problem and unknown cause
titanius81
Post by titanius81 » 2020-06-02 16:45
hello everyone, I state that I am new to the use of this software but I have discreet network knowledge. I installed the server on windows 10 normally following the guide and documentation that I found on your site. I set up the domain I own and I entered an email account with the associated domain. Also in advanced and TCP / IP I entered my local ip of my server for each port, imap, pop3 and smtp. I opened the ports of my router and I don't use firewalls in fact all the ports used are open regularly and nested for the local IP of the server.
It doesn't actually work and I don't understand the cause. I have created a new mx record for my domain but the server does not seem to communicate with the thunderbird client. I created a domain name that through a type A record points to my dynamic ip address of my internet provider.
in the log file I find the following lines:
"APPLICATION" 11872 "2020-06-02 16:23:03.724" "Starting servers..."
"DEBUG" 2308 "2020-06-02 16:23:03.724" "IOService::Start()"
"DEBUG" 11952 "2020-06-02 16:23:03.724" "Running worker in work queue SMTP delivery queue"
"DEBUG" 11872 "2020-06-02 16:23:03.724" "Started work queue SMTP delivery queue"
"DEBUG" 10276 "2020-06-02 16:23:03.724" "SMTPDeliveryManager::Start()"
"DEBUG" 2308 "2020-06-02 16:23:03.724" "Creating session 36"
"DEBUG" 11872 "2020-06-02 16:23:03.724" "Adding task ExternalFetchManager to work queue Server queue"
"DEBUG" 2308 "2020-06-02 16:23:03.739" "Creating work queue IOCPQueue"
"DEBUG" 1372 "2020-06-02 16:23:03.739" "Executing task ExternalFetchManager in work queue Server queue"
"DEBUG" 2308 "2020-06-02 16:23:03.739" "Starting work queue IOCPQueue"
"DEBUG" 1372 "2020-06-02 16:23:03.739" "ExternalFetchManager::Start()"
"APPLICATION" 11872 "2020-06-02 16:23:03.739" "Servers started."
"DEBUG" 9364 "2020-06-02 16:23:03.739" "Running worker in work queue IOCPQueue"
"DEBUG" 6412 "2020-06-02 16:23:03.739" "Running worker in work queue IOCPQueue"
"DEBUG" 10576 "2020-06-02 16:23:03.739" "Running worker in work queue IOCPQueue"
"DEBUG" 10332 "2020-06-02 16:23:03.739" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 2308 "2020-06-02 16:23:03.739" "Adding task IOCPQueueWorkerTask to work queue IOCPQueue"
"DEBUG" 9856 "2020-06-02 16:23:03.739" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
"DEBUG" 2272 "2020-06-02 16:23:03.739" "Executing task IOCPQueueWorkerTask in work queue IOCPQueue"
I always want to learn
Re: problem and unknown cause
Post by RvdH » 2020-06-02 17:30
:shock:
Why not first try with the defaults? Really can't understand people sometimes, why on earth you would change default (working!) settings and start off with changing TCP/IP settings :?:
Where in the documentation did you read that changing the TCP/IP settings was required?
Ah, wait....you probably didn't even read the documentation.
I would suggest you do clean install/clean database/settings, and start with reading the documentation on basic configuration
Anyways, the above log snippet has nothing to do with "it" not working, that's just the server starting
titanius81
Post by titanius81 » 2020-06-03 12:31
i only read about installing it. The ip in tcp / ip have been changed only to try since with 0.0.0.0 by default I always have the problem.
I entered the log lines because I thought there was some clue that I am missing.
I will try to do a new installation and be careful of the documentation. I'll let you know the outcome
titanius81
Post by titanius81 » 2020-06-03 16:41
591/5000
I was able to start everything even by changing the TCP / IP entry as before. I was wrong to enter the server name both inbound and outbound on thunderbird. now everything is ok as shown by diagnostics:
The x character replaces the exact value for privacy reasons
Test: Collect server details
Database type: MSSQL Compact
Test: Test IPv6
Test: Test outbound port
SMTP relayer not in use. Attempting xxx.xxx.com...
Trying to connect to host xxx.xxx.com...
Trying to connect to TCP/IP address 82.57.xxx.xxx on port 25.
Received: 220 xxx.xxx.com ESMTP.
Connected successfully.
Test: Test backup directory
Backup directory C:\Program Files (x86)\hMailServer\Backup is writable.
Test: Test MX records
Trying to resolve MX records for xxx.xxx.com...
Host name found: xxx.xxx.com...
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain xxx.xxx.com...
Trying to connect to TCP/IP address 62.211.xxx.xxx on port 25.
Received: 220 mik.ns01.biz ESMTP.
Now of course I get the emails but I can't send them. If I run the command telnet mail.hmailserver.com 25 obviously it does not connect. I also tried with SMTP Relayer of my email address and it seems to be configured correctly, however using thunderbird I can't send email
Post by RvdH » 2020-06-03 17:28
titanius81 wrote:
2020-06-03 16:41
You can't connect to telnet mail.hmailserver.com 25?
Maybe you're outbound port is blocked by ISP? In that case use the outgoing mail relay from your ISP
https://mxtoolbox.com/SuperTool.aspx?ac ... n=toolpage
domain that end in *.biz....mmm, not even sure i which to help you any further, those domains and your intentions are/look :evil:
titanius81
Post by titanius81 » 2020-06-03 18:51
I created a second level domain name for free to try your server, if everything goes well I will buy a classic domain. How can I find the data to configure my provider's outgoing mail? :twisted: :twisted:
Post by RvdH » 2020-06-03 19:03
titanius81 wrote:
2020-06-03 18:51
Are you sure port 25 is blocked? Is it open in firewall? Looks unlikely to have outbound closed but inbound open as you can see in the mxlookup tool above
titanius81
Post by titanius81 » 2020-06-03 19:23
yes I'm sure because I don't have a firewall, the windows one is disabled and then I use other services like ftp, sftp, vnc I know how to open the ports in the router. port 25 if I do an online test it is open to me, on the other hand in the diagnosis port 25 is ok
any solutions?
Post by palinka » 2020-06-03 19:24
2020-06-03 19:03
That's common here. My residential service has outbound closed and inbound open.
Edit - forgot he's in Italy. Same may still apply.
titanius81
Post by titanius81 » 2020-06-03 19:35
if I run the telnet command mail.hmailserver.com 25 I can't connect, but if I run telnet out.alice.it 587 I can connect without problems. why?
out.alice.it is the domain name of a service I subscribe to (not as an internet provider but only as an email)
Also can't I make use of other ports to be able to use the output channel?
Post by RvdH » 2020-06-03 19:59
Relay through smtp.telecomitalia.it?
You might need your ISP account details to login...dont know how and what telecomitalia.it needs/requires, ask your ISP.
titanius81
Post by titanius81 » 2020-06-03 20:32
usually when you sign up for an internet subscription, they also give you an email. I could have used that mail for my outgoing smtp server. In my case I have not received an email associated with my internet subscription and therefore I don't know what to insert in the smtp field. i am trying to contact their customer service but i can't cause covid 19
Post by RvdH » 2020-06-03 22:21
titanius81 wrote:
2020-06-03 19:35
This is exactly your problem, outbound port 25 is blocked, so you can send out on 587 (out.alice.it) but not on 25, which is required to SMTP to SMTP conversations, eg: operating a mailserver
Did you even try smtp.telecomitalia.it as relay, or find another smarthost address for that ISP? Or does it need uname/pass?
Post by jimimaseye » 2020-06-03 23:21
If he is in Italy then port v25 IS LIKELY BLOCKED inbound. I know. Had it myself.
Also this proves nothing:
Run the test again and do not change the domain or blank anything. (Who don't know you haven't connected to yourself with incorrect setup of dns).
Also run this and post the results: https://www.hmailserver.com/forum/viewt ... 20&t=30914
titanius81
Post by titanius81 » 2020-06-03 23:32
I tried to insert mail.smartmailtim.it, port 587, TLS and in fact it is resolved as a name in the hmailserver. In thudnerbird when I send mail it is marked as sent regularly, only that nothing arrives to the recipient. With smtp.telecomitalia.it the domain name is not resolved giving me an error.
ok i will try this other diagnostic method. But I just want to remember that when I enter various names of various suppliers for outgoing mail, I see that the IP marked as diagnostics is associated with the server which I entered in the smtp relay field
Post by jimimaseye » 2020-06-04 00:21
titanius81 wrote:
2020-06-03 23:32
Irrelevant and pointless.
Your signature says "i always want to learn". So please just do as you are advised and await further guidance from the experts. And then you will learn.
titanius81 wrote:
2020-06-03 23:32
Run the test again and do not change the domain or blank anything. (We don't know you haven't connected to yourself with incorrect setup of dns).
Don't do other domains - we are not interested. Don't change ports - we are not interested. Just do what is asked.
titanius81
Post by titanius81 » 2020-06-04 10:17
if I follow this advice
that is to leave the smtp realyer field empty I get error sending the email, I can only receive and return at the start point. From to the incoming email i get this message "Message undeliverable"
Post by RvdH » 2020-06-04 10:18
2020-06-03 23:21
titanius81
Post by titanius81 » 2020-06-04 10:46
Here, the report
2020-06-04   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - mix.nsxx.bix                   Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
GLOBAL RULES
IP RANGES
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: False
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2020-06-04.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2020-06-04.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Generated by HMSSettingsDiagnostics v2.01, Hmailserver Forum.
Post by jimimaseye » 2020-06-04 11:04
titanius81 wrote:
2020-06-04 10:17
Why don't you do as asked??! No one asked you to try sending emails again! You were asked to run the diagnostic and post the results. You are making this WAY more complicated and tortuous than it needs to be. We all know the problem and solution but need YOU to do what is asked to confirm.
Last chance... then I'm done.
titanius81
Post by titanius81 » 2020-06-04 11:07
Ok i wrote the report as asked me
Post by jimimaseye » 2020-06-04 12:25
titanius81 wrote:
2020-06-04 11:07
Where?
2020-06-03 23:21
Post by RvdH » 2020-06-04 14:07
2020-06-04 12:25
titanius81 wrote:
2020-06-04 11:07
Where?
2020-06-03 23:21
@jimimaseye
82.57.xxx.xxx looks like a different server, 62.211.xxx.xxx seems to be his IP (mik.ns01.biz)
titanius81
Post by titanius81 » 2020-06-04 16:59
I can't understand why I don't like it on port 25 anymore, it is smtp.tim.it the one used by my provider, it seems to go only on port 587.
Test: IPv6 test
SMTP relayer is in use.
Trying to connect to host smtp.tim.it ...
Trying to connect to TCP / IP address 82.57.200.135 on port 587.
Received: 220 smtp214t.alice.it ESMTP Service ready.
Backup directory C: \ Program Files (x86) \ hMailServer \ Backup is writable.
Trying to resolve MX records for mik.ns01.biz ...
Host name found: mik.ns01.biz
Connecting to TCP / IP address in MX records for local domain domain mik.ns01.biz ...
Trying to connect to host mik.ns01.biz ...
Trying to connect to TCP / IP address 62.211.102.33 on port 25.
while with port 25 this error:
Test: IPv6 test
Trying to connect to TCP / IP address 82.57.200.135 on port 25.
I spoke with the customer service of my internet telecom provider in Italy and they told me that it is not going because they only use port 587 with authentication and no encryption
Is it possible that I have to use port 25 to send emails?
Post by jimimaseye » 2020-06-04 21:19
titanius81 wrote:
2020-06-04 16:59
No.
We all knew it, but needed you to do the correct tests to prove it. (Took a while).
You cant go picking and choosing random ISP-supplied relays because they will require authentication or one of their connections; unless you are their customer, you will NOT have authentication.
Use the relay provided by your ISP with whatever port they tell you to. Dont use Tim, or Fastweb, or Libero or any other unless they are YOUR ISP.
The good news is that your inbound port 25 is not blocked.
telnet mik.ns01.biz 25
quit
221 goodbye
(assuming mik.ns01.biz is you and 62.211.102.33 is your correct ip address). If it is then I presume you are actually with Alice so use their relay as supplied by them.
johang
Post by johang » 2020-06-04 21:51
emailservers on internet talk via SMTP port 25 to each other
but since your port 25 outgoing traffic is blocked .. "you are not on the SMTPserver internet.."
unless you.. realise you should use your isp as relay OUT ( if they let you mail from your "own" domain out )
if your isp does not not let you mail out with your own domain you have to find someone on the internet that provides the services outgoing smtp ( propabally pay for it )
perhaps you get it
yes the picture sux
titanius81
Post by titanius81 » 2020-06-04 23:32
All these news that you have listed me, I know them all and I know that to solve I have to rely on paid SMTP servers. I would not want to do this because I regularly pay for a subscription and I would like to be able to use the mail server regularly. On the vps servers that I own through dovecot, postfix etc., I can send mail regularly. So I know very well that I can solve the problem through their relay and by doing various tests even though I know that smtp.tim.it is the same that they gave me (it is from my provider), so it took me time to give the various results and that you thought I didn't understand. Now since I need a user and password for authentication I can't configure correctly, because I think I should have a username and password associated with my phone line. The test I did with port 587 returns me ok 220 because even if I do not enter my username and password, hservermail always connects, the problem remains with the mail client that if I leave the mail I send as ok on port 587, the email I send back to me in the form of an undelivered message.
I hope I made myself understood, everything else is to be learned and maybe I can't understand what you mean to me
Post by jimimaseye » 2020-06-04 23:44
Nope. Niente.
I am lost.
I'm out.
johang
Post by johang » 2020-06-05 08:36
actually i had to sleep on if i wanted to write... but i have decided to take it humoursly ... 8) and you know... there might be others reading this forum and sometimes it is very good to answer very thoroughly so others understand as well :wink:
titanius81 wrote:
2020-06-04 23:32
yes .. ok .. :D lets not write anything you know then .. .. and you know it all ?? 8) :D
whay a pity you did not explain all this to us ... because we stupidly tried to help you based on what information you gave us... we should have understood that you already knew everything and that you already had a solution.. :wink: :wink:
.. but you knew that already ? :roll:
here it is getting tricky .. perhaps it is a language barrier .. "i think" and "i believe" is very different from "i understand" and "i know"
:shock: :shock: :shock:
earlier you have written you cant send mail .... in my world that means you get an SMTP ERROR saying you cant send and it does not go next hop.. into NEXT mailserver ..
Sooo.. the relay mailserver accepts your mail ( you wrote: i send as ok on port 587, problem solved.. why are we writing here ?? ) ????????????????
and sends an undelivered message back at you ????????, but then it NOT OK ( so inside that mail it tells you the problem )
oohhh maaan how can we tell if you know at this stage.. or if you are guessing, im a bit lost here ... should i write or not ... :? :?
no - yes - perhaps do you know ?
IF you get a "undelivered notice" of your sent emails from your ISP ... it is very likely that your provider knows why it is undelivered... i doubt .. no no :) let me refrase it .. i know 8) .. that testing ports will not solve that ...( you sort of past "the port" issue if they accept your mail )
Post by jimimaseye » 2020-06-05 08:58
johang wrote:
2020-06-05 08:36
Credit to you.
(Good luck. :lol: )
titanius81
Post by titanius81 » 2020-06-05 09:21
Ok I apologize to everyone if I have been very arrogant but I assure you that I am not. There will certainly be a language problem since I am Italian and I try to write in English as best I can.
Let's put it this way, I would not want to pay for additional services and I would like to be able to send mail from the server through your software. Now, if there is any test to do that you recommend, I will do it and post the results.
I'm glad my thread aroused so much interest, I didn't expect it
Post by jimimaseye » 2020-06-05 09:27
https://www.hmailserver.com/forum/viewt ... =7&t=21484
Prova la.
titanius81
Post by titanius81 » 2020-06-05 10:52
i wrote in that discussion in italian language. I hope that someone answer me
johang
Post by johang » 2020-06-05 14:38
titanius81 wrote:
2020-06-05 09:21
no no .. no tests ..
i took your italian question and put it through google translate .. i
Salve ragazzi, qualcuno che è riuscito a creare un server mail con hmailserver con linea di casa telecom? Perchè ho il problema della posta in uscita sulla porta 25 come da errore comando telnet mail.hmailserver.com 25.
your isp has blocked port 25 outgoing for your dsl line because of fear of spammers.. they most certanly provide you with a way to send mail out ( perhaps via SMTP on port 587, with/without authentication .. ) what else information is provided by your ISP regarding sending mail out through their relay server ?
Siccome adesso tutti richiedono un accesso oltre che usare il loro server come smtp e non avendo associato nessun account sul mio abbonamento non riesco a configurare correttamente il realy d'uscita.
is there no information on how your provider will let you mail through their mail relay server ?
Ho provato ad usare vari smtp con autenticazione, porta e crittografia giuste ma ovviamente vengo bloccato perchè per quei smtp usati non sono riconosciuto,
if you used the right credentials: smtpserver settings, authentication and port settings .. what does the SMTP log say ?
perchè credo che debba possedere mail con quel dominio.
sometimes the ISP does not accept if you mail with emailadress from you own domain, or have certain other rules that apply.. (perhaps you need to setup dns and mx and spf in certain ways .. ..)
Is the ISP ok with you.. realying your email, with your own emaildomain as from adress ?
those are questions you want to know answers to ..
titanius81
Post by titanius81 » 2020-06-05 19:07
ok for this
They have already provided me with this smtp.tim.it port 587 with authentication but the problem is that i do not have the authentication credentials.
Since my provider owns alice, virgilio, tin, tim (mobile) and telecom, on the web and on their pages there are all the parameters for those who have these emails as accounts but not those for subscribers of adsl or fiber
For the log are you referring to the hmailserver log or diagnostics? if I use smtp for example alice (being a subscriber with @ alice.it account) while inserting the credentials the diagnostic part says ok and thunderbird marks me the mail as sent only after a few minutes I get the unrecognizable message.
If I had to set the records in another way, I would have found some web page explaining how to do it and nothing instead. I contacted my supplier via pec and I will get an answer within 2 or 3 days I think. The operator on the phone gave me the same information that I already knew and that doesn't work.
here are all the answers
Post by jimimaseye » 2020-06-05 19:26
Ask them! They will advise you.
You might not need one and authentication is automatic by virtue that you are already in their line. (Quite common).
There are thousands of people simply setting their servers to point to their isp supplied SMTP server relay and asking their isp for the help (details) if needed. Why on earth are you finding this concept so difficult?
You haven't provided any smtp logs from hmailserver showing the problem either.
johang
Post by johang » 2020-06-05 20:06
titanius81 wrote:
2020-06-05 19:07
ok for this
I am reffering to the Hmailserver Log, set it ( at least ) to include TCP and SMTP
try to send a mail and show us coresponding lines from the log
thunderbird logs and behaviour i secondary .. you need to produce SMTP logs from your mailserver
titanius81
Post by titanius81 » 2020-06-05 23:34
I'm sure I'm going to make a bad impression, I'm sure that in the logs I make some configuration errors and I have not kept in mind the easiest way but I try to repair the mistake. Here are the details
All_Log&Screenshots.zip
(166.08 KiB) Downloaded 9 times
johang
Post by johang » 2020-06-06 09:09
"SMTPC" 10548 195 "2020-06-05 19:51:15.831" "82.57.200.132" "RECEIVED: 220 smtp202.alice.it ESMTP Service ready"
"SMTPC" 10548 195 "2020-06-05 19:51:15.841" "82.57.200.132" "SENT: EHLO mik.ns01.biz"
"SMTPC" 8612 195 "2020-06-05 19:51:15.891" "82.57.200.132" "RECEIVED: 250-smtp202.alice.it[nl]250-DSN[nl]250-8BITMIME[nl]250-PIPELINING[nl]250-HELP[nl]250-AUTH=LOGIN[nl]250-AUTH LOGIN CRAM-MD5 DIGEST-MD5 PLAIN[nl]250-DELIVERBY 300[nl]250 SIZE 31457280"
"SMTPC" 8612 195 "2020-06-05 19:51:15.891" "82.57.200.132" "SENT: AUTH LOGIN"
"SMTPC" 10548 195 "2020-06-05 19:51:15.932" "82.57.200.132" "RECEIVED: 334 VXNlcm5hbWU6"
"SMTPC" 10548 195 "2020-06-05 19:51:15.932" "82.57.200.132" "SENT: cGV0aXRvbWljaGVsZUBhbGljZS5pdA=="
"SMTPC" 3012 195 "2020-06-05 19:51:15.992" "82.57.200.132" "RECEIVED: 334 UGFzc3dvcmQ6"
"SMTPC" 3012 195 "2020-06-05 19:51:15.992" "82.57.200.132" "SENT: ***"
"SMTPC" 8612 195 "2020-06-05 19:51:16.041" "82.57.200.132" "RECEIVED: 235 LOGIN authentication successful"
"SMTPC" 8612 195 "2020-06-05 19:51:16.041" "82.57.200.132" "SENT: ***"
"SMTPC" 3012 195 "2020-06-05 19:51:16.252" "82.57.200.132" "RECEIVED: 553 MAIL FROM:<prova@mik.ns01.biz> does not match authenticated user name"
"SMTPC" 3012 195 "2020-06-05 19:51:16.252" "82.57.200.132" "SENT: QUIT"
"SMTPC" 3012 195 "2020-06-05 19:51:16.301" "82.57.200.132" "RECEIVED: 221 smtp202.alice.it QUIT"
the e-mailserver smtp202.alice.it says that your email "from address" must match with the emauil address you authenticated with ...
Post by jimimaseye » 2020-06-06 10:17
johang wrote:
2020-06-06 09:09
There you go. Simple (and not unknown) . Something that should have been able to determine from the ISP support desk/ pages or posting the logs at the beginning within 3 posts.
Seemingly you can only authenticate with isp supplied email addresses and you can only send mail FROM those addresses through their relay.
You will need routes and rules:
Route 1:
Authenticate user: luca@tim.it
Route 2:
Authenticate user: marco@tim.it
Ecc.
Then set rules:
If fromaddress contains 'luca@tim'
send using route
"Luca"
If fromaddress contains 'marco@tim'
send using route
"Marco"
ecc.
titanius81
Post by titanius81 » 2020-06-06 11:13
I don't know the software well. Could you tell me how to insert the right paths and rules if you wanted to use my email for example xxx@alice.it?
titanius81
Post by titanius81 » 2020-06-06 13:11
What is means this? the account prova@mik.ns01.biz is exactly
johang
Post by johang » 2020-06-06 13:34
titanius81 wrote:
2020-06-06 13:11
No
you are connecting to the emailserver: smtp202.alice.it and you are authenicating with the emailuser: petitomichele@alice.it
Post by jimimaseye » 2020-06-06 13:37
you authenticated to the relay with "petitomichele @ alice.it."
"petitomichele @ alice.it" is not "prova@mik.ns01.biz"
You want to run some sort of business domain and email out from your residence. You cant. There are restrictions in place that make it difficult to do so. If you want to runa business domain then you will need to start paying or looking for alternatives but your curent HOME DOMESTIC adsl is not going to let you. You need to sign (and probably pay for) a hosting or relay service OR pay to upgrade your adsl to a business class line.
titanius81
Post by titanius81 » 2020-06-06 14:25
like this dynu.com SMTP Outbound Relay service? But can i solve with route and rules or no?
johang
Post by johang » 2020-06-06 14:36
titanius81 wrote:
2020-06-06 14:25
in hmailserver configuration you add 1 relay route out ...
( use their Relay server with their provided user for authentication )
( just like you have configured relay with alice.it ... except that alice.it dont let you use your own domain )
Dynu.com let you use your own domain as "from" address
But you could set up your own SMTP relay service on a vps somewhere else if you know what you are doing ...
perhaps there is a free vps provider where you can install a SMTP relay server of you own... sell the service to other italian DSL users
titanius81
Post by titanius81 » 2020-06-06 14:48
do I have to delete the values from the smtp relay to use routes? How can I use my Alice account for routes?
In the 3 fields: General, addresses, delivery? what should I enter?
before selling I have to learn well what I'm doing, then i would solve in free way and the i take the idea for external services as dynu or vps
johang
Post by johang » 2020-06-06 15:11
My bad using language a bit flimsy
only use SMTP Relayer
it tells your mailserver to send everything out VIA the provider you configure there ..
( YES you delete whatever you have there right now )
ROUTE
you use if you have SPECIFIC deliveries out for specific mailrecipient that accepts specially .. ( you could use it specifically for YYYYY@alice.it/XXXX@alice.it/ YYY@tim.it and so on ) since they accepts you sending XXXXX@alice.it emails ...
check what jimimasey wrote in earlier answer above
titanius81
Post by titanius81 » 2020-06-06 16:07
yes i read, so do i have to pay for a service if i want to create my own server at home?
I modified this way, am I wrong?
johang
Post by johang » 2020-06-06 17:33
titanius81 wrote:
2020-06-06 16:07
YOU know this.......
you need an SMTP OUT RELAY service
for example duny.com has one ... it costs money to use it..
that is wrong
change Domain to alice.it
titanius81
Post by titanius81 » 2020-06-06 17:51
in summary, I changed the domain from mik.ns01.biz to alice.it and in general smtp I left the fields empty regarding the relay
here is the image of the modification
titanius81
Post by titanius81 » 2020-06-06 18:32
I changed the mail account to my domain leaving the suggested one as configuration. I only left smtp as a log then I did a test of sending mail and it gave me this result, but i don't receive tha mail
"SMTPD"	6544	516	"2020-06-06 18:27:59.563"	"79.27.60.125"	"SENT: 220 mik.ns01.biz ESMTP"
"SMTPD"	6544	516	"2020-06-06 18:27:59.563"	"79.27.60.125"	"RECEIVED: EHLO [192.168.178.2]"
"SMTPD"	6544	516	"2020-06-06 18:27:59.563"	"79.27.60.125"	"SENT: 250-mik.ns01.biz[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD"	6544	516	"2020-06-06 18:27:59.563"	"79.27.60.125"	"RECEIVED: AUTH LOGIN"
"SMTPD"	6544	516	"2020-06-06 18:27:59.563"	"79.27.60.125"	"SENT: 334 VXNlcm5hbWU6"
"SMTPD"	11776	516	"2020-06-06 18:27:59.563"	"79.27.60.125"	"RECEIVED: b2tAbWlrLm5zMDEuYml6"
"SMTPD"	11776	516	"2020-06-06 18:27:59.563"	"79.27.60.125"	"SENT: 334 UGFzc3dvcmQ6"
"SMTPD"	10364	516	"2020-06-06 18:27:59.579"	"79.27.60.125"	"RECEIVED: ***"
"SMTPD"	10364	516	"2020-06-06 18:27:59.579"	"79.27.60.125"	"SENT: 235 authenticated."
"SMTPD"	11776	516	"2020-06-06 18:27:59.579"	"79.27.60.125"	"RECEIVED: MAIL FROM:<ok@mik.ns01.biz> SIZE=1577"
"SMTPD"	11776	516	"2020-06-06 18:27:59.579"	"79.27.60.125"	"SENT: 250 OK"
"SMTPD"	6544	516	"2020-06-06 18:27:59.579"	"79.27.60.125"	"RECEIVED: RCPT TO:<petitomichele@alice.it>"
"SMTPD"	6544	516	"2020-06-06 18:27:59.579"	"79.27.60.125"	"SENT: 250 OK"
"SMTPD"	10364	516	"2020-06-06 18:27:59.594"	"79.27.60.125"	"RECEIVED: DATA"
"SMTPD"	10364	516	"2020-06-06 18:27:59.594"	"79.27.60.125"	"SENT: 354 OK, send."
"SMTPD"	8004	516	"2020-06-06 18:27:59.594"	"79.27.60.125"	"SENT: 250 Queued (0.000 seconds)"
"SMTPD"	10764	516	"2020-06-06 18:27:59.594"	"79.27.60.125"	"RECEIVED: QUIT"
"SMTPD"	10764	516	"2020-06-06 18:27:59.594"	"79.27.60.125"	"SENT: 221 goodbye"
johang
Post by johang » 2020-06-06 19:01
SMTPD
what comes into YOUR mailserver
SMTPC
what goes out from YOUR mailserver
you post from log SMTPD lines...
so .. you mailed from your local client into your local hmailserver ..
BUT it seems you still TRY to use your private domain as sender through alice.it ............ ( you know already alice.it will NOT accept this ? , so that will end up in delivery queue inside your hmailserver and you will get an undelivered notification after a while)
( you missed in your configuration that your "alice.it"-ROUTE still needs to authenticate )
ROUTE is used when you based on sending as an alice.it emailuser, send via a specific route
xxx@alice.it authenticate as xxx@alice.it route traffic .. ; yyy@alice.it authenticate as yyy@alice.it
already explained here: https://www.hmailserver.com/forum/viewt ... 15#p221219
titanius81
Post by titanius81 » 2020-06-06 21:01
I see 2 items for authentication:
1) it is located in SMTP -> delivery of e-mail
2) it is located in SMTP -> routes -> alice.it -> delivery
Now i only configured number 2 and left number 1 blank as you said.
johang
Post by johang » 2020-06-07 22:42
perhaps you could use the "transactional package":
https://reachmail.com/pricing/easysmtp
if you sign up "today" you get 10.000 bonus credits for free
and then the cost 5$ for 10.000 email credits .. and its valid for 2 years
not a bad deal ....
titanius81
Post by titanius81 » 2020-06-08 00:13
I managed to send the emails through and fortunately with sendinblue with a free account and 300 emails per day 8) 8) 8) . Now I have to learn the other interesting things about software like spam and ssl certificates etc. etc. Obviously I'm waiting for response from my internet provider. Thanks for the invitation to the site you linked to me but as you know I was looking for a totally free way and that my provider would provide me with the right credentials
johang
Post by johang » 2020-06-08 00:29
lets hope for the best
titanius81
Post by titanius81 » 2020-06-09 13:32
I think it can be said solved since I understand the configurations to do :)
