in the wrong place but I can't find a 32bit version of MySQL Community Server 8.0.20 on the website.
Post by mattg » 2020-05-22 01:05
I think (not certain) that the earlier version of MySQL ZIPs for 32 bit contain a version of the dll that works with the higher version MySQL
Or you can install the 32 MSI of MySQL, that creates all of the file
Some of us are also using 64 bit versions of hMailserver, but these are ALPHA versions really
Virinum
Post by Virinum » 2020-05-22 02:29
LVTS
Post by LVTS » 2020-05-22 07:59
Thanks for your reply. I downloaded the file and that error went away but we seem to have a big problem now.... I am getting this error:
Starting task...
Settings updated.
Restarting server...
Database version could not be detected.
And now no users are able to login to the server! Upon futher looking I can see that no files were transfered to the SQL database, it is empty. Futhermore I can no longer log-in to the local administration program, I am receiving this message:
I have run the dbupdater.exe file but I immediatley receive this error:
The Hmailserver error log was updated with the following new errors:
"ERROR"	14428	"2020-05-22 06:56:41.935"	"Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'Task-AsynchronousTask'"
"ERROR"	14428	"2020-05-22 06:56:42.352"	"Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2020-05-22 065641_{E11994F2-E89D-4C25-8D17-8450C0BA8262}.dmp"
"ERROR"	22884	"2020-05-22 06:57:32.476"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: MySQL: Table 'hmailserver.hm_dbversion' doesn't exist (Additional info: select * from hm_dbversion)"
"ERROR"	22884	"2020-05-22 06:57:32.478"	"Severity: 1 (Critical), Code: HM5010, Source: Application::OnDatabaseConnected, Description: Database version could not be detected."
"ERROR"	22884	"2020-05-22 06:57:49.388"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: MySQL: Table 'hmailserver.hm_dbversion' doesn't exist (Additional info: select * from hm_dbversion)"
"ERROR"	22884	"2020-05-22 06:57:49.389"	"Severity: 1 (Critical), Code: HM5010, Source: Application::OnDatabaseConnected, Description: Database version could not be detected."
"ERROR"	22884	"2020-05-22 06:59:43.479"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: MySQL: Table 'hmailserver.hm_dbversion' doesn't exist (Additional info: select * from hm_dbversion)"
"ERROR"	22884	"2020-05-22 06:59:43.480"	"Severity: 1 (Critical), Code: HM5010, Source: Application::OnDatabaseConnected, Description: Database version could not be detected."
"ERROR"	8620	"2020-05-22 07:01:13.434"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: MySQL: Table 'hmailserver.hm_dbversion' doesn't exist (Additional info: select * from hm_dbversion)"
"ERROR"	8620	"2020-05-22 07:01:13.435"	"Severity: 1 (Critical), Code: HM5010, Source: Application::OnDatabaseConnected, Description: Database version could not be detected."
"ERROR"	10752	"2020-05-22 07:01:39.627"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: MySQL: Table 'hmailserver.hm_dbversion' doesn't exist (Additional info: select * from hm_dbversion)"
"ERROR"	10752	"2020-05-22 07:01:39.635"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: MySQL: Table 'hmailserver.hm_dbversion' doesn't exist (Additional info: select * from hm_dbversion)"
"ERROR"	10752	"2020-05-22 07:04:07.461"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: MySQL: Table 'hmailserver.hm_dbversion' doesn't exist (Additional info: select * from hm_dbversion)"
"ERROR"	10752	"2020-05-22 07:04:07.470"	"Severity: 2 (High), Code: HM5033, Source: DALRecordset::Open, Description: MySQL: Table 'hmailserver.hm_dbversion' doesn't exist (Additional info: select * from hm_dbversion)"
I am just able to go back to whatever database it was using before?
Post by mattg » 2020-05-22 08:43
LVTS wrote:
2020-05-22 07:59
Change your hmailserver.ini settings back to what it was...
Did you back that up?
LVTS
Post by LVTS » 2020-05-22 08:50
Sadly no I did not back this up. Only the data folder.
Post by mattg » 2020-05-24 03:23
Was the original install a default install?
LVTS
Post by LVTS » 2020-05-24 09:01
Yes it was just a default install.
Post by mattg » 2020-05-25 05:32
Using the same windows user, you could probably rename the hMailserver.ini that you have and then run the installer to create a new one
That should take you to the existing default database
Really not tested, so use at own risk
LVTS
Post by LVTS » 2020-05-28 13:08
Hi there - sorry for the late reply. I have been busy and haven't checked the forum in a couple of days. I actually give up with my current database - I created a new one so I could get my mail server running quickly as me and many others needed email access.
